Dear All,
Could you guide me how to install NVIDIA-Linux-x86_64-384.98 on Red Hat 7.4 ?
It always show Error: "Unable to load the kernel module ‘nvidia.ko’. This happens most
frequently when this kernel module was built against the wrong or
improperly configured kernel sources, with a version of gcc that
differs from the one used to build the target kernel, or if a driver
such as rivafb, nvidiafb, or nouveau is present and prevents the
NVIDIA kernel module from obtaining ownership of the NVIDIA graphics
device(s), or no NVIDIA GPU installed in this system is supported by
this NVIDIA Linux graphics driver release.
Please see the log entries 'Kernel module load error' and 'Kernel
messages' at the end of the file '/var/log/nvidia-installer.log' for
more information.
TH
generix
December 13, 2017, 10:46am
2
Please attach the file /var/log/nvidia-installer.log to your post.
Or run nvidia-bug-report.sh and attach the tar.gz file it creates.
HI Generix,
Here is log ifle:
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Thu Dec 14 02:27:48 2017
installer version: 384.98
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 12 CPUs online; setting concurrency level to 12.
→ Tagging shared libraries with chcon -t textrel_shlib_t.
→ License accepted.
→ Installing NVIDIA driver version 384.98.
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/3.10.0-693.el7.x86_64.debug/source’
→ Kernel output path: ‘/lib/modules/3.10.0-693.el7.x86_64.debug/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j12 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.10.0-693.el7.x86_64.debug/source” SYSOUT=“/lib/modules/3.10.0-693.el7.x86_64.debug/build”’…
rm -f -r conftest
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/3.10.0-693.el7.x86_64.debug/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-693.el7.x86_64.debug/source M=/tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-693.el7.x86_64.debug/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-693.el7.x86_64.debug/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory /usr/src/kernels/3.10.0-693.el7.x86_64.debug' /usr/bin/make -C /lib/modules/3.10.0-693.el7.x86_64.debug/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-693.el7.x86_64.debug \ KBUILD_EXTMOD="/tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel" -f /usr/src/kernels/3.10.0-693.el7.x86_64.debug/Makefile \ clean make[1]: Leaving directory /usr/src/kernels/3.10.0-693.el7.x86_64.debug’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j12 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.10.0-693.el7.x86_64.debug/source” SYSOUT=“/lib/modules/3.10.0-693.el7.x86_64.debug/build”’…
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/3.10.0-693.el7.x86_64.debug/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-693.el7.x86_64.debug/source M=/tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-693.el7.x86_64.debug/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-693.el7.x86_64.debug/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
make[1]: Entering directory /usr/src/kernels/3.10.0-693.el7.x86_64.debug' /usr/bin/make -C /lib/modules/3.10.0-693.el7.x86_64.debug/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-693.el7.x86_64.debug \ KBUILD_EXTMOD="/tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel" -f /usr/src/kernels/3.10.0-693.el7.x86_64.debug/Makefile \ modules SYMLINK /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset/nv-modeset-kernel.o SYMLINK /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kernel.o CONFTEST: INIT_WORK CONFTEST: remap_pfn_range CONFTEST: follow_pfn CONFTEST: hash__remap_4k_pfn CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: console_lock CONFTEST: kmem_cache_create CONFTEST: on_each_cpu CONFTEST: smp_call_function CONFTEST: acpi_evaluate_integer CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_get_property CONFTEST: of_find_node_by_phandle CONFTEST: of_node_to_nid CONFTEST: pnv_pci_get_npu_dev CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: pci_stop_and_remove_bus_device CONFTEST: pci_remove_bus_device CONFTEST: request_threaded_irq CONFTEST: register_cpu_notifier CONFTEST: cpuhp_setup_state CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: radix_tree_empty CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: drm_atomic_state_free CONFTEST: drm_driver_has_gem_prime_res_obj CONFTEST: is_export_symbol_gpl_of_node_to_nid CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: vm_fault_present CONFTEST: vm_fault_has_address CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: mm_context_t CONFTEST: vm_ops_fault_removed_vma_arg CONFTEST: pnv_npu2_init_context CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_driver_has_set_busid CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_function_args CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_helper_mode_fill_fb_struct CONFTEST: drm_master_drop_has_from_release_arg CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc CONFTEST: drm_driver_unload_has_int_return_type CONFTEST: drm_crtc_helper_funcs_has_atomic_enable CONFTEST: dom0_kernel_present CONFTEST: nvidia_vgpu_kvm_build CONFTEST: nvidia_grid_build CONFTEST: drm_available CONFTEST: drm_atomic_available CONFTEST: drm_atomic_modeset_nonblocking_commit_available CONFTEST: is_export_symbol_gpl_refcount_inc CONFTEST: is_export_symbol_gpl_refcount_dec_and_test CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-drv.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-utils.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-crtc.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-encoder.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-connector.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-gem.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-fb.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-modeset.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-linux.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-helper.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-prime-fence.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nv-pci-table.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset/nvidia-modeset-linux.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_volta_host.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_volta.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_access_counters.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm_utils.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm_common.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm_linux.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/nvstatus.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_tools.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_global.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_isr.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_procfs.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_va_space.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_mem.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_rm_mem.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_channel.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_lock.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_hal.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_tree.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_allocator.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_va_range.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_va_block.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_group.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_events.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_module.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_mmu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pte_batch.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_tlb_batch.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_push.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pushbuffer.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_thread_context.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_tracker.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kepler.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kepler_ce.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kepler_host.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kepler_mmu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_maxwell.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_maxwell_host.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal_ce.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal_host.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal_mmu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_policy.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_utils.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kvmalloc.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pmm_gpu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_migrate.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_map_external.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_user_channel.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_hmm.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_heuristics.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_thrashing.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_prefetch.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_test_rng.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_tree_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_allocator_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_mem_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_rm_mem_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_page_tree_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_tracker_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_push_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_channel_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_ce_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_lock_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_utils_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kvmalloc_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pmm_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_events_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_module_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_mmu_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_va_block_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_group_tree_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-frontend.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-instance.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gpu-numa.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-acpi.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-chrdev.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-cray.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-dma.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gvi.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-i2c.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mempool.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mmap.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-p2p.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-procfs.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pat.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-usermap.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vm.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vtophys.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-interface.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-mlock.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-pci.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-registry.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-usermap.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-modeset-interface.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pci-table.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q-selftest.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-memdbg.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-report-err.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv_uvm_interface.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nvlink_linux.o ld -r -o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset/nvidia-modeset-linux.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset.o ld -r -o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-frontend.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-instance.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-acpi.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-chrdev.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-cray.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-dma.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gvi.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-i2c.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mempool.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mmap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidi a/nv-p2p.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pat.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-procfs.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-usermap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vm.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vtophys.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-mlock.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-pci.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-registry.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-usermap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pci-table.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q-selftest.o /tmp/se lfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-memdbg.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-report-err.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nvlink_linux.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm.o Building modules, stage 2. MODPOST 4 modules FATAL: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol 'lockdep_init_map' make[3]: *** [__modpost] Error 1 make[3]: Target _modpost’ not remade because of errors.
make[2]: *** [modules] Error 2
make[1]: *** [sub-make] Error 2
make[1]: Target modules' not remade because of errors. make[1]: Leaving directory /usr/src/kernels/3.10.0-693.el7.x86_64.debug’
make: *** [modules] Error 2
→ Error.
ERROR: An error occurred while performing the step: “Building kernel modules”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j12 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/3.10.0-693.el7.x86_64.debug/source" SYSOUT="/lib/modules/3.10.0-693.el7.x86_64.debug/build" failed with the following output:
make[1]: Entering directory /usr/src/kernels/3.10.0-693.el7.x86_64.debug' /usr/bin/make -C /lib/modules/3.10.0-693.el7.x86_64.debug/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-693.el7.x86_64.debug \ KBUILD_EXTMOD="/tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel" -f /usr/src/kernels/3.10.0-693.el7.x86_64.debug/Makefile \ modules SYMLINK /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset/nv-modeset-kernel.o SYMLINK /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kernel.o CONFTEST: INIT_WORK CONFTEST: remap_pfn_range CONFTEST: follow_pfn CONFTEST: hash__remap_4k_pfn CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: console_lock CONFTEST: kmem_cache_create CONFTEST: on_each_cpu CONFTEST: smp_call_function CONFTEST: acpi_evaluate_integer CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_get_property CONFTEST: of_find_node_by_phandle CONFTEST: of_node_to_nid CONFTEST: pnv_pci_get_npu_dev CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: pci_stop_and_remove_bus_device CONFTEST: pci_remove_bus_device CONFTEST: request_threaded_irq CONFTEST: register_cpu_notifier CONFTEST: cpuhp_setup_state CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: radix_tree_empty CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: drm_atomic_state_free CONFTEST: drm_driver_has_gem_prime_res_obj CONFTEST: is_export_symbol_gpl_of_node_to_nid CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: vm_fault_present CONFTEST: vm_fault_has_address CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: mm_context_t CONFTEST: vm_ops_fault_removed_vma_arg CONFTEST: pnv_npu2_init_context CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_driver_has_set_busid CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_function_args CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_helper_mode_fill_fb_struct CONFTEST: drm_master_drop_has_from_release_arg CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc CONFTEST: drm_driver_unload_has_int_return_type CONFTEST: drm_crtc_helper_funcs_has_atomic_enable CONFTEST: dom0_kernel_present CONFTEST: nvidia_vgpu_kvm_build CONFTEST: nvidia_grid_build CONFTEST: drm_available CONFTEST: drm_atomic_available CONFTEST: drm_atomic_modeset_nonblocking_commit_available CONFTEST: is_export_symbol_gpl_refcount_inc CONFTEST: is_export_symbol_gpl_refcount_dec_and_test CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-drv.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-utils.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-crtc.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-encoder.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-connector.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-gem.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-fb.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-modeset.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-linux.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-helper.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nvidia-drm-prime-fence.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm/nv-pci-table.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset/nvidia-modeset-linux.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_volta_host.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_volta.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_access_counters.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm_utils.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm_common.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm_linux.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/nvstatus.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_tools.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_global.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_isr.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_procfs.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_va_space.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_mem.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_rm_mem.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_channel.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_lock.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_hal.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_tree.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_allocator.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_va_range.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_va_block.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_group.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_events.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_module.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_mmu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pte_batch.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_tlb_batch.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_push.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pushbuffer.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_thread_context.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_tracker.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kepler.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kepler_ce.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kepler_host.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kepler_mmu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_maxwell.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_maxwell_host.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal_ce.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal_host.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal_mmu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_policy.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_utils.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kvmalloc.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pmm_gpu.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_migrate.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_map_external.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_user_channel.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_hmm.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_heuristics.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_thrashing.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_prefetch.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_test_rng.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_tree_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_allocator_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_mem_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_rm_mem_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_page_tree_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_tracker_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_push_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_channel_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_ce_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_lock_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_utils_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_kvmalloc_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_pmm_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_events_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_perf_module_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_mmu_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_va_block_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm/uvm8_range_group_tree_test.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-frontend.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-instance.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gpu-numa.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-acpi.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-chrdev.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-cray.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-dma.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gvi.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-i2c.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mempool.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mmap.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-p2p.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-procfs.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pat.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-usermap.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vm.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vtophys.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-interface.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-mlock.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-pci.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-registry.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-usermap.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-modeset-interface.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pci-table.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q-selftest.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-memdbg.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-report-err.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv_uvm_interface.o CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nvlink_linux.o ld -r -o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset/nvidia-modeset-linux.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-uvm.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-modeset.o ld -r -o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-frontend.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-instance.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-acpi.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-chrdev.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-cray.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-dma.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gvi.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-i2c.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mempool.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mmap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-p2p.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pat.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-procfs.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-usermap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vm.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vtophys.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-mlock.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-pci.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-registry.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-usermap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pci-table.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-memdbg.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-report-err.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nvlink_linux.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia-drm.o Building modules, stage 2. MODPOST 4 modules FATAL: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol 'lockdep_init_map' make[3]: *** [__modpost] Error 1 make[3]: Target _modpost’ not remade because of errors.
→ Checking to see whether the nvidia kernel module was successfully built
executing: ‘cd ./kernel; /usr/bin/make -k -j12 NV_KERNEL_MODULES=“nvidia” NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.10.0-693.el7.x86_64.debug/source” SYSOUT=“/lib/modules/3.10.0-693.el7.x86_64.debug/build”’…
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/3.10.0-693.el7.x86_64.debug/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-693.el7.x86_64.debug/source M=/tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-693.el7.x86_64.debug/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-693.el7.x86_64.debug/build NV_KERNEL_MODULES=“nvidia” INSTALL_MOD_DIR=kernel/drivers/video modules
make[1]: Entering directory /usr/src/kernels/3.10.0-693.el7.x86_64.debug' /usr/bin/make -C /lib/modules/3.10.0-693.el7.x86_64.debug/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-693.el7.x86_64.debug \ KBUILD_EXTMOD="/tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel" -f /usr/src/kernels/3.10.0-693.el7.x86_64.debug/Makefile \ modules CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pci-table.o ld -r -o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-frontend.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-instance.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-acpi.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-chrdev.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-cray.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-dma.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gvi.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-i2c.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mempool.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mmap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-p2p.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pat.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-procfs.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-usermap.o /tmp/selfgz21505/NVIDIA-Linux-x8 6_64-384.98/kernel/nvidia/nv-vm.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vtophys.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-mlock.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-pci.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-registry.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-usermap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pci-table.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-memdbg.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-report-err.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64- 384.98/kernel/nvidia/nvlink_linux.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia.o Building modules, stage 2. MODPOST 1 modules FATAL: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol 'lockdep_init_map' make[3]: *** [__modpost] Error 1 make[3]: Target _modpost’ not remade because of errors.
→ Error.
ERROR: An error occurred while performing the step: “Checking to see whether the nvidia kernel module was successfully built”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j12 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/3.10.0-693.el7.x86_64.debug/source" SYSOUT="/lib/modules/3.10.0-693.el7.x86_64.debug/build" failed with the following output:
make[1]: Entering directory /usr/src/kernels/3.10.0-693.el7.x86_64.debug' /usr/bin/make -C /lib/modules/3.10.0-693.el7.x86_64.debug/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-693.el7.x86_64.debug \ KBUILD_EXTMOD="/tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel" -f /usr/src/kernels/3.10.0-693.el7.x86_64.debug/Makefile \ modules CC [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pci-table.o ld -r -o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-frontend.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-instance.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-acpi.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-chrdev.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-cray.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-dma.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-gvi.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-i2c.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mempool.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-mmap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-p2p.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pat.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-procfs.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-usermap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vm.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-vtophys.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-mlock.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-pci.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-registry.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/os-usermap.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-pci-table.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-memdbg.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv-report-err.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia/nvlink_linux.o LD [M] /tmp/selfgz21505/NVIDIA-Linux-x86_64-384.98/kernel/nvidia.o Building modules, stage 2. MODPOST 1 modules FATAL: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol 'lockdep_init_map' make[3]: *** [__modpost] Error 1 make[3]: Target _modpost’ not remade because of errors.
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com .
generix
December 14, 2017, 8:42am
4
You will have to install a nodebug kernel as the debug kernel you’re running now is incompatible regarding licenses with the closed source nvidia driver.
Hi generix,
Could you guide me how to run nodebug kernel?
TH
generix
December 14, 2017, 9:28am
6
Not really. I can only give you hints.
See what other kernels are installed
rpm -qa | grep kernel | sort
The debug kernels are those ending with .debug, your current default is 3.10.0-693.el7.x86_64.debug
Maybe you already have the same kernel without debug installed, then you can uninstall the .debug kernel.
HI Generix,
i tried remove 3.10.0-693.el7.x86_64.debug successfull after that i install driver again and it appear kernel not fond.
TH
generix
December 14, 2017, 9:43am
8
You need to install the matching kernel-devel package. I hope you have some kernel installed right now?
You needs to get the most recent version of the NVIDIA drivers , dispose of the reinstallation issue caused bby dkms, or utilizing Linux dispersions that don’t have nvidia drivers gave in the stores, introducing from runfile is prescribed.
Delete Previous Installations (Important)
One may have installed the driver through apt get. So before reinstall the driver from runfile, uninstalling past establishments is required. Executing the accompanying contents precisely one by one. See more (Install NVIDIA Driver and CUDA on Ubuntu / CentOS / Fedora Linux OS · GitHub )
Hi
the issue was fixed. just reinstall kernel-devel.
Thanks for your help
TH
