something i have trouble about cuda runtime version
my system is this
CUDA 8.0
UBUNTU 16.04 LTS
Copyright (c) 2005-2016 NVIDIA Corporation
Built on Tue_Jan_10_13:22:03_CST_2017
Cuda compilation tools, release 8.0, V8.0.61
in bash.rc
export CUDA_HOME=/usr/local/cuda-8.0
export PATH=/usr/local/cuda-8.0/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-8.0/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
i spend time about cuda tutorial
first i write ex1.cu
include
include <stdio.h>
include “common/book.h”
global void add(int a, int b, int *c){
*c=a+b;
int main(){
int c;
int *dev_c;
HANDLE_ERROR(cudaMalloc( (void**)&dev_c, sizeof(int) ) );
add<<<1,1>>>(2,7, dev_c);
HANDLE_ERROR( cudaMemcpy( &c, dev_c, sizeof(int),cudaMemcpyDeviceToHost));
printf("2+7 = %d",c);
cudaFree(dev_c);
return 0;
and i compiled then it occured
won@won-desktop:~/cuda_example$ nvcc ex1.cu
nvcc warning : The ‘compute_20’, ‘sm_20’, and ‘sm_21’ architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
won@won-desktop:~/cuda_example$ ./a.out
CUDA driver version is insufficient for CUDA runtime version in ex1.cu at line 14
Your CUDA install is broken. If you google that error message:
you will find many descriptions/writeups.
then i should be reinstall vga driver or cuda 8.0?
either will fix it, if you do it correctly
You must install a driver revision which contains CUDA 8.0 runtime (or newer, but matching is always best)
The SDK is only the SDK, no runtime. However the SDK suggests/includes an optional driver which matches the SDK version, which brings in the runtime (so I guess a runtime does come with the SDK but it’s an additional step really)
You must not have installed a proprietary driver / still on nouveau or such else useless 2D open-source drivers.
