Thank You !
I will check that topic now .
my nvidia bug report log is below:
Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 26499344
Date: Tue 2 Jul 21:57:58 AEST 2019
uname: Linux djczapslapTUF 5.1.15-050115-generic #201906250430 SMP Tue Jun 25 04:33:37 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r-- 1 root root 29 2018-11-29 22:46:32.000000000 +1100 /etc/issue
Linux Mint 19.1 Tessa \n \l
*** /etc/debian_version
*** ls: -rw-r–r-- 1 root root 11 2017-06-26 08:18:00.000000000 +1000 /etc/debian_version
buster/sid
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 29045 2019-06-23 20:51:50.644288922 +1000 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Sun Jun 23 20:50:04 2019
installer version: 430.09
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 8 CPUs online; setting concurrency level to 8.
→ Installing NVIDIA driver version 430.09.
→ There appears to already be a driver installed on your system (version: 430.09). As part of installing this driver (version: 430.09), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/5.1.14-050114-generic/build’
→ Kernel output path: ‘/lib/modules/5.1.14-050114-generic/build’
→ The CC version check failed:
The kernel was built with gcc version 8.3.0 (Ubuntu 8.3.0-14ubuntu1), but the current compiler version is cc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0.
This may lead to subtle problems; if you are not certain whether the mismatched compiler will be compatible with your kernel, you may wish to abort installation, set the CC environment variable to the name of the compiler used to compile your kernel, and restart installation. (Answer: Ignore CC version check)
WARNING: Ignoring CC version mismatch:
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j8 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.1.14-050114-generic/build” SYSOUT=“/lib/modules/5.1.14-050114-generic/build”’…
rm -f -r conftest
make[1]: Entering directory ‘/usr/src/linux-headers-5.1.14-050114-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-5.1.14-050114-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j8 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.1.14-050114-generic/build” SYSOUT=“/lib/modules/5.1.14-050114-generic/build”’…
SYMLINK /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: acpi_walk_namespace
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: ioremap_wc
CONFTEST: sg_alloc_table
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_find_node_by_phandle
CONFTEST: of_get_property
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: do_gettimeofday
CONFTEST: kernel_read
CONFTEST: kernel_write
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: vmf_insert_pfn
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: scatterlist
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: node_states_n_memory
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: pm_runtime_available
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_va_space_mm.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_turing.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_turing_mmu.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_turing_host.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_populate_pageable.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_migrate_pageable.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
ld -r -o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-interface.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-frontend.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-instance.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-acpi.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-chrdev.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-cray.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-dma.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-gvi.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-i2c.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-mempool.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-mmap.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-p2p.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-pat.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-procfs.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-usermap.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-vm.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-vtophys.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-43
0.09/kernel/nvidia/os-interface.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-mlock.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-pci.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-registry.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/os-usermap.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-pci-table.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-kthread-q.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-memdbg.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-report-err.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-rsync.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv-msi.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/nvlink_linux.
o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia/linux_nvswitch.o
ld -r -o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia.o
LD [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm.mod.o
CC /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia.mod.o
LD [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz6894/NVIDIA-Linux-x86_64-430.09/kernel/nvidia.ko
→ done.
→ Kernel module compilation complete.
→ Kernel messages:
[ 292.929439] wlp4s0: authenticated
[ 292.930894] wlp4s0: associate with 14:59:c0:59:55:2d (try 1/3)
[ 292.938266] wlp4s0: RX AssocResp from 14:59:c0:59:55:2d (capab=0x1511 status=0 aid=2)
[ 292.938505] wlp4s0: associated
[ 292.964182] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 293.100493] wlp4s0: Limiting TX power to 24 (24 - 0) dBm as advertised by 14:59:c0:59:55:2d
[ 972.298086] VFIO - User Level meta-driver version: 0.3
[ 972.312283] IPMI message handler: version 39.2
[ 972.313813] ipmi device interface
[ 972.325025] nvidia: loading out-of-tree module taints kernel.
[ 972.325042] nvidia: module license ‘NVIDIA’ taints kernel.
[ 972.325043] Disabling lock debugging due to kernel taint
[ 972.335572] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 972.342394] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 972.342874] nvidia 0000:01:00.0: enabling device (0000 → 0003)
[ 972.343008] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 972.383998] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 430.09 Thu Apr 18 03:09:38 CDT 2019
[ 972.391806] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 509
[ 972.394679] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 430.09 Thu Apr 18 02:25:57 CDT 2019
[ 972.398864] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 972.398867] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 972.400845] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 972.425148] nvidia-modeset: Unloading
[ 972.501693] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 972.520753] nvidia-nvlink: Unregistered the Nvlink Core, major device number 511
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
→ Will install GLVND GLX client libraries.
→ Will install GLVND EGL client libraries.
→ Skipping GLX non-GLVND file: “libGL.so.430.09”
→ Skipping GLX non-GLVND file: “libGL.so.1”
→ Skipping GLX non-GLVND file: “libGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.430.09”
→ Skipping EGL non-GLVND file: “libEGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.1”
→ Skipping GLX non-GLVND file: “./32/libGL.so.430.09”
→ Skipping EGL non-GLVND file: “./32/libEGL.so.430.09”
→ Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Checking libGLdispatch dispatch table
Checking call through libGLdispatch
All OK
libGLdispatch is OK
Checking for libGLX
libGLX is OK
Checking for libEGL
libEGL is OK
Checking entrypoint library libOpenGL.so.0
Checking call through library libOpenGL.so.0
dlopen(“libOpenGL.so.0”) failed: libOpenGL.so.0: cannot open shared object file: No such file or directory
Checking entrypoint library libGL.so.1
Checking call through library libGL.so.1
All OK
Entrypoint library libGL.so.1 is OK
Found libglvnd libraries: libGL.so.1 libEGL.so.1 libGLX.so.0 libGLdispatch.so.0
Missing libglvnd libraries: libOpenGL.so.0
→ An incomplete installation of libglvnd was found. All of the essential libglvnd libraries are present, but one or more optional components are missing. Do you want to install a full copy of libglvnd? This will overwrite any existing libglvnd libraries. (Answer: Install and overwrite existing files)
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (430.09):
executing: ‘/sbin/ldconfig’…
executing: '/sbin/depmod -a '…
→ done.
→ Driver file installation is complete.
ERROR: Unable to load the ‘nvidia-drm’ kernel module.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
*** /var/log/nvidia-uninstall.log
*** ls: -rw-r–r-- 1 root root 1980 2019-06-23 20:58:51.073042430 +1000 /var/log/nvidia-uninstall.log
nvidia-installer log file ‘/var/log/nvidia-uninstall.log’
creation time: Sun Jun 23 20:58:46 2019
-s
Using built-in stream user interface
→ If you plan to no longer use the NVIDIA driver, you should make sure that no X screens are configured to use the NVIDIA X driver in your X configuration file. If you used nvidia-xconfig to configure X, it may have created a backup of your original configuration. Would you like to run nvidia-xconfig --restore-original-backup to attempt restoration of the original X configuration file? (Answer: No)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ The installed file ‘/usr/share/man/man1/nvidia-cuda-mps-control.1.gz’ has a different checksum (2070222035l) than when it was installed (2291163083l).
→ The installed file ‘/usr/share/man/man1/nvidia-persistenced.1.gz’ has a different checksum (1396201986l) than when it was installed (3118426467l).
→ The installed file ‘/usr/bin/nvidia-persistenced’ seems to have changed, but prelink -u failed; unable to restore ‘/usr/bin/nvidia-persistenced’ to an un-prelinked state.
→ done.
WARNING: Your driver installation has been altered since it was initially installed; this may happen, for example, if you have since installed the NVIDIA driver through a mechanism other than nvidia-installer (such as your distribution’s native package management system). nvidia-installer will attempt to uninstall as best it can. Please see the file ‘/var/log/nvidia-uninstall.log’ for details.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-43009 (430.09)):
→ done.
→ Running depmod and ldconfig:
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (430.09) is complete.
*** /var/lib/dkms/nvidia/430.26/5.1.14-050114-generic/x86_64/log/make.log
*** ls: -rw-r–r-- 1 root root 390344 2019-06-23 20:59:16.559352289 +1000 /var/lib/dkms/nvidia/430.26/5.1.14-050114-generic/x86_64/log/make.log
DKMS make.log for nvidia-430.26 for kernel 5.1.14-050114-generic (x86_64)
Sun 23 Jun 20:58:55 AEST 2019
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (
echo >&2;
echo >&2 " ERROR: Kernel configuration is invalid.“;
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.”;
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it.";
echo >&2 ;
/bin/false)
mkdir -p /var/lib/dkms/nvidia/430.26/build/.tmp_versions ; rm -f /var/lib/dkms/nvidia/430.26/build/.tmp_versions/*
make -f ./scripts/Makefile.build obj=/var/lib/dkms/nvidia/430.26/build
ln -sf /var/lib/dkms/nvidia/430.26/build/nvidia/nv-kernel.o_binary /var/lib/dkms/nvidia/430.26/build/nvidia/nv-kernel.o
ln -sf /var/lib/dkms/nvidia/430.26/build/nvidia-modeset/nv-modeset-kernel.o_binary /var/lib/dkms/nvidia/430.26/build/nvidia-modeset/nv-modeset-kernel.o
(cat /dev/null; echo kernel//var/lib/dkms/nvidia/430.26/build/nvidia.ko; echo kernel//var/lib/dkms/nvidia/430.26/build/nvidia-uvm.ko; echo kernel//var/lib/dkms/nvidia/430.26/build/nvidia-modeset.ko; echo kernel//var/lib/dkms/nvidia/430.26/build/nvidia-drm.ko;) > /var/lib/dkms/nvidia/430.26/build/modules.order
CONFTEST: INIT_WORK
CONFTEST: pde_data
CONFTEST: write_cr4
CONFTEST: dma_direct_map_resource
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: kuid_t
CONFTEST: dma_ops
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-frontend.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_frontend”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-frontend.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-frontend.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-instance.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_instance”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-instance.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-instance.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-acpi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_acpi”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-acpi.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-acpi.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-chrdev.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_chrdev”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-chrdev.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-chrdev.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-cray.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_cray”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-cray.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-cray.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-dma.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_dma”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-dma.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-dma.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-gvi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_gvi”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-gvi.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-gvi.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-i2c.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_i2c”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-i2c.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-i2c.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-mempool.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_mempool”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-mempool.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-mempool.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-mmap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi -include ./include/linux/kconfig.h -include ./include/linux/compiler_types.h -D__KERNEL__ -Wall -Wundef -Werror=strict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -fshort-wchar -fno-PIE -Werror=implicit-function-declaration -Werror=implicit-int -Wno-format-security -std=gnu89 -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -Wno-sign-compare -fno-asynchronous-unwind-tables -mindirect-branch=thunk-extern -mindirect-branch-register -fno-jump-tables -fno-delete-null-pointer-checks -Wno-frame-address -Wno-format-truncation -Wno-format-overflow -Wno-int-in-bool-context -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -Wno-unused-const-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mrecord-mcount -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wvla -Wno-pointer-sign -fno-strict-overflow -fno-merge-all-constants -fmerge-constants -fno-stack-check -fconserve-stack -Werror=date-time -Werror=incompatible-pointer-types -Werror=designated-init -I/var/lib/dkms/nvidia/430.26/build/common/inc -I/var/lib/dkms/nvidia/430.26/build -Wall -MD -Wno-cast-qual -Wno-error -Wno-format-extra-args -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="430.26" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -Werror=undef -DNV_SPECTRE_V2=0 -I/var/lib/dkms/nvidia/430.26/build/nvidia -DNV_BUILD_MODULE_INSTANCES=0 -DNVIDIA_UNDEF_LEGACY_BIT_MACROS -UDEBUG -U_DEBUG -DNDEBUG -DMODULE -DKBUILD_BASENAME=‘“nv_mmap”’ -DKBUILD_MODNAME=‘“nvidia”’ -c -o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-mmap.o /var/lib/dkms/nvidia/430.26/build/nvidia/nv-mmap.c
cc -Wp,-MD,/var/lib/dkms/nvidia/430.26/build/nvidia/.nv-p2p.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/7/include -I./arch/x86/include -I./arch/x86/include/generated -I./include -I./arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I./include/uapi -I./include/generated/uapi
