I installed the cuda sdk and the cuda drivers. Version 3.2, both from the same page.
I compiled the sample code, which does compile successfully.
But then I get this error when running deviceQuery
-------------------------------------------------------------------------output--------------------------
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount FAILED CUDA Driver and Runtime version may be mismatched.
FAILED
Press to Quit…
----------------------------------------end output------------------------------------------------------
The card is a Tesla
I’ve blacklisted some modules that are mentioned in other forums
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
I’ve purge all nvidia packages and started from scratch . No improvment.
The card does have an issue recognizing monitors, which is also mention on other forums. But this is not a problem in need of solving since the machine will be a monitor-less server; nevertheless, this bit of info must be a good clue as to what is going on.
Any help is appreciated.
I’ll install version 3.0 while I wait for a response.
FAILED
Press to Quit…
The card is a Tesla
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
Thank you for posting a followup to your question. I came here to post the exact same question, and the script you linked to will serve as an acceptable solution.
I created a new topic inquiring if anyone knew why this was necessary (my system runs X, so the /dev entries should be automatically created). If you know the answer, or are interested in following the discussion, the thread is here:
Thanks for your mention of Centos 5.x success story. After spending roughly 30 hours trying to get what was a properly working F13 w 256.xx driver based system running with any and all 260.xx drivers (every combo of direct from nividia and rpmfusion sourced driver & settings), I will have to seriously consider switching the OS.
Any tips, tricks to installing devdriver 260.19.xx on centos 5.5? Have performed a clean install (direct from nvidia) and looked thru the xorg.conf file but startx halts @ NV-GLX loading. TIA, V.
Try to install the newest driver and a lower version of toolkit. I had the same problem and found the driver provided is not always sufficient for the runtime for some devices
