I have a 2080Ti setup with CUDA 10.1 preivously installed. The driver suddenly could not be recognised and hence I’m installing cuda again. however i cant seem to get i working this time. using the runfile cuda-installer.log provides:
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 418.87.00 failed, quitting
nvidia-installer.log provides this:
[i]nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Tue Jan 21 11:00:28 2020
installer version: 418.87.00
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
–ui=none
–no-questions
–accept-license
–disable-nouveau
–no-cc-version-check
–install-libglvnd
Using built-in stream user interface
→ Detected 16 CPUs online; setting concurrency level to 16.
→ Installing NVIDIA driver version 418.87.00.
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written. If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file. Please consult the NVIDIA driver README and your Linux distribution’s documentation for details on how to correctly disable the Nouveau kernel driver.
→ For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
→ One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/5.3.0-26-generic/build’
→ Kernel output path: ‘/lib/modules/5.3.0-26-generic/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j16 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.3.0-26-generic/build” SYSOUT=“/lib/modules/5.3.0-26-generic/build”’…
rm -f -r conftest
make[1]: Entering directory ‘/usr/src/linux-headers-5.3.0-26-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-5.3.0-26-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j16 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.3.0-26-generic/build” SYSOUT=“/lib/modules/5.3.0-26-generic/build”’…
SYMLINK /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: hash__remap_4k_pfn
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_choose_state
CONFTEST: pci_get_class
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: kmem_cache_create
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: acpi_walk_namespace
CONFTEST: ioremap_wc
CONFTEST: pci_dma_mapping_error
CONFTEST: ioremap_cache
CONFTEST: pci_domain_nr
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: sg_init_table
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: phys_to_dma
CONFTEST: xen_ioemu_inject_msi
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: backlight_device_register
CONFTEST: dma_map_resource
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: compound_order
CONFTEST: do_gettimeofday
CONFTEST: remap_page_range
CONFTEST: dma_direct_map_resource
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_dev_unref
CONFTEST: get_user_pages_remote
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: vmf_insert_pfn
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: atomic64_type
CONFTEST: fault_flags
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: node_states_n_memory
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-usermap.o
/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-mmap.c: In function ‘nv_encode_caching’:
/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-mmap.c:255:16: warning: this statement may fall through [-Wimplicit-fallthrough=]
if (NV_ALLOW_CACHING(memory_type))
/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-mmap.c:257:9: note: here
default:
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_va_space_mm.o
In file included from /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv_uvm_interface.c:21:0:
/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv_uvm_interface.c: In function ‘nvUvmInterfaceDeRegisterUvmOps’:
/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/common/inc/nv-linux.h:733:21: error: void value not ignored as it ought to be
int __ret = on_each_cpu(func, info, 1);
/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv_uvm_interface.c:991:5: note: in expansion of macro ‘NV_ON_EACH_CPU’
NV_ON_EACH_CPU(flush_top_half, NULL);
scripts/Makefile.build:288: recipe for target ‘/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv_uvm_interface.o’ failed
make[2]: *** [/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia/nv_uvm_interface.o] Error 1
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_range_allocator.o
/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_tools.c:209:13: error: conflicting types for ‘put_user_pages’
static void put_user_pages(struct page **pages, NvU64 page_count)
In file included from /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/common/inc/nv-pgprot.h:17:0,
from /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/common/inc/nv-linux.h:20,
from /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm_linux.h:41,
from /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm_common.h:48,
from /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_tools.c:23:
./include/linux/mm.h:1057:6: note: previous declaration of ‘put_user_pages’ was here
void put_user_pages(struct page **pages, unsigned long npages);
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_va_range.o
scripts/Makefile.build:288: recipe for target ‘/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_tools.o’ failed
make[2]: *** [/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_tools.o] Error 1
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_turing.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_turing_mmu.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_turing_host.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_populate_pageable.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_migrate_pageable.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
LD [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-modeset.o
ld -r -o /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel/nvidia-drm.o
make[2]: Target ‘__build’ not remade because of errors.
Makefile:1655: recipe for target ‘module/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel’ failed
make[1]: *** [module/tmp/selfgz2913/NVIDIA-Linux-x86_64-418.87.00/kernel] Error 2
make[1]: Target ‘modules’ not remade because of errors.
Makefile:81: recipe for target ‘modules’ failed
make: *** [modules] Error 2
→ Error.
ERROR: An error occurred while performing the step: “Building kernel modules”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j16 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/5.3.0-26-generic/build" SYSOUT="/lib/modules/5.3.0-26-generic/build"
failed with the following output:
CONFTEST: INIT_WORK
CONFTEST: vmap
CONFTEST: pde_data
CONFTEST: write_cr4
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: sg_table
CONFTEST: kuid_t
CONFTEST: dma_ops
default:
→ Checking to see whether the nvidia kernel module was successfully built
executing: ‘cd ./kernel; /usr/bin/make -k -j16 NV_KERNEL_MODULES=“nvidia” NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.3.0-26-generic/build” SYSOUT=“/lib/modules/5.3.0-26-generic/build”’…
→ Error.
ERROR: An error occurred while performing the step: “Checking to see whether the nvidia kernel module was successfully built”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j16 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/5.3.0-26-generic/build" SYSOUT="/lib/modules/5.3.0-26-generic/build"
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com[/i].
I dont really understand what the problem is. Any help is appreciated
