building nvidia 470.74 on
lsb_release -rd
Description: Fedora release 34 (Thirty Four)
Release: 34
cat /proc/version
Linux version 5.14.13-200.fc34.x86_64 (mockbuild@bkernel02.iad2.fedoraproject.org) (gcc (GCC) 11.2.1 20210728 (Red Hat 11.2.1-1), GNU ld version 2.35.2-6.fc34) #1 SMP Mon Oct 18 12:39:31 UTC 2021
mokutil --sb-state
SecureBoot disabled
Platform is in Setup Mode
with
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/11/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-redhat-linux
Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,objc,obj-c++,ada,go,d,lto --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --with-linker-hash-style=gnu --enable-plugin --enable-initfini-array --with-isl=/builddir/build/BUILD/gcc-11.2.1-20210728/obj-x86_64-redhat-linux/isl-install --enable-offload-targets=nvptx-none --without-cuda-driver --enable-gnu-indirect-function --enable-cet --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.2.1 20210728 (Red Hat 11.2.1-1) (GCC)
dkms -V
dkms-2.8.7
installing from .run
cd NVIDIA-Linux-x86_64-470.74-no-compat32/
build with
./nvidia-installer
--expert
--dkms
--accept-license
--ui=none
--disable-nouveau
--no-nouveau-check
--no-questions
fails @ dkms module install
cat /var/log/nvidia-installer.log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sat Oct 23 11:57:23 2021
installer version: 470.74
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/X11R6/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
--expert
--dkms
--accept-license
--ui=none
--disable-nouveau
--no-nouveau-check
--no-questions
chdir("./")
Using built-in stream user interface
-> Detected 12 CPUs online; setting concurrency level to 12.
-> Concurrency level (Answer: '12')
-> Searching for system utilities:
-> found `ldconfig` : `/usr/sbin/ldconfig`
-> found `ldd` : `/usr/bin/ldd`
-> found `grep` : `/usr/bin/grep`
-> found `dmesg` : `/usr/bin/dmesg`
-> found `tail` : `/usr/bin/tail`
-> found `cut` : `/usr/bin/cut`
-> found `tr` : `/usr/bin/tr`
-> found `sed` : `/usr/bin/sed`
-> found `objcopy` : `/usr/bin/objcopy`
-> found `chcon` : `/usr/bin/chcon`
-> found `selinuxenabled` : `/usr/sbin/selinuxenabled`
-> found `getenforce` : `/usr/sbin/getenforce`
-> found `pkg-config` : `/usr/bin/pkg-config`
-> found `X` : `/usr/bin/X`
-> found `openssl` : `/usr/bin/openssl`
-> found `dkms` : `/usr/sbin/dkms`
-> found `systemctl` : `/usr/bin/systemctl`
-> Searching for module utilities:
-> found `modprobe` : `/usr/sbin/modprobe`
-> found `rmmod` : `/usr/sbin/rmmod`
-> found `lsmod` : `/usr/sbin/lsmod`
-> found `depmod` : `/usr/sbin/depmod`
-> No distribution pre-unload script found.
-> Installing NVIDIA driver version 470.74.
-> There appears to already be a driver installed on your system (version: 470.74). As part of installing this driver (version: 470.74), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
-> Check for the availability or presence of alternate driver installs? (Answer: Yes)
-> No distribution pre-install script found.
-> Would you like to install the nvidia-uvm kernel module? You must install this module in order to use CUDA. (Answer: Yes)
-> Would you like to install the nvidia-drm kernel module? You must install this module in order to use DRM-KMS. (Answer: Yes)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> X installation prefix (only under rare circumstances should this be changed from the default) (Answer: '/usr')
-> X installation prefix is: '/usr'
-> X library path '/usr/lib64' determined from `/usr/bin/X -showDefaultLibPath`
-> X module path '/usr/lib64/xorg/modules' determined from `/usr/bin/X -showDefaultModulePath`
-> X library installation path (only under rare circumstances should this be changed from the default) (Answer: '/usr/lib64')
-> X library installation path is: '/usr/lib64'
-> X module installation path (only under rare circumstances should this be changed from the default) (Answer: '/usr/lib64/xorg/modules')
-> X module installation path is: '/usr/lib64/xorg/modules'
-> OpenGL installation prefix (only under rare circumstances should this be changed from the default) (Answer: '/usr')
-> OpenGL installation prefix is: '/usr'
-> Documentation installation prefix (only under rare circumstances should this be changed from the default) (Answer: '/usr')
-> Documentation installation prefix is: '/usr'
-> Utility installation prefix (only under rare circumstances should this be changed from the default) (Answer: '/usr')
-> Utility installation prefix is: '/usr'
-> Do you want to install kernel module sources? (Answer: Yes)
-> Kernel module source installation prefix (Answer: '/usr/src')
-> Kernel module source installation prefix is: '/usr/src'
-> Kernel module source installation directory (Answer: '')
-> Kernel module source installation directory is: '(null)'
-> Compat32 installation chroot (only under rare circumstances should this be changed from the default) (Answer: '')
-> Compat32 installation chroot is: '(null)'
-> Compat32 installation prefix (only under rare circumstances should this be changed from the default) (Answer: '/usr')
-> Compat32 installation prefix is: '/usr'
-> Parsing log file:
-> error.
ERROR: Error while parsing line 915 of '/var/lib/nvidia/log'.
ERROR: Uninstallation failed.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
Found libglvnd libraries: libGLESv2.so.2 libGLESv1_CM.so.1 libOpenGL.so.0 libEGL.so.1 libGLX.so.0 libGL.so.1
Found non-libglvnd libraries:
Missing libraries:
libglvnd appears to be installed.
Will not install libglvnd libraries.
-> Skipping GLVND file: "libOpenGL.so.0"
-> Skipping GLVND file: "libOpenGL.so"
-> Skipping GLVND file: "libGLESv1_CM.so.1.2.0"
-> Skipping GLVND file: "libGLESv1_CM.so.1"
-> Skipping GLVND file: "libGLESv1_CM.so"
-> Skipping GLVND file: "libGLESv2.so.2.1.0"
-> Skipping GLVND file: "libGLESv2.so.2"
-> Skipping GLVND file: "libGLESv2.so"
-> Skipping GLVND file: "libGLdispatch.so.0"
-> Skipping GLVND file: "libGLX.so.0"
-> Skipping GLVND file: "libGLX.so"
-> Skipping GLVND file: "libGL.so.1.7.0"
-> Skipping GLVND file: "libGL.so.1"
-> Skipping GLVND file: "libGL.so"
-> Skipping GLVND file: "libEGL.so.1.1.0"
-> Skipping GLVND file: "libEGL.so.1"
-> Skipping GLVND file: "libEGL.so"
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (470.74):
-> Backing up: /usr/lib/nvidia/libGLX_installcheck.so.0
-> Backing up: /usr/lib64/libnvidia-ml.so.470.74
-> Backing up: /usr/lib64/libcuda.so.470.74
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-kernel.o_binary
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-pci.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-acpi.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-cray.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-dma.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-i2c.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-mmap.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-p2p.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-pat.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-procfs.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-procfs-utils.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-usermap.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-vm.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-vtophys.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/os-interface.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/os-mlock.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/os-pci.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/os-registry.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/os-usermap.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-modeset-interface.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-pci-table.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-kthread-q.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-memdbg.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-ibmnpu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-report-err.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-rsync.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-msi.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-caps.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-frontend.c
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/rm-gpu-ops.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-ioctl.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-ioctl-numa.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-ioctl-numbers.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-pci.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-pgprot.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-timer.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-linux.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-memdbg.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-p2p.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-proto.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-msi.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-reg.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/os-interface.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv_gpu_ops.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nvCpuUuid.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-pci-table.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-lock.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-pat.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-ibmnpu.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-report-err.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-rsync.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-caps.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-pci-types.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv-frontend.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nv_uvm_interface.c
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv_uvm_interface.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv_uvm_types.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nvgputypes.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv_firmware_types.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/rmp2pdefines.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-hypervisor.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-kernel-interface-api.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv_speculation_barrier.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/os/nv_memory_type.h
-> Backing up: /usr/src/nvidia-470.74/Makefile
-> Backing up: /usr/src/nvidia-470.74/Kbuild
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvidia.Kbuild
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvidia-sources.Kbuild
-> Backing up: /usr/src/nvidia-470.74/conftest.sh
-> Backing up: /usr/src/nvidia-470.74/common/inc/conftest.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nvtypes.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-time.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-kref.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-list-helpers.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-procfs.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-procfs-utils.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-modeset-interface.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-gpu-info.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-kthread-q.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-hash.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-register-module.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/cpuopsys.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nvlimits.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nvstatus.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nvstatuscodes.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nvmisc.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/xapi-sdk.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-retpoline.h
-> Backing up: /usr/src/nvidia-470.74/common/inc/nv-mm.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_linux.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_caps.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_linux.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_os.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_common.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_proto.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_errors.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_pci.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_export.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/nvlink_caps.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/linux_nvswitch.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/export_nvswitch.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/ioctl_nvswitch.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/ioctl_common_nvswitch.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/procfs_nvswitch.c
-> Backing up: /usr/src/nvidia-470.74/nvidia/linux_nvswitch.h
-> Backing up: /usr/src/nvidia-470.74/nvidia/i2c_nvswitch.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_common.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_linux.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_debug_optimized.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/nvstatus.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/nvCpuUuid.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/nv-kthread-q.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/nv-kthread-q-selftest.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_common.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_linux.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_unit_test.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ioctl.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_linux_ioctl.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_types.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/cla06f.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/cla16f.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clb06f.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc06f.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/cla06fsubch.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/cla0b5.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clb0b5.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc0b5.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc1b5.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc076.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clb069.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc369.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc365.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc36f.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc46f.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc5b5.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc6b5.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc56f.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc7b5.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/clc3b5.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/ctrl2080mc.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/volta/gv100/dev_mmu.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/pascal/gp100/dev_mmu.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/kepler/gk104/dev_mmu.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/pascal/gp100/dev_fault.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/pascal/gp100/dev_fb.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/volta/gv100/dev_fault.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/turing/tu102/dev_mmu.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/turing/tu102/dev_fault.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/ampere/ga100/dev_fault.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/ampere/ga100/dev_runlist.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/hwref/volta/gv100/dev_fb.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/nvidia-uvm.Kbuild
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/nvidia-uvm-sources.Kbuild
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_tools_init.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_tools.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_tools.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_global.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_global.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_isr.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_isr.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_procfs.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_procfs.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_space.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_space.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_space_mm.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_space_mm.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_semaphore.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_semaphore.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_mem.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_mem.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_rm_mem.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_rm_mem.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_channel.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_channel.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_lock.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_lock.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_api.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_hal.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_hal.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_hal_types.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_extern_decl.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_forward_decl.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_processors.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_tree.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_tree.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_rb_tree.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_rb_tree.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_allocator.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_allocator.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_range.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_range.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_block.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_block_types.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_block.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_group.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_group.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_replayable_faults.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_replayable_faults.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_non_replayable_faults.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_non_replayable_faults.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_access_counters.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_access_counters.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_events.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_events.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_module.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_module.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_mmu.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_mmu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pte_batch.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pte_batch.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_tlb_batch.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_tlb_batch.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_push_macros.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_push.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_push.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pushbuffer.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pushbuffer.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_thread_context.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_thread_context.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_tracker.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_tracker.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_ce.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_host.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_mmu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_fault_buffer.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_access_counter_buffer.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_maxwell.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_maxwell_host.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_ce.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_host.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_mmu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_fault_buffer.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_fault_buffer.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_host.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_mmu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_fault_buffer.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_fault_buffer.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_access_counter_buffer.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_access_counter_buffer.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_fault_buffer.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_fault_buffer.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_mmu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_host.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere_ce.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere_host.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere_fault_buffer.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere_mmu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_policy.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_utils.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_utils.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kvmalloc.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kvmalloc.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_sysmem.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_sysmem.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_gpu.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_gpu.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_migrate.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_migrate.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_populate_pageable.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_populate_pageable.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_migrate_pageable.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_migrate_pageable.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_map_external.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_map_external.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_user_channel.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_user_channel.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_hmm.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_hmm.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_heuristics.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_heuristics.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_thrashing.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_thrashing.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_prefetch.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_prefetch.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ats_ibm.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ats_ibm.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ats_faults.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ats_faults.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_test.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_test_rng.h
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_test_rng.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_tree_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_allocator_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_semaphore_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_mem_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_rm_mem_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_page_tree_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_tracker_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_push_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_channel_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_ce_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_host_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_lock_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_utils_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_kvmalloc_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_sysmem_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_events_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_module_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_get_rm_ptes_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_fault_buffer_flush_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_mmu_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_peer_identity_mappings_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_block_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_group_tree_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_thread_context_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_rb_tree_test.c
-> Backing up: /usr/src/nvidia-470.74/nvidia-uvm/uvm_test_ioctl.h
-> Backing up: /lib/firmware/nvidia/470.74/gsp.bin
-> Backing up: /usr/share/doc/NVIDIA_GLX-1.0/NVIDIA_Changelog
-> Backing up: /usr/share/doc/NVIDIA_GLX-1.0/LICENSE
-> Backing up: /usr/bin/nvidia-bug-report.sh
-> Backing up: /usr/share/man/man1/nvidia-installer.1.gz
-> Backing up: /usr/bin/nvidia-installer
-> Backing up: /usr/bin/nvidia-modprobe
-> Backing up: /usr/share/man/man1/nvidia-modprobe.1.gz
-> Backing up: /usr/share/doc/NVIDIA_GLX-1.0/README.txt
-> Backing up: /usr/share/doc/NVIDIA_GLX-1.0/supported-gpus/supported-gpus.json
-> Backing up: /usr/share/doc/NVIDIA_GLX-1.0/supported-gpus/LICENSE
-> Backing up: /usr/lib/systemd/system/nvidia-suspend.service
-> Backing up: /usr/lib/systemd/system/nvidia-hibernate.service
-> Backing up: /usr/lib/systemd/system/nvidia-resume.service
-> Backing up: /usr/lib/systemd/system-sleep/nvidia
-> Backing up: /usr/bin/nvidia-sleep.sh
-> Backing up: /usr/lib/nvidia/glvnd_check
-> Backing up: /usr/lib/nvidia/egl_dummy_vendor.json
-> Backing up: /usr/bin/nvidia-smi
-> Backing up: /usr/share/man/man1/nvidia-smi.1.gz
-> Backing up: /usr/bin/nvidia-debugdump
-> Installing: kernel/nvidia/nv-kernel.o_binary --> /usr/src/nvidia-470.74/nvidia/nv-kernel.o_binary
-> Installing: kernel/nvidia/nv.c --> /usr/src/nvidia-470.74/nvidia/nv.c
-> Installing: kernel/nvidia/nv-pci.c --> /usr/src/nvidia-470.74/nvidia/nv-pci.c
-> Installing: kernel/nvidia/nv-acpi.c --> /usr/src/nvidia-470.74/nvidia/nv-acpi.c
-> Installing: kernel/nvidia/nv-cray.c --> /usr/src/nvidia-470.74/nvidia/nv-cray.c
-> Installing: kernel/nvidia/nv-dma.c --> /usr/src/nvidia-470.74/nvidia/nv-dma.c
-> Installing: kernel/nvidia/nv-i2c.c --> /usr/src/nvidia-470.74/nvidia/nv-i2c.c
-> Installing: kernel/nvidia/nv-mmap.c --> /usr/src/nvidia-470.74/nvidia/nv-mmap.c
-> Installing: kernel/nvidia/nv-p2p.c --> /usr/src/nvidia-470.74/nvidia/nv-p2p.c
-> Installing: kernel/nvidia/nv-pat.c --> /usr/src/nvidia-470.74/nvidia/nv-pat.c
-> Installing: kernel/nvidia/nv-procfs.c --> /usr/src/nvidia-470.74/nvidia/nv-procfs.c
-> Installing: kernel/nvidia/nv-procfs-utils.c --> /usr/src/nvidia-470.74/nvidia/nv-procfs-utils.c
-> Installing: kernel/nvidia/nv-usermap.c --> /usr/src/nvidia-470.74/nvidia/nv-usermap.c
-> Installing: kernel/nvidia/nv-vm.c --> /usr/src/nvidia-470.74/nvidia/nv-vm.c
-> Installing: kernel/nvidia/nv-vtophys.c --> /usr/src/nvidia-470.74/nvidia/nv-vtophys.c
-> Installing: kernel/nvidia/os-interface.c --> /usr/src/nvidia-470.74/nvidia/os-interface.c
-> Installing: kernel/nvidia/os-mlock.c --> /usr/src/nvidia-470.74/nvidia/os-mlock.c
-> Installing: kernel/nvidia/os-pci.c --> /usr/src/nvidia-470.74/nvidia/os-pci.c
-> Installing: kernel/nvidia/os-registry.c --> /usr/src/nvidia-470.74/nvidia/os-registry.c
-> Installing: kernel/nvidia/os-usermap.c --> /usr/src/nvidia-470.74/nvidia/os-usermap.c
-> Installing: kernel/nvidia/nv-modeset-interface.c --> /usr/src/nvidia-470.74/nvidia/nv-modeset-interface.c
-> Installing: kernel/nvidia/nv-pci-table.c --> /usr/src/nvidia-470.74/nvidia/nv-pci-table.c
-> Installing: kernel/nvidia/nv-kthread-q.c --> /usr/src/nvidia-470.74/nvidia/nv-kthread-q.c
-> Installing: kernel/nvidia/nv-memdbg.c --> /usr/src/nvidia-470.74/nvidia/nv-memdbg.c
-> Installing: kernel/nvidia/nv-ibmnpu.c --> /usr/src/nvidia-470.74/nvidia/nv-ibmnpu.c
-> Installing: kernel/nvidia/nv-report-err.c --> /usr/src/nvidia-470.74/nvidia/nv-report-err.c
-> Installing: kernel/nvidia/nv-rsync.c --> /usr/src/nvidia-470.74/nvidia/nv-rsync.c
-> Installing: kernel/nvidia/nv-msi.c --> /usr/src/nvidia-470.74/nvidia/nv-msi.c
-> Installing: kernel/nvidia/nv-caps.c --> /usr/src/nvidia-470.74/nvidia/nv-caps.c
-> Installing: kernel/nvidia/nv-frontend.c --> /usr/src/nvidia-470.74/nvidia/nv-frontend.c
-> Installing: kernel/common/inc/nv.h --> /usr/src/nvidia-470.74/common/inc/nv.h
-> Installing: kernel/common/inc/rm-gpu-ops.h --> /usr/src/nvidia-470.74/common/inc/rm-gpu-ops.h
-> Installing: kernel/common/inc/nv-ioctl.h --> /usr/src/nvidia-470.74/common/inc/nv-ioctl.h
-> Installing: kernel/common/inc/nv-ioctl-numa.h --> /usr/src/nvidia-470.74/common/inc/nv-ioctl-numa.h
-> Installing: kernel/common/inc/nv-ioctl-numbers.h --> /usr/src/nvidia-470.74/common/inc/nv-ioctl-numbers.h
-> Installing: kernel/common/inc/nv-pci.h --> /usr/src/nvidia-470.74/common/inc/nv-pci.h
-> Installing: kernel/common/inc/nv-pgprot.h --> /usr/src/nvidia-470.74/common/inc/nv-pgprot.h
-> Installing: kernel/common/inc/nv-timer.h --> /usr/src/nvidia-470.74/common/inc/nv-timer.h
-> Installing: kernel/common/inc/nv-linux.h --> /usr/src/nvidia-470.74/common/inc/nv-linux.h
-> Installing: kernel/common/inc/nv-memdbg.h --> /usr/src/nvidia-470.74/common/inc/nv-memdbg.h
-> Installing: kernel/nvidia/nv-p2p.h --> /usr/src/nvidia-470.74/nvidia/nv-p2p.h
-> Installing: kernel/common/inc/nv-proto.h --> /usr/src/nvidia-470.74/common/inc/nv-proto.h
-> Installing: kernel/common/inc/nv-msi.h --> /usr/src/nvidia-470.74/common/inc/nv-msi.h
-> Installing: kernel/nvidia/nv-reg.h --> /usr/src/nvidia-470.74/nvidia/nv-reg.h
-> Installing: kernel/common/inc/os-interface.h --> /usr/src/nvidia-470.74/common/inc/os-interface.h
-> Installing: kernel/nvidia/nv_gpu_ops.h --> /usr/src/nvidia-470.74/nvidia/nv_gpu_ops.h
-> Installing: kernel/common/inc/nvCpuUuid.h --> /usr/src/nvidia-470.74/common/inc/nvCpuUuid.h
-> Installing: kernel/nvidia/nv-pci-table.h --> /usr/src/nvidia-470.74/nvidia/nv-pci-table.h
-> Installing: kernel/common/inc/nv-lock.h --> /usr/src/nvidia-470.74/common/inc/nv-lock.h
-> Installing: kernel/nvidia/nv-pat.h --> /usr/src/nvidia-470.74/nvidia/nv-pat.h
-> Installing: kernel/nvidia/nv-ibmnpu.h --> /usr/src/nvidia-470.74/nvidia/nv-ibmnpu.h
-> Installing: kernel/nvidia/nv-report-err.h --> /usr/src/nvidia-470.74/nvidia/nv-report-err.h
-> Installing: kernel/nvidia/nv-rsync.h --> /usr/src/nvidia-470.74/nvidia/nv-rsync.h
-> Installing: kernel/common/inc/nv-caps.h --> /usr/src/nvidia-470.74/common/inc/nv-caps.h
-> Installing: kernel/common/inc/nv-pci-types.h --> /usr/src/nvidia-470.74/common/inc/nv-pci-types.h
-> Installing: kernel/nvidia/nv-frontend.h --> /usr/src/nvidia-470.74/nvidia/nv-frontend.h
-> Installing: kernel/nvidia/nv_uvm_interface.c --> /usr/src/nvidia-470.74/nvidia/nv_uvm_interface.c
-> Installing: kernel/common/inc/nv_uvm_interface.h --> /usr/src/nvidia-470.74/common/inc/nv_uvm_interface.h
-> Installing: kernel/common/inc/nv_uvm_types.h --> /usr/src/nvidia-470.74/common/inc/nv_uvm_types.h
-> Installing: kernel/common/inc/nvgputypes.h --> /usr/src/nvidia-470.74/common/inc/nvgputypes.h
-> Installing: kernel/common/inc/nv_firmware_types.h --> /usr/src/nvidia-470.74/common/inc/nv_firmware_types.h
-> Installing: kernel/nvidia/rmp2pdefines.h --> /usr/src/nvidia-470.74/nvidia/rmp2pdefines.h
-> Installing: kernel/common/inc/nv-hypervisor.h --> /usr/src/nvidia-470.74/common/inc/nv-hypervisor.h
-> Installing: kernel/common/inc/nv-kernel-interface-api.h --> /usr/src/nvidia-470.74/common/inc/nv-kernel-interface-api.h
-> Installing: kernel/common/inc/nv_speculation_barrier.h --> /usr/src/nvidia-470.74/common/inc/nv_speculation_barrier.h
-> Installing: kernel/common/inc/os/nv_memory_type.h --> /usr/src/nvidia-470.74/common/inc/os/nv_memory_type.h
-> Installing: kernel/Makefile --> /usr/src/nvidia-470.74/Makefile
-> Installing: kernel/Kbuild --> /usr/src/nvidia-470.74/Kbuild
-> Installing: kernel/nvidia/nvidia.Kbuild --> /usr/src/nvidia-470.74/nvidia/nvidia.Kbuild
-> Installing: kernel/nvidia/nvidia-sources.Kbuild --> /usr/src/nvidia-470.74/nvidia/nvidia-sources.Kbuild
-> Installing: kernel/conftest.sh --> /usr/src/nvidia-470.74/conftest.sh
-> Installing: kernel/common/inc/conftest.h --> /usr/src/nvidia-470.74/common/inc/conftest.h
-> Installing: kernel/common/inc/nvtypes.h --> /usr/src/nvidia-470.74/common/inc/nvtypes.h
-> Installing: kernel/common/inc/nv-time.h --> /usr/src/nvidia-470.74/common/inc/nv-time.h
-> Installing: kernel/common/inc/nv-kref.h --> /usr/src/nvidia-470.74/common/inc/nv-kref.h
-> Installing: kernel/common/inc/nv-list-helpers.h --> /usr/src/nvidia-470.74/common/inc/nv-list-helpers.h
-> Installing: kernel/common/inc/nv-procfs.h --> /usr/src/nvidia-470.74/common/inc/nv-procfs.h
-> Installing: kernel/common/inc/nv-procfs-utils.h --> /usr/src/nvidia-470.74/common/inc/nv-procfs-utils.h
-> Installing: kernel/common/inc/nv-modeset-interface.h --> /usr/src/nvidia-470.74/common/inc/nv-modeset-interface.h
-> Installing: kernel/common/inc/nv-gpu-info.h --> /usr/src/nvidia-470.74/common/inc/nv-gpu-info.h
-> Installing: kernel/common/inc/nv-kthread-q.h --> /usr/src/nvidia-470.74/common/inc/nv-kthread-q.h
-> Installing: kernel/common/inc/nv-hash.h --> /usr/src/nvidia-470.74/common/inc/nv-hash.h
-> Installing: kernel/common/inc/nv-register-module.h --> /usr/src/nvidia-470.74/common/inc/nv-register-module.h
-> Installing: kernel/common/inc/cpuopsys.h --> /usr/src/nvidia-470.74/common/inc/cpuopsys.h
-> Installing: kernel/common/inc/nvlimits.h --> /usr/src/nvidia-470.74/common/inc/nvlimits.h
-> Installing: kernel/common/inc/nvstatus.h --> /usr/src/nvidia-470.74/common/inc/nvstatus.h
-> Installing: kernel/common/inc/nvstatuscodes.h --> /usr/src/nvidia-470.74/common/inc/nvstatuscodes.h
-> Installing: kernel/common/inc/nvmisc.h --> /usr/src/nvidia-470.74/common/inc/nvmisc.h
-> Installing: kernel/common/inc/xapi-sdk.h --> /usr/src/nvidia-470.74/common/inc/xapi-sdk.h
-> Installing: kernel/common/inc/nv-retpoline.h --> /usr/src/nvidia-470.74/common/inc/nv-retpoline.h
-> Installing: kernel/common/inc/nv-mm.h --> /usr/src/nvidia-470.74/common/inc/nv-mm.h
-> Installing: kernel/nvidia/nvlink_linux.c --> /usr/src/nvidia-470.74/nvidia/nvlink_linux.c
-> Installing: kernel/nvidia/nvlink_caps.c --> /usr/src/nvidia-470.74/nvidia/nvlink_caps.c
-> Installing: kernel/nvidia/nvlink_linux.h --> /usr/src/nvidia-470.74/nvidia/nvlink_linux.h
-> Installing: kernel/nvidia/nvlink_os.h --> /usr/src/nvidia-470.74/nvidia/nvlink_os.h
-> Installing: kernel/nvidia/nvlink_common.h --> /usr/src/nvidia-470.74/nvidia/nvlink_common.h
-> Installing: kernel/nvidia/nvlink_proto.h --> /usr/src/nvidia-470.74/nvidia/nvlink_proto.h
-> Installing: kernel/nvidia/nvlink_errors.h --> /usr/src/nvidia-470.74/nvidia/nvlink_errors.h
-> Installing: kernel/nvidia/nvlink_pci.h --> /usr/src/nvidia-470.74/nvidia/nvlink_pci.h
-> Installing: kernel/nvidia/nvlink_export.h --> /usr/src/nvidia-470.74/nvidia/nvlink_export.h
-> Installing: kernel/nvidia/nvlink_caps.h --> /usr/src/nvidia-470.74/nvidia/nvlink_caps.h
-> Installing: kernel/nvidia/linux_nvswitch.c --> /usr/src/nvidia-470.74/nvidia/linux_nvswitch.c
-> Installing: kernel/nvidia/export_nvswitch.h --> /usr/src/nvidia-470.74/nvidia/export_nvswitch.h
-> Installing: kernel/nvidia/ioctl_nvswitch.h --> /usr/src/nvidia-470.74/nvidia/ioctl_nvswitch.h
-> Installing: kernel/nvidia/ioctl_common_nvswitch.h --> /usr/src/nvidia-470.74/nvidia/ioctl_common_nvswitch.h
-> Installing: kernel/nvidia/procfs_nvswitch.c --> /usr/src/nvidia-470.74/nvidia/procfs_nvswitch.c
-> Installing: kernel/nvidia/linux_nvswitch.h --> /usr/src/nvidia-470.74/nvidia/linux_nvswitch.h
-> Installing: kernel/nvidia/i2c_nvswitch.c --> /usr/src/nvidia-470.74/nvidia/i2c_nvswitch.c
-> Installing: kernel/nvidia-uvm/uvm_common.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_common.c
-> Installing: kernel/nvidia-uvm/uvm_linux.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_linux.c
-> Installing: kernel/nvidia-uvm/uvm_debug_optimized.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_debug_optimized.c
-> Installing: kernel/nvidia-uvm/nvstatus.c --> /usr/src/nvidia-470.74/nvidia-uvm/nvstatus.c
-> Installing: kernel/nvidia-uvm/nvCpuUuid.c --> /usr/src/nvidia-470.74/nvidia-uvm/nvCpuUuid.c
-> Installing: kernel/nvidia-uvm/nv-kthread-q.c --> /usr/src/nvidia-470.74/nvidia-uvm/nv-kthread-q.c
-> Installing: kernel/nvidia-uvm/nv-kthread-q-selftest.c --> /usr/src/nvidia-470.74/nvidia-uvm/nv-kthread-q-selftest.c
-> Installing: kernel/nvidia-uvm/uvm_common.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_common.h
-> Installing: kernel/nvidia-uvm/uvm_linux.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_linux.h
-> Installing: kernel/nvidia-uvm/uvm_unit_test.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_unit_test.h
-> Installing: kernel/nvidia-uvm/uvm.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm.h
-> Installing: kernel/nvidia-uvm/uvm_ioctl.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ioctl.h
-> Installing: kernel/nvidia-uvm/uvm_linux_ioctl.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_linux_ioctl.h
-> Installing: kernel/nvidia-uvm/uvm_types.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_types.h
-> Installing: kernel/nvidia-uvm/cla06f.h --> /usr/src/nvidia-470.74/nvidia-uvm/cla06f.h
-> Installing: kernel/nvidia-uvm/cla16f.h --> /usr/src/nvidia-470.74/nvidia-uvm/cla16f.h
-> Installing: kernel/nvidia-uvm/clb06f.h --> /usr/src/nvidia-470.74/nvidia-uvm/clb06f.h
-> Installing: kernel/nvidia-uvm/clc06f.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc06f.h
-> Installing: kernel/nvidia-uvm/cla06fsubch.h --> /usr/src/nvidia-470.74/nvidia-uvm/cla06fsubch.h
-> Installing: kernel/nvidia-uvm/cla0b5.h --> /usr/src/nvidia-470.74/nvidia-uvm/cla0b5.h
-> Installing: kernel/nvidia-uvm/clb0b5.h --> /usr/src/nvidia-470.74/nvidia-uvm/clb0b5.h
-> Installing: kernel/nvidia-uvm/clc0b5.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc0b5.h
-> Installing: kernel/nvidia-uvm/clc1b5.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc1b5.h
-> Installing: kernel/nvidia-uvm/clc076.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc076.h
-> Installing: kernel/nvidia-uvm/clb069.h --> /usr/src/nvidia-470.74/nvidia-uvm/clb069.h
-> Installing: kernel/nvidia-uvm/clc369.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc369.h
-> Installing: kernel/nvidia-uvm/clc365.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc365.h
-> Installing: kernel/nvidia-uvm/clc36f.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc36f.h
-> Installing: kernel/nvidia-uvm/clc46f.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc46f.h
-> Installing: kernel/nvidia-uvm/clc5b5.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc5b5.h
-> Installing: kernel/nvidia-uvm/clc6b5.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc6b5.h
-> Installing: kernel/nvidia-uvm/clc56f.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc56f.h
-> Installing: kernel/nvidia-uvm/clc7b5.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc7b5.h
-> Installing: kernel/nvidia-uvm/clc3b5.h --> /usr/src/nvidia-470.74/nvidia-uvm/clc3b5.h
-> Installing: kernel/nvidia-uvm/ctrl2080mc.h --> /usr/src/nvidia-470.74/nvidia-uvm/ctrl2080mc.h
-> Installing: kernel/nvidia-uvm/hwref/volta/gv100/dev_mmu.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/volta/gv100/dev_mmu.h
-> Installing: kernel/nvidia-uvm/hwref/pascal/gp100/dev_mmu.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/pascal/gp100/dev_mmu.h
-> Installing: kernel/nvidia-uvm/hwref/kepler/gk104/dev_mmu.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/kepler/gk104/dev_mmu.h
-> Installing: kernel/nvidia-uvm/hwref/pascal/gp100/dev_fault.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/pascal/gp100/dev_fault.h
-> Installing: kernel/nvidia-uvm/hwref/pascal/gp100/dev_fb.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/pascal/gp100/dev_fb.h
-> Installing: kernel/nvidia-uvm/hwref/volta/gv100/dev_fault.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/volta/gv100/dev_fault.h
-> Installing: kernel/nvidia-uvm/hwref/turing/tu102/dev_mmu.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/turing/tu102/dev_mmu.h
-> Installing: kernel/nvidia-uvm/hwref/turing/tu102/dev_fault.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/turing/tu102/dev_fault.h
-> Installing: kernel/nvidia-uvm/hwref/ampere/ga100/dev_fault.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/ampere/ga100/dev_fault.h
-> Installing: kernel/nvidia-uvm/hwref/ampere/ga100/dev_runlist.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/ampere/ga100/dev_runlist.h
-> Installing: kernel/nvidia-uvm/hwref/volta/gv100/dev_fb.h --> /usr/src/nvidia-470.74/nvidia-uvm/hwref/volta/gv100/dev_fb.h
-> Installing: kernel/nvidia-uvm/nvidia-uvm.Kbuild --> /usr/src/nvidia-470.74/nvidia-uvm/nvidia-uvm.Kbuild
-> Installing: kernel/nvidia-uvm/nvidia-uvm-sources.Kbuild --> /usr/src/nvidia-470.74/nvidia-uvm/nvidia-uvm-sources.Kbuild
-> Installing: kernel/nvidia-uvm/uvm.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm.c
-> Installing: kernel/nvidia-uvm/uvm_tools_init.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_tools_init.h
-> Installing: kernel/nvidia-uvm/uvm_tools.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_tools.h
-> Installing: kernel/nvidia-uvm/uvm_tools.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_tools.c
-> Installing: kernel/nvidia-uvm/uvm_global.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_global.h
-> Installing: kernel/nvidia-uvm/uvm_global.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_global.c
-> Installing: kernel/nvidia-uvm/uvm_gpu.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu.h
-> Installing: kernel/nvidia-uvm/uvm_gpu.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu.c
-> Installing: kernel/nvidia-uvm/uvm_gpu_isr.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_isr.h
-> Installing: kernel/nvidia-uvm/uvm_gpu_isr.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_isr.c
-> Installing: kernel/nvidia-uvm/uvm_procfs.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_procfs.h
-> Installing: kernel/nvidia-uvm/uvm_procfs.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_procfs.c
-> Installing: kernel/nvidia-uvm/uvm_va_space.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_space.h
-> Installing: kernel/nvidia-uvm/uvm_va_space.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_space.c
-> Installing: kernel/nvidia-uvm/uvm_va_space_mm.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_space_mm.h
-> Installing: kernel/nvidia-uvm/uvm_va_space_mm.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_space_mm.c
-> Installing: kernel/nvidia-uvm/uvm_gpu_semaphore.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_semaphore.h
-> Installing: kernel/nvidia-uvm/uvm_gpu_semaphore.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_semaphore.c
-> Installing: kernel/nvidia-uvm/uvm_mem.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_mem.h
-> Installing: kernel/nvidia-uvm/uvm_mem.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_mem.c
-> Installing: kernel/nvidia-uvm/uvm_rm_mem.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_rm_mem.h
-> Installing: kernel/nvidia-uvm/uvm_rm_mem.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_rm_mem.c
-> Installing: kernel/nvidia-uvm/uvm_channel.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_channel.h
-> Installing: kernel/nvidia-uvm/uvm_channel.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_channel.c
-> Installing: kernel/nvidia-uvm/uvm_lock.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_lock.h
-> Installing: kernel/nvidia-uvm/uvm_lock.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_lock.c
-> Installing: kernel/nvidia-uvm/uvm_api.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_api.h
-> Installing: kernel/nvidia-uvm/uvm_hal.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_hal.h
-> Installing: kernel/nvidia-uvm/uvm_hal.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_hal.c
-> Installing: kernel/nvidia-uvm/uvm_hal_types.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_hal_types.h
-> Installing: kernel/nvidia-uvm/uvm_extern_decl.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_extern_decl.h
-> Installing: kernel/nvidia-uvm/uvm_forward_decl.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_forward_decl.h
-> Installing: kernel/nvidia-uvm/uvm_processors.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_processors.h
-> Installing: kernel/nvidia-uvm/uvm_range_tree.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_tree.h
-> Installing: kernel/nvidia-uvm/uvm_range_tree.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_tree.c
-> Installing: kernel/nvidia-uvm/uvm_rb_tree.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_rb_tree.h
-> Installing: kernel/nvidia-uvm/uvm_rb_tree.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_rb_tree.c
-> Installing: kernel/nvidia-uvm/uvm_range_allocator.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_allocator.h
-> Installing: kernel/nvidia-uvm/uvm_range_allocator.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_allocator.c
-> Installing: kernel/nvidia-uvm/uvm_va_range.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_range.h
-> Installing: kernel/nvidia-uvm/uvm_va_range.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_range.c
-> Installing: kernel/nvidia-uvm/uvm_va_block.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_block.h
-> Installing: kernel/nvidia-uvm/uvm_va_block_types.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_block_types.h
-> Installing: kernel/nvidia-uvm/uvm_va_block.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_block.c
-> Installing: kernel/nvidia-uvm/uvm_range_group.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_group.c
-> Installing: kernel/nvidia-uvm/uvm_range_group.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_group.h
-> Installing: kernel/nvidia-uvm/uvm_gpu_replayable_faults.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_replayable_faults.h
-> Installing: kernel/nvidia-uvm/uvm_gpu_replayable_faults.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_replayable_faults.c
-> Installing: kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_non_replayable_faults.c
-> Installing: kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_non_replayable_faults.h
-> Installing: kernel/nvidia-uvm/uvm_gpu_access_counters.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_access_counters.c
-> Installing: kernel/nvidia-uvm/uvm_gpu_access_counters.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_access_counters.h
-> Installing: kernel/nvidia-uvm/uvm_perf_events.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_events.h
-> Installing: kernel/nvidia-uvm/uvm_perf_events.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_events.c
-> Installing: kernel/nvidia-uvm/uvm_perf_module.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_module.h
-> Installing: kernel/nvidia-uvm/uvm_perf_module.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_module.c
-> Installing: kernel/nvidia-uvm/uvm_mmu.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_mmu.h
-> Installing: kernel/nvidia-uvm/uvm_mmu.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_mmu.c
-> Installing: kernel/nvidia-uvm/uvm_pte_batch.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pte_batch.h
-> Installing: kernel/nvidia-uvm/uvm_pte_batch.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pte_batch.c
-> Installing: kernel/nvidia-uvm/uvm_tlb_batch.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_tlb_batch.h
-> Installing: kernel/nvidia-uvm/uvm_tlb_batch.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_tlb_batch.c
-> Installing: kernel/nvidia-uvm/uvm_push_macros.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_push_macros.h
-> Installing: kernel/nvidia-uvm/uvm_push.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_push.h
-> Installing: kernel/nvidia-uvm/uvm_push.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_push.c
-> Installing: kernel/nvidia-uvm/uvm_pushbuffer.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pushbuffer.h
-> Installing: kernel/nvidia-uvm/uvm_pushbuffer.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pushbuffer.c
-> Installing: kernel/nvidia-uvm/uvm_thread_context.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_thread_context.h
-> Installing: kernel/nvidia-uvm/uvm_thread_context.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_thread_context.c
-> Installing: kernel/nvidia-uvm/uvm_tracker.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_tracker.h
-> Installing: kernel/nvidia-uvm/uvm_tracker.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_tracker.c
-> Installing: kernel/nvidia-uvm/uvm_kepler.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler.c
-> Installing: kernel/nvidia-uvm/uvm_kepler_ce.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_ce.c
-> Installing: kernel/nvidia-uvm/uvm_kepler_host.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_host.c
-> Installing: kernel/nvidia-uvm/uvm_kepler_mmu.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_mmu.c
-> Installing: kernel/nvidia-uvm/uvm_kepler_fault_buffer.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_fault_buffer.c
-> Installing: kernel/nvidia-uvm/uvm_kepler_access_counter_buffer.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kepler_access_counter_buffer.c
-> Installing: kernel/nvidia-uvm/uvm_maxwell.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_maxwell.c
-> Installing: kernel/nvidia-uvm/uvm_maxwell_host.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_maxwell_host.c
-> Installing: kernel/nvidia-uvm/uvm_pascal.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal.c
-> Installing: kernel/nvidia-uvm/uvm_pascal_ce.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_ce.c
-> Installing: kernel/nvidia-uvm/uvm_pascal_host.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_host.c
-> Installing: kernel/nvidia-uvm/uvm_pascal_mmu.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_mmu.c
-> Installing: kernel/nvidia-uvm/uvm_pascal_fault_buffer.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_fault_buffer.c
-> Installing: kernel/nvidia-uvm/uvm_pascal_fault_buffer.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pascal_fault_buffer.h
-> Installing: kernel/nvidia-uvm/uvm_volta_host.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_host.c
-> Installing: kernel/nvidia-uvm/uvm_volta_mmu.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_mmu.c
-> Installing: kernel/nvidia-uvm/uvm_volta.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta.c
-> Installing: kernel/nvidia-uvm/uvm_volta_fault_buffer.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_fault_buffer.c
-> Installing: kernel/nvidia-uvm/uvm_volta_fault_buffer.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_fault_buffer.h
-> Installing: kernel/nvidia-uvm/uvm_volta_access_counter_buffer.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_volta_access_counter_buffer.c
-> Installing: kernel/nvidia-uvm/uvm_turing.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing.c
-> Installing: kernel/nvidia-uvm/uvm_turing_access_counter_buffer.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_access_counter_buffer.c
-> Installing: kernel/nvidia-uvm/uvm_turing_fault_buffer.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_fault_buffer.c
-> Installing: kernel/nvidia-uvm/uvm_turing_fault_buffer.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_fault_buffer.h
-> Installing: kernel/nvidia-uvm/uvm_turing_mmu.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_mmu.c
-> Installing: kernel/nvidia-uvm/uvm_turing_host.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_turing_host.c
-> Installing: kernel/nvidia-uvm/uvm_ampere.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere.c
-> Installing: kernel/nvidia-uvm/uvm_ampere_ce.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere_ce.c
-> Installing: kernel/nvidia-uvm/uvm_ampere_host.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere_host.c
-> Installing: kernel/nvidia-uvm/uvm_ampere_fault_buffer.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere_fault_buffer.h
-> Installing: kernel/nvidia-uvm/uvm_ampere_mmu.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ampere_mmu.c
-> Installing: kernel/nvidia-uvm/uvm_policy.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_policy.c
-> Installing: kernel/nvidia-uvm/uvm_perf_utils.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_utils.h
-> Installing: kernel/nvidia-uvm/uvm_perf_utils.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_utils.c
-> Installing: kernel/nvidia-uvm/uvm_kvmalloc.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kvmalloc.h
-> Installing: kernel/nvidia-uvm/uvm_kvmalloc.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kvmalloc.c
-> Installing: kernel/nvidia-uvm/uvm_pmm_sysmem.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_sysmem.h
-> Installing: kernel/nvidia-uvm/uvm_pmm_sysmem.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_sysmem.c
-> Installing: kernel/nvidia-uvm/uvm_pmm_gpu.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_gpu.h
-> Installing: kernel/nvidia-uvm/uvm_pmm_gpu.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_gpu.c
-> Installing: kernel/nvidia-uvm/uvm_migrate.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_migrate.c
-> Installing: kernel/nvidia-uvm/uvm_migrate.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_migrate.h
-> Installing: kernel/nvidia-uvm/uvm_populate_pageable.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_populate_pageable.c
-> Installing: kernel/nvidia-uvm/uvm_populate_pageable.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_populate_pageable.h
-> Installing: kernel/nvidia-uvm/uvm_migrate_pageable.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_migrate_pageable.c
-> Installing: kernel/nvidia-uvm/uvm_migrate_pageable.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_migrate_pageable.h
-> Installing: kernel/nvidia-uvm/uvm_map_external.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_map_external.h
-> Installing: kernel/nvidia-uvm/uvm_map_external.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_map_external.c
-> Installing: kernel/nvidia-uvm/uvm_user_channel.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_user_channel.h
-> Installing: kernel/nvidia-uvm/uvm_user_channel.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_user_channel.c
-> Installing: kernel/nvidia-uvm/uvm_hmm.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_hmm.h
-> Installing: kernel/nvidia-uvm/uvm_hmm.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_hmm.c
-> Installing: kernel/nvidia-uvm/uvm_perf_heuristics.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_heuristics.h
-> Installing: kernel/nvidia-uvm/uvm_perf_heuristics.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_heuristics.c
-> Installing: kernel/nvidia-uvm/uvm_perf_thrashing.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_thrashing.h
-> Installing: kernel/nvidia-uvm/uvm_perf_thrashing.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_thrashing.c
-> Installing: kernel/nvidia-uvm/uvm_perf_prefetch.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_prefetch.h
-> Installing: kernel/nvidia-uvm/uvm_perf_prefetch.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_prefetch.c
-> Installing: kernel/nvidia-uvm/uvm_ats_ibm.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ats_ibm.h
-> Installing: kernel/nvidia-uvm/uvm_ats_ibm.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ats_ibm.c
-> Installing: kernel/nvidia-uvm/uvm_ats_faults.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ats_faults.h
-> Installing: kernel/nvidia-uvm/uvm_ats_faults.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ats_faults.c
-> Installing: kernel/nvidia-uvm/uvm_test.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_test.h
-> Installing: kernel/nvidia-uvm/uvm_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_test.c
-> Installing: kernel/nvidia-uvm/uvm_test_rng.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_test_rng.h
-> Installing: kernel/nvidia-uvm/uvm_test_rng.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_test_rng.c
-> Installing: kernel/nvidia-uvm/uvm_range_tree_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_tree_test.c
-> Installing: kernel/nvidia-uvm/uvm_range_allocator_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_allocator_test.c
-> Installing: kernel/nvidia-uvm/uvm_gpu_semaphore_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_gpu_semaphore_test.c
-> Installing: kernel/nvidia-uvm/uvm_mem_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_mem_test.c
-> Installing: kernel/nvidia-uvm/uvm_rm_mem_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_rm_mem_test.c
-> Installing: kernel/nvidia-uvm/uvm_page_tree_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_page_tree_test.c
-> Installing: kernel/nvidia-uvm/uvm_tracker_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_tracker_test.c
-> Installing: kernel/nvidia-uvm/uvm_push_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_push_test.c
-> Installing: kernel/nvidia-uvm/uvm_channel_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_channel_test.c
-> Installing: kernel/nvidia-uvm/uvm_ce_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_ce_test.c
-> Installing: kernel/nvidia-uvm/uvm_host_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_host_test.c
-> Installing: kernel/nvidia-uvm/uvm_lock_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_lock_test.c
-> Installing: kernel/nvidia-uvm/uvm_perf_utils_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_utils_test.c
-> Installing: kernel/nvidia-uvm/uvm_kvmalloc_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_kvmalloc_test.c
-> Installing: kernel/nvidia-uvm/uvm_pmm_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_test.c
-> Installing: kernel/nvidia-uvm/uvm_pmm_sysmem_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_pmm_sysmem_test.c
-> Installing: kernel/nvidia-uvm/uvm_perf_events_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_events_test.c
-> Installing: kernel/nvidia-uvm/uvm_perf_module_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_perf_module_test.c
-> Installing: kernel/nvidia-uvm/uvm_get_rm_ptes_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_get_rm_ptes_test.c
-> Installing: kernel/nvidia-uvm/uvm_fault_buffer_flush_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_fault_buffer_flush_test.c
-> Installing: kernel/nvidia-uvm/uvm_mmu_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_mmu_test.c
-> Installing: kernel/nvidia-uvm/uvm_peer_identity_mappings_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_peer_identity_mappings_test.c
-> Installing: kernel/nvidia-uvm/uvm_va_block_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_va_block_test.c
-> Installing: kernel/nvidia-uvm/uvm_range_group_tree_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_range_group_tree_test.c
-> Installing: kernel/nvidia-uvm/uvm_thread_context_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_thread_context_test.c
-> Installing: kernel/nvidia-uvm/uvm_rb_tree_test.c --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_rb_tree_test.c
-> Installing: kernel/nvidia-uvm/uvm_test_ioctl.h --> /usr/src/nvidia-470.74/nvidia-uvm/uvm_test_ioctl.h
-> Installing: firmware/gsp.bin --> /lib/firmware/nvidia/470.74/gsp.bin
-> Installing: NVIDIA_Changelog --> /usr/share/doc/NVIDIA_GLX-1.0/NVIDIA_Changelog
-> Installing: LICENSE --> /usr/share/doc/NVIDIA_GLX-1.0/LICENSE
-> Installing: nvidia-bug-report.sh --> /usr/bin/nvidia-bug-report.sh
-> Installing: nvidia-installer.1.gz --> /usr/share/man/man1/nvidia-installer.1.gz
-> Installing: nvidia-installer --> /usr/bin/nvidia-installer
-> Installing: nvidia-modprobe --> /usr/bin/nvidia-modprobe
-> Installing: nvidia-modprobe.1.gz --> /usr/share/man/man1/nvidia-modprobe.1.gz
-> Installing: README.txt --> /usr/share/doc/NVIDIA_GLX-1.0/README.txt
-> Installing: supported-gpus/supported-gpus.json --> /usr/share/doc/NVIDIA_GLX-1.0/supported-gpus/supported-gpus.json
-> Installing: supported-gpus/LICENSE --> /usr/share/doc/NVIDIA_GLX-1.0/supported-gpus/LICENSE
-> Installing: systemd/system/nvidia-suspend.service --> /usr/lib/systemd/system/nvidia-suspend.service
-> Installing: systemd/system/nvidia-hibernate.service --> /usr/lib/systemd/system/nvidia-hibernate.service
-> Installing: systemd/system/nvidia-resume.service --> /usr/lib/systemd/system/nvidia-resume.service
-> Installing: systemd/system-sleep/nvidia --> /usr/lib/systemd/system-sleep/nvidia
-> Installing: systemd/nvidia-sleep.sh --> /usr/bin/nvidia-sleep.sh
-> Installing: libglvnd_install_checker/glvnd_check --> /usr/lib/nvidia/glvnd_check
-> Installing: libglvnd_install_checker/libGLX_installcheck.so.0 --> /usr/lib/nvidia/libGLX_installcheck.so.0
-> Installing: libglvnd_install_checker/egl_dummy_vendor.json --> /usr/lib/nvidia/egl_dummy_vendor.json
-> Installing: nvidia-smi --> /usr/bin/nvidia-smi
-> Installing: nvidia-smi.1.gz --> /usr/share/man/man1/nvidia-smi.1.gz
-> Installing: libnvidia-ml.so.470.74 --> /usr/lib64/libnvidia-ml.so.470.74
-> Installing: nvidia-debugdump --> /usr/bin/nvidia-debugdump
-> Installing: libcuda.so.470.74 --> /usr/lib64/libcuda.so.470.74
-> Installing: libnvidia-opencl.so.470.74 --> /usr/lib64/libnvidia-opencl.so.470.74
-> Installing: libOpenCL.so.1.0.0 --> /usr/lib64/libOpenCL.so.1.0.0
-> Installing: nvidia.icd --> /etc/OpenCL/vendors/nvidia.icd
-> Installing: nvidia-cuda-mps-control --> /usr/bin/nvidia-cuda-mps-control
-> Installing: nvidia-cuda-mps-server --> /usr/bin/nvidia-cuda-mps-server
-> Installing: nvidia-cuda-mps-control.1.gz --> /usr/share/man/man1/nvidia-cuda-mps-control.1.gz
-> Installing: libnvidia-ptxjitcompiler.so.470.74 --> /usr/lib64/libnvidia-ptxjitcompiler.so.470.74
-> Installing: libnvidia-nvvm.so.4.0.0 --> /usr/lib64/libnvidia-nvvm.so.4.0.0
-> Installing: nvidia-persistenced-init.tar.bz2 --> /usr/share/doc/NVIDIA_GLX-1.0/samples/nvidia-persistenced-init.tar.bz2
-> Installing: nvidia-persistenced.1.gz --> /usr/share/man/man1/nvidia-persistenced.1.gz
-> Installing: nvidia-persistenced --> /usr/bin/nvidia-persistenced
-> Installing: libnvidia-compiler.so.470.74 --> /usr/lib64/libnvidia-compiler.so.470.74
-> Installing: kernel/nvidia-peermem/nvidia-peermem.Kbuild --> /usr/src/nvidia-470.74/nvidia-peermem/nvidia-peermem.Kbuild
-> Installing: kernel/nvidia-peermem/nvidia-peermem.c --> /usr/src/nvidia-470.74/nvidia-peermem/nvidia-peermem.c
-> Installing: kernel/nvidia-peermem/peer_mem.h --> /usr/src/nvidia-470.74/nvidia-peermem/peer_mem.h
-> Installing: kernel/nvidia-peermem/nv-p2p.h --> /usr/src/nvidia-470.74/nvidia-peermem/nv-p2p.h
-> Installing: libnvidia-glcore.so.470.74 --> /usr/lib64/libnvidia-glcore.so.470.74
-> Installing: libnvidia-tls.so.470.74 --> /usr/lib64/libnvidia-tls.so.470.74
-> Installing: nvidia_icd.json --> /etc/vulkan/icd.d/nvidia_icd.json
-> Installing: nvidia_layers.json --> /etc/vulkan/implicit_layer.d/nvidia_layers.json
-> Installing: nvidia-application-profiles-470.74-rc --> /usr/share/nvidia/nvidia-application-profiles-470.74-rc
-> Installing: nvidia-application-profiles-470.74-key-documentation --> /usr/share/nvidia/nvidia-application-profiles-470.74-key-documentation
-> Installing: libGLX_nvidia.so.470.74 --> /usr/lib64/libGLX_nvidia.so.470.74
-> Installing: libnvidia-glsi.so.470.74 --> /usr/lib64/libnvidia-glsi.so.470.74
-> Installing: libnvidia-glvkspirv.so.470.74 --> /usr/lib64/libnvidia-glvkspirv.so.470.74
-> Installing: 10_nvidia.json --> /usr/share/glvnd/egl_vendor.d/10_nvidia.json
-> Installing: libglxserver_nvidia.so.470.74 --> /usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so.470.74
-> Installing: libnvidia-eglcore.so.470.74 --> /usr/lib64/libnvidia-eglcore.so.470.74
-> Installing: libEGL_nvidia.so.470.74 --> /usr/lib64/libEGL_nvidia.so.470.74
-> Installing: libGLESv2_nvidia.so.470.74 --> /usr/lib64/libGLESv2_nvidia.so.470.74
-> Installing: libGLESv1_CM_nvidia.so.470.74 --> /usr/lib64/libGLESv1_CM_nvidia.so.470.74
-> Installing: libnvidia-egl-wayland.so.1.1.7 --> /usr/lib64/libnvidia-egl-wayland.so.1.1.7
-> Installing: 10_nvidia_wayland.json --> /usr/share/egl/egl_external_platform.d/10_nvidia_wayland.json
-> Installing: libnvidia-vulkan-producer.so.470.74 --> /usr/lib64/libnvidia-vulkan-producer.so.470.74
-> Installing: nvidia_drv.so --> /usr/lib64/xorg/modules/drivers/nvidia_drv.so
-> Installing: nvidia-drm-outputclass.conf --> /usr/share/X11/xorg.conf.d/nvidia-drm-outputclass.conf
-> Installing: nvidia-settings.png --> /usr/share/doc/NVIDIA_GLX-1.0/nvidia-settings.png
-> Installing: nvidia-xconfig --> /usr/bin/nvidia-xconfig
-> Installing: nvidia-xconfig.1.gz --> /usr/share/man/man1/nvidia-xconfig.1.gz
-> Installing: nvidia-settings --> /usr/bin/nvidia-settings
-> Installing: libnvidia-gtk2.so.470.74 --> /usr/lib64/libnvidia-gtk2.so.470.74
-> Installing: libnvidia-gtk3.so.470.74 --> /usr/lib64/libnvidia-gtk3.so.470.74
-> Installing: nvidia-settings.1.gz --> /usr/share/man/man1/nvidia-settings.1.gz
-> Installing: libnvidia-cfg.so.470.74 --> /usr/lib64/libnvidia-cfg.so.470.74
-> Installing: libvdpau_nvidia.so.470.74 --> /usr/lib64/vdpau/libvdpau_nvidia.so.470.74
-> Installing: kernel/nvidia-modeset/nv-modeset-kernel.o_binary --> /usr/src/nvidia-470.74/nvidia-modeset/nv-modeset-kernel.o_binary
-> Installing: kernel/nvidia-modeset/nvidia-modeset.Kbuild --> /usr/src/nvidia-470.74/nvidia-modeset/nvidia-modeset.Kbuild
-> Installing: kernel/nvidia-modeset/nvidia-modeset-linux.c --> /usr/src/nvidia-470.74/nvidia-modeset/nvidia-modeset-linux.c
-> Installing: kernel/nvidia-modeset/nv-kthread-q.c --> /usr/src/nvidia-470.74/nvidia-modeset/nv-kthread-q.c
-> Installing: kernel/nvidia-modeset/nvidia-modeset-os-interface.h --> /usr/src/nvidia-470.74/nvidia-modeset/nvidia-modeset-os-interface.h
-> Installing: kernel/nvidia-modeset/nvkms.h --> /usr/src/nvidia-470.74/nvidia-modeset/nvkms.h
-> Installing: kernel/nvidia-modeset/nvkms-ioctl.h --> /usr/src/nvidia-470.74/nvidia-modeset/nvkms-ioctl.h
-> Installing: kernel/common/inc/nvkms-api-types.h --> /usr/src/nvidia-470.74/common/inc/nvkms-api-types.h
-> Installing: kernel/common/inc/nvkms-format.h --> /usr/src/nvidia-470.74/common/inc/nvkms-format.h
-> Installing: kernel/common/inc/nvkms-kapi.h --> /usr/src/nvidia-470.74/common/inc/nvkms-kapi.h
-> Installing: kernel/nvidia-drm/nvidia-drm.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm.c
-> Installing: kernel/nvidia-drm/nvidia-drm.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm.h
-> Installing: kernel/nvidia-drm/nvidia-drm-helper.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-helper.h
-> Installing: kernel/nvidia-drm/nvidia-dma-fence-helper.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-dma-fence-helper.h
-> Installing: kernel/nvidia-drm/nvidia-dma-resv-helper.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-dma-resv-helper.h
-> Installing: kernel/nvidia-drm/nvidia-drm-priv.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-priv.h
-> Installing: kernel/nvidia-drm/nvidia-drm-connector.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-connector.h
-> Installing: kernel/nvidia-drm/nvidia-drm-crtc.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-crtc.h
-> Installing: kernel/nvidia-drm/nvidia-drm-drv.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-drv.h
-> Installing: kernel/nvidia-drm/nvidia-drm-encoder.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-encoder.h
-> Installing: kernel/nvidia-drm/nvidia-drm-fb.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-fb.h
-> Installing: kernel/nvidia-drm/nvidia-drm-gem.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-gem.h
-> Installing: kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-gem-nvkms-memory.h
-> Installing: kernel/nvidia-drm/nvidia-drm-gem-user-memory.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-gem-user-memory.h
-> Installing: kernel/nvidia-drm/nvidia-drm-gem-dma-buf.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-gem-dma-buf.h
-> Installing: kernel/nvidia-drm/nvidia-drm-modeset.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-modeset.h
-> Installing: kernel/nvidia-drm/nvidia-drm-utils.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-utils.h
-> Installing: kernel/nvidia-drm/nvidia-drm-os-interface.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-os-interface.h
-> Installing: kernel/nvidia-drm/nvidia-drm-prime-fence.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-prime-fence.h
-> Installing: kernel/nvidia-drm/nvidia-drm-format.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-format.h
-> Installing: kernel/nvidia-drm/nvidia-drm-ioctl.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-ioctl.h
-> Installing: kernel/nvidia-drm/nvidia-drm-drv.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-drv.c
-> Installing: kernel/nvidia-drm/nvidia-drm-helper.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-helper.c
-> Installing: kernel/nvidia-drm/nvidia-drm-utils.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-utils.c
-> Installing: kernel/nvidia-drm/nvidia-drm-crtc.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-crtc.c
-> Installing: kernel/nvidia-drm/nvidia-drm-encoder.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-encoder.c
-> Installing: kernel/nvidia-drm/nvidia-drm-connector.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-connector.c
-> Installing: kernel/nvidia-drm/nvidia-drm-gem.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-gem.c
-> Installing: kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-gem-nvkms-memory.c
-> Installing: kernel/nvidia-drm/nvidia-drm-gem-user-memory.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-gem-user-memory.c
-> Installing: kernel/nvidia-drm/nvidia-drm-gem-dma-buf.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-gem-dma-buf.c
-> Installing: kernel/nvidia-drm/nvidia-drm-fb.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-fb.c
-> Installing: kernel/nvidia-drm/nvidia-drm-modeset.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-modeset.c
-> Installing: kernel/nvidia-drm/nvidia-drm-prime-fence.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-prime-fence.c
-> Installing: kernel/nvidia-drm/nvidia-drm-format.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-format.c
-> Installing: kernel/nvidia-drm/nvidia-drm.Kbuild --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm.Kbuild
-> Installing: kernel/nvidia-drm/nvidia-drm-conftest.h --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-conftest.h
-> Installing: kernel/nvidia-drm/nvidia-drm-linux.c --> /usr/src/nvidia-470.74/nvidia-drm/nvidia-drm-linux.c
-> Installing: kernel/nvidia-drm/nv-pci-table.c --> /usr/src/nvidia-470.74/nvidia-drm/nv-pci-table.c
-> Installing: kernel/nvidia-drm/nv-pci-table.h --> /usr/src/nvidia-470.74/nvidia-drm/nv-pci-table.h
-> Installing: libnvidia-allocator.so.470.74 --> /usr/lib64/libnvidia-allocator.so.470.74
-> Installing: libnvidia-rtcore.so.470.74 --> /usr/lib64/libnvidia-rtcore.so.470.74
-> Installing: libnvidia-cbl.so.470.74 --> /usr/lib64/libnvidia-cbl.so.470.74
-> Installing: libnvoptix.so.470.74 --> /usr/lib64/libnvoptix.so.470.74
-> Installing: libnvidia-ngx.so.470.74 --> /usr/lib64/libnvidia-ngx.so.470.74
-> Installing: nvidia-ngx-updater --> /usr/bin/nvidia-ngx-updater
-> Installing: libnvidia-ifr.so.470.74 --> /usr/lib64/libnvidia-ifr.so.470.74
-> Installing: libnvidia-fbc.so.470.74 --> /usr/lib64/libnvidia-fbc.so.470.74
-> Installing: libnvcuvid.so.470.74 --> /usr/lib64/libnvcuvid.so.470.74
-> Installing: libnvidia-encode.so.470.74 --> /usr/lib64/libnvidia-encode.so.470.74
-> Installing: libnvidia-opticalflow.so.470.74 --> /usr/lib64/libnvidia-opticalflow.so.470.74
-> Installing: html/acknowledgements.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/acknowledgements.html
-> Installing: html/addressingcapabilities.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/addressingcapabilities.html
-> Installing: html/addtlresources.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/addtlresources.html
-> Installing: html/appendices.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/appendices.html
-> Installing: html/audiosupport.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/audiosupport.html
-> Installing: html/commonproblems.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/commonproblems.html
-> Installing: html/configlaptop.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/configlaptop.html
-> Installing: html/configmultxscreens.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/configmultxscreens.html
-> Installing: html/configtwinview.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/configtwinview.html
-> Installing: html/depth30.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/depth30.html
-> Installing: html/displaydevicenames.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/displaydevicenames.html
-> Installing: html/egpu.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/egpu.html
-> Installing: html/gpunames.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/gpunames.html
-> Installing: html/dma_issues.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/dma_issues.html
-> Installing: html/dpi.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/dpi.html
-> Installing: html/editxconfig.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/editxconfig.html
-> Installing: html/faq.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/faq.html
-> Installing: html/flippingubb.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/flippingubb.html
-> Installing: html/framelock.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/framelock.html
-> Installing: html/glxsupport.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/glxsupport.html
-> Installing: html/i2c.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/i2c.html
-> Installing: html/index.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/index.html
-> Installing: html/installationandconfiguration.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/installationandconfiguration.html
-> Installing: html/installdriver.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/installdriver.html
-> Installing: html/installedcomponents.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/installedcomponents.html
-> Installing: html/introduction.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/introduction.html
-> Installing: html/kms.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/kms.html
-> Installing: html/knownissues.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/knownissues.html
-> Installing: html/minimumrequirements.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/minimumrequirements.html
-> Installing: html/newusertips.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/newusertips.html
-> Installing: html/nvidia-debugdump.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/nvidia-debugdump.html
-> Installing: html/nvidia-ml.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/nvidia-ml.html
-> Installing: html/nvidia-peermem.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/nvidia-peermem.html
-> Installing: html/nvidia-persistenced.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/nvidia-persistenced.html
-> Installing: html/gsp.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/gsp.html
-> Installing: html/nvidia-smi.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/nvidia-smi.html
-> Installing: html/nvidiasettings.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/nvidiasettings.html
-> Installing: html/ngx.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/ngx.html
-> Installing: html/retpoline.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/retpoline.html
-> Installing: html/openglenvvariables.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/openglenvvariables.html
-> Installing: html/optimus.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/optimus.html
-> Installing: html/powermanagement.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/powermanagement.html
-> Installing: html/dynamicpowermanagement.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/dynamicpowermanagement.html
-> Installing: html/procinterface.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/procinterface.html
-> Installing: html/profiles.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/profiles.html
-> Installing: html/programmingmodes.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/programmingmodes.html
-> Installing: html/randr14.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/randr14.html
-> Installing: html/primerenderoffload.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/primerenderoffload.html
-> Installing: html/selectdriver.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/selectdriver.html
-> Installing: html/sli.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/sli.html
-> Installing: html/supportedchips.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/supportedchips.html
-> Installing: html/vdpausupport.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/vdpausupport.html
-> Installing: html/xcompositeextension.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/xcompositeextension.html
-> Installing: html/xconfigoptions.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/xconfigoptions.html
-> Installing: html/xineramaglx.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/xineramaglx.html
-> Installing: html/xrandrextension.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/xrandrextension.html
-> Installing: html/xwayland.html --> /usr/share/doc/NVIDIA_GLX-1.0/html/xwayland.html
-> Installing: /tmp/template-YmcxFl --> /usr/src/nvidia-470.74/dkms.conf
-> Deleting: /tmp/template-YmcxFl
-> Installing: /tmp/template-o2twPk --> /usr/share/applications/nvidia-settings.desktop
-> Deleting: /tmp/template-o2twPk
-> Creating symlink: /usr/bin/nvidia-uninstall -> nvidia-installer
-> Creating symlink: /etc/systemd/system/systemd-suspend.service.requires/nvidia-suspend.service -> /usr/lib/systemd/system/nvidia-suspend.service
-> Creating symlink: /etc/systemd/system/systemd-hibernate.service.requires/nvidia-hibernate.service -> /usr/lib/systemd/system/nvidia-hibernate.service
-> Creating symlink: /etc/systemd/system/systemd-suspend.service.requires/nvidia-resume.service -> /usr/lib/systemd/system/nvidia-resume.service
-> Creating symlink: /etc/systemd/system/systemd-hibernate.service.requires/nvidia-resume.service -> /usr/lib/systemd/system/nvidia-resume.service
-> Creating symlink: /usr/lib64/libnvidia-ml.so.1 -> libnvidia-ml.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-ml.so -> libnvidia-ml.so.1
-> Creating symlink: /usr/lib64/libcuda.so.1 -> libcuda.so.470.74
-> Creating symlink: /usr/lib64/libcuda.so -> libcuda.so.1
-> Creating symlink: /usr/lib64/libnvidia-opencl.so.1 -> libnvidia-opencl.so.470.74
-> Creating symlink: /usr/lib64/libOpenCL.so.1.0 -> libOpenCL.so.1.0.0
-> Creating symlink: /usr/lib64/libOpenCL.so.1 -> libOpenCL.so.1.0
-> Creating symlink: /usr/lib64/libOpenCL.so -> libOpenCL.so.1
-> Creating symlink: /usr/lib64/libnvidia-ptxjitcompiler.so.1 -> libnvidia-ptxjitcompiler.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-ptxjitcompiler.so -> libnvidia-ptxjitcompiler.so.1
-> Creating symlink: /usr/lib64/libnvidia-nvvm.so.4 -> libnvidia-nvvm.so.4.0.0
-> Creating symlink: /usr/lib64/libnvidia-nvvm.so -> libnvidia-nvvm.so.4
-> Creating symlink: /usr/lib64/libGLX_nvidia.so.0 -> libGLX_nvidia.so.470.74
-> Creating symlink: /usr/lib64/libGLX_indirect.so.0 -> libGLX_nvidia.so.470.74
-> Creating symlink: /usr/lib64/xorg/modules/extensions/libglxserver_nvidia.so -> libglxserver_nvidia.so.470.74
-> Creating symlink: /usr/lib64/libEGL_nvidia.so.0 -> libEGL_nvidia.so.470.74
-> Creating symlink: /usr/lib64/libGLESv2_nvidia.so.2 -> libGLESv2_nvidia.so.470.74
-> Creating symlink: /usr/lib64/libGLESv1_CM_nvidia.so.1 -> libGLESv1_CM_nvidia.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-vulkan-producer.so -> libnvidia-vulkan-producer.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-cfg.so.1 -> libnvidia-cfg.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-cfg.so -> libnvidia-cfg.so.1
-> Creating symlink: /usr/lib64/vdpau/libvdpau_nvidia.so.1 -> libvdpau_nvidia.so.470.74
-> Creating symlink: /usr/lib64/libvdpau_nvidia.so -> vdpau/libvdpau_nvidia.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-allocator.so.1 -> libnvidia-allocator.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-allocator.so -> libnvidia-allocator.so.1
-> Creating symlink: /usr/lib64/libnvoptix.so.1 -> libnvoptix.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-ifr.so.1 -> libnvidia-ifr.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-ifr.so -> libnvidia-ifr.so.1
-> Creating symlink: /usr/lib64/libnvidia-fbc.so.1 -> libnvidia-fbc.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-fbc.so -> libnvidia-fbc.so.1
-> Creating symlink: /usr/lib64/libnvcuvid.so.1 -> libnvcuvid.so.470.74
-> Creating symlink: /usr/lib64/libnvcuvid.so -> libnvcuvid.so.1
-> Creating symlink: /usr/lib64/libnvidia-encode.so.1 -> libnvidia-encode.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-encode.so -> libnvidia-encode.so.1
-> Creating symlink: /usr/lib64/libnvidia-opticalflow.so.1 -> libnvidia-opticalflow.so.470.74
-> Creating symlink: /usr/lib64/libnvidia-opticalflow.so -> libnvidia-opticalflow.so.1
-> Creating symlink: /usr/lib/libGL.so.1 -> /usr/lib64/libGL.so.1
-> Executing: /usr/sbin/ldconfig
executing: '/usr/sbin/ldconfig'...
-> Executing: /usr/bin/systemctl daemon-reload
executing: '/usr/bin/systemctl daemon-reload'...
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
-> done.
ERROR: Unable to load the 'nvidia-drm' kernel module: 'modprobe: ERROR: could not insert 'nvidia_drm': Exec format error'
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
where, after build^,
tree /var/lib/dkms/
/var/lib/dkms/
├── dkms_dbversion
└── nvidia
├── 470.74
│ ├── 5.14.13-200.fc34.x86_64
│ │ └── x86_64
│ │ ├── log
│ │ │ └── make.log
│ │ └── module
│ │ ├── nvidia-drm.ko.xz
│ │ ├── nvidia.ko.xz
│ │ ├── nvidia-modeset.ko.xz
│ │ ├── nvidia-peermem.ko.xz
│ │ └── nvidia-uvm.ko.xz
│ └── source -> /usr/src/nvidia-470.74
└── kernel-5.14.13-200.fc34.x86_64-x86_64 -> 470.74/5.14.13-200.fc34.x86_64/x86_64
8 directories, 7 files
modprobe -vvv nvidia
modprobe: INFO: custom logging function 0x55e8641dd840 registered
insmod /lib/modules/5.14.13-200.fc34.x86_64/extra/nvidia.ko.xz
modprobe: INFO: Failed to insert module '/lib/modules/5.14.13-200.fc34.x86_64/extra/nvidia.ko.xz': Exec format error
modprobe: ERROR: could not insert 'nvidia': Exec format error
modprobe: INFO: context 0x55e8652d0770 released
modprobe -vvv nvidia-drm
modprobe: INFO: custom logging function 0x56341cdab840 registered
modprobe: INFO: context 0x56341d166770 released
insmod ./nvidia-drm.ko.xz
insmod: ERROR: could not insert module ./nvidia-drm.ko.xz: Unknown symbol in module
insmod ./nvidia-modeset.ko.xz
insmod: ERROR: could not insert module ./nvidia-modeset.ko.xz: Unknown symbol in module
dmesg |egrep -i "\] nvi"
[ 5.929963] nvidia: loading out-of-tree module taints kernel.
[ 5.929973] nvidia: module license 'NVIDIA' taints kernel.
[ 5.934258] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2198.046755] nvidia_drm: Unknown symbol nvKmsKapiGetFunctionsTable (err -2)
[ 5421.415304] nvidia_modeset: Unknown symbol nvidia_register_module (err -2)
[ 5421.415331] nvidia_modeset: Unknown symbol nvidia_get_rm_ops (err -2)
[ 5421.415352] nvidia_modeset: Unknown symbol nvidia_unregister_module (err -2)
[ 5432.205654] nvidia_drm: Unknown symbol nvKmsKapiGetFunctionsTable (err -2)
and
modinfo ./nvidia-drm.ko.xz
filename: /var/lib/dkms/nvidia/470.74/5.14.13-200.fc34.x86_64/x86_64/module/./nvidia-drm.ko.xz
version: 470.74
supported: external
license: MIT
srcversion: CBB4EE4C99F37AD0FDDB887
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends: drm,drm_kms_helper,nvidia-modeset
retpoline: Y
vermagic: 5.14.13-200.fc34.x86_64 SMP mod_unload
parm: modeset:Enable atomic kernel modesetting (1 = enable, 0 = disable (default)) (bool)
modinfo ./nvidia-modeset.ko.xz
filename: /var/lib/dkms/nvidia/470.74/5.14.13-200.fc34.x86_64/x86_64/module/./nvidia-modeset.ko.xz
version: 470.74
supported: external
license: NVIDIA
srcversion: 537F6235ECD9587A501B512
depends: nvidia
retpoline: Y
parm: fail_malloc:Fail the Nth call to nvkms_alloc (int)
parm: malloc_verbose:Report information about malloc calls on module unload (bool)
modinfo ./nvidia.ko.xz
filename: /var/lib/dkms/nvidia/470.74/5.14.13-200.fc34.x86_64/x86_64/module/./nvidia.ko.xz
firmware: nvidia/470.74/gsp.bin
alias: char-major-195-*
version: 470.74
supported: external
license: NVIDIA
srcversion: 94BFCF260310458AAFE84C5
depends: drm
retpoline: Y
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_EnableS0ixPowerManagement:int
parm: NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableGpuFirmware:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_ExcludedGpus:charp
parm: rm_firmware_active:charp
uname -r
