Hi all,
I am trying to upgrade to the 3.2 version of CUDA but having a familiar problem:
$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount FAILED CUDA Driver and Runtime version may be mismatched.
FAILED
Press <Enter> to Quit...
I know it’s a common problem, and maybe the solution is obvious, but even after trolling this site and google for hours, I can’t solve it. So I’m sorry, but I’m making one more post on this subject. Here is what I’ve done:
First, I verify that CUDA is 3.2 and driver 260.19.26:
$ nvcc -V
Copyright (c) 2005-2010 NVIDIA Corporation
Built on Wed_Nov__3_16:16:57_PDT_2010
Cuda compilation tools, release 3.2, V0.2.1221
$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 260.19.26 Mon Nov 29 00:53:44 PST 2010
GCC version: gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5)
Now, I’m following the “CUDA - Getting Started with Linux” document. I am reasonably satisfied that the driver and tools are installed. I run make and everything compiles (albeit with many warnings). However, as shown above, when I run “deviceQuery” I get a bad result.
I am running Ubuntu 10.04 in 64-bit. I can see my card in lspci. Also I’ve already modified my .bash_profile to have LD_LIBRARY_PATH. And, I can see the files I expect in /dev:
$ uname -m && cat /etc/*release
x86_64
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=10.04
DISTRIB_CODENAME=lucid
DISTRIB_DESCRIPTION="Ubuntu 10.04.2 LTS"
$ lspci
....... <omitted lines> ........
01:00.0 VGA compatible controller: nVidia Corporation G84 [Quadro FX 570] (rev a1)
$ cat ~/.bash_profile
# NVIDIA told me to add these variables
export PATH=$PATH:~/bin:~/usr/bin:/usr/local/cuda/bin
export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$LD_LIBRARY_PATH
$ ls -l /dev/nvid*
crw-rw---- 1 root video 195, 0 2011-02-05 12:26 /dev/nvidia0
crw-rw---- 1 root video 195, 255 2011-02-05 12:26 /dev/nvidiactl
I can’t find anything else to try! Please, someone advise.
Thanks in advance!
