Hi, I tried to install CUDA toolkit 11.2 via this instruction.
EDIT: I’m trying this in a multipass instance (Ubuntu 18.04).
However, when running sudo sh cuda_11.2.0_460.27.04_linux.run
and press the install button,
I encountered some errors.
In /var/log/cuda-installer.log
[INFO]: Driver not installed.
[INFO]: Checking compiler version...
[INFO]: gcc location: /usr/bin/gcc
[INFO]: gcc version: gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)
[INFO]: Initializing menu
[INFO]: Setup complete
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 460.27.04
[INFO]: Executing NVIDIA-Linux-x86_64-460.27.04.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --install-libglvnd 2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 460.27.04 failed, quitting
and in /var/log/nvidia-installer.log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue Jul 5 14:59:55 2022
installer version: 460.27.04
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
--ui=none
--no-questions
--accept-license
--disable-nouveau
--install-libglvnd
Using built-in stream user interface
-> Detected 4 CPUs online; setting concurrency level to 4.
WARNING: You do not appear to have an NVIDIA GPU supported by the 460.27.04 NVIDIA Linux graphics driver installed in this system. For further details, please see the appendix SUPPORTED NVIDIA GRAPHICS CHIPS in the README available on the Linux driver download page at www.nvidia.com.
-> Installing NVIDIA driver version 460.27.04.
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written. If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file. Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
-> For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
-> One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to re-enable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Performing CC check.
-> Kernel source path: '/lib/modules/4.15.0-187-generic/build'
-> Kernel output path: '/lib/modules/4.15.0-187-generic/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /usr/bin/make -k -j4 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.15.0-187-generic/build" SYSOUT="/lib/modules/4.15.0-187-generic/build"'...
rm -f -r conftest
make[1]: Entering directory '/usr/src/linux-headers-4.15.0-187-generic'
make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-187-generic'
-> Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.15.0-187-generic/build" SYSOUT="/lib/modules/4.15.0-187-generic/build"'...
SYMLINK /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: get_backlight_device_by_name
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: dev_is_pci
CONFTEST: of_find_matching_node
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: hlist_for_each_entry
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: vga_tryget
CONFTEST: pgprot_decrypted
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: radix_tree_empty
CONFTEST: cpumask_of_node
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_screen_info
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: acpi_fadt_low_power_s0
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-pci.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-caps.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nvlink_caps.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/procfs_nvswitch.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_tools.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_global.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_gpu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_gpu_isr.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_procfs.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_va_space.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_va_space_mm.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_gpu_semaphore.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_mem.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_rm_mem.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_channel.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_lock.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_hal.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_range_tree.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_rb_tree.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_range_allocator.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_va_range.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_va_block.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_range_group.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_gpu_replayable_faults.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_gpu_access_counters.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_events.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_module.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_mmu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pte_batch.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_tlb_batch.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_push.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pushbuffer.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_thread_context.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_tracker.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_kepler.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_kepler_ce.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_kepler_host.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_kepler_mmu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_maxwell.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_maxwell_host.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pascal.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pascal_ce.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pascal_host.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pascal_mmu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_volta_host.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_volta_mmu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_volta.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_turing.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_turing_mmu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_turing_host.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_ampere.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_ampere_ce.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_ampere_host.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_ampere_mmu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_policy.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_utils.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_kvmalloc.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pmm_sysmem.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pmm_gpu.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_migrate.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_populate_pageable.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_migrate_pageable.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_map_external.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_user_channel.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_hmm.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_heuristics.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_thrashing.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_prefetch.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_ats_ibm.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_ats_faults.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_test_rng.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_range_tree_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_range_allocator_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_mem_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_rm_mem_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_page_tree_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_tracker_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_push_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_channel_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_ce_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_lock_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_utils_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_kvmalloc_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pmm_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_events_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_perf_module_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_mmu_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_va_block_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_range_group_tree_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_thread_context_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm/uvm_rb_tree_test.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-linux.o
/tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-modeset.c: In function '__will_generate_flip_event':
/tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-modeset.c:96:23: warning: unused variable 'primary_plane' [-Wunused-variable]
struct drm_plane *primary_plane = crtc->primary;
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-gem-dma-buf.o
CC [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm/nvidia-drm-format.o
ld -r -o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-interface.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-frontend.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-pci.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-acpi.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-cray.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-dma.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-i2c.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-mmap.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/n
v-p2p.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-pat.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-procfs.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-usermap.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-vm.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-vtophys.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-interface.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-mlock.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-pci.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-registry.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/os-usermap.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-pci-table.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-kthread-q.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-mem
dbg.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-report-err.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-rsync.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-msi.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv-caps.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nvlink_linux.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/nvlink_caps.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/linux_nvswitch.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia/procfs_nvswitch.o
ld -r -o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia.o
LD [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset.o
LD [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm.mod.o
CC /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia.mod.o
LD [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia.ko
LD [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz1781/NVIDIA-Linux-x86_64-460.27.04/kernel/nvidia-drm.ko
-> done.
-> Kernel module compilation complete.
-> Unable to determine if Secure Boot is enabled: No such file or directory
ERROR: Unable to load the kernel module 'nvidia.ko'. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA GPU installed in this system is supported by this NVIDIA Linux graphics driver release.
Please see the log entries 'Kernel module load error' and 'Kernel messages' at the end of the file '/var/log/nvidia-installer.log' for more information.
-> Kernel module load error: No such device
-> Kernel messages:
[ 19.399138] audit: type=1400 audit(1657058138.432:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=794 comm="apparmor_parser"
[ 19.399139] audit: type=1400 audit(1657058138.432:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=794 comm="apparmor_parser"
[ 26.980102] print_req_error: I/O error, dev fd0, sector 0
[ 26.980769] floppy: error 10 while reading block 0
[ 27.012074] print_req_error: I/O error, dev fd0, sector 0
[ 27.012674] floppy: error 10 while reading block 0
[ 27.040077] print_req_error: I/O error, dev fd0, sector 0
[ 27.040597] floppy: error 10 while reading block 0
[ 27.068080] print_req_error: I/O error, dev fd0, sector 0
[ 27.068644] floppy: error 10 while reading block 0
[ 27.096074] print_req_error: I/O error, dev fd0, sector 0
[ 27.096644] floppy: error 10 while reading block 0
[ 27.129064] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 27.129378] ISOFS: changing to secondary root
[ 32.206595] new mount options do not match the existing superblock, will be ignored
[ 322.178349] VFIO - User Level meta-driver version: 0.3
[ 322.227525] ipmi message handler version 39.2
[ 322.241917] ipmi device interface
[ 322.247409] nvidia: loading out-of-tree module taints kernel.
[ 322.247416] nvidia: module license 'NVIDIA' taints kernel.
[ 322.247417] Disabling lock debugging due to kernel taint
[ 322.251495] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 322.256250] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 322.256694] NVRM: No NVIDIA GPU found.
[ 322.256794] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
What should I do?
