For workaround, i use this:
Kernel side:
- Patch:
diff --git a/kernel/rcu/tree_plugin.h b/kernel/rcu/tree_plugin.h
index 340bbefe5f652..181965356d9cb 100644
--- a/kernel/rcu/tree_plugin.h
+++ b/kernel/rcu/tree_plugin.h
@@ -406,7 +406,7 @@ void __rcu_read_lock(void)
WRITE_ONCE(current->rcu_read_unlock_special.b.need_qs, true);
barrier(); /* critical section after entry code. */
-EXPORT_SYMBOL_GPL(__rcu_read_lock);
+EXPORT_SYMBOL(__rcu_read_lock);
* Preemptible RCU implementation for rcu_read_unlock().
@@ -431,7 +431,7 @@ void __rcu_read_unlock(void)
WARN_ON_ONCE(rrln < 0 || rrln > RCU_NEST_PMAX);
-EXPORT_SYMBOL_GPL(__rcu_read_unlock);
+EXPORT_SYMBOL(__rcu_read_unlock);
* Advance a ->blkd_tasks-list pointer to the next entry, instead
2.Patch:
diff --git a/mm/memory.c b/mm/memory.c
index d022c84c22080..d00f494c62f2f 100644
--- a/mm/memory.c
+++ b/mm/memory.c
@@ -6011,7 +6011,7 @@ int follow_pte(struct vm_area_struct *vma, unsigned long address,
out:
return -EINVAL;
-EXPORT_SYMBOL_GPL(follow_pte);
+EXPORT_SYMBOL(follow_pte);
#ifdef CONFIG_HAVE_IOREMAP_PROT
NVidia Driver side:
diff --git a/kernel/nvidia/os-mlock.c b/kernel/nvidia/os-mlock.c
index 46f99a1..b8f4100 100644
--- a/kernel/nvidia/os-mlock.c
+++ b/kernel/nvidia/os-mlock.c
@@ -30,11 +30,21 @@ static inline int nv_follow_pfn(struct vm_area_struct *vma,
unsigned long *pfn)
-#if defined(NV_UNSAFE_FOLLOW_PFN_PRESENT)
- return unsafe_follow_pfn(vma, address, pfn);
-#else
- return follow_pfn(vma, address, pfn);
-#endif
+ int status = 0;
+ spinlock_t *ptl;
+ pte_t *ptep;
+ if (!(vma->vm_flags & (VM_IO | VM_PFNMAP)))
+ return status;
+ status = follow_pte(vma, address, &ptep, &ptl);
+ if (status)
+ return status;
+ *pfn = pte_pfn(ptep_get(ptep));
+ // The lock is acquired inside follow_pte()
+ pte_unmap_unlock(ptep, ptl);
+ return 0;
And driver is started now:
sudo dmesg | grep -E "NV|vmlinuz"
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.10.0-rc1-x64zen4+ root=UUID=a7528a1d-9d96-4917-87e7-63a3c2870243 nouveau.modeset=0 clocksource=tsc tsc=reliable splash resume=/dev/disk/by-uuid/79c14cbd-bdd5-48d9-b6ab-30d060ac0cd7 mitigations=auto quiet security=apparmor nosimplefb=1
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ec253000-0x00000000ec54cfff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000000a200000-0x000000000a20efff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x00000000ec253000-0x00000000ec54cfff] ACPI NVS
[ 0.045954] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.10.0-rc1-x64zen4+ root=UUID=a7528a1d-9d96-4917-87e7-63a3c2870243 nouveau.modeset=0 clocksource=tsc tsc=reliable splash resume=/dev/disk/by-uuid/79c14cbd-bdd5-48d9-b6ab-30d060ac0cd7 mitigations=auto quiet security=apparmor nosimplefb=1
[ 0.046042] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.10.0-rc1-x64zen4+", will be passed to user space.
[ 0.288565] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20efff] (61440 bytes)
[ 0.288565] ACPI: PM: Registering ACPI NVS region [mem 0xec253000-0xec54cfff] (3121152 bytes)
[ 0.336886] ACPI: \_SB_.PCI0.GPP6.P0NV: New power resource
[ 1.738203] BOOT_IMAGE=/boot/vmlinuz-6.10.0-rc1-x64zen4+
[ 6.154214] nvidia: module license 'NVIDIA' taints kernel.
[ 6.351520] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.239.06 Sat Feb 3 06:03:07 UTC 2024
[ 6.463612] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.239.06 Sat Feb 3 06:03:51 UTC 2024
[ 6.736055] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input19
[ 6.736135] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input20
[ 6.736245] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input21
[ 6.736328] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input22
