Hi There,
I’ve just got a new laptop with an Nvidia Geforce GTX 1070 installed with Ubuntu 16.04 and I’m having trouble installing a CUDA development environment on it.
I’m using a run-file installation and I’ve been following the installation instructions at:
http://docs.nvidia.com/cuda/cuda-installation-guide-linux/#axzz4RVfXeFsj
I’ve completed all the pre-installation checks okay but the installer keeps failing, saying it’s unable to locate the kernel source. Looking into the log files though it seems that the problem is either being caused by the Nouveau driver still being loaded or the compiled nvidia driver not being signed. Both errors are mentioned in the logs. I’ve added the ‘/etc/modprobe.d/blacklist-nouveau.conf’ file and rebooted as per the instructions but apparently this doesn’t always work.
Does anyone have any idea how I get this fixed?
Here are the cuda_install and nvidia_installer log files with all the details
----- cuda_install_2274.log ---------------------------------------------------------
Using more to view the EULA.
Installing the NVIDIA display driver…
Verifying archive integrity… OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86_64 367.48…
Welcome to the NVIDIA Software Installer for Unix/Linux
Detected 8 CPUs online; setting concurrency level to 8.
License accepted by command line option.
Installing NVIDIA driver version 367.48.
Running distribution scripts
Executing /usr/lib/nvidia/pre-install: [ ] 0%
Executing /usr/lib/nvidia/pre-install: [##############################] 100%
WARNING: One or more modprobe configuration files to disable Nouveau are
already present at:
/etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be
sure you have rebooted your system since these files were written.
If you have rebooted, then Nouveau may be enabled for other
reasons, such as being included in the system initial ramdisk or
in your X configuration file. Please consult the NVIDIA driver
README and your Linux distribution's documentation for details on
how to correctly disable the Nouveau kernel driver.
The distribution-provided pre-install script failed! Are you sure you want
to continue? (Answer: Continue installation)
For some distributions, Nouveau can be disabled by adding a file in the
modprobe configuration directory. Would you like nvidia-installer to
attempt to create this modprobe file for you? (Answer: Yes)
One or more modprobe configuration files to disable Nouveau have been
written. For some distributions, this may be sufficient to disable
Nouveau; other distributions may require modification of the initial
ramdisk. Please reboot your system and attempt NVIDIA driver installation
again. Note if you later wish to reenable Nouveau, you will need to delete
these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
Performing CC sanity check with CC=“/usr/bin/cc”.
Kernel source path: ‘/lib/modules/4.4.0-51-generic/build’
Kernel output path: ‘/lib/modules/4.4.0-51-generic/build’
Performing rivafb check.
Performing nvidiafb check.
Performing Xen check.
Performing PREEMPT_RT check.
Cleaning kernel module build directory.
Building kernel modules
: [ ] 0%
: [## ] 3%
: [### ] 7%
: [#### ] 11%
: [##### ] 15%
: [###### ] 20%
: [######## ] 23%
: [######### ] 28%
: [########## ] 31%
: [########### ] 36%
: [############ ] 40%
: [############## ] 43%
: [############### ] 47%
: [################ ] 51%
: [################# ] 56%
: [################## ] 60%
: [#################### ] 63%
: [##################### ] 68%
: [###################### ] 72%
: [####################### ] 75%
: [######################## ] 80%
: [########################## ] 83%
: [########################### ] 87%
: [############################ ] 92%
: [############################# ] 95%
ERROR: The kernel module failed to load, because it was not signed by a key
that is trusted by the kernel. Please try installing the driver
again, and sign the kernel module when prompted to do so.
ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most
frequently when this kernel module was built against the wrong or
improperly configured kernel sources, with a version of gcc that
differs from the one used to build the target kernel, or if a driver
such as rivafb, nvidiafb, or nouveau is present and prevents the
NVIDIA kernel module from obtaining ownership of the NVIDIA graphics
device(s), or no NVIDIA GPU installed in this system is supported by
this NVIDIA Linux graphics driver release.
Please see the log entries 'Kernel module load error' and 'Kernel
messages' at the end of the file '/var/log/nvidia-installer.log' for
more information.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find
suggestions on fixing installation problems in the README available
on the Linux driver download page at www.nvidia.com.
Kernel module compilation complete.
The target kernel has CONFIG_MODULE_SIG set, which means that it supports
cryptographic signatures on kernel modules. On some systems, the kernel may
refuse to load modules without a valid signature from a trusted key. This
system also has UEFI Secure Boot enabled; many distributions enforce module
signature verification on UEFI systems when Secure Boot is enabled. Would
you like to sign the NVIDIA kernel module? (Answer: Install without
signing)
Kernel module load error: Required key not available
Kernel messages:
[ 35.707810] Bluetooth: RFCOMM TTY layer initialized
[ 35.707816] Bluetooth: RFCOMM socket layer initialized
[ 35.707818] Bluetooth: RFCOMM ver 1.11
[ 97.717954] wlp61s0: authenticate with d8:84:66:0f:8e:80
[ 97.782228] wlp61s0: send auth to d8:84:66:0f:8e:80 (try 1/3)
[ 97.783650] wlp61s0: authenticated
[ 97.789556] wlp61s0: associate with d8:84:66:0f:8e:80 (try 1/3)
[ 97.792794] wlp61s0: RX AssocResp from d8:84:66:0f:8e:80 (capab=0x411
status=0 aid=4)
[ 97.795698] wlp61s0: associated
[ 97.795719] IPv6: ADDRCONF(NETDEV_CHANGE): wlp61s0: link becomes ready
[ 97.797715] ath: EEPROM regdomain: 0x833a
[ 97.797716] ath: EEPROM indicates we should expect a country code
[ 97.797717] ath: doing EEPROM country->regdmn map search
[ 97.797718] ath: country maps to regdmn code: 0x37
[ 97.797719] ath: Country alpha2 being used: GB
[ 97.797720] ath: Regpair used: 0x37
[ 97.797721] ath: regdomain 0x833a dynamically updated by country IE
[ 97.797726] cfg80211: Regulatory domain changed to country: GB
[ 97.797727] cfg80211: DFS Master region: ETSI
[ 97.797728] cfg80211: (start_freq - end_freq @ bandwidth),
(max_antenna_gain, max_eirp), (dfs_cac_time)
[ 97.797730] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A,
2000 mBm), (N/A)
[ 97.797731] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000
KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 97.797733] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000
KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 97.797734] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A,
2700 mBm), (0 s)
[ 97.797735] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz),
(N/A, 4000 mBm), (N/A)
The driver installation is unable to locate the kernel source. Please make sure that the kernel source packages are installed and set up correctly.
If you know that the kernel source packages are installed and set up correctly, you may pass the location of the kernel source with the ‘–kernel-source-path’ flag.
= Summary =
Driver: Installation Failed
Toolkit: Installation skipped
Samples: Installation skipped
Logfile is /tmp/cuda_install_2274.log
----- nvidia_installer.log -----------------------------------------------------------
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Nov 30 13:38:11 2016
installer version: 367.48
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
–ui=none
–no-questions
–accept-license
–disable-nouveau
–run-nvidia-xconfig
Using built-in stream user interface
→ Detected 8 CPUs online; setting concurrency level to 8.
→ License accepted by command line option.
→ Installing NVIDIA driver version 367.48.
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written. If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file. Please consult the NVIDIA driver README and your Linux distribution’s documentation for details on how to correctly disable the Nouveau kernel driver.
→ For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
→ One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.4.0-51-generic/build’
→ Kernel output path: ‘/lib/modules/4.4.0-51-generic/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j8 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.4.0-51-generic/build” SYSOUT=“/lib/modules/4.4.0-51-generic/build”’…
rm -f -r conftest
/usr/bin/make “CC=cc” KBUILD_VERBOSE= -C /lib/modules/4.4.0-51-generic/build M=/tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.4.0-51-generic/build NV_KERNEL_OUTPUT=/lib/modules/4.4.0-51-generic/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory ‘/usr/src/linux-headers-4.4.0-51-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-4.4.0-51-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j8 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.4.0-51-generic/build” SYSOUT=“/lib/modules/4.4.0-51-generic/build”’…
/usr/bin/make “CC=cc” KBUILD_VERBOSE= -C /lib/modules/4.4.0-51-generic/build M=/tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.4.0-51-generic/build NV_KERNEL_OUTPUT=/lib/modules/4.4.0-51-generic/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
SYMLINK /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: kmem_cache_create
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: drm_driver_has_set_busid
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_parse_phandle
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: request_threaded_irq
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_op_remove
CONFTEST: acpi_device_ops
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: kernel_write
CONFTEST: strnstr
CONFTEST: iterate_dir
CONFTEST: kstrtoull
CONFTEST: mm_context_t
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_functions_have_name_arg
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_grid_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nvlink_pci.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/ebridge_linux.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/ibmnpu_linux.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_page_migration.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_page_migration_stubs.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_page_migration_kepler.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_page_migration_maxwell.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_page_migration_pascal.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_channel_mgmt.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_common_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_channel_directed_tests.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_channel_basic_sanity_tests.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_kernel_events.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_kernel_counters.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_debug_session.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_gpu_ops_tests.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_lite.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_page_cache.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_lite_api.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_lite_prefetch.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_lite_region_tracking.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_mmu_mgmt.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_full_fault_buffer.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/mmu_fmt.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/gmmu_fmt.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_gpu_page_fault.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-mmap.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nvidia-drm-linux.o
ld -r -o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-interface.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-frontend.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-instance.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-acpi.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-chrdev.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-cray.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-dma.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-gvi.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-i2c.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-mempool.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-mmap.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-p2p.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-pat.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-procfs.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-usermap.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-vm.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-vtophys.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48
/kernel/nvidia/os-interface.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-mlock.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-pci.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-registry.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/os-usermap.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv-pci-table.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nvlink_linux.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/nvlink_pci.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/ebridge_linux.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia/ibmnpu_linux.o
ld -r -o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia.o
CC [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm/nv-pci-table.o
LD [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm.mod.o
CC /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia.mod.o
CC /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm.mod.o
LD [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia.ko
LD [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz2327/NVIDIA-Linux-x86_64-367.48/kernel/nvidia-uvm.ko
→ done.
→ Kernel module compilation complete.
→ The target kernel has CONFIG_MODULE_SIG set, which means that it supports cryptographic signatures on kernel modules. On some systems, the kernel may refuse to load modules without a valid signature from a trusted key. This system also has UEFI Secure Boot enabled; many distributions enforce module signature verification on UEFI systems when Secure Boot is enabled. Would you like to sign the NVIDIA kernel module? (Answer: Install without signing)
ERROR: The kernel module failed to load, because it was not signed by a key that is trusted by the kernel. Please try installing the driver again, and sign the kernel module when prompted to do so.
ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if a driver such as rivafb, nvidiafb, or nouveau is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA graphics device(s), or no NVIDIA GPU installed in this system is supported by this NVIDIA Linux graphics driver release.
Please see the log entries ‘Kernel module load error’ and ‘Kernel messages’ at the end of the file ‘/var/log/nvidia-installer.log’ for more information.
→ Kernel module load error: Required key not available
→ Kernel messages:
[ 97.792794] wlp61s0: RX AssocResp from d8:84:66:0f:8e:80 (capab=0x411 status=0 aid=4)
[ 97.797728] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 97.797730] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 97.797731] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 97.797733] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 97.797734] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[ 97.797735] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
