I am attempting to install Cuda 9.0 on my lenovo laptop running Ubuntu 16.04 and am getting an error when I run ./deviceQuery.
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
~$ lspci -v | grep -i nvidia
01:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1)
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_390, nvidia_390_drm
~$ nvidia-settings -q NvidiaDriverVersion
Attribute 'NvidiaDriverVersion' (joe-Lenovo-IdeaPad-U410:0.0): 390.87
Attribute 'NvidiaDriverVersion' (joe-Lenovo-IdeaPad-U410:0[gpu:0]): 390.87
~$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 390.87 Tue Aug 21 12:33:05 PDT 2018
GCC version: gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10)
~$ nvcc -V
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_21:08:03_CDT_2017
Cuda compilation tools, release 9.0, V9.0.176
~$ nvidia-smi
Mon Oct 1 15:48:43 2018
| NVIDIA-SMI 390.87 Driver Version: 390.87 |
| 0 GeForce 710M Off | 00000000:01:00.0 N/A | N/A |
| N/A 42C P0 N/A / N/A | 116MiB / 1985MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
I am able to compile all of the cuda samples. Although I did have to add the following line to the makefile in ~/NVIDIA_CUDA-9.0_Samples/3_Imaging/cudaDecodeGL
LIBRARIES += -L/usr/lib/nvidia-390
I tried following the comment in this forum: https://devtalk.nvidia.com/default/topic/617414/cuda-setup-and-installation/-solved-cuda-driver-version-is-insufficient-for-cuda-runtime-version-fedora-18-rpmfusion-driver/post/4149917/#4149917 but it did not change any results.
I also added the following file before re-running sudo ldconfig
~$ cat /etc/ld.so.conf.d/nvidia-lib.conf
/usr/lib/nvidia-390
/usr/lib32/nvidia-390
/usr/lib/nvidia
Is there anything else I can try to fix this error?
Thanks in advance for any help.
