ERROR: Unable to load the 'nvidia-drm' kernel module - CentOS 6.10
I install NVIDIA driver:
sh ./NVIDIA-Linux-x86_64-440.33.01.run --kernel-source-path=/usr/src/kernels/2.6.32-754.24.3.el6.x86_64/ -k $(uname -r)
nvidia-installer.log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Dec  1 11:46:18 2019
installer version: 440.33.01
PATH: /usr/local/cuda/bin:/usr/local/ffmpeg/bin:/usr/local/cuda/bin:/usr/local/ffmpeg/bin:/home/zhangqinyi/anaconda3/bin:/usr/local/cuda/bin:/usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/opt/bin:/home/opt/bin:/opt/bin:/home/opt/bin:/root/bin:/root/baidupcs/BaiduPCS/:/opt/bin:/home/opt/bin:/root/bin:/root/baidupcs/BaiduPCS/
nvidia-installer command line:
    ./nvidia-installer
    -k
    3.10.0_3-0-0-13
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 28 CPUs online; setting concurrency level to 28.
-> Installing NVIDIA driver version 440.33.01.
-> There appears to already be a driver installed on your system (version: 440.33.01).  As part of installing this driver (version: 440.33.01), the existing driver will be uninstalled.  Are you sure you want to continue? (Answer: Continue installation)
-> Not probing for precompiled kernel interfaces.
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Performing CC check.
-> Using the kernel source path '/usr/src/kernels/2.6.32-754.24.3.el6.x86_64/' as specified by the '--kernel-source-path' commandline option.
-> Kernel source path: '/usr/src/kernels/2.6.32-754.24.3.el6.x86_64/'
-> Kernel output path: '/usr/src/kernels/2.6.32-754.24.3.el6.x86_64/'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
   executing: 'cd ./kernel; /usr/bin/make -k -j28 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/usr/src/kernels/2.6.32-754.24.3.el6.x86_64/" SYSOUT="/usr/src/kernels/2.6.32-754.24.3.el6.x86_64/"'...
   rm -f -r conftest
   make[1]: Entering directory `/usr/src/kernels/2.6.32-754.24.3.el6.x86_64'
   make[1]: Leaving directory `/usr/src/kernels/2.6.32-754.24.3.el6.x86_64'
-> Building kernel modules
   executing: 'cd ./kernel; /usr/bin/make -k -j28  NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/usr/src/kernels/2.6.32-754.24.3.el6.x86_64/" SYSOUT="/usr/src/kernels/2.6.32-754.24.3.el6.x86_64/"'...
     SYMLINK /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nv-modeset-kernel.o
     SYMLINK /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-kernel.o
    CONFTEST: hash__remap_4k_pfn
    CONFTEST: set_pages_uc
    CONFTEST: set_memory_uc
    CONFTEST: list_is_first
    CONFTEST: set_memory_array_uc
    CONFTEST: acquire_console_sem
    CONFTEST: console_lock
    CONFTEST: ioremap_cache
    CONFTEST: ioremap_wc
    CONFTEST: acpi_walk_namespace
    CONFTEST: sg_alloc_table
    CONFTEST: pci_get_domain_bus_and_slot
    CONFTEST: get_num_physpages
    CONFTEST: efi_enabled
    CONFTEST: pde_data
    CONFTEST: proc_remove
    CONFTEST: pm_vt_switch_required
    CONFTEST: xen_ioemu_inject_msi
    CONFTEST: phys_to_dma
    CONFTEST: get_dma_ops
    CONFTEST: write_cr4
    CONFTEST: of_get_property
    CONFTEST: of_find_node_by_phandle
    CONFTEST: of_node_to_nid
    CONFTEST: pnv_pci_get_npu_dev
    CONFTEST: of_get_ibm_chip_id
    CONFTEST: node_end_pfn
    CONFTEST: pci_bus_address
    CONFTEST: pci_stop_and_remove_bus_device
    CONFTEST: pci_remove_bus_device
    CONFTEST: register_cpu_notifier
    CONFTEST: cpuhp_setup_state
    CONFTEST: dma_map_resource
    CONFTEST: backlight_device_register
    CONFTEST: timer_setup
    CONFTEST: pci_enable_msix_range
    CONFTEST: do_gettimeofday
    CONFTEST: kernel_read
    CONFTEST: kernel_write
    CONFTEST: kthread_create_on_node
    CONFTEST: of_find_matching_node
    CONFTEST: dev_is_pci
    CONFTEST: dma_direct_map_resource
    CONFTEST: tegra_get_platform
    CONFTEST: flush_cache_all
    CONFTEST: vmf_insert_pfn
    CONFTEST: address_space_init_once
    CONFTEST: kbasename
    CONFTEST: vzalloc
    CONFTEST: wait_on_bit_lock_argument_count
    CONFTEST: bitmap_clear
    CONFTEST: usleep_range
    CONFTEST: radix_tree_empty
    CONFTEST: radix_tree_replace_slot
    CONFTEST: pnv_npu2_init_context
    CONFTEST: cpumask_of_node
    CONFTEST: drm_dev_unref
    CONFTEST: drm_reinit_primary_mode_group
    CONFTEST: get_user_pages_remote
    CONFTEST: drm_gem_object_lookup
    CONFTEST: drm_atomic_state_ref_counting
    CONFTEST: drm_driver_has_gem_prime_res_obj
    CONFTEST: drm_atomic_helper_connector_dpms
    CONFTEST: drm_connector_funcs_have_mode_in_name
    CONFTEST: drm_framebuffer_get
    CONFTEST: drm_gem_object_get
    CONFTEST: drm_dev_put
    CONFTEST: is_export_symbol_gpl_of_node_to_nid
    CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
    CONFTEST: is_export_symbol_present_swiotlb_dma_ops
    CONFTEST: is_export_symbol_present_kthread_create_on_node
    CONFTEST: acpi_op_remove
    CONFTEST: outer_flush_all
    CONFTEST: file_operations
    CONFTEST: file_inode
    CONFTEST: kuid_t
    CONFTEST: dma_ops
    CONFTEST: swiotlb_dma_ops
    CONFTEST: noncoherent_swiotlb_dma_ops
    CONFTEST: vm_fault_has_address
    CONFTEST: backlight_properties_type
    CONFTEST: vm_insert_pfn_prot
    CONFTEST: vmf_insert_pfn_prot
    CONFTEST: vm_ops_fault_removed_vma_arg
    CONFTEST: vmbus_channel_has_ringbuffer_page
    CONFTEST: device_driver_of_match_table
    CONFTEST: device_of_node
    CONFTEST: node_states_n_memory
    CONFTEST: kmem_cache_has_kobj_remove_work
    CONFTEST: sysfs_slab_unlink
    CONFTEST: backing_dev_info
    CONFTEST: mm_context_t
    CONFTEST: drm_bus_present
    CONFTEST: drm_bus_has_bus_type
    CONFTEST: drm_bus_has_get_irq
    CONFTEST: drm_bus_has_get_name
    CONFTEST: drm_driver_has_legacy_dev_list
    CONFTEST: drm_driver_has_set_busid
    CONFTEST: drm_crtc_state_has_connectors_changed
    CONFTEST: drm_init_function_args
    CONFTEST: drm_helper_mode_fill_fb_struct
    CONFTEST: drm_master_drop_has_from_release_arg
    CONFTEST: drm_driver_unload_has_int_return_type
    CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
    CONFTEST: drm_mode_object_find_has_file_priv_arg
    CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
    CONFTEST: dma_buf_owner
    CONFTEST: drm_connector_list_iter
    CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
    CONFTEST: drm_driver_prime_flag_present
    CONFTEST: nvidia_vgpu_hyperv_available
    CONFTEST: dom0_kernel_present
    CONFTEST: nvidia_vgpu_kvm_build
    CONFTEST: nvidia_grid_build
    CONFTEST: nvidia_grid_csp_build
    CONFTEST: pm_runtime_available
    CONFTEST: drm_available
    CONFTEST: drm_atomic_available
    CONFTEST: is_export_symbol_gpl_refcount_inc
    CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
    CONFTEST: drm_alpha_blending_available
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-drv.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-utils.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-crtc.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-encoder.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-connector.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-gem.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-fb.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-modeset.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-prime-fence.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-linux.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-helper.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nv-pci-table.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nvidia-modeset-linux.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nv-kthread-q.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm_utils.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm_common.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm_linux.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/nvstatus.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/nvCpuUuid.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/nv-kthread-q.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/nv-kthread-q-selftest.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_tools.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_global.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_isr.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_procfs.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_space.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_space_mm.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_mem.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_rm_mem.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_channel.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_lock.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_hal.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_tree.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_allocator.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_range.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_block.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_group.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_events.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_module.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_mmu.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pte_batch.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_tlb_batch.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_push.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pushbuffer.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_thread_context.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_tracker.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kepler.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kepler_ce.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kepler_host.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kepler_mmu.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_maxwell.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_maxwell_host.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal_ce.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal_host.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal_mmu.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta_host.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta_mmu.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_turing.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_turing_mmu.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_turing_host.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_policy.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_utils.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kvmalloc.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pmm_gpu.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_migrate.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_populate_pageable.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_migrate_pageable.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_map_external.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_user_channel.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_hmm.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_heuristics.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_thrashing.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_prefetch.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_ats_ibm.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_ats_faults.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_test_rng.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_tree_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_allocator_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_mem_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_rm_mem_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_page_tree_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_tracker_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_push_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_channel_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_ce_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_lock_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_utils_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pmm_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_events_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_module_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_mmu_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_block_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_thread_context_test.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-frontend.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pci.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-acpi.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-cray.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-dma.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-i2c.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-mempool.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-mmap.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-p2p.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pat.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-procfs.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-usermap.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-vm.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-vtophys.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-interface.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-mlock.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-pci.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-registry.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-usermap.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-modeset-interface.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pci-table.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-kthread-q.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-memdbg.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-ibmnpu.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-report-err.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-rsync.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-msi.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv_uvm_interface.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nvlink_linux.o
   ld -r -o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nv-kthread-q.o
     CC [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/linux_nvswitch.o
     LD [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia.o
     LD [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset.o
     LD [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm.o
   ld -r -o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-interface.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-frontend.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pci.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-acpi.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-cray.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-dma.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-i2c.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-mempool.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-mmap.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-p2p.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pat.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-procfs.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-usermap.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-vm.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-vtophys.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.0
   1/kernel/nvidia/os-interface.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-mlock.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-pci.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-registry.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-usermap.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pci-table.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-kthread-q.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-memdbg.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-report-err.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-rsync.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-msi.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz42953/NVID
   IA-Linux-x86_64-440.33.01/kernel/nvidia/nvlink_linux.o /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/linux_nvswitch.o
     LD [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm.o
     Building modules, stage 2.
     MODPOST 4 modules
     CC      /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm.mod.o
     CC      /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset.mod.o
     CC      /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm.mod.o
     CC      /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia.mod.o
     LD [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm.ko.unsigned
     LD [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset.ko.unsigned
     NO SIGN [M] /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm.ko
     NO SIGN [M] /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset.ko
     LD [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm.ko.unsigned
     LD [M]  /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia.ko.unsigned
     NO SIGN [M] /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm.ko
     NO SIGN [M] /tmp/selfgz42953/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia.ko
-> done.
-> Kernel module compilation complete.
-> Unable to determine if Secure Boot is enabled: No such file or directory
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: No)
-> Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
   executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
   Checking for libglvnd installation.
   Checking libGLdispatch...
   Can't load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (440.33.01):
   executing: '/sbin/ldconfig'...
   executing: '/sbin/depmod -a 3.10.0_3-0-0-13'...
-> done.
-> Driver file installation is complete.
ERROR: Unable to load the 'nvidia-drm' kernel module.
ERROR: Installation has failed.  Please see the file '/var/log/nvidia-installer.log' for details.  You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
nvidia-bug-report.log.gz (58.7 KB)
nvidia-installer.log (26 KB)
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/
Thanks for your response. I have upload the files.
You’re building the modules for a RH 3.10 kernel against the sources of a RH 2.6.32 kernel. That doesn’t work. Please install the headers for the currently running kernel and use those.
thanks your respose!
I run:
yum -y install gcc kernel-devel "kernel-devel-uname-r == $(uname -r)" dkms
the output:
Loaded plugins: aliases, fastestmirror, priorities, security
Setting up Install Process
Loading mirror speeds from cached hostfile
 * base: mirrors.aliyun.com
 * extras: mirrors.aliyun.com
 * nux-dextop: mirror.li.nux.ro
 * updates: mirrors.aliyun.com
base        | 3.7 kB     00:00
base-debuginfo        | 2.5 kB     00:00
centos6u3        |  951 B     00:00
cuda-10-2-local-10.2.89-440.33.01                                                               | 2.5 kB     00:00 ...
extras        | 3.4 kB     00:00
nux-dextop        | 2.9 kB     00:00
updates        | 3.4 kB     00:00
Package gcc-4.4.7-23.el6.x86_64 already installed and latest version
Package kernel-devel-2.6.32-754.24.3.el6.x86_64 already installed and latest version
No package kernel-devel-uname-r == 3.10.0_3-0-0-13 available.
Nothing to do
so the running kernel is 3.10, but kernel-devel-uname-r == 3.10.0_3-0-0-13 is not available. how to do? thanks!
Looking at the RH release dates https://access.redhat.com/articles/3078 the standard kernel would be a 2.6.32, RH also has a different naming scheme. 3.10.0_3-0-0-13 must be some non-standard third-party kernel. Please check from where you got that or switch back to the standard kernel.
