File Attachment doesn’t seem to be working. Here’s the whole nvidia-installer.log:
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Fri Jul 2 10:36:28 2010
installer version: 1.0.7
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
OpenGL header files : true
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
no cc version check : false
force tls : (not specified)
force compat32 tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
compat32 install chroot : (not specified)
compat32 install prefix : (not specified)
compat32 install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : ftp://download.nvidia.com
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 195.36.15.
-> Performing CC sanity check with CC=“cc”.
-> Performing CC version check with CC=“cc”.
-> Kernel source path: ‘/lib/modules/2.6.32-22-generic/build’
-> Kernel output path: ‘/lib/modules/2.6.32-22-generic/build’
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Cleaning kernel module build directory.
executing: ‘cd ./usr/src/nv; make clean’…
-> Building kernel module:
executing: ‘cd ./usr/src/nv; make module SYSSRC=/lib/modules/2.6.32-22-gener
ic/build SYSOUT=/lib/modules/2.6.32-22-generic/build’…
NVIDIA: calling KBUILD…
test -e include/linux/autoconf.h -a -e include/config/auto.conf || (
echo;
echo " ERROR: Kernel configuration is invalid.";
echo " include/linux/autoconf.h or include/config/auto.conf are mis
sing.";
echo " Run ‘make oldconfig && make prepare’ on kernel src to fix it
echo;
/bin/false)
mkdir -p /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/.tmp_
versions ; rm -f /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/
nv/.tmp_versions/*
make -f scripts/Makefile.build obj=/tmp/selfgz1487/NVIDIA-Linux-x86_64-195.3
cc -Wp,-MD,/tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/.
nv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/include -Iin
clude -I/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include -include
include/linux/autoconf.h -Iubuntu/include -D__KERNEL__ -Wall -Wundef -Wstri
ct-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implic
it-functio
n-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64
-mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-o
utgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAM
E=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mm
x -mno-sse2 -mno-3dnow -Wframe-larger-than=1024 -fno-omit-frame-pointer -fno
-optimize-sibling-calls -pg -Wdeclaration-after-statement -Wno-pointer-sign
-fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz1487/
NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv -Wall -Wimplicit -Wreturn-type
-Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -Wno-multi
char -Werror -mcmodel=kernel -mno-red-zone -fno-defer-pop -MD -Wsign-compare
-Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=
“195.36.15” -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s" -D"KBU
ILD_BASENAME=KBUILD_STR(nv)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /
-195.36.15-pkg2/usr/src/nv/.tmp_nv.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195
.36.15-pkg2/usr/src/nv/nv.c
In file included from include/linux/bitops.h:17,
from include/linux/kernel.h:15,
from include/linux/sched.h:54,
from include/linux/utsname.h:35,
from /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr
/src/nv/nv-linux.h:27,
/src/nv/nv.c:14:
/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include/asm/bitops.h: In f
unction ‘set_bit’:
/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include/asm/bitops.h:64: w
arning: pointer of type ‘void *’ used in arithmetic
unction ‘clear_bit’:
/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include/asm/bitops.h:102:
warning: pointer of type ‘void *’ used in arithmetic
unction ‘change_bit’:
/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include/asm/bitops.h:178:
In file included from include/linux/utsname.h:35,
/src/nv/nv.c:14:
include/linux/sched.h: In function ‘object_is_on_stack’:
include/linux/sched.h:2282: warning: pointer of type ‘void *’ used in ar
ithmetic
In file included from include/linux/dma-mapping.h:7,
from include/asm-generic/pci-dma-compat.h:7,
from /usr/src/linux-headers-2.6.32-22-generic/arch/x86/incl
ude/asm/pci.h:128,
from include/linux/pci.h:1126,
/src/nv/nv-linux.h:95,
/src/nv/nv.c:14:
include/linux/scatterlist.h: In function ‘sg_virt’:
include/linux/scatterlist.h:199: warning: pointer of type ‘void *’ used
in arithmetic
In file included from /usr/src/linux-headers-2.6.32-22-generic/arch/x86/incl
ude/asm/dma-mapping.h:42,
from include/linux/dma-mapping.h:103,
ude/asm/pci.h:128,
/src/nv/nv.c:14:
include/asm-generic/dma-mapping-common.h: In function ‘dma_map_page’:
include/asm-generic/dma-mapping-common.h:77: warning: pointer of type ‘voi
In file included from /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr
/src/nv/nv-linux.h:126,
/src/nv/nv.c:14:
include/linux/highmem.h: In function ‘zero_user_segments’:
include/linux/highmem.h:149: warning: pointer of type ‘void *’ used in a
rithmetic
include/linux/highmem.h:152: warning: pointer of type ‘void *’ used in a
rithmetic
In file included from include/linux/compat.h:14,
ude/asm/mtrr.h:173,
/src/nv/nv-linux.h:161,
/src/nv/nv.c:14:
/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include/asm/compat.h: In f
unction ‘compat_alloc_user_space’:
/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include/asm/compat.h:210:
set -e ; perl /usr/src/linux-headers-2.6.32-22-generic/scripts/recordmcoun
t.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz
1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nv.o”;
nv_gvi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/include
-Iinclude -I/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include -incl
ude include/linux/autoconf.h -Iubuntu/include -D__KERNEL__ -Wall -Wundef -W
strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-im
plicit-function-declaration -Wno-format-security -fno-delete-null-pointer-ch
ecks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time
-maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_C
FI_SIGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -m
no-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=1024 -fno-omit-fram
e-pointer -fno-optimize-sibling-calls -pg -Wdeclaration-after-statement -Wno
-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/t
mp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv -Wall -Wimplicit
Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-ari
th -Wno-multichar -Werror -mcmodel=kernel -mno-red-zone -fno-defer-pop -MD -
Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VE
RSION_STRING=“195.36.15” -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D"KBUILD_STR
(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_gvi)" -D"KBUILD_MODNAME=KBUILD_STR
(nvidia)" -c -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/
nv/.tmp_nv_gvi.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/
nv/nv_gvi.c
/src/nv/nv_gvi.c:15:
unction ‘set_bit’:
ithmetic
ude/asm/pci.h:128,
in arithmetic
ude/asm/pci.h:128,
rithmetic
rithmetic
ude/asm/mtrr.h:173,
1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nv_gvi.o”;
nv-vm.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/include -
Iinclude -I/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include -inclu
de include/linux/autoconf.h -Iubuntu/include -D__KERNEL__ -Wall -Wundef -Ws
trict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-imp
licit-function-declaration -Wno-format-security -fno-delete-null-pointer-che
t-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCO
NFIG_AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-
tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=1024 -fno-
omit-frame-pointer -fno-optimize-sibling-calls -pg -Wdeclaration-after-state
ment -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-s
tack -I/tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv -Wall -
Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -W
pointer-arith -Wno-multichar -Werror -mcmodel=kernel -mno-red-zone -fno-defe
r-pop -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DN
VRM -DNV_VERSION_STRING=“195.36.15” -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D
“KBUILD_STR(s)=#s” -D"KBUILD_BASENAME=KBUILD_STR(nv_vm)" -D"KBUILD_MODNAME=
KBUILD_STR(nvidia)" -c -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg
2/usr/src/nv/.tmp_nv-vm.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2
/usr/src/nv/nv-vm.c
/src/nv/nv-vm.c:14:
unction ‘set_bit’:
/src/nv/nv-vm.c:14:
ithmetic
ude/asm/pci.h:128,
/src/nv/nv-vm.c:14:
in arithmetic
ude/asm/pci.h:128,
/src/nv/nv-vm.c:14:
/src/nv/nv-vm.c:14:
rithmetic
rithmetic
ude/asm/mtrr.h:173,
/src/nv/nv-vm.c:14:
1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nv-vm.o”;
os-agp.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/include
-Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-ar
or -mcmodel=kernel -mno-red-zone -fno-defer-pop -MD -Wsign-compare -Wno-cast
-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“195.36.1
5” -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASEN
AME=KBUILD_STR(os_agp)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/s
elfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/.tmp_os-agp.o /tmp/s
elfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/os-agp.c
/src/nv/os-agp.c:24:
unction ‘set_bit’:
ithmetic
ude/asm/pci.h:128,
in arithmetic
ude/asm/pci.h:128,
rithmetic
rithmetic
ude/asm/mtrr.h:173,
1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/os-agp.o”;
os-interface.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/inc
lude -Iinclude -I/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include
-include include/linux/autoconf.h -Iubuntu/include -D__KERNEL__ -Wall -Wund
ef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werr
or-implicit-function-declaration -Wno-format-security -fno-delete-null-point
er-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-
time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG
AS_CFI_SIGN
AL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse
-mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=1024 -fno-omit-frame-point
er -fno-optimize-sibling-calls -pg -Wdeclaration-after-statement -Wno-pointe
r-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/self
gz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv -Wall -Wimplicit -Wretu
rn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -W
no-multichar -Werror -mcmodel=kernel -mno-red-zone -fno-defer-pop -MD -Wsign
-compare -Wno-cast-qual -Wno-error -D__KERNEL_ -DMODULE -DNVRM -DNV_VERSION
STRING=“195.36.15” -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#
s" -D"KBUILD_BASENAME=KBUILD_STR(os_interface)" -D"KBUILD_MODNAME=KBUILD_ST
R(nvidia)" -c -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src
/nv/.tmp_os-interface.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/u
sr/src/nv/os-interface.c
/src/nv/os-interface.c:26:
unction ‘set_bit’:
ithmetic
ude/asm/pci.h:128,
in arithmetic
ude/asm/pci.h:128,
rithmetic
rithmetic
ude/asm/mtrr.h:173,
1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/os-interface.o”;
os-registry.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/incl
-include include/linux/autoconf.h -Iubuntu/include -D__KERNEL_ -Wall -Wund
AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tabl
es -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=1024 -fno-omit
-frame-pointer -fno-optimize-sibling-calls -pg -Wdeclaration-after-statement
-Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack
-I/tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv -Wall -Wimpl
icit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpoint
l -mno-red-zone -fno-defer-pop -MD -Wsign-compare -Wno-cast-qual -Wno-error
-D__KERNEL_ -DMODULE -DNVRM -DNV_VERSION_STRING=“195.36.15” -UDEBUG -U_DE
BUG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os
registry)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz1487/NV
IDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/.tmp_os-registry.o /tmp/selfgz14
87/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/os-registry.c
/src/nv/os-registry.c:15:
unction ‘set_bit’:
ithmetic
ude/asm/pci.h:128,
in arithmetic
ude/asm/pci.h:128,
rithmetic
rithmetic
ude/asm/mtrr.h:173,
1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/os-registry.o”;
nv-i2c.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/include
ude include/linux/autoconf.h -Iubuntu/include -D__KERNEL_ -Wall -Wundef -W
CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchron
ous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than
=1024 -fno-omit-frame-pointer -fno-optimize-sibling-calls -pg -Wdeclaration-
after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -
fconserve-stack -I/tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src
/nv -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wpar
entheses -Wpointer-arith -Wno-multichar -Werror -mcmodel=kernel -mno-red-zon
e -fno-defer-pop -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL_ -
DMODULE -DNVRM -DNV_VERSION_STRING=“195.36.15” -UDEBUG -U_DEBUG -DNDEBUG
-DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_i2c)" -D"KBU
ILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-1
95.36.15-pkg2/usr/src/nv/.tmp_nv-i2c.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-1
95.36.15-pkg2/usr/src/nv/nv-i2c.c
/src/nv/nv-i2c.c:8:
unction ‘set_bit’:
/src/nv/nv-i2c.c:8:
ithmetic
ude/asm/pci.h:128,
/src/nv/nv-i2c.c:8:
in arithmetic
ude/asm/pci.h:128,
/src/nv/nv-i2c.c:8:
/src/nv/nv-i2c.c:8:
rithmetic
rithmetic
ude/asm/mtrr.h:173,
/src/nv/nv-i2c.c:8:
1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nv-i2c.o”;
nvacpi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/include
ith -Wno-multichar -Werror -mcmodel=kernel -mno-red-zone -fno-defer-pop -MD
-Wsign-co
mpare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_ST
RING=“195.36.15” -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s"
-D"KBUILD_BASENAME=KBUILD_STR(nvacpi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)
" -c -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/.tmp_
nvacpi.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nvacp
i.c
/src/nv/nvacpi.c:15:
unction ‘set_bit’:
ithmetic
ude/asm/pci.h:128,
in arithmetic
ude/asm/pci.h:128,
rithmetic
rithmetic
ude/asm/mtrr.h:173,
1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nvacpi.o”;
ld -m elf_x86_64 -r -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg
2/usr/src/nv/nvidia.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr
/src/nv/nv-kernel.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/s
rc/nv/nv.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nv_
gvi.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nv-vm.o
/tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/os-agp.o /tmp/
selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/os-interface.o /tmp
/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/os-registry.o /tmp
/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nv-i2c.o /tmp/se
lfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/nvacpi.o
(cat /dev/null; echo kernel//tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-
pkg2/usr/src/nv/nvidia.ko;) > /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-
pkg2/usr/src/nv/modules.order
make -f /usr/src/linux-headers-2.6.32-22-generic/scripts/Makefile.modpost
scripts/mod/modpost -m -a -i /usr/src/linux-headers-2.6.32-22-generic/Modu
le.symvers -I /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/src/nv/
Module.symvers -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/sr
c/nv/Module.symvers -S -w -s
WARNING: could not find /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/u
sr/src/nv/.nv-kernel.o.cmd for /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15
-pkg2/usr/src/nv/nv-kernel.o
nvidia.mod.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.4.3/inclu
de -Iinclude -I/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include -
buntu/include -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs
-fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-
format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno
-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstac
k-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign
-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3d
now -Wframe-larger-than=1024 -fno-omit-frame-pointer -fno-optimize-sibling-c
alls -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflo
w -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz1487/NVIDIA-Linux-x86_64
-195.36.15-pkg2/usr/src/nv -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat
-Wchar-subscripts -Wparentheses -Wpointer-arith -Wno-multichar -Werror -mcmo
del=kernel -mno-red-zone -fno-defer-pop -MD -Wsign-compare -Wno-cast-qual -W
no-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=“195.36.15” -UDE
BUG -U_DEBUG -DNDEBUG -D"KBUILD_ST
R(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nvidia.mod)" -D"KBUILD_MODNAME=KBUIL
D_STR(nvidia)" -DMODULE -c -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15
-pkg2/usr/src/nv/nvidia.mod.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-
pkg2/usr/src/nv/nvidia.mod.c
ude/asm/percpu.h:45,
ude/asm/current.h:5,
ude/asm/processor.h:15,
from include/linux/prefetch.h:14,
from include/linux/list.h:6,
from include/linux/module.h:9,
/src/nv/nvidia.mod.c:1:
unction ‘set_bit’:
ld -r -m elf_x86_64 -T /usr/src/linux-headers-2.6.32-22-generic/scripts/mo
dule-common.lds --build-id -o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-
pkg2/usr/src/nv/nvidia.ko /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2
/usr/src/nv/nvidia.o /tmp/selfgz1487/NVIDIA-Linux-x86_64-195.36.15-pkg2/usr/
src/nv/nvidia.mod.o
NVIDIA: left KBUILD.
-> done.
-> Kernel module compilation complete.
ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most
frequently when this kernel module was built against the wrong or
improperly configured kernel sources, with a version of gcc that differs
from the one used to build the target kernel, or if a driver such as
rivafb/nvidiafb is present and prevents the NVIDIA kernel module from
obtaining ownership of the NVIDIA graphics device(s), or NVIDIA GPU
installed in this system is not supported by this NVIDIA Linux graphics
driver release.
Please see the log entries 'Kernel module load error' and 'Kernel
messages' at the end of the file '/var/log/nvidia-installer.log' for
more information.
-> Kernel module load error: insmod: error inserting ‘./usr/src/nv/nvidia.ko’:
-1 No such device
-> Kernel messages:
[ 22.576821] type=1505 audit(1278030
