I’d like to know how to install CUDA 3.0 drivers under linux Ubuntu 10.04
I’ve tried to remove the native nvidia drivers with : sudo apt-get remove nvidia*, then I blacklisted the nouveau, nv, rivafb… in modprobe.d\blacklist.conf file,
I’ve installed the GCC 4.3
i’ve stopped the gdm to launch : sudo sh devdriver*
but it still tells me there’s a conflit with nvidia.ko !
I’ve already succesfully installed them because I found the right tutorial after 2 days of searching, but now i’m stuck
I had one system (NF980-G65) which loaded nouveau even though it was blacklisted. I think because it was an embedded display. Use “lsmod” and see if nouveau is listed anyway, or one of the other drivers.
I solved it by holding shift while booting to bring up the GRUB menu, then picking the “recovery” mode and dropping straight to a shell without starting X even once. Once I got the nvidia driver installed, it used that from now on.
Finally, make sure that gcc is symlinked to gcc 4.4 (not 4.3). That’s what the driver needs to compile a kernel module. After the driver is running, I symlink gcc back to gcc-4.3 for CUDA compiles.
hmm Im having the same problem, and i managed to get done of the black listed stuff to load, successfully installed it… but after undoing theblacklist and rebooting, it fails to load the module and X gives me a nice error message telling me cant load the nvidia module…
any suggestions…
also my x session is not on ctrl+alt+F3 and when i kill gdm it doesnt even drop to a shell just a blinking underscore haha
Did anyone faced any problems while installing cuda driver when there is already a built in graphics card? My laptop has integrated intels graphics card and nvidia’s graphics card. So when i try to install its not able to install the driver correctly. Infact after installing I cannot even run xserver.
Can somebody help me with this?
other question:after setup driver my resolution is very bad and system can not detect my graphic and i do not have x server in system.
what am i doing?
