glxinfo gives the output below. I don’t know if the problem lies with Ubuntu not being officially supported, it might as well be because I have a laptop G8 rather than a desktop one. I had the same problem with graphics interoperability not working in XP. Unfortunately, the fix for XP (basically just leaving out the “isGraphicsInteroperabilitySupported” function call) does not eliminate the problem in Ubuntu. It just gives me a black window.
Thanks for helping out.
----------------------------------------- begin glxinfo ------------------------------------------------------------
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
GLX_EXT_texture_from_pixmap, GLX_ARB_multisample, GLX_NV_float_buffer,
GLX_ARB_fbconfig_float, GLX_EXT_framebuffer_sRGB
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
GLX_EXT_fbconfig_packed_float, GLX_EXT_texture_from_pixmap,
GLX version: 1.3
GLX extensions:
GLX_ARB_fbconfig_float, GLX_EXT_framebuffer_sRGB,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 8600M GT/PCI/SSE2
OpenGL version string: 2.1.1 NVIDIA 100.14.11
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_half_float_pixel, GL_ARB_imaging,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_texture_float,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_S3_s3tc, GL_EXT_texture_env_add,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_Cg_shader, GL_EXT_bindable_uniform, GL_EXT_depth_bounds_test,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_object, GL_EXTX_framebuffer_mixed_formats,
GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_buffer_object,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
GL_EXT_texture_shared_exponent, GL_EXT_timer_query, GL_EXT_vertex_array,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_copy_depth_to_color,
GL_NV_depth_buffer_float, GL_NV_depth_clamp, GL_NV_fence,
GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_program,
GL_NV_fragment_program_option, GL_NV_fragment_program2,
GL_NV_framebuffer_multisample_coverage, GL_NV_geometry_shader4,
GL_NV_gpu_program4, GL_NV_half_float, GL_NV_light_max_exponent,
GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
GL_NV_register_combiners, GL_NV_register_combiners2,
GL_NV_texgen_reflection, GL_NV_texture_compression_vtc,
GL_NV_texture_env_combine4, GL_NV_texture_expand_normal,
GL_NV_texture_rectangle, GL_NV_texture_shader, GL_NV_texture_shader2,
GL_NV_texture_shader3, GL_NV_transform_feedback, GL_NV_vertex_array_range,
GL_NV_vertex_array_range2, GL_NV_vertex_program, GL_NV_vertex_program1_1,
GL_NV_vertex_program2, GL_NV_vertex_program2_option,
GL_NV_vertex_program3, GL_NVX_conditional_render, GL_SGIS_generate_mipmap,
GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
GL_SUN_slice_accum
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x24 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x28 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x29 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x2a 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x2b 24 tc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x2c 24 tc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x2d 24 tc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x2e 24 tc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x2f 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x30 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x31 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x32 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x33 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x34 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x35 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x36 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x37 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x38 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x39 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x3a 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x3b 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x3c 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x3d 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x3e 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x3f 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x40 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x41 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x42 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x43 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x44 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x45 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x46 24 dc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x47 24 dc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x48 24 dc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x49 24 dc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x4a 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x4b 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x4c 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x4d 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x4e 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x4f 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x50 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x51 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x52 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x53 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x54 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x55 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x56 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x57 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x58 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x59 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x23 32 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x5a 32 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x5b 32 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x5c 32 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x5d 32 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x5e 32 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x5f 32 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x60 32 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x61 32 tc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x62 32 tc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x63 32 tc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x64 32 tc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x65 32 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x66 32 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x67 32 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x68 32 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x69 32 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x6a 32 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x6b 32 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 Ncon
0x6c 32 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 Ncon
0x6d 32 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x6e 32 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x6f 32 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x70 32 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x71 32 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x72 32 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
0x73 32 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 Ncon
0x74 32 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 Ncon
