I used CUDA for a while without any problems, but after some problems of version that appeared a few days ago, I have decided to re-install cuda toolkit 7.0.
So I tried to remove all traces of old driver and toolkit versions, and I re-installed it.
The problem is that I cannot run the toolkit samples, nor any other cuda program :
$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
However, the driver version is the one installed with the toolkit (352.68) :
$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 352.68 Tue Dec 1 17:24:11 PST 2015
GCC version: gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04)
$ nvidia-settings -q NvidiaDriverVersion
Attribute 'NvidiaDriverVersion' (vincent-SATELLITE-P850:0.0): 352.68
Attribute 'NvidiaDriverVersion' (vincent-SATELLITE-P850:0[gpu:0]): 352.68
$ nvidia-smi
Tue Jan 12 12:23:08 2016
| NVIDIA-SMI 352.68 Driver Version: 352.68 |
| 0 GeForce GT 630M Off | 0000:01:00.0 N/A | N/A |
| N/A 62C P0 N/A / N/A | 185MiB / 2047MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
$ dpkg -l | grep nvidia
ii nvidia-352 352.68-0ubuntu1 amd64 NVIDIA binary driver - version 352.68
ii nvidia-352-dev 352.68-0ubuntu1 amd64 NVIDIA binary Xorg driver development files
ii nvidia-352-uvm 352.68-0ubuntu1 amd64 Transitional package for nvidia-352
ii nvidia-modprobe 352.68-0ubuntu1 amd64 Load the NVIDIA kernel driver and create device files
ii nvidia-opencl-icd-352 352.68-0ubuntu1 amd64 NVIDIA OpenCL ICD
ii nvidia-prime 0.6.2 amd64 Tools to enable NVIDIA's Prime
ii nvidia-settings 352.68-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
(and the CUDA version : )
$ nvcc -V
Copyright (c) 2005-2015 NVIDIA Corporation
Built on Mon_Feb_16_22:59:02_CST_2015
Cuda compilation tools, release 7.0, V7.0.27
My hardware :
$ lspci -v | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 630M] (rev a1) (prog-if 00 [VGA controller])
Kernel driver in use: nvidia
Can somebody help me?
Thanks in advance!
