installer version: 352.39 ERROR: Unable to build the NVIDIA kernel module.
trying to install cuda 7.5 on ubuntu 16 (EC2 AWS instance) and getting this error:
Performing CC sanity check with CC="/usr/bin/cc".
Kernel source path: '/lib/modules/4.4.0-38-generic/build'
Kernel output path: '/lib/modules/4.4.0-38-generic/build'
Performing rivafb check.
Performing nvidiafb check.
Performing Xen check.
Performing PREEMPT_RT check.
Cleaning kernel module build directory.
Building NVIDIA kernel module:
  Building: [##############################] 100%
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find
       suggestions on fixing installation problems in the README available
       on the Linux driver download page at www.nvidia.com.
The driver installation is unable to locate the kernel source. Please make sure that the kernel source packages are installed and set up correctly.
If you know that the kernel source packages are installed and set up correctly, you may pass the location of the kernel source with the '--kernel-source-path' flag.
= Summary =
Driver:   Installation Failed
Toolkit:  Installation skipped
Samples:  Installation skipped
and this is the beginning and the end of /tmp/cuda_install_5882.log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue Oct 11 06:24:09 2016
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
    ./nvidia-installer
    --ui=none
    --no-questions
    --accept-license
    --disable-nouveau
Using built-in stream user interface
-> Detected 8 CPUs online; setting concurrency level to 8.
-> License accepted by command line option.
-> Installing NVIDIA driver version 352.39.
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf.  Please be sure you have rebooted your system since these files were written.  If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file.  Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
-> For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory.  Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
-> One or more modprobe configuration files to disable Nouveau have been written.  For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk.  Please reboot your system and attempt NVIDIA driver installation again.  Note if you later wish to reenable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Kernel source path: '/lib/modules/4.4.0-38-generic/build'
-> Kernel output path: '/lib/modules/4.4.0-38-generic/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Cleaning kernel module build directory.
   executing: 'cd ./kernel; /usr/bin/make clean'...
-> Building NVIDIA kernel module:
   executing: 'cd ./kernel; /usr/bin/make module SYSSRC=/lib/modules/4.4.0-38-generic/build SYSOUT=/lib/modules/4.4.0-38-generic/build -j8  NV_BUILD_MODULE_INSTANCES='...
   NVIDIA: calling KBUILD...
   make[1]: Entering directory '/usr/src/linux-headers-4.4.0-38-generic'
   test -e include/generated/autoconf.h -a -e include/config/auto.conf || (		\
   echo >&2;							\
   echo >&2 "  ERROR: Kernel configuration is invalid.";		\
   echo >&2 "         include/generated/autoconf.h or include/config/auto.conf are missing.";\
   echo >&2 "         Run 'make oldconfig && make prepare' on kernel src to fix it.";	\
   echo >&2 ;							\
   /bin/false)
   mkdir -p /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_versions ; rm -f /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_versions/*
   /usr/bin/make -f ./scripts/Makefile.build obj=/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel
     cc -Wp,-MD,/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.nv-frontend.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/5/include  -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/ge
   nerated/uapi -include ./include/linux/kconfig.h -Iubuntu/include  -D__KERNEL__ -fno-pie -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-pie -no-pie -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-a
   ssignments -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"352.39\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_frontend)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-frontend.o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-frontend.c
     cc -Wp,-MD,/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.nv-instance.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/5/include  -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -Iubuntu/include  -D__KERNEL__ -fno-pie -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-pie -no-pie -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unuse
   d-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"352.39\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_instance)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-instance.o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-instance.c
     cc -Wp,-MD,/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.nv-acpi.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/5/include  -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -Iubuntu/include  -D__KERNEL__ -fno-pie -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-pie -no-pie -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param
   =allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"352.39\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_acpi)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-acpi.o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-acpi.c
     cc -Wp,-MD,/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.nv-chrdev.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/5/include  -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -Iubuntu/include  -D__KERNEL__ -fno-pie -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-pie -no-pie -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare
    -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"352.39\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_chrdev)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-chrdev.o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/n
   v-chrdev.c
     cc -Wp,-MD,/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.nv-cray.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/5/include  -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -Iubuntu/include  -D__KERNEL__ -fno-pie -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-pie -no-pie -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG
   _AS_AVX2=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"352.39\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_cray)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.
   39/kernel/.tmp_nv-cray.o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-cray.c
     cc -Wp,-MD,/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.nv-dma.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/5/include  -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -Iubuntu/include  -D__KERNEL__ -fno-pie -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-pie -no-pie -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXS
   AVEQ=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"352.39\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_dma)"  -D"KBUILD_MO
   DNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-dma.o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-dma.c
     cc -Wp,-MD,/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.nv-drm.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/5/include  -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -Iubuntu/include  -D__KERNEL__ -fno-pie -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-pie -no-pie -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DC
   ONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"352.39\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE  -DMODULE  -D"
   KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_drm)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-drm.o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-drm.c
     cc -Wp,-MD,/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.nv-gvi.o.d  -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/5/include  -I./arch/x86/include -Iarch/x86/include/generated/uapi -Iarch/x86/include/generated  -Iinclude -I./arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -Iubuntu/include  -D__KERNEL__ -fno-pie -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -fno-pie -no-pie -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -m64 -falign-jumps=1 -falign-loops=1 -mno-80387 -mno-fp-ret-in-387 -mpreferred-stack-boundary=3 -mskip-rax-setup -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time
    -maccumulate-outgoing-args -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_SSSE3=1 -DCONFIG_AS_CRC32=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-delete-null-pointer-checks -O2 --param=allow-store-data-races=0 -Wframe-larger-than=1024 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -Werror=implicit-int -Werror=strict-prototypes -Werror=date-time -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"352.39\" -Wno-unused-function -Wuninitialized -fno-strict
   -aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE  -DMODULE  -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_gvi)"  -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-gvi.o /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-gvi.c
   In file included from include/uapi/linux/stddef.h:1:0,
                    from include/linux/stddef.h:4,
                    from ./include/uapi/linux/posix_types.h:4,
                    from include/uapi/linux/types.h:13,
                    from include/linux/types.h:5,
                    from include/uapi/linux/capability.h:16,
                    from include/linux/capability.h:15,
                    from include/linux/sched.h:15,
                    from include/linux/utsname.h:5,
                    from /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-linux.h:40,
                    from /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-instance.c:13:
   include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’:
   include/asm-generic/qrwlock.h:93:36: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
              cnts, cnts | _QW_LOCKED) == cnts);
   include/linux/compiler.h:165:40: note: in definition of macro ‘likely’
    # define likely(x) __builtin_expect(!!(x), 1)
     if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-vtophys.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-vtophys.o"; fi; fi;
     if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-usermap.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-usermap.o"; fi; fi;
     if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-p2p.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-p2p.o"; fi; fi;
     if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/os-mlock.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/os-mlock.o"; fi; fi;
     if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-vm.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/nv-vm.o"; fi; fi;
     if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/os-interface.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount  "/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel/os-interface.o"; fi; fi;
   Makefile:1403: recipe for target '_module_/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel' failed
   make[1]: *** [_module_/tmp/selfgz5930/NVIDIA-Linux-x86_64-352.39/kernel] Error 2
   make[1]: Leaving directory '/usr/src/linux-headers-4.4.0-38-generic'
   NVIDIA: left KBUILD.
   nvidia.ko failed to build!
   nvidia-modules-common.mk:245: recipe for target 'module' failed
   make: *** [module] Error 1
-> Error.
ERROR: Installation has failed.  Please see the file '/var/log/nvidia-installer.log' for details.  You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Can you please attach the complete nvidia-installer.log file? Also, 352.39 is pretty old. Do you still get this error with the current releases? See https://devtalk.nvidia.com/default/topic/533434/linux/current-graphics-driver-releases/ for a list.
I have to use cuda 7.5 because of the package I run on it requires this specific version. I found out the 7.5 is not supported on Ubuntu 16 so I am using now Ubuntu 14 which works with this version of cuda.
