I am trying to install 340.107 on my CentOS server.
I run the command sh ./nvidia-linux-x86_64-340.107.run
Here is the log file.
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Dec 11 19:43:07 2019
installer version: 340.107
PATH: /sbin:/bin:/usr/sbin:/usr/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Tagging shared libraries with chcon -t textrel_shlib_t.
→ License accepted.
→ Installing NVIDIA driver version 340.107.
→ There appears to already be a driver installed on your system (version: 340.96). As part of installing this driver (version: 340.107), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/bin/cc”.
→ Kernel source path: ‘/lib/modules/3.10.0-1062.9.1.el7.x86_64/source’
→ Kernel output path: ‘/lib/modules/3.10.0-1062.9.1.el7.x86_64/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /bin/make clean’…
→ Building NVIDIA kernel module:
executing: ‘cd ./kernel; /bin/make module SYSSRC=/lib/modules/3.10.0-1062.9.1.el7.x86_64/source SYSOUT=/lib/modules/3.10.0-1062.9.1.el7.x86_64/build NV_BUILD_MODULE_INSTANCES=’…
NVIDIA: calling KBUILD…
make[1]: Entering directory /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64' /bin/make -C /lib/modules/3.10.0-1062.9.1.el7.x86_64/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64 \ KBUILD_EXTMOD="/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel" -f /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/Makefile \ modules test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \ echo >&2; \ echo >&2 " ERROR: Kernel configuration is invalid."; \ echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\ echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \ echo >&2 ; \ /bin/false) mkdir -p /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.tmp_versions ; rm -f /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.tmp_versions/* /bin/make -f /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/scripts/Makefile.build obj=/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel cc -Wp,-MD,/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.nv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kconfig.h -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTION S=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\" -DMODULE -D"KBUILD_STR(s)=# s" -D"KBUILD_BASENAME=KBUILD_STR(nv)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.tmp_nv.o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv.c In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/little_endian.h:6:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi/asm/byteorder.h:4, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/bitops/le.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/bitops.h:514, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/bitops.h:37, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kernel.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:15, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv.c:13: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘cpu_to_be32_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:177:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘be32_to_cpu_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:185:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpumask.h:4:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/msr.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/processor.h:20, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpufeature.h:7, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/thread_info.h:22, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/thread_info.h:66, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/preempt.h:9, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/spinlock.h:50, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/seqlock.h:35, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/time.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:17, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv.c:13: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h: In function ‘cpumask_parse’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h:634:26: warning: signed and unsigned type in conditional expression [-Wsign-compare] int len = nl ? nl - buf : strlen(buf); ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv.c:13: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h:93:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] cnts, cnts | _QW_LOCKED) == cnts); ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ In file included from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:91:0, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv.c:13: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h: In function ‘cpufreq_next_valid’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:534:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] while ((*pos)->frequency != CPUFREQ_TABLE_END) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:535:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if ((*pos)->frequency != CPUFREQ_ENTRY_INVALID) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv.c:13: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:78:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= n)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_to_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:95:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= size)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount "/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv.o"; fi; fi; cc -Wp,-MD,/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.nv-acpi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kconfig.h -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-ar gs -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zon e -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\" -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_acpi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.tmp_nv-acpi.o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-acpi.c In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/little_endian.h:6:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi/asm/byteorder.h:4, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/bitops/le.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/bitops.h:514, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/bitops.h:37, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kernel.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:15, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-acpi.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘cpu_to_be32_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:177:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘be32_to_cpu_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:185:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpumask.h:4:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/msr.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/processor.h:20, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpufeature.h:7, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/thread_info.h:22, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/thread_info.h:66, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/preempt.h:9, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/spinlock.h:50, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/seqlock.h:35, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/time.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:17, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-acpi.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h: In function ‘cpumask_parse’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h:634:26: warning: signed and unsigned type in conditional expression [-Wsign-compare] int len = nl ? nl - buf : strlen(buf); ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-acpi.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h:93:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] cnts, cnts | _QW_LOCKED) == cnts); ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ In file included from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:91:0, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-acpi.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h: In function ‘cpufreq_next_valid’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:534:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] while ((*pos)->frequency != CPUFREQ_TABLE_END) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:535:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if ((*pos)->frequency != CPUFREQ_ENTRY_INVALID) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-acpi.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:78:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= n)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_to_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:95:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= size)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-acpi.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount "/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-acpi.o"; fi; fi; cc -Wp,-MD,/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.nv-chrdev.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kconfig.h -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks - std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -Wall -MD -Wsign-compare -Wno- cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\" -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_chrdev)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.tmp_nv-chrdev.o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-chrdev.c In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/little_endian.h:6:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi/asm/byteorder.h:4, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/bitops/le.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/bitops.h:514, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/bitops.h:37, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kernel.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:15, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-chrdev.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘cpu_to_be32_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:177:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘be32_to_cpu_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:185:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpumask.h:4:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/msr.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/processor.h:20, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpufeature.h:7, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/thread_info.h:22, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/thread_info.h:66, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/preempt.h:9, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/spinlock.h:50, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/seqlock.h:35, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/time.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:17, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-chrdev.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h: In function ‘cpumask_parse’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h:634:26: warning: signed and unsigned type in conditional expression [-Wsign-compare] int len = nl ? nl - buf : strlen(buf); ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-chrdev.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h:93:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] cnts, cnts | _QW_LOCKED) == cnts); ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ In file included from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:91:0, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-chrdev.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h: In function ‘cpufreq_next_valid’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:534:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] while ((*pos)->frequency != CPUFREQ_TABLE_END) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:535:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if ((*pos)->frequency != CPUFREQ_ENTRY_INVALID) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-chrdev.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:78:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= n)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_to_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:95:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= size)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-chrdev.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount "/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-chrdev.o"; fi; fi; cc -Wp,-MD,/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.nv-cray.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kconfig.h -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -D__KERNEL__ -Wal l -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM _GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\" -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_cray)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.tmp_nv-cray.o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-cray.c In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/little_endian.h:6:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi/asm/byteorder.h:4, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/bitops/le.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/bitops.h:514, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/bitops.h:37, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kernel.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:15, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-cray.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘cpu_to_be32_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:177:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘be32_to_cpu_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:185:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpumask.h:4:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/msr.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/processor.h:20, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpufeature.h:7, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/thread_info.h:22, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/thread_info.h:66, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/preempt.h:9, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/spinlock.h:50, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/seqlock.h:35, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/time.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:17, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-cray.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h: In function ‘cpumask_parse’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h:634:26: warning: signed and unsigned type in conditional expression [-Wsign-compare] int len = nl ? nl - buf : strlen(buf); ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-cray.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h:93:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] cnts, cnts | _QW_LOCKED) == cnts); ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ In file included from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:91:0, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-cray.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h: In function ‘cpufreq_next_valid’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:534:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] while ((*pos)->frequency != CPUFREQ_TABLE_END) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:535:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if ((*pos)->frequency != CPUFREQ_ENTRY_INVALID) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-cray.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:78:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= n)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_to_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:95:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= size)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-cray.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount "/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-cray.o"; fi; fi; cc -Wp,-MD,/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.nv-dma.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kconfig.h -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-larger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -D CC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\" -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_dma)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.tmp_nv-dma.o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-dma.c In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/little_endian.h:6:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi/asm/byteorder.h:4, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/bitops/le.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/bitops.h:514, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/bitops.h:37, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kernel.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:15, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-dma.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘cpu_to_be32_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:177:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘be32_to_cpu_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:185:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpumask.h:4:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/msr.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/processor.h:20, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpufeature.h:7, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/thread_info.h:22, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/thread_info.h:66, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/preempt.h:9, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/spinlock.h:50, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/seqlock.h:35, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/time.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:17, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-dma.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h: In function ‘cpumask_parse’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h:634:26: warning: signed and unsigned type in conditional expression [-Wsign-compare] int len = nl ? nl - buf : strlen(buf); ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-dma.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h:93:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] cnts, cnts | _QW_LOCKED) == cnts); ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ In file included from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:91:0, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-dma.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h: In function ‘cpufreq_next_valid’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:534:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] while ((*pos)->frequency != CPUFREQ_TABLE_END) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:535:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if ((*pos)->frequency != CPUFREQ_ENTRY_INVALID) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-dma.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:78:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= n)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_to_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:95:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= size)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ if [ "-pg" = "-pg" ]; then if [ /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-dma.o != "scripts/mod/empty.o" ]; then ./scripts/recordmcount "/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-dma.o"; fi; fi; cc -Wp,-MD,/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.nv-drm.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.8.5/include -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include -Iarch/x86/include/generated -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include -Iinclude -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/a rch/x86/include/uapi -Iarch/x86/include/generated/uapi -I/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi -Iinclude/generated/uapi -include /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kconfig.h -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -std=gnu89 -O2 -m64 -mno-mmx -mno-sse -mpreferred-stack-boundary=3 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -Wframe-larger-than=2048 -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -DCONFIG_AS_FXSAVEQ=1 -DCONFIG_AS_AVX=1 -DCONFIG_AS_AVX2=1 -DCONFIG_AS_AVX512=1 -DCONFIG_AS_SHA1_NI=1 -DCONFIG_AS_SHA256_NI=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -mno-avx -mindirect-branch=thunk-extern -mindirect-branch-register -DRETPOLINE -Wframe-la rger-than=2048 -fstack-protector-strong -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -mfentry -DCC_USING_FENTRY -fno-inline-functions-called-once -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fconserve-stack -DCC_HAVE_ASM_GOTO -DNV_MODULE_INSTANCE=0 -DNV_BUILD_MODULE_INSTANCES=0 -UDEBUG -U_DEBUG -DNDEBUG -I/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"340.107\" -Wno-unused-function -Wuninitialized -fno-strict-aliasing -mno-red-zone -mcmodel=kernel -DNV_UVM_ENABLE -D__linux__ -DNV_DEV_NAME=\"nvidia\" -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_drm)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/.tmp_nv-drm.o /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/little_endian.h:6:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/uapi/asm/byteorder.h:4, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/bitops/le.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/bitops.h:514, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/bitops.h:37, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/kernel.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:15, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘cpu_to_be32_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:177:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h: In function ‘be32_to_cpu_array’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/byteorder/generic.h:185:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < len; i++) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpumask.h:4:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/msr.h:10, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/processor.h:20, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/cpufeature.h:7, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/thread_info.h:22, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/thread_info.h:66, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/preempt.h:9, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/spinlock.h:50, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/seqlock.h:35, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/time.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/uapi/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/timex.h:56, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:17, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h: In function ‘cpumask_parse’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpumask.h:634:26: warning: signed and unsigned type in conditional expression [-Wsign-compare] int len = nl ? nl - buf : strlen(buf); ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h: In function ‘queued_write_trylock’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/asm-generic/qrwlock.h:93:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] cnts, cnts | _QW_LOCKED) == cnts); ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ In file included from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:91:0, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h: In function ‘cpufreq_next_valid’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:534:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] while ((*pos)->frequency != CPUFREQ_TABLE_END) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/cpufreq.h:535:25: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if ((*pos)->frequency != CPUFREQ_ENTRY_INVALID) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/rh_kabi.h:22:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/sched.h:5, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/utsname.h:5, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-linux.h:44, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c:15: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_from_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:78:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= n)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h: In function ‘copy_to_user’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/arch/x86/include/asm/uaccess_64.h:95:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] if (likely(sz == -1 || sz >= size)) { ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/compiler.h:152:40: note: in definition of macro ‘likely’ # define likely(x) __builtin_expect(!!(x), 1) ^ In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/drm/drm_crtc.h:31:0, from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/drm/drmP.h:69, from /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c:19: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/fb.h: In function ‘__fb_pad_aligned_buffer’: /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/linux/fb.h:651:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (j = 0; j < s_pitch; j++) ^ /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c: In function ‘nv_alloc_os_descriptor_handle’: /tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.c:255:5: error: implicit declaration of function ‘drm_gem_object_unreference_unlocked’ [-Werror=implicit-function-declaration] drm_gem_object_unreference_unlocked(&nv_obj->base); ^ cc1: some warnings being treated as errors make[3]: *** [/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel/nv-drm.o] Error 1 make[2]: *** [_module_/tmp/selfgz9667/NVIDIA-Linux-x86_64-340.107/kernel] Error 2 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64’
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make: *** [nvidia.ko] Error 1
→ Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
any suggestions?
