I have a jetson nano with ubuntu installed on it and im trying to install cuda but i keep getting multiple errors. I’ve followed the Pre-install steps i had a slight issue with the pre install steps when installing the linux headers: when i run uname -r i get the following output: 4.9.253-tegra but then when i try to update the headers udo apt-get install linux-headers-$(uname -r) i get the following error:
E: Unable to locate package linux-headers-4.9.253-tegra
E: Couldn't find any package by glob 'linux-headers-4.9.253-tegra'
E: Couldn't find any package by regex 'linux-headers-4.9.253-tegra'
after researching online i found that the best solution is to use apt-cache to find all the available headers then download the closest fit. I ended up downloading
sudo apt-get install linux-headers-4.18.0.25-generic
and this worked fine, then i went on and downloaded the cuda toolkit however this gave me an error again.
When i enter in:
sudo sh cuda_11.4.1_470.57.02_linux_sbsa.run
i run into the following error:
Installation failed. See log at /var/log/cuda-installer.log for details.
this is the log files outputted by the cuda installer
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)
[INFO]: Initializing menu
[INFO]: Setup complete
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 470.57.02
[INFO]: Executing NVIDIA-Linux-aarch64-470.57.02.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --install-libglvnd 2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 470.57.02 failed, quitting
And this is the file outputted by the nvidia-installer:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri Aug 20 11:11:11 2021
installer version: 470.57.02
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
--ui=none
--no-questions
--accept-license
--disable-nouveau
--install-libglvnd
Using built-in stream user interface
-> Detected 4 CPUs online; setting concurrency level to 4.
WARNING: You do not appear to have an NVIDIA GPU supported by the 470.57.02 NVIDIA Linux graphics driver installed in this system. For further details, please see the appendix SUPPORTED NVIDIA GRAPHICS CHIPS in the README available on the Linux driver download page at www.nvidia.com.
-> Installing NVIDIA driver version 470.57.02.
-> An alternate method of installing the NVIDIA driver was detected. (This is usually a package provided by your distributor.) A driver installed via that method may integrate better with your system than a driver installed by nvidia-installer.
Please review the message provided by the maintainer of this alternate installation method and decide how to proceed:
The NVIDIA driver provided by Ubuntu can be installed by launching the "Software & Updates" application, and by selecting the NVIDIA driver from the "Additional Drivers" tab.
(Answer: Continue installation)
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written. If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file. Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
-> For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
-> One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to re-enable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Performing CC check.
-> Kernel source path: '/lib/modules/4.9.253-tegra/build'
-> Kernel output path: '/lib/modules/4.9.253-tegra/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /usr/bin/make -k -j4 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.9.253-tegra/build" SYSOUT="/lib/modules/4.9.253-tegra/build"'...
rm -f -r conftest
make[1]: Entering directory '/usr/src/linux-headers-4.9.253-tegra-ubuntu18.04_aarch64/kernel-4.9'
make[1]: Leaving directory '/usr/src/linux-headers-4.9.253-tegra-ubuntu18.04_aarch64/kernel-4.9'
-> Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.9.253-tegra/build" SYSOUT="/lib/modules/4.9.253-tegra/build"'...
SYMLINK /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: list_is_first
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: get_backlight_device_by_name
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: hlist_for_each_entry
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: vga_tryget
CONFTEST: pgprot_decrypted
CONFTEST: iterate_fd
CONFTEST: seq_read_iter
CONFTEST: sg_page_iter_page
CONFTEST: unsafe_follow_pfn
CONFTEST: drm_gem_object_get
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: set_close_on_exec
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: drm_dev_unref
CONFTEST: get_user_pages_remote
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present_close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: acpi_fadt_low_power_s0
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_device_list
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: pm_runtime_available
CONFTEST: nvidia_grid_csp_build
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: ib_peer_memory_symbols
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-pci.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-mmap.o
/tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-dma.c:963:0: warning: "IMPORT_SGT_STUBS_NEEDED" redefined
#define IMPORT_SGT_STUBS_NEEDED 0
/tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-dma.c:957:0: note: this is the location of the previous definition
#define IMPORT_SGT_STUBS_NEEDED 1
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-procfs-utils.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-caps.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nvlink_caps.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/procfs_nvswitch.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/i2c_nvswitch.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_tools.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_global.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_gpu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_gpu_isr.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_procfs.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_va_space.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_va_space_mm.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_gpu_semaphore.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_mem.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_rm_mem.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_channel.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_lock.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_hal.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_range_tree.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_rb_tree.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_range_allocator.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_va_range.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_va_block.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_range_group.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_gpu_replayable_faults.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_gpu_access_counters.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_events.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_module.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_mmu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pte_batch.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_tlb_batch.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_push.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pushbuffer.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_thread_context.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_tracker.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_kepler.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_kepler_ce.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_kepler_host.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_kepler_mmu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_kepler_fault_buffer.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_kepler_access_counter_buffer.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_maxwell.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_maxwell_host.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pascal.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pascal_ce.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pascal_host.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pascal_mmu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_volta_host.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_volta_mmu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_volta.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_turing.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_turing_access_counter_buffer.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_turing_fault_buffer.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_turing_mmu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_turing_host.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_ampere.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_ampere_ce.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_ampere_host.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_ampere_mmu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_policy.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_utils.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_kvmalloc.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pmm_sysmem.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pmm_gpu.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_migrate.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_populate_pageable.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_migrate_pageable.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_map_external.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_user_channel.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_hmm.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_heuristics.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_thrashing.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_prefetch.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_ats_ibm.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_ats_faults.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_test_rng.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_range_tree_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_range_allocator_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_mem_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_rm_mem_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_page_tree_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_tracker_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_push_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_channel_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_ce_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_host_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_lock_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_utils_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_kvmalloc_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pmm_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_events_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_perf_module_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_mmu_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_va_block_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_range_group_tree_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_thread_context_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm/uvm_rb_tree_test.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-gem.o
/tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-crtc.c: In function 'plane_req_config_update':
/tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-crtc.c:89:9: warning: unused variable 'ret' [-Wunused-variable]
int ret = 0;
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-linux.o
/tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-modeset.c: In function '__will_generate_flip_event':
/tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-modeset.c:96:23: warning: unused variable 'primary_plane' [-Wunused-variable]
struct drm_plane *primary_plane = crtc->primary;
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-gem-dma-buf.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm/nvidia-drm-format.o
CC [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-peermem/nvidia-peermem.o
ld -EL -r -o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-interface.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-pci.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-acpi.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-cray.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-dma.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-i2c.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-mmap.o /tmp/selfgz17
441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-p2p.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-pat.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-procfs.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-procfs-utils.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-usermap.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-vm.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-vtophys.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-interface.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-mlock.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-pci.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-registry.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/os-usermap.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv
-pci-table.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-kthread-q.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-memdbg.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-report-err.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-rsync.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-msi.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-caps.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv-frontend.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nvlink_linux.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/nvlink_caps.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/linux_nvswitch.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia/procfs_nvswitch.o /tmp/selfgz17441/NVIDIA
ld -EL -r -o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia.o
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm.o
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-peermem.o
Building modules, stage 2.
MODPOST 5 modules
CC /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm.mod.o
CC /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-peermem.mod.o
CC /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia.mod.o
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-peermem.ko
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz17441/NVIDIA-Linux-aarch64-470.57.02/kernel/nvidia.ko
-> done.
-> Kernel module compilation complete.
-> Unable to determine if Secure Boot is enabled: No such file or directory
ERROR: Unable to load the kernel module 'nvidia.ko'. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA GPU installed in this system is supported by this NVIDIA Linux graphics driver release.
Please see the log entries 'Kernel module load error' and 'Kernel messages' at the end of the file '/var/log/nvidia-installer.log' for more information.
-> Kernel module load error: Exec format error
-> Kernel messages:
[ 7.503488] Bridge firewalling registered
[ 7.538125] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 7.828025] Netfilter messages via NETLINK v0.30.
[ 7.830573] ctnetlink v0.93: registering with nfnetlink.
[ 8.031370] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 8.310578] tegradc tegradc.0: unblank
[ 8.310844] tegradc tegradc.1: blank - powerdown
[ 8.434794] r8168: eth0: link up
[ 8.434873] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.643305] fuse init (API version 7.26)
[ 12.173665] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.173675] Bluetooth: BNEP socket layer initialized
[ 13.077319] tegradc tegradc.0: unblank
[ 13.077329] tegradc tegradc.1: blank - powerdown
[ 31.861378] vdd-fan: disabling
[ 31.861420] vdd-usb-vbus: disabling
[ 31.861451] vdd-usb-vbus2: disabling
[ 31.861546] vddio-sdmmc3-ap: disabling
[ 31.862156] avdd-io-edp-1v05: disabling
[ 31.862188] vdd-usb-hub-en: disabling
[ 413.879709] nvidia: loading out-of-tree module taints kernel.
[ 413.879734] nvidia: module license 'NVIDIA' taints kernel.
[ 413.879736] Disabling lock debugging due to kernel taint
[ 414.396682] nvidia: exports duplicate symbol nvidia_p2p_dma_map_pages (owned by nvgpu)
[ 2465.754297] nvidia: exports duplicate symbol nvidia_p2p_dma_map_pages (owned by nvgpu)
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
can i please get some assistance on how to fix this? ive tried everything mentioned in the other forums, and tried rebooting my system but nothing seems to fix it. is it because i downloaded the wrong driver? if its because of the wrong driver then how am i supposed to install the correct driver?
