I have nvidia GeForce 840M.
I installed CUDA 9 with nvidia drivers 384.111. I checked up on the forum and found they were compatible.
I have a weird error.
The output of nvidia-smi
Thu Jan 25 14:45:20 2018
| NVIDIA-SMI 384.111 Driver Version: 384.111 |
| 0 GeForce 840M Off | 00000000:03:00.0 Off | N/A |
| N/A 53C P0 N/A / N/A | 278MiB / 4044MiB | 13% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1429 G /usr/lib/xorg/Xorg 167MiB |
| 0 2149 G compiz 108MiB |
Output of nvcc is
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_21:08:03_CDT_2017
Cuda compilation tools, release 9.0, V9.0.176
But, I can’t seem to run nvidia-detector or deviceQuery.
I get None when I run nvidia-detector and
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
Any help appreciated. I am seeing this error in many of the posts in the forum but nothing is working for me.
