If I try to compile the nvidia driver with the RPM or manually the installation failes.
First error on compile is a duplicate definition caused by
- arch_ftrace_set_direct_caller
located in
- include/linux/ftrace.h:static
- arch/x86/include/asm/ftrace.h
removing this (I just commented out the lines in include/linux/ftrace.h for testing) the compile runs into other issues
here is the log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri Jan 7 08:37:47 2022
installer version: 470.94
PATH: /sbin:/usr/sbin:/usr/local/sbin:/root/bin:/usr/local/bin:/usr/bin:/bin:/usr/games:/usr/lib/mit/bin:/usr/lib/mit/sbin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
-> Detected 16 CPUs online; setting concurrency level to 16.
-> Installing NVIDIA driver version 470.94.
-> Running distribution scripts
executing: '/usr/lib/nvidia/pre-install'...
-> done.
-> The distribution-provided pre-install script completed successfully. If this is the first time you have run the installer, this script may have helped disable Nouveau, but a reboot may be required first. Would you like to continue, or would you prefer to abort installation to reboot the system? (Answer: Continue installation)
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Performing CC check.
-> Kernel source path: '/lib/modules/5.3.18-59.10.1-default/source'
-> Kernel output path: '/lib/modules/5.3.18-59.10.1-default/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /usr/bin/make -k -j16 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/5.3.18-59.10.1-default/source" SYSOUT="/lib/modules/5.3.18-59.10.1-default/build"'...
rm -f -r conftest
make[1]: Entering directory '/data/usr/src/linux-5.3.18-59.10'
make[2]: Entering directory '/data/usr/src/linux-5.3.18-59.10.1-obj/x86_64/default'
CLEAN /tmp/NVIDIA-Linux-x86_64-470.94/kernel
CLEAN /tmp/NVIDIA-Linux-x86_64-470.94/kernel/Module.symvers
make[2]: Leaving directory '/data/usr/src/linux-5.3.18-59.10.1-obj/x86_64/default'
make[1]: Leaving directory '/data/usr/src/linux-5.3.18-59.10'
-> Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j16 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/5.3.18-59.10.1-default/source" SYSOUT="/lib/modules/5.3.18-59.10.1-default/build"'...
SYMLINK /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: get_backlight_device_by_name
CONFTEST: backlight_device_register
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: hlist_for_each_entry
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: pgprot_decrypted
CONFTEST: vga_tryget
CONFTEST: iterate_fd
CONFTEST: seq_read_iter
CONFTEST: sg_page_iter_page
CONFTEST: unsafe_follow_pfn
CONFTEST: drm_gem_object_get
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: set_close_on_exec
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: acpi_fadt_low_power_s0
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_device_list
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: drm_device_has_pdev
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: ib_peer_memory_symbols
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pci.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-acpi.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-cray.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-dma.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-i2c.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-mmap.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-p2p.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pat.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-procfs.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-procfs-utils.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-usermap.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-vm.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-interface.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-mlock.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-pci.o
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-dma.c:963:0: warning: "IMPORT_SGT_STUBS_NEEDED" redefined
#define IMPORT_SGT_STUBS_NEEDED 0
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-dma.c:957:0: note: this is the location of the previous definition
#define IMPORT_SGT_STUBS_NEEDED 1
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-registry.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-usermap.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-report-err.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-rsync.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-msi.o
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-procfs.o: warning: objtool: nv_procfs_init() falls through to next function nv_procfs_exit()
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-caps.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-frontend.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nvlink_caps.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/procfs_nvswitch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/i2c_nvswitch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_tools.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_global.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_gpu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_gpu_isr.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_procfs.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_va_space.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_va_space_mm.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_gpu_semaphore.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_mem.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_rm_mem.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_channel.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_lock.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_hal.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_range_tree.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_rb_tree.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_range_allocator.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_va_range.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_va_block.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_range_group.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_gpu_replayable_faults.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_gpu_access_counters.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_events.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_module.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pte_batch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_tlb_batch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_push.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pushbuffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_thread_context.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_tracker.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_kepler.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_kepler_ce.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_kepler_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_kepler_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_kepler_fault_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_kepler_access_counter_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_maxwell.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_maxwell_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pascal.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pascal_ce.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pascal_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pascal_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_volta_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_volta_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_volta.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_turing.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_turing_access_counter_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_turing_fault_buffer.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_turing_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_turing_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_ampere.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_ampere_ce.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_ampere_host.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_ampere_mmu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_policy.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_utils.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_kvmalloc.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pmm_sysmem.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pmm_gpu.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_populate_pageable.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_map_external.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_user_channel.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_hmm.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_heuristics.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_thrashing.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_prefetch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_ats_ibm.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_ats_faults.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_test_rng.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_range_tree_test.o
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:675:15: error: variable ‘g_migrate_vma_ops’ has initializer but incomplete type
static struct migrate_vma_ops g_migrate_vma_ops =
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:677:6: error: ‘struct migrate_vma_ops’ has no member named ‘alloc_and_copy’
.alloc_and_copy = migrate_vma_alloc_and_copy,
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:677:23: warning: excess elements in struct initializer
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:677:23: note: (near initialization for ‘g_migrate_vma_ops’)
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:678:6: error: ‘struct migrate_vma_ops’ has no member named ‘finalize_and_map’
.finalize_and_map = migrate_vma_finalize_and_map,
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:678:25: warning: excess elements in struct initializer
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:678:25: note: (near initialization for ‘g_migrate_vma_ops’)
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c: In function ‘migrate_pageable_vma_migrate_mask’:
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:717:19: error: implicit declaration of function ‘migrate_vma’; did you mean ‘migrate_pfn’? [-Werror=implicit-function-declaration]
int ret = migrate_vma(&g_migrate_vma_ops,
migrate_pfn
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c: At top level:
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.c:675:31: error: storage size of ‘g_migrate_vma_ops’ isn’t known
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_range_allocator_test.o
cc1: some warnings being treated as errors
make[3]: *** [/data/usr/src/linux-5.3.18-59.10/scripts/Makefile.build:288: /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_migrate_pageable.o] Error 1
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_mem_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_rm_mem_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_page_tree_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_tracker_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_push_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_channel_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_ce_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_host_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_lock_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_utils_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_kvmalloc_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pmm_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_events_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_perf_module_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_mmu_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_va_block_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_range_group_tree_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_thread_context_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-uvm/uvm_rb_tree_test.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-crtc.c: In function ‘plane_req_config_update’:
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-crtc.c:89:9: warning: unused variable ‘ret’ [-Wunused-variable]
int ret = 0;
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-crtc.c: In function ‘nv_drm_plane_atomic_set_property’:
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-crtc.c:371:32: warning: unused variable ‘nv_drm_plane_state’ [-Wunused-variable]
struct nv_drm_plane_state *nv_drm_plane_state =
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-gem-dma-buf.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-format.o
LD [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.o
ld -r -o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pci.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-acpi.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-cray.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-dma.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-i2c.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-mmap.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-p2p.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pat.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-procfs.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-procfs-utils.o /tmp
/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-usermap.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-vm.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-vtophys.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-mlock.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-pci.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-registry.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-usermap.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-modeset-interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pci-table.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-kthread-q.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-memdbg.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-ibmnpu.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-report-err.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-rsync.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-msi.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-caps.o /tmp/NVIDIA-Linux-x86_64-47
0.94/kernel/nvidia/nv-frontend.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv_uvm_interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nvlink_linux.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nvlink_caps.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/linux_nvswitch.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/procfs_nvswitch.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/i2c_nvswitch.o
CC [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-peermem/nvidia-peermem.o
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-modeset.c: In function ‘__will_generate_flip_event’:
/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm/nvidia-drm-modeset.c:96:23: warning: unused variable ‘primary_plane’ [-Wunused-variable]
struct drm_plane *primary_plane = crtc->primary;
ld -r -o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-modeset.o
LD [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-drm.o
LD [M] /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia-peermem.o
make[3]: Target '__build' not remade because of errors.
make[2]: *** [/data/usr/src/linux-5.3.18-59.10/Makefile:1675: _module_/tmp/NVIDIA-Linux-x86_64-470.94/kernel] Error 2
make[2]: Target 'modules' not remade because of errors.
make[1]: *** [Makefile:179: sub-make] Error 2
make[1]: Target 'modules' not remade because of errors.
make: *** [Makefile:80: modules] Error 2
-> Error.
ERROR: An error occurred while performing the step: "Building kernel modules". See /var/log/nvidia-installer.log for details.
-> The command `cd ./kernel; /usr/bin/make -k -j16 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/5.3.18-59.10.1-default/source" SYSOUT="/lib/modules/5.3.18-59.10.1-default/build"` failed with the following output:
CONFTEST: pde_data
CONFTEST: write_cr4
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: proc_ops
migrate_pfn
int ret = 0;
ld -r -o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pci.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-acpi.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-cray.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-dma.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-i2c.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-mmap.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-p2p.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pat.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-procfs.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-procfs-utils.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-usermap.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-vm.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-vtophys.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-mlock.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-pci.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-registry.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/os-usermap.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-modeset-interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-pci-table.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-kthread-q.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-memdbg.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-ibmnpu.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-report-err.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-rsync.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-msi.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-caps.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv-frontend.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nv_uvm_interface.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nvlink_linux.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/nvlink_caps.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/linux_nvswitch.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/procfs_nvswitch.o /tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia/i2c_nvswitch.o
-> Checking to see whether the nvidia kernel module was successfully built
executing: 'cd ./kernel; /usr/bin/make -k -j16 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/5.3.18-59.10.1-default/source" SYSOUT="/lib/modules/5.3.18-59.10.1-default/build"'...
Building modules, stage 2.
MODPOST 1 modules
ERROR: "dma_map_sg_attrs" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
ERROR: "dma_unmap_sg_attrs" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
ERROR: "dma_map_resource" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
ERROR: "preempt_voluntary_key" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
ERROR: "dma_sync_single_for_cpu" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
ERROR: "dma_map_page_attrs" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
ERROR: "dma_unmap_resource" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
ERROR: "dma_sync_single_for_device" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
ERROR: "dma_unmap_page_attrs" [/tmp/NVIDIA-Linux-x86_64-470.94/kernel/nvidia.ko] undefined!
make[3]: *** [/data/usr/src/linux-5.3.18-59.10/scripts/Makefile.modpost:110: modules-modpost] Error 1
make[3]: Target '__modpost' not remade because of errors.
make[2]: *** [/data/usr/src/linux-5.3.18-59.10/Makefile:1679: modules] Error 2
-> Error.
ERROR: An error occurred while performing the step: "Checking to see whether the nvidia kernel module was successfully built". See /var/log/nvidia-installer.log for details.
-> The command `cd ./kernel; /usr/bin/make -k -j16 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/5.3.18-59.10.1-default/source" SYSOUT="/lib/modules/5.3.18-59.10.1-default/build"` failed with the following output:
MODPOST 1 modules
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
