I’m stucked for almost one week installing drivers for my Quadro K4000 and CUDA 9.0
First of all this is the output for nvidia-smi:
| NVIDIA-SMI 384.130 Driver Version: 384.130 |
| 0 Quadro K4000 Off | 00000000:03:00.0 On | N/A |
| 30% 43C P8 12W / 87W | 327MiB / 3012MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1328 G /usr/lib/xorg/Xorg 184MiB |
| 0 1887 G /opt/teamviewer/tv_bin/TeamViewer 12MiB |
| 0 2066 G compiz 124MiB |
| 0 3179 G /usr/lib/firefox/firefox 1MiB |
So i suppose the driver is installed properly.
After that this is the output for nvcc --version:
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_21:08:03_CDT_2017
Cuda compilation tools, release 9.0, V9.0.176
When i try to run the devicequery example, this is my output:
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
Any help would be appreciated, please i have reinstalled several times on my laptop with a GTX 1060 was to simple, here i’m stucked.
