Problem installing NVIDIA driver on acer predator triton 500 which is running on ubuntu
Hi, I downloaded the recommended driver for my laptop which is for acer predator triton 500 which supports GeForce RTX 2060 and is running on Ubuntu 22.04.
and followed the installation instructions which are provided in README file.
I even tried installing driver from Software & Updates. The same issue repeats.
Even after following the procedures mentioned in README file, Im getting blank screen after restart.
Im attaching the logs. Please help me with this.
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Mon Sep 25 14:54:33 2023
installer version: 535.113.01
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
→ Detected 12 CPUs online; setting concurrency level to 12.
→ Installing NVIDIA driver version 535.113.01.
→ An alternate method of installing the NVIDIA driver was detected. (This is usually a package provided by your distributor.) A driver installed via that method may integrate better with your system than a driver installed by nvidia-installer.
Please review the message provided by the maintainer of this alternate installation method and decide how to proceed:
The NVIDIA driver provided by Ubuntu can be installed by launching the “Software & Updates” application, and by selecting the NVIDIA driver from the “Additional Drivers” tab.
(Answer: Continue installation)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Performing CC check.
→ Kernel source path: ‘/lib/modules/5.19.0-32-generic/build’
→ Kernel output path: ‘/lib/modules/5.19.0-32-generic/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j12 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.19.0-32-generic/build” SYSOUT=“/lib/modules/5.19.0-32-generic/build” clean’…
rm -f -r conftest
make[1]: Entering directory ‘/usr/src/linux-headers-5.19.0-32-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-5.19.0-32-generic’
→ Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j12 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.19.0-32-generic/build” SYSOUT=“/lib/modules/5.19.0-32-generic/build” '…
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0
You are using: cc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
Warning: Compiler version check failed:
The major and minor number of the compiler used to
compile the kernel:
x86_64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38
does not match the compiler used here:
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
It is recommended to set the CC environment variable
to the compiler that was used to compile the kernel.
To skip the test and silence this warning message, set
the IGNORE_CC_MISMATCH environment variable to “1”.
However, mixing compiler versions between the kernel
and kernel modules can result in subtle bugs that are
difficult to diagnose.
*** Failed CC version check. ***
 SYMLINK /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-kernel.o
 SYMLINK /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: ioremap_driver_hardened
CONFTEST: ioremap_driver_hardened_wc
CONFTEST: ioremap_cache_shared
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: pde_data
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_rebar_get_possible_sizes
CONFTEST: wait_for_random_bytes
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: get_backlight_device_by_name
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write_has_pointer_pos_arg
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: vga_tryget
CONFTEST: cc_platform_has
CONFTEST: seq_read_iter
CONFTEST: unsafe_follow_pfn
CONFTEST: drm_gem_object_get
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: add_memory_driver_managed
CONFTEST: device_property_read_u64
CONFTEST: devm_of_platform_populate
CONFTEST: of_dma_configure
CONFTEST: of_property_count_elems_of_size
CONFTEST: of_property_read_variable_u8_array
CONFTEST: of_property_read_variable_u32_array
CONFTEST: i2c_new_client_device
CONFTEST: i2c_unregister_device
CONFTEST: of_get_named_gpio
CONFTEST: devm_gpio_request_one
CONFTEST: gpio_direction_input
CONFTEST: gpio_direction_output
CONFTEST: gpio_get_value
CONFTEST: gpio_set_value
CONFTEST: gpio_to_irq
CONFTEST: icc_get
CONFTEST: icc_put
CONFTEST: icc_set_bw
CONFTEST: dma_buf_export_args
CONFTEST: dma_buf_ops_has_kmap
CONFTEST: dma_buf_ops_has_kmap_atomic
CONFTEST: dma_buf_ops_has_map
CONFTEST: dma_buf_ops_has_map_atomic
CONFTEST: dma_buf_has_dynamic_attachment
CONFTEST: dma_buf_attachment_has_peer2peer
CONFTEST: dma_set_mask_and_coherent
CONFTEST: devm_clk_bulk_get_all
CONFTEST: get_task_ioprio
CONFTEST: mdev_set_iommu_device
CONFTEST: offline_and_remove_memory
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: ioasid_get
CONFTEST: mm_pasid_drop
CONFTEST: mmget_not_zero
CONFTEST: mmgrab
CONFTEST: iommu_sva_bind_device_has_drvdata_arg
CONFTEST: vm_fault_to_errno
CONFTEST: acpi_video_backlight_use_native
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: pin_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_connector_has_vrr_capable_property
CONFTEST: drm_framebuffer_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: nvhost_dma_fence_unpack
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_pxm_to_node
CONFTEST: is_export_symbol_present_screen_info
CONFTEST: is_export_symbol_present_i2c_bus_status
CONFTEST: is_export_symbol_present_tegra_fuse_control_read
CONFTEST: is_export_symbol_present_pci_find_host_bridge
CONFTEST: is_export_symbol_present_tegra_get_platform
CONFTEST: is_export_symbol_present_tsec_comms_send_cmd
CONFTEST: is_export_symbol_present_tsec_comms_set_init_cb
CONFTEST: is_export_symbol_present_tsec_comms_clear_init_cb
CONFTEST: is_export_symbol_present_tsec_comms_alloc_mem_from_gscco
CONFTEST: is_export_symbol_present_tsec_comms_free_gscco_mem
CONFTEST: crypto
CONFTEST: is_export_symbol_present_memory_block_size_bytes
CONFTEST: is_export_symbol_present_int_active_memcg
CONFTEST: is_export_symbol_present_migrate_vma_setup
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_insert_pfn_prot
CONFTEST: vm_fault_has_address
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: pci_dev_has_ats_enabled
CONFTEST: remove_memory_has_nid_arg
CONFTEST: add_memory_driver_managed_has_mhp_flags_arg
CONFTEST: num_registered_fb
CONFTEST: pci_driver_has_driver_managed_dma
CONFTEST: vm_area_struct_has_const_vm_flags
CONFTEST: memory_failure_has_trapno_arg
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: migrate_vma_added_flags
CONFTEST: migrate_device_range
CONFTEST: handle_mm_fault_has_mm_arg
CONFTEST: handle_mm_fault_has_pt_regs_arg
CONFTEST: mempolicy_has_unified_nodes
CONFTEST: mempolicy_has_home_node
CONFTEST: mmu_interval_notifier
CONFTEST: mpol_preferred_many_present
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_device_list
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_crtc_state_has_vrr_enabled
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: drm_device_has_pdev
CONFTEST: drm_crtc_state_has_no_vblank
CONFTEST: drm_mode_config_has_allow_fb_modifiers
CONFTEST: drm_has_hdr_output_metadata
CONFTEST: dma_resv_add_fence
CONFTEST: dma_resv_reserve_fences
CONFTEST: reservation_object_reserve_shared_has_num_fences_arg
CONFTEST: drm_connector_has_override_edid
CONFTEST: drm_master_has_leases
CONFTEST: drm_file_get_master
CONFTEST: drm_modeset_lock_all_end
CONFTEST: drm_connector_lookup
CONFTEST: drm_connector_put
CONFTEST: drm_driver_has_dumb_destroy
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: vfio_pci_core_available
CONFTEST: mdev_available
CONFTEST: cmd_uphy_display_port_init
CONFTEST: cmd_uphy_display_port_off
CONFTEST: memory_failure_mf_sw_simulated_defined
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: is_export_symbol_present_drm_gem_prime_fd_to_handle
CONFTEST: is_export_symbol_present_drm_gem_prime_handle_to_fd
CONFTEST: ib_peer_memory_symbols
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-pci.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-dmabuf.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-nano-timer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-acpi.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-cray.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-dma.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-i2c.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-mmap.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-p2p.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-pat.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-procfs.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-usermap.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-vm.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-vtophys.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-interface.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-mlock.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-pci.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-registry.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-usermap.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-modeset-interface.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-pci-table.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-kthread-q.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-memdbg.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-ibmnpu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-report-err.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-rsync.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-msi.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-caps.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-frontend.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv_uvm_interface.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_aead.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_ecc.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_hkdf.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_rand.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_shash.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_aead_aes_gcm.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_sha.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_hmac_sha.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_hkdf_sha.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_ec.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_x509.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nvlink_linux.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nvlink_caps.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/linux_nvswitch.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/procfs_nvswitch.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/i2c_nvswitch.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ats_sva.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_conf_computing.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_sec2_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_maxwell_sec2.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_hopper_sec2.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_common.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_linux.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/nvstatus.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/nvCpuUuid.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/nv-kthread-q.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/nv-kthread-q-selftest.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_tools.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_global.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_gpu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_gpu_isr.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_procfs.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_va_space.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_va_space_mm.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_gpu_semaphore.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_mem.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_rm_mem.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_channel.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_lock.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_hal.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_range_tree.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_rb_tree.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_range_allocator.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_va_range.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_va_policy.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_va_block.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_range_group.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_gpu_replayable_faults.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_gpu_access_counters.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_events.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_module.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_mmu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pte_batch.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_tlb_batch.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_push.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pushbuffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_thread_context.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_tracker.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_maxwell.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_maxwell_host.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_maxwell_ce.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_maxwell_mmu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_maxwell_fault_buffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_maxwell_access_counter_buffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pascal.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pascal_ce.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pascal_host.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pascal_mmu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pascal_fault_buffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_volta_ce.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_volta_host.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_volta_mmu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_volta.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_volta_fault_buffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_volta_access_counter_buffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_turing.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_turing_access_counter_buffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_turing_fault_buffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_turing_mmu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_turing_host.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ampere.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ampere_ce.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ampere_host.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ampere_mmu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_hopper.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_hopper_fault_buffer.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_hopper_ce.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_hopper_host.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_hopper_mmu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ada.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_policy.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_utils.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_kvmalloc.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pmm_sysmem.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pmm_gpu.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_migrate.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_populate_pageable.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_migrate_pageable.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_map_external.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_user_channel.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_hmm.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_heuristics.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_thrashing.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_prefetch.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ats.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ats_ibm.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ats_faults.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_test_rng.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_range_tree_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_range_allocator_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_gpu_semaphore_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_mem_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_rm_mem_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_page_tree_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_tracker_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_push_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_channel_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_ce_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_host_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_lock_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_utils_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_kvmalloc_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pmm_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_pmm_sysmem_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_events_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_module_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_get_rm_ptes_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_fault_buffer_flush_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_peer_identity_mappings_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_va_block_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_range_group_tree_test.o
 CC [M]  /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_thread_context_test.o
/tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_events_test.c: In function ‘test_events’:
/tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_perf_events_test.c:83:1: warning: the frame size of 1048 bytes is larger than 1024 bytes [-Wframe-larger-than=]
83 | }
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm/uvm_rb_tree_test.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-fence.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-helper.o
/tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-crtc.c: In function ‘__nv_drm_plane_atomic_destroy_state’:
/tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-crtc.c:695:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
695 | struct nv_drm_plane_state nv_drm_plane_state =
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-gem-dma-buf.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm/nvidia-drm-format.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-peermem/nvidia-peermem.o
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia.o
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm.o
ld -r -o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-interface.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-pci.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-dmabuf.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-nano-timer.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-acpi.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-cray.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-dma.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-i2c.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-mmap.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-p2p.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-pat.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-
535.113.01/kernel/nvidia/nv-procfs.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-usermap.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-vm.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-vtophys.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-interface.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-mlock.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-pci.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-registry.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/os-usermap.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-pci-table.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-kthread-q.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-memdbg.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-ibmnpu.o /tmp/sel
fgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-report-err.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-rsync.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-msi.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-caps.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv-frontend.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_aead.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_ecc.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_hkdf.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_rand.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_shash.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_aead_aes_gcm.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_sha.o /tmp/selfgz14601/NVIDIA-Linux-x86_6
4-535.113.01/kernel/nvidia/libspdm_hmac_sha.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_hkdf_sha.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_ec.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/libspdm_x509.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nvlink_linux.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/nvlink_caps.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/linux_nvswitch.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/procfs_nvswitch.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia/i2c_nvswitch.o
ld -r -o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset.o
/tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-peermem/nvidia-peermem.c: In function ‘nv_mem_client_init’:
/tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-peermem/nvidia-peermem.c:462:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
462 | int status = 0;
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-peermem.o
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm.o
MODPOST /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/Module.symvers
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm.mod.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset.mod.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-peermem.mod.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm.mod.o
CC [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia.mod.o
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-peermem.ko
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm.ko
BTF [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-peermem.ko
Skipping BTF generation for /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-peermem.ko due to unavailability of vmlinux
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia.ko
BTF [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset.ko
Skipping BTF generation for /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-modeset.ko due to unavailability of vmlinux
BTF [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm.ko
Skipping BTF generation for /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-drm.ko due to unavailability of vmlinux
BTF [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm.ko
Skipping BTF generation for /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia-uvm.ko due to unavailability of vmlinux
BTF [M] /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia.ko
Skipping BTF generation for /tmp/selfgz14601/NVIDIA-Linux-x86_64-535.113.01/kernel/nvidia.ko due to unavailability of vmlinux
→ done.
→ Kernel module compilation complete.
→ The target kernel has CONFIG_MODULE_SIG set, which means that it supports cryptographic signatures on kernel modules. On some systems, the kernel may refuse to load modules without a valid signature from a trusted key. This system also has UEFI Secure Boot enabled; many distributions enforce module signature verification on UEFI systems when Secure Boot is enabled. Would you like to sign the NVIDIA kernel module? (Answer: Sign the kernel module)
→ Would you like to sign the NVIDIA kernel module with an existing key pair, or would you like to generate a new one? (Answer: Generate a new key pair)
Generating key pair for module signing…
executing: ‘cd ./kernel; /usr/bin/openssl req -new -x509 -newkey rsa:2048 -days 7300 -nodes -subj “/CN=nvidia-installer generated signing key/” -keyout /tmp/nv-tmp-2ycHqW -outform DER -out /tmp/nv-tmp-JzUTeA -sha512’…
Signing keys generated successfully.
→ Signing kernel module:
executing: ‘“/lib/modules/5.19.0-32-generic/build/scripts/sign-file” “sha512” “/tmp/nv-tmp-2ycHqW” “/tmp/nv-tmp-JzUTeA” “./kernel/nvidia.ko”’…
→ done.
executing: ‘“/lib/modules/5.19.0-32-generic/build/scripts/sign-file” “sha512” “/tmp/nv-tmp-2ycHqW” “/tmp/nv-tmp-JzUTeA” “./kernel/nvidia-uvm.ko”’…
→ done.
executing: ‘“/lib/modules/5.19.0-32-generic/build/scripts/sign-file” “sha512” “/tmp/nv-tmp-2ycHqW” “/tmp/nv-tmp-JzUTeA” “./kernel/nvidia-modeset.ko”’…
→ done.
executing: ‘“/lib/modules/5.19.0-32-generic/build/scripts/sign-file” “sha512” “/tmp/nv-tmp-2ycHqW” “/tmp/nv-tmp-JzUTeA” “./kernel/nvidia-drm.ko”’…
→ done.
executing: ‘“/lib/modules/5.19.0-32-generic/build/scripts/sign-file” “sha512” “/tmp/nv-tmp-2ycHqW” “/tmp/nv-tmp-JzUTeA” “./kernel/nvidia-peermem.ko”’…
→ done.
→ The NVIDIA kernel module was successfully signed with a newly generated key pair. Would you like to delete the private signing key? (Answer: Yes)
→ An X.509 certificate containing the public signing key will be installed to /usr/share/nvidia/nvidia-modsign-crt-DAFF0F2F.der. The SHA1 fingerprint of this certificate is: DA:FF:0F:2F:B3:32:E1:C4:20:D8:98:54:E6:99:32:FB:1D:A3:43:4A.
This certificate must be added to a key database which is trusted by your kernel in order for the kernel to be able to verify the module signature.
/usr/bin/shred -u “/tmp/nv-tmp-2ycHqW”:
→ The signed kernel module failed to load. Secure boot is enabled on this system, so this is likely because the kernel does not trust any key which is capable of verifying the module signature. Would you like to install the signed kernel module anyway?
Note that if this module loading failure is due to the lack of a trusted signature, you will not be able to load the installed module until after a key that can verify the module signature is added to a key database that is trusted by the kernel. This will likely require rebooting your computer. (Answer: Install signed kernel module)
→ An error was encountered when loading the kernel module, but that error was ignored, and the kernel module will be installed, anyway. The error was: Key was rejected by service
→ Ignoring failure to load nvidia.ko.
→ Kernel messages:
[ 1248.884922] IPv6: MLD: clamping QRV from 1 to 2!
[ 1254.824028] IPv6: MLD: clamping QRV from 1 to 2!
[ 1260.976591] IPv6: MLD: clamping QRV from 1 to 2!
[ 1266.906561] IPv6: MLD: clamping QRV from 1 to 2!
[ 1272.845753] IPv6: MLD: clamping QRV from 1 to 2!
[ 1278.784619] IPv6: MLD: clamping QRV from 1 to 2!
[ 1284.928963] IPv6: MLD: clamping QRV from 1 to 2!
[ 1290.868232] IPv6: MLD: clamping QRV from 1 to 2!
[ 1296.808732] IPv6: MLD: clamping QRV from 1 to 2!
[ 1302.951676] IPv6: MLD: clamping QRV from 1 to 2!
[ 1308.890116] IPv6: MLD: clamping QRV from 1 to 2!
[ 1314.829002] IPv6: MLD: clamping QRV from 1 to 2!
[ 1320.973501] IPv6: MLD: clamping QRV from 1 to 2!
[ 1326.913933] IPv6: MLD: clamping QRV from 1 to 2!
[ 1332.851452] IPv6: MLD: clamping QRV from 1 to 2!
[ 1338.993606] IPv6: MLD: clamping QRV from 1 to 2!
[ 1344.935762] IPv6: MLD: clamping QRV from 1 to 2!
[ 1350.874593] IPv6: MLD: clamping QRV from 1 to 2!
[ 1356.813674] IPv6: MLD: clamping QRV from 1 to 2!
[ 1362.957931] IPv6: MLD: clamping QRV from 1 to 2!
[ 1368.897145] IPv6: MLD: clamping QRV from 1 to 2!
[ 1374.836660] IPv6: MLD: clamping QRV from 1 to 2!
[ 1380.980021] IPv6: MLD: clamping QRV from 1 to 2!
[ 1386.919618] IPv6: MLD: clamping QRV from 1 to 2!
[ 1388.923499] Loading of module with unavailable key is rejected
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: No)
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if your kernel changes later. (Answer: Yes)
→ Registering the kernel modules with DKMS:
→ done.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Found libglvnd libraries: libGLESv2.so.2 libOpenGL.so.0 libEGL.so.1 libGLX.so.0 libGL.so.1
Found non-libglvnd libraries:
Missing libraries: libGLESv1_CM.so.1
libglvnd appears to be installed.
Will not install libglvnd libraries.
→ Skipping GLVND file: “libOpenGL.so.0”
→ Skipping GLVND file: “libOpenGL.so”
→ Skipping GLVND file: “libGLESv1_CM.so.1.2.0”
→ Skipping GLVND file: “libGLESv1_CM.so.1”
→ Skipping GLVND file: “libGLESv1_CM.so”
→ Skipping GLVND file: “libGLESv2.so.2.1.0”
→ Skipping GLVND file: “libGLESv2.so.2”
→ Skipping GLVND file: “libGLESv2.so”
→ Skipping GLVND file: “libGLdispatch.so.0”
→ Skipping GLVND file: “libGLX.so.0”
→ Skipping GLVND file: “libGLX.so”
→ Skipping GLVND file: “libGL.so.1.7.0”
→ Skipping GLVND file: “libGL.so.1”
→ Skipping GLVND file: “libGL.so”
→ Skipping GLVND file: “libEGL.so.1.1.0”
→ Skipping GLVND file: “libEGL.so.1”
→ Skipping GLVND file: “libEGL.so”
WARNING: Unable to determine the path to install the libglvnd EGL vendor library config files. Check that you have pkg-config and the libglvnd development libraries installed, or specify a path with --glvnd-egl-config-path.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (535.113.01):
executing: ‘/usr/sbin/ldconfig’…
executing: '/usr/sbin/depmod -a '…
executing: ‘/usr/bin/systemctl daemon-reload’…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: Yes)
→ Your X configuration file has been successfully updated. Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 535.113.01) is now complete.
