Thank you for your response!
but, actually I installed kernel 3.12.64-generic, and booted linux-3.12.64,
$ uname -r
3.12.64
but, when i install cuda~~.run, the same problem happens…
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Tue Oct 11 13:19:09 2016
installer version: 352.39
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
–ui=none
–no-questions
–accept-license
–disable-nouveau
–no-opengl-files
Using built-in stream user interface
→ Detected 32 CPUs online; setting concurrency level to 32.
→ License accepted by command line option.
→ Installing NVIDIA driver version 352.39.
→ There appears to already be a driver installed on your system (version: 340.93). As part of installing this driver (version: 352.39), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be sure you have rebooted your system since these files were written. If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file. Please consult the NVIDIA driver README and your Linux distribution’s documentation for details on how to correctly disable the Nouveau kernel driver.
→ For some distributions, Nouveau can be disabled by adding a file in the modprobe configuration directory. Would you like nvidia-installer to attempt to create this modprobe file for you? (Answer: Yes)
→ One or more modprobe configuration files to disable Nouveau have been written. For some distributions, this may be sufficient to disable Nouveau; other distributions may require modification of the initial ramdisk. Please reboot your system and attempt NVIDIA driver installation again. Note if you later wish to reenable Nouveau, you will need to delete these files: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/3.12.64/source’
→ Kernel output path: ‘/lib/modules/3.12.64/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make clean’…
→ Building NVIDIA kernel module:
executing: ‘cd ./kernel; /usr/bin/make module SYSSRC=/lib/modules/3.12.64/source SYSOUT=/lib/modules/3.12.64/build -j32 NV_BUILD_MODULE_INSTANCES=’…
NVIDIA: calling KBUILD…
make[1]: Entering directory `/usr/src/linux-3.12.64’
/usr/bin/make -C /lib/modules/3.12.64/build
KBUILD_SRC=/usr/src/linux-3.12.64
KBUILD_EXTMOD=“/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel” -f /usr/src/linux-3.12.64/Makefile
modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (
echo >&2;
echo >&2 " ERROR: Kernel configuration is invalid.“;
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.”;
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it.“;
echo >&2 ;
/bin/false)
mkdir -p /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_versions ; rm -f /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_versions/*
/usr/bin/make -f /usr/src/linux-3.12.64/scripts/Makefile.build obj=/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-frontend.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larg
er-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s” -D"KBUILD_BASENAME=KBUILD_STR(nv_frontend)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-frontend.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-frontend.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-instance.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-point
er -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_instance)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-instance.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-instance.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-acpi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg
-mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_acpi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-acpi.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-acpi.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-chrdev.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/gen
erated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -
fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_chrdev)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-chrdev.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-chrdev.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-cray.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uap
i -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE
INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL_ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_cray)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-cray.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-cray.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-dma.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NV
IDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-3
52.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_dma)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-dma.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-dma.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-drm.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno
-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODU
LE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_drm)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-drm.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-drm.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-gvi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -
Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-
strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_gvi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-gvi.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-gvi.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nvlink.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -m
no-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_
STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nvlink)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nvlink.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nvlink.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-i2c.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -f
unit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_i2c)" -D"KBUILD_MODNAME=KBUILD_STR(nvi
dia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-i2c.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-i2c.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-mempool.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_AB
I -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_mempool)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-mempo
ol.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-mempool.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-mmap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SEC
TIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_mmap)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-mmap.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-mmap.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-p2p.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-si
gn-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_p2p)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-p2p.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-p2p.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-pat.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -
mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_pat)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-pat.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-pat.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-procfs.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-po
inter -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_procfs)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-procfs.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-procfs.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-usermap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg
-mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_usermap)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-usermap.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-usermap.c
In file included from /usr/src/linux-3.12.64/arch/x86/include/asm/bitops.h:522:0,
from /usr/src/linux-3.12.64/include/linux/bitops.h:22,
from /usr/src/linux-3.12.64/include/linux/kernel.h:10,
from /usr/src/linux-3.12.64/include/linux/sched.h:15,
from /usr/src/linux-3.12.64/include/linux/utsname.h:5,
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-linux.h:40,
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-instance.c:13:
/usr/src/linux-3.12.64/include/linux/bitops.h: In function ‘hweight_long’:
/usr/src/linux-3.12.64/include/asm-generic/bitops/const_hweight.h:27:70: warning: signed and unsigned type in conditional expression [-Wsign-compare]
#define hweight64(w) (__builtin_constant_p(w) ? const_hweight64(w) : arch_hweight64(w))
/usr/src/linux-3.12.64/include/linux/bitops.h:66:41: note: in expansion of macro ‘hweight64’
return sizeof(w) == 4 ? hweight32(w) : hweight64(w);
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-vm.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-cal
ls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_vm)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-vm.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-vm.c
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-frontend.c:13:
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-acpi.c:15:
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-vtophys.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict
-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL -DMODULE -DNVRM -DNV_VERSION
_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_vtophys)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_nv-vtophys.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-vtophys.c
#define hweight64(w) (builtin_constant_p(w) ? const_hweight64(w) : arch_hweight64(w))
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.os-interface.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-un
used-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_interface)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_os-interface.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/os-interface.c
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-chrdev.c:15:
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.os-mlock.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3
dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_mlock)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_os-mlock.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/os-mlock.c
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.os-pci.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit
-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_pci)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_os-pci.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/os-pci.c
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-cray.c:15:
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.os-registry.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unus
ed-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_registry)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_os-registry.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/os-registry.c
In file included from /usr/src/linux-3.12.64/arch/x86/include/asm/cpumask.h:4:0,
from /usr/src/linux-3.12.64/arch/x86/include/asm/msr.h:10,
from /usr/src/linux-3.12.64/arch/x86/include/asm/processor.h:20,
from /usr/src/linux-3.12.64/arch/x86/include/asm/thread_info.h:22,
from /usr/src/linux-3.12.64/include/linux/thread_info.h:54,
from /usr/src/linux-3.12.64/include/linux/preempt.h:9,
from /usr/src/linux-3.12.64/include/linux/spinlock.h:50,
from /usr/src/linux-3.12.64/include/linux/seqlock.h:35,
from /usr/src/linux-3.12.64/include/linux/time.h:5,
from /usr/src/linux-3.12.64/include/uapi/linux/timex.h:56,
from /usr/src/linux-3.12.64/include/linux/timex.h:56,
from /usr/src/linux-3.12.64/include/linux/sched.h:17,
/usr/src/linux-3.12.64/include/linux/cpumask.h: In function ‘cpumask_parse’:
/usr/src/linux-3.12.64/include/linux/cpumask.h:603:26: warning: signed and unsigned type in conditional expression [-Wsign-compare]
int len = nl ? nl - buf : strlen(buf);
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-drm.c:15:
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nvlink-linux.h:14,
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nvlink.c:13:
#define hweight64(w) (__builtin_constant_p(w) ? __const_hweight64(w) : __arch_hweight64(w))
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-dma.c:15:
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.os-usermap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -inclu
de /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -Wframe-larger-than=1024 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-var-tracking-assignments -g -pg -mfentry -DCC_USING_FENTRY -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_BUILD_MODULE_INSTANC
ES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL -DMODULE -DNVRM -DNV_VERSION_STRING="352.39" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_usermap)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.tmp_os-usermap.o /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/os-usermap.c
from /tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/nv-gvi.c:15:
#define hweight64(w) (__builtin_constant_p(w) ? __const_hweight64(w) : arch_hweight64(w))
cc -Wp,-MD,/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel/.nv-modeset-interface.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-linux-gnu/4.8/include -I/usr/src/linux-3.12.64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/linux-3.12.64/include -Iinclude -I/usr/src/linux-3.12.64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/linux-3.12.64/include/uapi -Iinclude/generated/uapi -include /usr/src/linux-3.12.64/include/linux/kconfig.h -I/tmp/selfgz8647/NVIDIA-Linux-x86_64-352.39/kernel -D__KERNEL -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_X86_X32_ABI -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCON
