Hello everyone, hope you are all having a great time.
I have been trying to install cuda 10.2 on my ubuntu 18.04.5 without any luck for couple of days now.
I have 2 Tesla V100 and this is my OS configs(fresh install):
x86_64
4.15.0-136-generic
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.5 LTS"
NAME="Ubuntu"
VERSION="18.04.5 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04.5 LTS"
VERSION_ID="18.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
I downloaded the cudatoolkit from the official link and tried to install it.
These are the commands I used :
sudo apt-get install linux-headers-$(uname -r)
sudo apt-get install g++ freeglut3-dev build-essential libx11-dev libxmu-dev libxi-dev libglu1-mesa libglu1-mesa-dev
sudo service lightdm stop # this resulted in Failed to stop lightdm.service: Unit lightdm.service not loaded.
then I did :
sudo nano /etc/modprobe.d/blacklist-nouveau.conf
and wrote :
blacklist nouveau
options nouveau modset=0
then did :
sudo update-initramfs -u
reboot
then tried to install the driver :
bash ./cuda_10.2.89_440.33.01_linux_2.run
with the defaults values. then shortly after the process starts it fails with the following errors:
root@meme-1:~# bash ./cuda_10.2.89_440.33.01_linux_2.run
Installation failed. See log at /var/log/cuda-installer.log for details.
root@meme-1:~# cat /var/log/cuda-installer.log
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)
[INFO]: Initializing menu
[INFO]: Setup complete
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 440.33.01
[INFO]: Executing NVIDIA-Linux-x86_64-440.33.01.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --install-libglvnd 2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 440.33.01 failed, quitting
Inspecting the cuda logs I see :
[INFO]: Driver
[INFO]: 440.33.01
And inspecting the nvidia-installer shows :
root@meme-1:~# cat /var/log/nvidia-installer.log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue Mar 9 14:18:56 2021
installer version: 440.33.01
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
nvidia-installer command line:
./nvidia-installer
--ui=none
--no-questions
--accept-license
--disable-nouveau
--install-libglvnd
Using built-in stream user interface
-> Detected 112 CPUs online; setting concurrency level to 32.
-> Installing NVIDIA driver version 440.33.01.
-> For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
-> One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Performing CC check.
-> Kernel source path: '/lib/modules/4.15.0-136-generic/build'
-> Kernel output path: '/lib/modules/4.15.0-136-generic/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /usr/bin/make -k -j32 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.15.0-136-generic/build" SYSOUT="/lib/modules/4.15.0-136-generic/build"'...
rm -f -r conftest
make[1]: Entering directory '/usr/src/linux-headers-4.15.0-136-generic'
make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-136-generic'
-> Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.15.0-136-generic/build" SYSOUT="/lib/modules/4.15.0-136-generic/build"'...
SYMLINK /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: of_get_property
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: do_gettimeofday
CONFTEST: kernel_read
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pci.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_space_mm.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_turing.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_turing_mmu.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_turing_host.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_populate_pageable.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_migrate_pageable.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm/uvm8_thread_context_test.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
ld -r -o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-interface.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-frontend.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pci.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-acpi.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-cray.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-dma.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-i2c.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-mempool.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-mmap.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-p2p.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pat.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-procfs.o /tmp/selfgz25
26/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-usermap.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-vm.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-vtophys.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-interface.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-mlock.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-pci.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-registry.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/os-usermap.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-pci-table.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-kthread-q.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-memdbg.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-report-err.o /tmp/sel
fgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-rsync.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv-msi.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/nvlink_linux.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
LD [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia.o
ld -r -o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm.o
LD [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm.mod.o
CC /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia.mod.o
LD [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia.ko
LD [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz2526/NVIDIA-Linux-x86_64-440.33.01/kernel/nvidia-drm.ko
-> done.
-> Kernel module compilation complete.
ERROR: Unable to load the kernel module 'nvidia.ko'. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA GPU installed in this system is supported by this NVIDIA Linux graphics driver release.
Please see the log entries 'Kernel module load error' and 'Kernel messages' at the end of the file '/var/log/nvidia-installer.log' for more information.
-> Kernel module load error: No such device
-> Kernel messages:
[ 25.882616] kvm: disabled by bios
[ 25.954605] kvm: disabled by bios
[ 26.018502] kvm: disabled by bios
[ 26.082412] kvm: disabled by bios
[ 258.768110] sd 1:0:0:0: [sda] tag#0 Sense Key : Recovered Error [current]
[ 258.768139] sd 1:0:0:0: [sda] tag#0 Add. Sense: Hardware impending failure general hard drive failure
[ 288.652636] VFIO - User Level meta-driver version: 0.3
[ 288.687236] nvidia: loading out-of-tree module taints kernel.
[ 288.687246] nvidia: module license 'NVIDIA' taints kernel.
[ 288.687247] Disabling lock debugging due to kernel taint
[ 288.694093] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 288.705065] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 288.705775] nvidia 0000:b1:00.0: enabling device (0140 -> 0142)
[ 288.705863] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
NVRM: BAR0 is 0M @ 0x0 (PCI:0000:b1:00.0)
[ 288.705864] NVRM: The system BIOS may have misconfigured your GPU.
[ 288.705875] nvidia: probe of 0000:b1:00.0 failed with error -1
[ 288.705889] nvidia 0000:b2:00.0: enabling device (0140 -> 0142)
[ 288.705937] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
NVRM: BAR0 is 0M @ 0x0 (PCI:0000:b2:00.0)
[ 288.705938] NVRM: The system BIOS may have misconfigured your GPU.
[ 288.705944] nvidia: probe of 0000:b2:00.0 failed with error -1
[ 288.705959] NVRM: The NVIDIA probe routine failed for 2 device(s).
[ 288.705959] NVRM: None of the NVIDIA devices were initialized.
[ 288.706098] nvidia-nvlink: Unregistered the Nvlink Core, major device number 511
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Also after balcklisting noveu lsmod | grep nouveau returns nothing. so it seems to be its disabled. however, I’m still failing
What’s wrong here and how should I be going about this?
Thank you all very much in advance
pn: I know there are other topics like this, I have checked them to no avail.
