Can't build 375.26 on Linux 4.9 (Fedora 25)
The 375.26 driver fails to compile for me on Linux 4.9 on Fedora 25. The kernel I’ve been using previously is 4.4.39 and 375.26 works fine with it but it fails on 4.9. Here is my /var/log/nvidia-installer.log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Wed Jan  4 17:35:44 2017
installer version: 375.26
PATH: /sbin:/bin:/usr/sbin:/usr/bin
nvidia-installer command line:
    ./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
-> Detected 8 CPUs online; setting concurrency level to 8.
-> Tagging shared libraries with chcon -t textrel_shlib_t.
-> License accepted.
-> Installing NVIDIA driver version 375.26.
-> There appears to already be a driver installed on your system (version: 375.26).  As part of installing this driver (version: 375.26), the existing driver will be uninstalled.  Are you sure you want to continue? (Answer: Continue installation)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes)
-> Will install GLVND GLX client libraries.
-> Will install GLVND EGL client libraries.
-> Skipping GLX non-GLVND file: "libGL.so.375.26"
-> Skipping GLX non-GLVND file: "libGL.so.1"
-> Skipping GLX non-GLVND file: "libGL.so"
-> Skipping EGL non-GLVND file: "libEGL.so.375.26"
-> Skipping EGL non-GLVND file: "libEGL.so"
-> Skipping EGL non-GLVND file: "libEGL.so.1"
-> Skipping GLX non-GLVND file: "./32/libGL.so.375.26"
-> Skipping EGL non-GLVND file: "./32/libEGL.so.375.26"
-> Uninstalling the previous installation with /bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
   executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
   Checking for libglvnd installation.
   Checking libGLdispatch...
   Can't load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (375.26):
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glcore.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/extensions/libglx.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-tls.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/tls/libnvidia-tls.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLX_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libOpenGL.so.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv1_CM.so.1'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv2.so.2'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLdispatch.so.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLX.so.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGL.so.1.0.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libEGL.so.1'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/drivers/nvidia_drv.so'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/libnvidia-wfb.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk2.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk3.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-cfg.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ml.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/vdpau/libvdpau_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libcuda.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-opencl.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libOpenCL.so.1.0.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fatbinaryloader.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ptxjitcompiler.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvcuvid.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-encode.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ifr.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fbc.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-compiler.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-eglcore.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glsi.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libEGL_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv2_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv1_CM_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-egl-wayland.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libcuda.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fatbinaryloader.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ptxjitcompiler.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ml.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libOpenCL.so.1.0.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-compiler.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-opencl.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libOpenGL.so.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLdispatch.so.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv2.so.2'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv1_CM.so.1'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGL.so.1.0.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLX_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLX.so.0'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glcore.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-tls.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/tls/libnvidia-tls.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/vdpau/libvdpau_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvcuvid.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-encode.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-eglcore.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glsi.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libEGL.so.1'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libEGL_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv2_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv1_CM_nvidia.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ifr.so.375.26'...
   executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fbc.so.375.26'...
   executing: '/sbin/ldconfig'...
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
ERROR: Failed to run `/sbin/dkms build -m nvidia -v 375.26 -k 4.9.0-1-devhen`:
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area...
'make' -j8 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=4.9.0-1-devhen modules....(bad exit status: 2)
Error! Bad return status for module build on kernel: 4.9.0-1-devhen (x86_64)
Consult /var/lib/dkms/nvidia/375.26/build/make.log for more information.
-> error.
ERROR: Failed to install the kernel module through DKMS. No kernel module was installed; please try installing again without DKMS, or check the DKMS logs for more information.
ERROR: Installation has failed.  Please see the file '/var/log/nvidia-installer.log' for details.  You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
And the dkms build log:
DKMS make.log for nvidia-375.26 for kernel 4.9.0-1-devhen (x86_64)
Wed Jan  4 17:35:59 MST 2017
make "CC=cc" KBUILD_OUTPUT=/lib/modules/4.9.0-1-devhen/build KBUILD_VERBOSE= -C /lib/modules/4.9.0-1-devhen/source M=/var/lib/dkms/nvidia/375.26/build ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.9.0-1-devhen/source NV_KERNEL_OUTPUT=/lib/modules/4.9.0-1-devhen/build NV_KERNEL_MODULES="nvidia nvidia-uvm nvidia-modeset nvidia-drm" INSTALL_MOD_DIR=kernel/drivers/video modules
make[1]: Entering directory '/usr/src/kernels/4.9.0-1-devhen'
make[2]: Entering directory '/usr/src/kernels/4.9.0-1-devhen'
  SYMLINK /var/lib/dkms/nvidia/375.26/build/nvidia/nv-kernel.o
  SYMLINK /var/lib/dkms/nvidia/375.26/build/nvidia-modeset/nv-modeset-kernel.o
 CONFTEST: INIT_WORK
 CONFTEST: follow_pfn
 CONFTEST: vmap
 CONFTEST: remap_pfn_range
 CONFTEST: set_pages_uc
 CONFTEST: set_memory_uc
 CONFTEST: set_memory_array_uc
 CONFTEST: change_page_attr
 CONFTEST: pci_get_class
 CONFTEST: pci_choose_state
 CONFTEST: vm_insert_page
 CONFTEST: acpi_device_id
 CONFTEST: acquire_console_sem
 CONFTEST: console_lock
 CONFTEST: kmem_cache_create
 CONFTEST: on_each_cpu
 CONFTEST: smp_call_function
 CONFTEST: acpi_evaluate_integer
 CONFTEST: ioremap_cache
 CONFTEST: ioremap_wc
 CONFTEST: acpi_walk_namespace
 CONFTEST: pci_domain_nr
 CONFTEST: pci_dma_mapping_error
 CONFTEST: sg_alloc_table
 CONFTEST: sg_init_table
 CONFTEST: pci_get_domain_bus_and_slot
 CONFTEST: get_num_physpages
 CONFTEST: proc_create_data
 CONFTEST: efi_enabled
 CONFTEST: pde_data
 CONFTEST: proc_remove
 CONFTEST: pm_vt_switch_required
 CONFTEST: drm_driver_has_set_busid
 CONFTEST: drm_driver_has_gem_prime_res_obj
 CONFTEST: xen_ioemu_inject_msi
 CONFTEST: phys_to_dma
 CONFTEST: get_dma_ops
 CONFTEST: write_cr4
 CONFTEST: of_parse_phandle
 CONFTEST: for_each_online_node
 CONFTEST: node_end_pfn
 CONFTEST: pci_stop_and_remove_bus_device
 CONFTEST: pci_bus_address
 CONFTEST: pci_remove_bus_device
 CONFTEST: request_threaded_irq
 CONFTEST: remap_page_range
 CONFTEST: address_space_init_once
 CONFTEST: kbasename
 CONFTEST: fatal_signal_pending
 CONFTEST: list_cut_position
 CONFTEST: vzalloc
 CONFTEST: wait_on_bit_lock_argument_count
 CONFTEST: bitmap_clear
 CONFTEST: usleep_range
 CONFTEST: radix_tree_empty
 CONFTEST: drm_dev_unref
 CONFTEST: drm_reinit_primary_mode_group
 CONFTEST: drm_atomic_set_mode_for_crtc
 CONFTEST: drm_atomic_clean_old_fb
 CONFTEST: get_user_pages_remote
 CONFTEST: drm_gem_object_lookup
 CONFTEST: i2c_adapter
 CONFTEST: pm_message_t
 CONFTEST: irq_handler_t
 CONFTEST: acpi_device_ops
 CONFTEST: acpi_op_remove
 CONFTEST: outer_flush_all
 CONFTEST: proc_dir_entry
 CONFTEST: scatterlist
 CONFTEST: sg_table
 CONFTEST: file_operations
 CONFTEST: vm_operations_struct
 CONFTEST: atomic_long_type
 CONFTEST: pci_save_state
 CONFTEST: file_inode
 CONFTEST: task_struct
 CONFTEST: dma_ops
 CONFTEST: kuid_t
 CONFTEST: dma_map_ops
 CONFTEST: noncoherent_swiotlb_dma_ops
 CONFTEST: fault_flags
 CONFTEST: atomic64_type
 CONFTEST: backing_dev_info
 CONFTEST: kernel_write
 CONFTEST: strnstr
 CONFTEST: iterate_dir
 CONFTEST: kstrtoull
 CONFTEST: mm_context_t
 CONFTEST: drm_bus_present
 CONFTEST: drm_bus_has_bus_type
 CONFTEST: drm_bus_has_get_irq
 CONFTEST: drm_bus_has_get_name
 CONFTEST: drm_driver_has_legacy_dev_list
 CONFTEST: drm_crtc_state_has_connectors_changed
 CONFTEST: drm_init_functions_have_name_arg
 CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
 CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg
 CONFTEST: drm_master_drop_has_from_release_arg
 CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc
 CONFTEST: dom0_kernel_present
 CONFTEST: nvidia_vgpu_kvm_build
 CONFTEST: drm_available
 CONFTEST: nvidia_grid_build
 CONFTEST: drm_atomic_available
 CONFTEST: drm_atomic_modeset_nonblocking_commit_available
  LD [M]  /var/lib/dkms/nvidia/375.26/build/nvidia.o
ld -r -o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-interface.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-frontend.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-instance.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-acpi.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-chrdev.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-cray.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-dma.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-gvi.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-i2c.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-mempool.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-mmap.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-p2p.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-pat.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-procfs.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-usermap.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-vm.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-vtophys.o /var/lib/dkms/nvidia/375.26/build/nvidia/os-interface.o /var/lib/dkms/nvidia/375.26/build/nvidia/os-mlock.o /var/lib/dkms/nvidia/375.26/build/nvidia/os-pci.o /var/lib/dkms/nvidia/375.26/build/nvidia/os-registry.o /var/lib/dkms/nvidia/375.26/build/nvidia/os-usermap.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-modeset-interface.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-pci-table.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-kthread-q.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv-kthread-q-selftest.o /var/lib/dkms/nvidia/375.26/build/nvidia/nv_uvm_interface.o /var/lib/dkms/nvidia/375.26/build/nvidia/ebridge_linux.o /var/lib/dkms/nvidia/375.26/build/nvidia/ibmnpu_linux.o /var/lib/dkms/nvidia/375.26/build/nvidia/nvlink_linux.o /var/lib/dkms/nvidia/375.26/build/nvidia/nvlink_pci.o
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-frontend.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-instance.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-acpi.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-chrdev.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-cray.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-dma.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-gvi.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-i2c.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-mempool.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-mmap.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-p2p.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-pat.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-procfs.o: No such file or directoryld -r -o /var/lib/dkms/nvidia/375.26/build/nvidia-modeset/nv-modeset-interface.o /var/lib/dkms/nvidia/375.26/build/nvidia-modeset/nvidia-modeset-linux.o
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-usermap.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-vm.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-vtophys.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/os-interface.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/os-mlock.o: No such file or directory
  LD [M]  /var/lib/dkms/nvidia/375.26/build/nvidia-modeset.o
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/os-pci.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/os-registry.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/os-usermap.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-modeset-interface.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-pci-table.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-kthread-q.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv-kthread-q-selftest.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nv_uvm_interface.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/ebridge_linux.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/ibmnpu_linux.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nvlink_linux.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nvlink_pci.o: No such file or directory
  LD [M]  /var/lib/dkms/nvidia/375.26/build/nvidia-uvm.o
  LD [M]  /var/lib/dkms/nvidia/375.26/build/nvidia-drm.o
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-modeset/nvidia-modeset-linux.o: No such file or directory
/var/lib/dkms/nvidia/375.26/build/nvidia-modeset/nvidia-modeset.Kbuild:73: recipe for target '/var/lib/dkms/nvidia/375.26/build/nvidia-modeset/nv-modeset-interface.o' failed
make[3]: *** [/var/lib/dkms/nvidia/375.26/build/nvidia-modeset/nv-modeset-interface.o] Error 1
make[3]: *** Waiting for unfinished jobs....
ldld: cannot find : cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-modeset/nvidia-modeset-linux.o/var/lib/dkms/nvidia/375.26/build/nvidia/nv-chrdev.o: : No such file or directoryNo such file or directory
ldld: cannot find : cannot find /var/lib/dkms/nvidia/375.26/build/nvidia/nvlink_pci.o/var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm.o: : No such file or directoryNo such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-drv.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-utils.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-crtc.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-encoder.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-connector.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-gem.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-fb.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-modeset.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-mmap.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-fence.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nvidia-drm-linux.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-drm/nv-pci-table.o: No such file or directory
/var/lib/dkms/nvidia/375.26/build/nvidia/nvidia.Kbuild:90: recipe for target '/var/lib/dkms/nvidia/375.26/build/nvidia/nv-interface.o' failed
make[3]: *** [/var/lib/dkms/nvidia/375.26/build/nvidia/nv-interface.o] Error 1
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_utils.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_common.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_linux.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_page_migration.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_page_migration_stubs.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_page_migration_kepler.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_page_migration_maxwell.o: No such file or directory/usr/src/kernels/4.9.0-1-devhen/scripts/Makefile.build:531: recipe for target '/var/lib/dkms/nvidia/375.26/build/nvidia-drm.o' failed
make[3]: *** [/var/lib/dkms/nvidia/375.26/build/nvidia-drm.o] Error 1
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_page_migration_pascal.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_channel_mgmt.o: No such file or directory
/usr/src/kernels/4.9.0-1-devhen/scripts/Makefile.build:531: recipe for target '/var/lib/dkms/nvidia/375.26/build/nvidia-modeset.o' failed
ldmake[3]: *** [/var/lib/dkms/nvidia/375.26/build/nvidia-modeset.o] Error 1
: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/nvstatus.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/nv-kthread-q.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/nv-kthread-q-selftest.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_common_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_channel_directed_tests.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_channel_basic_sanity_tests.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_kernel_events.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_kernel_counters.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_debug_session.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_gpu_ops_tests.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_lite.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_page_cache.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_lite_api.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_lite_prefetch.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_lite_region_tracking.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_mmu_mgmt_pascal.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_mmu_mgmt.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_mmu_mgmt_stubs.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_full_fault_buffer.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm_full_fault_buffer_pascal.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/mmu_fmt.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/gmmu_fmt.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_tools.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_global.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_gpu.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_procfs.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_va_space.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_gpu_semaphore.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_mem.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_rm_mem.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_channel.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_lock.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_hal.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_range_tree.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_range_allocator.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_va_range.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_va_block.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_range_group.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_gpu_page_fault.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_events.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_module.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_mmu.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pte_batch.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_tlb_batch.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_push.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pushbuffer.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_thread_context.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_tracker.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_kepler.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_kepler_ce.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_kepler_host.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_kepler_mmu.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_maxwell.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_maxwell_host.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pascal.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pascal_ce.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pascal_host.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pascal_mmu.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pascal_fault_buffer.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_policy.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_utils.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_kvmalloc.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pmm_gpu.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_migrate.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_map_external.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_user_channel.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_hmm.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_heuristics.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_thrashing.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_prefetch.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_test_rng.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_range_tree_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_range_allocator_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_gpu_semaphore_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_mem_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_rm_mem_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_page_tree_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_tracker_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_push_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_channel_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_ce_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_lock_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_utils_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_kvmalloc_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_pmm_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_events_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_perf_module_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_get_rm_ptes_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_fault_buffer_flush_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_mmu_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_peer_identity_mappings_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_va_block_test.o: No such file or directory
ld: cannot find /var/lib/dkms/nvidia/375.26/build/nvidia-uvm/uvm8_range_group_tree_test.o: No such file or directory
/usr/src/kernels/4.9.0-1-devhen/scripts/Makefile.build:531: recipe for target '/var/lib/dkms/nvidia/375.26/build/nvidia-uvm.o' failed
make[3]: *** [/var/lib/dkms/nvidia/375.26/build/nvidia-uvm.o] Error 1
/usr/src/kernels/4.9.0-1-devhen/scripts/Makefile.build:531: recipe for target '/var/lib/dkms/nvidia/375.26/build/nvidia.o' failed
make[3]: *** [/var/lib/dkms/nvidia/375.26/build/nvidia.o] Error 1
/usr/src/kernels/4.9.0-1-devhen/Makefile:1490: recipe for target '_module_/var/lib/dkms/nvidia/375.26/build' failed
make[2]: *** [_module_/var/lib/dkms/nvidia/375.26/build] Error 2
make[2]: Leaving directory '/usr/src/kernels/4.9.0-1-devhen'
Makefile:150: recipe for target 'sub-make' failed
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory '/usr/src/kernels/4.9.0-1-devhen'
Makefile:81: recipe for target 'modules' failed
make: *** [modules] Error 2
Any ideas?
Stop using DKMS.
Doesn’t make a difference. Still fails in the same way. And using dkms is the only way to avoid having to rebuild with every new kernel that I boot.
It compiles fine here on fedora 25 with 4.9 kernel!
Yeah, that’s what is so weird. I’ve heard from multiple sources that 375.26 is compatible with 4.9 and that some people have it working on 4.9 on Fedora 25 so I’m not sure what is different about my setup…
Just tried 4.9.1 and got the same results.
I use the Arch Linux kernel config (but with SELinux enabled) so I decided to try the Fedora config but that didn’t work either.
So I did some testing and found that on a fresh F25 install with all packages updated, the build still fails. It built successfully on the current F25 kernel, 4.8.15-300.fc25.x86_64, but it fails on my 4.9.1 kernel as well as the current rawhide-kernel-nodebug which is 4.10.0-0.rc2.git4.2.fc26.x86_64. It seems maybe there is an issue with > 4.8 kernels.
This is interesting. The latest kernel, 4.9.2, now builds successfully. But I might have been experiencing two different issues on my main machine because I just realized that I didn’t have elfutils-libelf-devel installed which is required now for CONFIG_STACK_VALIDATION. However, my F25 fresh install did have elfutils-libelf-devel and 4.9.1 still failed to build.
Anyway, 4.9.2 builds successfully on both the fresh F25 install and on my main machine so I’m happy now.
