After installing Cuda 9.1 everything is working fine. I then reboot the machine and start getting:
CUDA Error: CUDA driver version is insufficient for CUDA runtime version
I then reinstall Cuda 9.1 and everything works again. But then after another reboot the error above. What’s going on here?
I’m using cuda_9.1.85._windows. Tried installing all the patches but it doesn’t make any difference. I basically need to reinstall cuda everytime I want to use it :(
When you reboot and have the error, what is the GPU driver version?
What happens if you run nvidia-smi from a command prompt in the failing state?
In the failing state:
| NVIDIA-SMI 386.07 Driver Version: 386.07 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 Tesla K80 TCC | 0000F9BF:00:00.0 Off | 0 |
| N/A 30C P8 32W / 149W | 0MiB / 11444MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
After re-installing cuda_9.1.85_win10 again:
| NVIDIA-SMI 388.19 Driver Version: 388.19 |
| N/A 30C P8 33W / 149W | 0MiB / 11444MiB | 0% Default |
And the problem goes away :)
