I followed exactly the linux installation guide several times to install cuda 9.1 but getting error when running ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
I have
cuda-runtime-9-1 is already the newest version (9.1.85-1).
cuda-drivers is already the newest version (387.26-1).
$ nvidia-smi
Fri May 4 23:30:55 2018
| NVIDIA-SMI 390.48 Driver Version: 390.48 |
| 0 GeForce 940MX Off | 00000000:02:00.0 Off | N/A |
| N/A 37C P0 N/A / N/A | 432MiB / 2004MiB | 3% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1092 G /usr/lib/xorg/Xorg 168MiB |
| 0 2717 G compiz 50MiB |
| 0 2944 G ...-token=96A2E858145FF6AAA83B5DF70E9F010B 38MiB |
| 0 3342 G ...-token=C5993195008196AAAD306CA180F63FAA 171MiB |
$ nvcc -V
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Nov__3_21:07:56_CDT_2017
Cuda compilation tools, release 9.1, V9.1.85
$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 390.48 Thu Mar 22 00:42:57 PDT 2018
GCC version: gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.9)
$ ll /dev/ | grep nvidia
crwxrw-rw- 1 root root 195, 0 May 4 22:47 nvidia0
crwxrw-rw- 1 root root 195, 255 May 4 22:47 nvidiactl
crwxrw-rw- 1 root root 195, 254 May 4 22:47 nvidia-modeset
crwxrw-rw- 1 root root 237, 0 May 4 22:47 nvidia-uvm
$ uname -a
Linux vincent-ThinkPad 4.13.0-38-generic #43~16.04.1-Ubuntu SMP Wed Mar 14 17:48:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
What is wrong with my installation?
