CUDA driver version is insufficient for CUDA runtime version
Hello:
Could anyone help me figure out this?
Ubuntu 16.04 Cuda-8.0
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
→ CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
nvidia-smi:
| NVIDIA-SMI 375.39 Driver Version: 375.39 |
| 0 Quadro 600 Off | 0000:03:00.0 On | N/A |
| 30% 74C P0 N/A / N/A | 497MiB / 959MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
.bashrc:
export PATH=“/usr/local/cuda-8.0/bin:$PATH”
export LD_LIBRARY_PATH=/usr/local/cuda-8.0/lib64
export CUDA_HOME=“/usr/local/cuda-8.0:$CUDA_HOME”
Did you find a solution for that? I have the same error after I updated the nvidia driver from 375.26 to 375.39
It worked with cuda-8.0.run file instead of the deb version. The driver version is 375.26
