CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_crtc_state_has_vrr_enabled
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: drm_device_has_pdev
CONFTEST: drm_crtc_state_has_no_vblank
CONFTEST: drm_mode_config_has_allow_fb_modifiers
CONFTEST: drm_has_hdr_output_metadata
CONFTEST: dma_resv_add_fence
CONFTEST: dma_resv_reserve_fences
CONFTEST: reservation_object_reserve_shared_has_num_fences_arg
CONFTEST: drm_connector_has_override_edid
CONFTEST: drm_master_has_leases
CONFTEST: drm_file_get_master
CONFTEST: drm_modeset_lock_all_end
CONFTEST: drm_connector_lookup
CONFTEST: drm_connector_put
CONFTEST: drm_driver_has_dumb_destroy
CONFTEST: fence_ops_use_64bit_seqno
CONFTEST: drm_aperture_remove_conflicting_pci_framebuffers_has_driver_arg
CONFTEST: drm_mode_create_dp_colorspace_property_has_supported_colorspaces_arg
CONFTEST: drm_unlocked_ioctl_flag_present
CONFTEST: drm_output_poll_changed
CONFTEST: file_operations_fop_unsigned_offset_present
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: vfio_pci_core_available
CONFTEST: mdev_available
CONFTEST: cmd_uphy_display_port_init
CONFTEST: cmd_uphy_display_port_off
CONFTEST: memory_failure_mf_sw_simulated_defined
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: is_export_symbol_present_drm_gem_prime_fd_to_handle
CONFTEST: is_export_symbol_present_drm_gem_prime_handle_to_fd
CONFTEST: ib_peer_memory_symbols
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-pci.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-dmabuf.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-nano-timer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-caps.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-caps-imex.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_aead.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_ecc.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_hkdf.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_rand.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_shash.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_rsa.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_aead_aes_gcm.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_sha.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_hmac_sha.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_internal_crypt_lib.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_hkdf_sha.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_ec.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_x509.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_rsa_ext.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nvlink_caps.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/procfs_nvswitch.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/i2c_nvswitch.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ats_sva.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_conf_computing.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_sec2_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_maxwell_sec2.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_hopper_sec2.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_tools.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_global.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_gpu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_gpu_isr.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_procfs.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_va_space.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_va_space_mm.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_gpu_semaphore.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_mem.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_rm_mem.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_channel.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_lock.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_hal.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_processors.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_range_tree.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_rb_tree.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_range_allocator.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_va_range.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_va_policy.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_va_block.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_range_group.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_gpu_replayable_faults.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_gpu_access_counters.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_events.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_module.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_mmu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pte_batch.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_tlb_batch.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_push.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pushbuffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_thread_context.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_tracker.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_maxwell.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_maxwell_host.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_maxwell_ce.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_maxwell_mmu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_maxwell_fault_buffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_maxwell_access_counter_buffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pascal.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pascal_ce.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pascal_host.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pascal_mmu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_volta_ce.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_volta_host.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_volta_mmu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_volta.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_turing.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_turing_access_counter_buffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_turing_fault_buffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_turing_mmu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_turing_host.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ampere.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ampere_ce.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ampere_host.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ampere_mmu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_hopper.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_hopper_fault_buffer.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_hopper_ce.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_hopper_host.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_hopper_mmu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ada.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_policy.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_utils.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_kvmalloc.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pmm_sysmem.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pmm_gpu.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_migrate.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_populate_pageable.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_migrate_pageable.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_map_external.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_user_channel.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_hmm.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_heuristics.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_thrashing.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_prefetch.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ats.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ats_ibm.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ats_faults.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_test_rng.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_range_tree_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_range_allocator_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_mem_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_rm_mem_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_page_tree_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_tracker_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_push_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_channel_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_ce_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_host_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_lock_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_utils_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_kvmalloc_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pmm_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_events_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_perf_module_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_va_block_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_range_group_tree_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_thread_context_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm/uvm_rb_tree_test.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-crtc.o
/tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-drv.c: In function ‘nv_drm_register_drm_device’:
/tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-drv.c:1817:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
1817 | bool bus_is_pci =
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-fence.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nv-kthread-q.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-gem-dma-buf.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-format.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-os-interface.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-peermem/nvidia-peermem.o
LD [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia.o
LD [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-modeset.o
ld -r -o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-interface.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-pci.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-dmabuf.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-nano-timer.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-acpi.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-cray.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-dma.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-i2c.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-mmap.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-p2p.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-pat.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-procfs.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-usermap.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-vm.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-vtophys.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-interface.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-mlock.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-pci.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-registry.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/os-usermap.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-pci-table.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-kthread-q.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-memdbg.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-report-err.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-rsync.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-msi.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-caps.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv-caps-imex.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_aead.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_ecc.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_hkdf.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_rand.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_shash.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_rsa.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_aead_aes_gcm.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_sha.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_hmac_sha.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_internal_crypt_lib.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_hkdf_sha.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_ec.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_x509.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/libspdm_rsa_ext.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nvlink_linux.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/nvlink_caps.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/linux_nvswitch.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/procfs_nvswitch.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia/i2c_nvswitch.o
ld -r -o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-drm.o
LD [M] /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/nvidia-peermem.o
MODPOST /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/Module.symvers
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘lockdep_rcu_suspicious’
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘mutex_lock_interruptible_nested’
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘mutex_lock_nested’
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘lockdep_init_map_type’
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘debug_lockdep_rcu_enabled’
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘rcu_read_lock_held’
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘mutex_destroy’
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol ‘lock_is_held_type’
ERROR: modpost: GPL-incompatible module nvidia-modeset.ko uses GPL-only symbol ‘lockdep_init_map_type’
ERROR: modpost: GPL-incompatible module nvidia-modeset.ko uses GPL-only symbol ‘debug_check_no_locks_held’
ERROR: modpost: GPL-incompatible module nvidia-drm.ko uses GPL-only symbol ‘mutex_lock_nested’
ERROR: modpost: GPL-incompatible module nvidia-drm.ko uses GPL-only symbol ‘lockdep_init_map_type’
ERROR: modpost: GPL-incompatible module nvidia-drm.ko uses GPL-only symbol ‘ww_mutex_lock’
make[2]: *** [scripts/Makefile.modpost:126: /tmp/selfgz76367/NVIDIA-Linux-x86_64-550.144.03/kernel/Module.symvers] Error 1
make[2]: Target ‘__modpost’ not remade because of errors.
make[1]: *** [Makefile:1989: modpost] Error 2
make[1]: Target ‘modules’ not remade because of errors.
make[1]: Leaving directory ‘/kernel’
make: *** [Makefile:115: modules] Error 2
→ Failed to estimate output lines: /bin/sh: .: line 0: can’t open ‘/lib/modules/6.1.27/build/.config’: No such file or directory
conftests:162 objects:50 modules:1
→ Checking to see whether the nvidia kernel module was successfully built
executing: ‘cd kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/kernel” SYSOUT=“/kernel” NV_KERNEL_MODULES=“nvidia”’…
make[1]: Entering directory ‘/kernel’
→ Error.
ERROR: An error occurred while performing the step: “Checking to see whether the nvidia kernel module was successfully built”. See /var/log/nvidia-installer.log for details.
→ The command cd kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/kernel" SYSOUT="/kernel" NV_KERNEL_MODULES="nvidia" failed with the following output:
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
