Hello, the nvidia driver 375.39 does not install with kernel 4.2.0.
The log file as follows:
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Tue Apr 18 16:48:31 2017
installer version: 375.39
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 8 CPUs online; setting concurrency level to 8.
→ License accepted.
→ Installing NVIDIA driver version 375.39.
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.2.0-42-generic/build’
→ Kernel output path: ‘/lib/modules/4.2.0-42-generic/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j8 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.2.0-42-generic/build” SYSOUT=“/lib/modules/4.2.0-42-generic/build”’…
rm -f -r conftest
/usr/bin/make “CC=cc” KBUILD_VERBOSE= -C /lib/modules/4.2.0-42-generic/build M=/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.2.0-42-generic/build NV_KERNEL_OUTPUT=/lib/modules/4.2.0-42-generic/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory ‘/usr/src/linux-headers-4.2.0-42-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-4.2.0-42-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j8 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.2.0-42-generic/build” SYSOUT=“/lib/modules/4.2.0-42-generic/build”’…
/usr/bin/make “CC=cc” KBUILD_VERBOSE= -C /lib/modules/4.2.0-42-generic/build M=/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.2.0-42-generic/build NV_KERNEL_OUTPUT=/lib/modules/4.2.0-42-generic/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
Makefile:669: Cannot use CONFIG_CC_STACKPROTECTOR_STRONG: -fstack-protector-strong not supported by compiler
SYMLINK /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: set_memory_uc
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: console_lock
CONFTEST: acquire_console_sem
CONFTEST: on_each_cpu
CONFTEST: kmem_cache_create
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_parse_phandle
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: drm_gem_object_lookup
CONFTEST: get_user_pages_remote
CONFTEST: drm_atomic_state_free
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: task_struct
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: kernel_write
CONFTEST: strnstr
CONFTEST: iterate_dir
CONFTEST: kstrtoull
CONFTEST: mm_context_t
CONFTEST: vm_fault_has_address
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_functions_have_name_arg
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: nvidia_grid_build
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-instance.o
cc: error: unrecognized command line option ‘-fstack-protector-strong’
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-frontend.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-frontend.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-instance.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-instance.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-acpi.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-chrdev.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-acpi.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-acpi.o] Error 1
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-chrdev.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-chrdev.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-dma.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-cray.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-cray.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-gvi.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-dma.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-dma.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-i2c.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-gvi.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-gvi.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-mempool.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-i2c.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-i2c.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-mmap.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-mempool.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-mempool.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-p2p.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-mmap.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-mmap.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-pat.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-p2p.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-p2p.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-procfs.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-pat.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-pat.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-usermap.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-procfs.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-procfs.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-vm.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-usermap.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-usermap.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-vtophys.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-vm.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-vm.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-interface.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-vtophys.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-vtophys.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-mlock.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-interface.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-interface.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-pci.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-mlock.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-mlock.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-registry.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-pci.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-pci.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-usermap.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-registry.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-registry.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-modeset-interface.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-usermap.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/os-usermap.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-pci-table.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-modeset-interface.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-modeset-interface.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-kthread-q.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-pci-table.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-pci-table.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-kthread-q-selftest.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-kthread-q.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-kthread-q.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv_uvm_interface.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-kthread-q-selftest.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv-kthread-q-selftest.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/ebridge_linux.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv_uvm_interface.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nv_uvm_interface.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/ibmnpu_linux.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/ebridge_linux.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/ebridge_linux.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nvlink_linux.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/ibmnpu_linux.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/ibmnpu_linux.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nvlink_pci.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nvlink_linux.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nvlink_linux.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_utils.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nvlink_pci.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia/nvlink_pci.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_common.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_utils.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_utils.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_linux.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_common.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_common.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_linux.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_linux.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_stubs.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_kepler.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_stubs.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_stubs.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_maxwell.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_kepler.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_kepler.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_pascal.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_maxwell.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_maxwell.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nvstatus.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_pascal.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_page_migration_pascal.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nv-kthread-q.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nvstatus.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nvstatus.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nv-kthread-q-selftest.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nv-kthread-q.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nv-kthread-q.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_kernel_events.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nv-kthread-q-selftest.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/nv-kthread-q-selftest.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_kernel_counters.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_kernel_events.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_kernel_events.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_debug_session.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_kernel_counters.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_kernel_counters.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_debug_session.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_debug_session.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_full_fault_buffer.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_full_fault_buffer.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_full_fault_buffer.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/mmu_fmt.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/gmmu_fmt.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/mmu_fmt.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/mmu_fmt.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/gmmu_fmt.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/gmmu_fmt.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tools.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_global.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tools.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tools.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_global.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_global.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_procfs.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_space.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_procfs.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_procfs.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_space.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_space.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mem.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_semaphore.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_semaphore.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_rm_mem.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mem.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mem.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_channel.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_rm_mem.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_rm_mem.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_lock.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_channel.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_channel.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_hal.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_lock.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_lock.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_tree.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_hal.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_hal.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_allocator.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_tree.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_tree.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_range.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_allocator.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_allocator.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_block.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_range.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_range.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_group.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_block.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_block.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_page_fault.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_group.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_group.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_events.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_page_fault.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_page_fault.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_module.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_events.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_events.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mmu.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_module.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_module.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pte_batch.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mmu.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mmu.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tlb_batch.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pte_batch.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pte_batch.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_push.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tlb_batch.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tlb_batch.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pushbuffer.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_push.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_push.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_thread_context.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pushbuffer.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pushbuffer.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tracker.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_thread_context.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_thread_context.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tracker.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tracker.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_ce.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_host.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_ce.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_ce.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_mmu.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_host.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_host.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_maxwell.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_mmu.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kepler_mmu.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_maxwell_host.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_maxwell.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_maxwell.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_maxwell_host.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_maxwell_host.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_ce.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_host.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_ce.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_ce.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_mmu.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_host.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_host.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_mmu.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_mmu.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_policy.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_utils.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_policy.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_policy.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kvmalloc.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_utils.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_utils.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pmm_gpu.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kvmalloc.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kvmalloc.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_migrate.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pmm_gpu.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pmm_gpu.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_map_external.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_migrate.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_migrate.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_user_channel.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_map_external.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_map_external.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_hmm.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_user_channel.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_user_channel.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_heuristics.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_hmm.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_hmm.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_thrashing.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_heuristics.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_heuristics.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_prefetch.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_thrashing.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_thrashing.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_prefetch.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_prefetch.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_test_rng.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_tree_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_test_rng.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_test_rng.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_allocator_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_tree_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_tree_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_allocator_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_allocator_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mem_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_rm_mem_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mem_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mem_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_page_tree_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_rm_mem_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_rm_mem_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tracker_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_page_tree_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_page_tree_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_push_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tracker_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_tracker_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_channel_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_push_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_push_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_ce_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_channel_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_channel_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_lock_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_ce_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_ce_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_utils_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_lock_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_lock_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_utils_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_utils_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pmm_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kvmalloc_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_kvmalloc_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_events_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pmm_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_pmm_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_module_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_events_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_events_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_module_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_perf_module_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mmu_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mmu_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_mmu_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_block_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_block_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_va_block_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-modeset/nvidia-modeset-linux.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_group_tree_test.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-uvm/uvm8_range_group_tree_test.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-modeset/nvidia-modeset-linux.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-modeset/nvidia-modeset-linux.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-drv.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-utils.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-drv.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-drv.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-crtc.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-utils.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-utils.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-encoder.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-crtc.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-crtc.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-connector.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-encoder.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-encoder.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-gem.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-connector.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-connector.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-fb.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-gem.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-gem.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-modeset.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-fb.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-fb.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-mmap.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-modeset.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-modeset.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-fence.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-mmap.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-mmap.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-linux.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-fence.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-fence.o] Error 1
CC [M] /tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nv-pci-table.o
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-linux.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nvidia-drm-linux.o] Error 1
scripts/Makefile.build:258: recipe for target ‘/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nv-pci-table.o’ failed
make[2]: *** [/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel/nvidia-drm/nv-pci-table.o] Error 1
make[2]: Target ‘__build’ not remade because of errors.
Makefile:1399: recipe for target ‘module/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/kernel’ failed
make[1]: *** [module/tmp/selfgz11799/NVIDIA-Linux-x86_64-375.39/ke
