On running Nvidia-Modprobe from the Developer Zone CUDA 5.5 repository with Mint 15 x64, Nvidia-Current 319.21-0ubuntu1, and Xorg 1:7.7+1ubuntu4, and a GTX 570, the task fails with the following output:
sudo nvidia-modprobe
libkmod: ERROR ../libkmod/libkmod-module.c:791 kmod_module_insert_module: could not find module by name='nvidia_current'
ERROR: could not insert 'nvidia_current': Function not implemented
This causes the desktop environment to crash on login due to being unable to detect OpenGL and thus it goes to a fallback mode.
Upon trying to run Nvidia bug report, I get the following output:
sudo nvidia-bug-report.sh
nvidia-bug-report.sh will now collect information about your
system and create the file 'nvidia-bug-report.log.gz' in the current
directory. It may take several seconds to run. In some
cases, it may hang trying to capture data generated dynamically
by the Linux kernel and/or the NVIDIA kernel module. While
the bug report log file will be incomplete if this happens, it
may still contain enough data to diagnose your problem.
Please include the 'nvidia-bug-report.log.gz' log file when reporting
your bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to 'linux-bugs@nvidia.com'.
Running nvidia-bug-report.sh...
If the bug report script hangs after this point consider running with
--safe-mode command line argument.
NVIDIA: failed to load the NVIDIA kernel module.
complete.
Do you have any files in /lib/modprobe.d, /etc/modprobe.d, or /run/modprobe.d that alias the module ‘nvidia’ to ‘nvidia_current’? That could explain why libkmod has the wrong name for the module. Do you see the same problem if you run “modprobe nvidia” as root?
sudo modprobe nvidia
Reinstalling puts in the file nvidia-graphics-drivers.conf with the contents:
# This file was installed by nvidia-current
# Do not edit this file manually
blacklist nouveau
blacklist lbm-nouveau
blacklist nvidia-173
blacklist nvidia-96
blacklist nvidia-current-updates
blacklist nvidia-173-updates
blacklist nvidia-96-updates
alias nvidia nvidia_current
alias nouveau off
alias lbm-nouveau off
Trying to mess with
tosses a syntax error or an error saying it can’t find anything.
Hmm, I don’t think those packages were meant to be used on Raring (and by extension, Olivia).
I just tried installing the nvidia-current-319 package on a Raring system, and it looks like the dkms.conf file tries to apply a patch which isn’t necessary for 319, probably left over from a previous driver version that didn’t support Linux 3.8.
This is what happens when I try to go ahead with the DKMS build on my system:
applying patch buildfix_kernel_3.8.patch...patching file conftest.sh
Reversed (or previously applied) patch detected! Assume -R? [n] n
Apply anyway? [n] n
Skipping patch.
1 out of 1 hunk ignored -- saving rejects to file conftest.sh.rej
(bad exit status: 1)
Error! Application of patch buildfix_kernel_3.8.patch failed.
Check /var/lib/dkms/nvidia-current/319.24/build/ for more information.
Does the following help?
dkms remove -m nvidia-current -v 319.21 --all
edit /usr/src/nvidia-current-319.21/dkms.conf and remove the “PATCH” and “PATCH_MATCH” lines
dkms install -m nvidia-current -v 319.21
In the meantime, I’ll inform the team that produces those packages that they’re picking up a redundant patch.
I get the same error as th3flyboy when I run modprobe nvidia. I have
installed debian 7.2.0 and the nvidia drivers I installed was 319.72 for
a geforce 9400GT. I didn’t try to run the above 3 steps because there
are no lines containing PATCH or PATCH_MATCH in
/usr/src/nvidia-current-319.72/dkms.conf.
I get this error to, using debian testing repo. I got a GTX 780Ti and no PATCH/PATCH_MATCH in dkms.conf.
It looks likes the installer can’t find the kernel headers in debian 7/testing.
