I’ve posted here (https://forums.geforce.com/default/topic/1101187/geforce-drivers/error-unable-to-load-the-nvidia-drm-kernel-module-centos-7-x86_64-version-396-54) but I was recommended to post in this forum instead.
We’ve been having a problem with installing Nvidia drivers for some time now (several versions). Here’s an example:
$ curl http://download.nvidia.com/XFree86/Linux-x86_64/396.54/NVIDIA-Linux-x86_64-396.54.run > nvidia.bin
$ chmod a+rx nvidia.bin
$ ./nvidia.bin -a -q -s -X -Z -z --no-x-check --dkms
Verifying archive integrity... OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86_64 396.54..................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
WARNING: Unable to determine the path to install the libglvnd EGL vendor
library config files. Check that you have pkg-config and the
libglvnd development libraries installed, or specify a path with
--glvnd-egl-config-path.
ERROR: Unable to load the 'nvidia-drm' kernel module.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find
suggestions on fixing installation problems in the README available
on the Linux driver download page at www.nvidia.com.
I paste here the entire nvidia-installer.log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue Mar 5 12:53:22 2019
installer version: 396.54
PATH: <snip>
nvidia-installer command line:
./nvidia-installer
-a
-q
-s
-X
-Z
-z
--no-x-check
--dkms
Using built-in stream user interface
-> Detected 16 CPUs online; setting concurrency level to 16.
-> Tagging shared libraries with chcon -t textrel_shlib_t.
-> Installing NVIDIA driver version 396.54.
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes)
-> Will install GLVND GLX client libraries.
-> Will install GLVND EGL client libraries.
-> Skipping GLX non-GLVND file: "libGL.so.396.54"
-> Skipping GLX non-GLVND file: "libGL.so.1"
-> Skipping GLX non-GLVND file: "libGL.so"
-> Skipping EGL non-GLVND file: "libEGL.so.396.54"
-> Skipping EGL non-GLVND file: "libEGL.so"
-> Skipping EGL non-GLVND file: "libEGL.so.1"
-> Skipping GLX non-GLVND file: "./32/libGL.so.396.54"
-> Skipping EGL non-GLVND file: "./32/libEGL.so.396.54"
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
Checking for libglvnd installation.
Checking libGLdispatch...
Checking libGLdispatch dispatch table
Checking call through libGLdispatch
All OK
libGLdispatch is OK
Checking for libGLX
libGLX is OK
Checking for libEGL
libEGL is OK
Checking entrypoint library libOpenGL.so.0
Checking call through library libOpenGL.so.0
dlopen("libOpenGL.so.0") failed: libOpenGL.so.0: cannot open shared object file: No such file or directory
Checking entrypoint library libGL.so.1
Checking call through library libGL.so.1
All OK
Entrypoint library libGL.so.1 is OK
Found libglvnd libraries: libGL.so.1 libEGL.so.1 libGLX.so.0 libGLdispatch.so.0
Missing libglvnd libraries: libOpenGL.so.0
-> An incomplete installation of libglvnd was found. All of the essential libglvnd libraries are present, but one or more optional components are missing. Do you want to install a full copy of libglvnd? This will overwrite any existing libglvnd libraries. (Answer: Don't install libglvnd files)
Will not install libglvnd libraries.
-> Skipping GLVND file: "libOpenGL.so.0"
-> Skipping GLVND file: "libOpenGL.so"
-> Skipping GLVND file: "libGLESv1_CM.so.1.2.0"
-> Skipping GLVND file: "libGLESv1_CM.so.1"
-> Skipping GLVND file: "libGLESv1_CM.so"
-> Skipping GLVND file: "libGLESv2.so.2.1.0"
-> Skipping GLVND file: "libGLESv2.so.2"
-> Skipping GLVND file: "libGLESv2.so"
-> Skipping GLVND file: "libGLdispatch.so.0"
-> Skipping GLVND file: "libGLX.so.0"
-> Skipping GLVND file: "libGLX.so"
-> Skipping GLVND file: "libGL.so.1.7.0"
-> Skipping GLVND file: "libGL.so.1"
-> Skipping GLVND file: "libGL.so"
-> Skipping GLVND file: "libEGL.so.1.1.0"
-> Skipping GLVND file: "libEGL.so.1"
-> Skipping GLVND file: "libEGL.so"
-> Skipping GLVND file: "./32/libOpenGL.so.0"
-> Skipping GLVND file: "./32/libGLdispatch.so.0"
-> Skipping GLVND file: "./32/libGLESv2.so.2.1.0"
-> Skipping GLVND file: "./32/libGLESv1_CM.so.1.2.0"
-> Skipping GLVND file: "./32/libGL.so.1.7.0"
-> Skipping GLVND file: "./32/libGLX.so.0"
-> Skipping GLVND file: "./32/libEGL.so.1.1.0"
WARNING: Unable to determine the path to install the libglvnd EGL vendor library config files. Check that you have pkg-config and the libglvnd development libraries installed, or specify a path with --glvnd-egl-config-path.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (396.54):
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glcore.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/extensions/libglx.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-tls.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/tls/libnvidia-tls.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLX_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glvkspirv.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/drivers/nvidia_drv.so'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/libnvidia-wfb.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk2.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-gtk3.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-cfg.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ml.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/vdpau/libvdpau_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libcuda.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-opencl.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libOpenCL.so.1.0.0'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fatbinaryloader.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ptxjitcompiler.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvcuvid.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-encode.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ifr.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-fbc.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-compiler.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-eglcore.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glsi.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libEGL_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv2_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libGLESv1_CM_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-egl-wayland.so.1.0.3'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libcuda.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fatbinaryloader.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ptxjitcompiler.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ml.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libOpenCL.so.1.0.0'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-compiler.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-opencl.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLX_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glcore.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-tls.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/tls/libnvidia-tls.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glvkspirv.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/vdpau/libvdpau_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvcuvid.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-encode.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-eglcore.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glsi.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libEGL_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv2_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libGLESv1_CM_nvidia.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ifr.so.396.54'...
executing: '/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-fbc.so.396.54'...
executing: '/sbin/ldconfig'...
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
-> done.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
After reboot, the GPUs work fine, even with this error. Do you have any insight on how to solve it? I’ve looked into http://download.nvidia.com/XFree86/Linux-x86_64/396.54/README/knownissues.html but I could not find anything related with this error.
Thank you,
João
