Hello, I’m trying to install Cuuda 12.0 on Ubuntu 12.0. I have gcc 11.4 installed and I’m getting compiler mismatch errors while installing the driver
→ Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/6.2.0-26-generic/build” SYSOUT="/li>
make[1]: Entering directory ‘/usr/src/linux-headers-6.2.0-26-generic’
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-11 (Ubuntu 11.3.0-1ubuntu1~22.04.1) 11.3.0
You are using: cc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
Warning: Compiler version check failed:
The major and minor number of the compiler used to
compile the kernel:
x86_64-linux-gnu-gcc-11 (Ubuntu 11.3.0-1ubuntu1~22.04.1) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38
does not match the compiler used here:
I passed the override flag to the run command:
sudo ./cuda_12.0.0_525.60.13_linux.run --silent --driver --override --override-driver-check
and also set the IGNORE_CC_MISMATCH=“1”
All to no avail. Please help.
this is for the driver installation. none of those overrides or env vars are for the driver installation.
Get your toolchain matched up to the one that was used to compile the kernel (11.3)
Robert, can you be more specific?
I also ran into this problem… due to the linux kernel update. ~
Now we can not reinstall/install the drivers.
compile the kernel:
For our application, we need to follow these requirements:
Our setup is:
Ubuntu 22.04 (kernel version: Ubuntu 22.04.3 LTS (GNU/Linux 6.2.0-26-generic x86_64))
Nvidia Driver: NVIDIA-Linux-x86_64**-520.61.05.run**
To have the CUDA 11.8, the driver 520.61.05 seems to be the latest currently supported CUDA – Drivers compatibility table
Are we missing something? We can not install the version gcc-11.3 as this is now not supported by our kernel and I fear it might brick the system.
Best Regards,
André.
To me, that is very specific. You are using gcc/g++ 11.4, and in order to eliminate that warning with your current kernel, you need to switch to using gcc/g++ 11.3.
Switching the gcc/g++ toolchain in use is not something that is unique or specific to CUDA. You should be able to find many articles on the web that describe how to use a particular gcc/g++ version in linux.
To be clear, neither posting gives any indication that the driver install failed, nor any indication of the actual problem if it did. It may have failed or it might not have. But this post doesn’t contain the necessary info to sort anything out (other than the suggestion to switch gcc/g++ version if you want to eliminate that particular warning. Generally speaking, a warning is not an error.)
I’m not sure what the reason is for your driver install issues. If you’re unwilling to use gcc-11.3 then I cannot make this warning go away. Whether that is an actual problem or not, I cannot say.
Update: I just compiled gcc11.3 from source, now the logs look like this…
***@***:/home/***/NVIDIA# cat /var/log/nvidia-installer.log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Aug 21 18:27:42 2023
installer version: 520.61.05
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/cuda-11.8/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
-> Detected 96 CPUs online; setting concurrency level to 32.
-> Installing NVIDIA driver version 520.61.05.
-> There appears to already be a driver installed on your system (version: 520.61.05). As part of installing this driver (version: 520.61.05), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
-> An alternate method of installing the NVIDIA driver was detected. (This is usually a package provided by your distributor.) A driver installed via that method may integrate better with your system than a driver installed by nvidia-installer.
Please review the message provided by the maintainer of this alternate installation method and decide how to proceed:
The NVIDIA driver provided by Ubuntu can be installed by launching the "Software & Updates" application, and by selecting the NVIDIA driver from the "Additional Drivers" tab.
-> Performing CC sanity check with CC="/usr/local/gcc-11.3.0/bin/x86_64-linux-gnu-gcc-11.3".
-> Performing CC check.
-> Kernel source path: '/lib/modules/6.2.0-26-generic/build'
-> Kernel output path: '/lib/modules/6.2.0-26-generic/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.2.0-26-generic/build" SYSOUT="/lib/modules/6.2.0-26-generic/build" clean'...
rm -f -r conftest
make[1]: Entering directory '/usr/src/linux-headers-6.2.0-26-generic'
make[1]: Leaving directory '/usr/src/linux-headers-6.2.0-26-generic'
-> Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.2.0-26-generic/build" SYSOUT="/lib/modules/6.2.0-26-generic/build" '...
You are using: x86_64-linux-gnu-gcc-11.3 (GCC) 11.3.0
SYMLINK /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: sg_alloc_table
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_remove
CONFTEST: pde_data
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_node_to_nid
CONFTEST: of_find_node_by_phandle
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: get_backlight_device_by_name
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kthread_create_on_node
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: hlist_for_each_entry
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: vga_tryget
CONFTEST: pgprot_decrypted
CONFTEST: cc_mkdec
CONFTEST: seq_read_iter
CONFTEST: iterate_fd
CONFTEST: sg_page_iter_page
CONFTEST: unsafe_follow_pfn
CONFTEST: drm_gem_object_get
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: set_close_on_exec
CONFTEST: add_memory_driver_managed
CONFTEST: device_property_read_u64
CONFTEST: devm_of_platform_populate
CONFTEST: of_dma_configure
CONFTEST: of_property_count_elems_of_size
CONFTEST: of_property_read_variable_u8_array
CONFTEST: i2c_new_client_device
CONFTEST: i2c_unregister_device
CONFTEST: of_get_named_gpio
CONFTEST: devm_gpio_request_one
CONFTEST: gpio_direction_input
CONFTEST: gpio_direction_output
CONFTEST: gpio_get_value
CONFTEST: gpio_set_value
CONFTEST: gpio_to_irq
CONFTEST: icc_get
CONFTEST: icc_put
CONFTEST: icc_set_bw
CONFTEST: dma_buf_export_args
CONFTEST: dma_buf_ops_has_kmap
CONFTEST: dma_buf_ops_has_kmap_atomic
CONFTEST: dma_buf_ops_has_map
CONFTEST: dma_buf_ops_has_map_atomic
CONFTEST: dma_buf_has_dynamic_attachment
CONFTEST: dma_buf_attachment_has_peer2peer
CONFTEST: dma_set_mask_and_coherent
CONFTEST: get_task_ioprio
CONFTEST: address_space_init_once
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: ioasid_get
CONFTEST: migrate_vma_setup
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: nvhost_dma_fence_unpack
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_pxm_to_node
CONFTEST: is_export_symbol_present_screen_info
CONFTEST: is_export_symbol_present_int_active_memcg
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: file_operations
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: pci_dev_has_ats_enabled
CONFTEST: remove_memory_has_nid_arg
CONFTEST: add_memory_driver_managed_has_mhp_flags_arg
CONFTEST: num_registered_fb
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: migrate_vma_added_flags
CONFTEST: make_device_exclusive_range
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_device_list
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_device_has_pdev
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: drm_crtc_state_has_no_vblank
CONFTEST: drm_mode_config_has_allow_fb_modifiers
CONFTEST: dma_resv_add_fence
CONFTEST: dma_resv_reserve_fences
CONFTEST: reservation_object_reserve_shared_has_num_fences_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: ib_peer_memory_symbols
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pci.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-dmabuf.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-procfs-utils.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-caps.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nvlink_caps.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/procfs_nvswitch.o
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-dma.c: In function ‘nv_dma_use_map_resource’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-dma.c:783:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
783 | const struct dma_map_ops *ops = get_dma_ops(dma_dev->dev);
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-mmap.c: In function ‘nv_encode_caching’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-mmap.c:344:16: warning: this statement may fall through [-Wimplicit-fallthrough=]
344 | if (NV_ALLOW_CACHING(memory_type))
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-mmap.c:347:9: note: here
347 | default:
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/i2c_nvswitch.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_hopper.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_hopper_fault_buffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_hopper_ce.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_hopper_host.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_hopper_mmu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ada.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_tools.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_global.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_gpu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_gpu_isr.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_procfs.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_va_space.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_va_space_mm.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_gpu_semaphore.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_mem.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_rm_mem.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_channel.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_lock.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_hal.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_range_tree.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_rb_tree.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_range_allocator.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_va_range.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_va_policy.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_va_block.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_range_group.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_gpu_replayable_faults.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_gpu_access_counters.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_events.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_module.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_mmu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pte_batch.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_tlb_batch.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_push.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pushbuffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_thread_context.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_tracker.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_maxwell.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_maxwell_host.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_maxwell_ce.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_maxwell_mmu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_maxwell_fault_buffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_maxwell_access_counter_buffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pascal.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pascal_ce.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pascal_host.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pascal_mmu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_volta_host.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_volta_mmu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_volta.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_turing.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_turing_access_counter_buffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_turing_fault_buffer.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_turing_mmu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_turing_host.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ampere.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ampere_ce.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ampere_host.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ampere_mmu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_policy.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_utils.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_kvmalloc.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pmm_sysmem.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pmm_gpu.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_migrate.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_populate_pageable.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_migrate_pageable.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_map_external.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_user_channel.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_hmm.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_heuristics.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_thrashing.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_prefetch.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ats.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ats_ibm.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ats_faults.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_test_rng.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_range_tree_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_range_allocator_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_hmm_sanity_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_mem_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_rm_mem_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_page_tree_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_tracker_test.o
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pmm_gpu.c: In function ‘uvm_pmm_gpu_alloc_kernel’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pmm_gpu.c:601:16: warning: unused variable ‘gpu’ [-Wunused-variable]
601 | uvm_gpu_t *gpu = uvm_pmm_to_gpu(pmm);
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_push_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_channel_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_ce_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_host_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_lock_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_utils_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_kvmalloc_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pmm_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_events_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_perf_module_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_va_block_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_range_group_tree_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_thread_context_test.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_rb_tree_test.o
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_channel_test.c: In function ‘test_unexpected_completed_values’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm/uvm_channel_test.c:156:15: warning: unused variable ‘status’ [-Wunused-variable]
156 | NV_STATUS status;
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-gem-dma-buf.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-format.o
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-peermem/nvidia-peermem.o
ld -r -o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pci.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-dmabuf.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-acpi.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-cray.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-dma.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-i2c.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-mmap.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-p2p.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pat.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-procfs.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-procfs-utils.o /tmp/selfgz735972
/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-usermap.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-vm.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-vtophys.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-mlock.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-pci.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-registry.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-usermap.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pci-table.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-kthread-q.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-memdbg.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/
nv-report-err.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-rsync.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-msi.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-caps.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-frontend.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nvlink_linux.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nvlink_caps.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/linux_nvswitch.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/procfs_nvswitch.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/i2c_nvswitch.o
LD [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia.o
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-drv.c: In function ‘nv_drm_init_mode_config’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-drv.c:245:21: error: ‘struct drm_mode_config’ has no member named ‘fb_base’
245 | dev->mode_config.fb_base = 0;
make[2]: *** [scripts/Makefile.build:260: /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-drv.o] Error 1
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c: In function ‘cursor_plane_req_config_update’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c:88:32: warning: unused variable ‘nv_drm_plane_state’ [-Wunused-variable]
88 | struct nv_drm_plane_state *nv_drm_plane_state =
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c:87:27: warning: unused variable ‘nv_dev’ [-Wunused-variable]
87 | struct nv_drm_device *nv_dev = to_nv_device(plane->dev);
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c: In function ‘plane_req_config_update’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c:189:9: warning: unused variable ‘ret’ [-Wunused-variable]
189 | int ret = 0;
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c: In function ‘nv_drm_plane_atomic_set_property’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c:504:32: warning: unused variable ‘nv_drm_plane_state’ [-Wunused-variable]
504 | struct nv_drm_plane_state *nv_drm_plane_state =
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c: In function ‘nv_drm_enumerate_crtcs_and_planes’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-crtc.c:1148:13: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
1148 | struct drm_plane *overlay_plane =
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-modeset.c: In function ‘__will_generate_flip_event’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-modeset.c:98:10: warning: unused variable ‘overlay_event’ [-Wunused-variable]
98 | bool overlay_event = false;
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-modeset.c:97:10: warning: unused variable ‘primary_event’ [-Wunused-variable]
97 | bool primary_event = false;
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-modeset.c:96:23: warning: unused variable ‘primary_plane’ [-Wunused-variable]
96 | struct drm_plane *primary_plane = crtc->primary;
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-connector.c: In function ‘__nv_drm_detect_encoder’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-connector.c:101:18: error: ‘struct drm_connector’ has no member named ‘override_edid’
101 | if (connector->override_edid) {
make[2]: *** [scripts/Makefile.build:260: /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-drm/nvidia-drm-connector.o] Error 1
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-peermem/nvidia-peermem.c: In function ‘nv_mem_client_init’:
/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-peermem/nvidia-peermem.c:445:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
445 | int status = 0;
ld -r -o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-peermem.o
LD [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.o
make[2]: Target '/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/' not remade because of errors.
make[1]: *** [Makefile:2026: /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel] Error 2
make[1]: Target 'modules' not remade because of errors.
make: *** [Makefile:82: modules] Error 2
-> Error.
ERROR: An error occurred while performing the step: "Building kernel modules". See /var/log/nvidia-installer.log for details.
-> The command `cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.2.0-26-generic/build" SYSOUT="/lib/modules/6.2.0-26-generic/build" ` failed with the following output:
CONFTEST: pde_data
CONFTEST: write_cr4
CONFTEST: cc_mkdec
CONFTEST: icc_get
CONFTEST: icc_put
CONFTEST: vzalloc
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: proc_ops
347 | default:
ld -r -o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pci.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-dmabuf.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-acpi.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-cray.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-dma.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-i2c.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-mmap.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-p2p.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pat.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-procfs.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-procfs-utils.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-usermap.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-vm.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-vtophys.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-mlock.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-pci.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-registry.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/os-usermap.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-pci-table.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-kthread-q.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-memdbg.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-report-err.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-rsync.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-msi.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-caps.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv-frontend.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nvlink_linux.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/nvlink_caps.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/linux_nvswitch.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/procfs_nvswitch.o /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia/i2c_nvswitch.o
189 | int ret = 0;
-> Checking to see whether the nvidia kernel module was successfully built
executing: 'cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.2.0-26-generic/build" SYSOUT="/lib/modules/6.2.0-26-generic/build" NV_KERNEL_MODULES="nvidia"'...
MODPOST /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/Module.symvers
CC [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia.mod.o
LD [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia.ko
BTF [M] /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia.ko
Skipping BTF generation for /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia.ko due to unavailability of vmlinux
-> done.
-> Checking to see whether the nvidia-uvm kernel module was successfully built
executing: 'cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.2.0-26-generic/build" SYSOUT="/lib/modules/6.2.0-26-generic/build" NV_KERNEL_MODULES="nvidia-uvm"'...
ERROR: modpost: "nvUvmInterfaceDisableAccessCntr" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfaceChannelDestroy" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfaceQueryCaps" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfaceUnsetPageDirectory" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfaceInitAccessCntrInfo" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfaceReleaseChannel" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfaceMemoryAllocSys" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfaceMemoryCpuMap" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfacePagingChannelAllocate" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: "nvUvmInterfacePmaFreePages" [/tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/nvidia-uvm.ko] undefined!
WARNING: modpost: suppressed 49 unresolved symbol warnings because there were too many)
make[2]: *** [scripts/Makefile.modpost:138: /tmp/selfgz735972/NVIDIA-Linux-x86_64-520.61.05/kernel/Module.symvers] Error 1
make[2]: Target '__modpost' not remade because of errors.
make[1]: *** [Makefile:1978: modpost] Error 2
-> Error.
ERROR: An error occurred while performing the step: "Checking to see whether the nvidia-uvm kernel module was successfully built". See /var/log/nvidia-installer.log for details.
-> The command `cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.2.0-26-generic/build" SYSOUT="/lib/modules/6.2.0-26-generic/build" NV_KERNEL_MODULES="nvidia-uvm"` failed with the following output:
ERROR: The nvidia-uvm kernel module was not created.
ERROR: The nvidia-uvm kernel module failed to build. This kernel module is required for the proper operation of CUDA. If you do not need to use CUDA, you can try to install this driver package again with the '--no-unified-memory' option.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Update: You can install any driver you want! There is retro compatibility with previous versions of CUDA.
Meaning, you install driver X with, for example, cuda 12.2. You can afterwards install any previous CUDA version you like to use and point the env vars LD_LIBRARY_PATH and PATH to the version CUDA you desire to use, note that paths are shown right after CUDA’s installation.
This is not clearly stated anywhere.
I am now running 535, which comes with CUDA 12.2 as default. Afterwards, I installed CUDA 11.8 without a problem.
rs277
September 1, 2023, 7:06pm
7
Glad you got it sorted, but to be fair, it is fairly clearly explained in the Programming Guide, under “Versioning and Compatibility”.
