We are trying to install the NVidia drivers for Linux CentOS 7.3-1611. The current loaded kernel is 3.10.0-862.9.1.el7.x86_64.
We try to install the drivers from the file “NVIDIA-Linux-x86_64-384.98.run” and we basically got our graphical.target broken now (the system works like a terminal for now only and GNOME won’t start up).
I was also unable to find the file “nvidia-bug-report.sh” as I was checking the sticky thread.
The installer failed with this error message:
ERROR: Failed to run `usr/sbin/dkms build -m nvidia -v 304.137 -k 3.10.0-862.9.1.el7.x86_64`:
kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
make -j20 KERNELRELEASE=3.10.0-862.9.1.el7.x86_64 module SYSSRC=/lib/modules/3.10.0-862.9.1.el7.x86_64/build......(bad exit status: 2)
Error! Bad return status for module build on kernel: 3.10.0-862.9.1.el7.x86_64 (x86_64)
Consult /var/lib/dkms/nvidia/304.137/build/make.log for more information.
The contents of “/var/log/nvidia-installer.log” are:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Wed Jul 18 17:51:57 2018
installer version: 304.137
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/home/hasan/arm-cortex_a9-linux-gnueabihf-linaro_4.9-master/bin:/root/bin
nvidia-installer command line:
    ./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Tagging shared libraries with chcon -t textrel_shlib_t.
-> License accepted.
-> Installing NVIDIA driver version 304.137.
-> There appears to already be a driver installed on your system (version: 304.137).  As part of installing this driver (version: 304.137), the existing driver will be uninstalled.  Are you sure you want to continue? ('no' will abort installation) (Answer: Yes)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility OpenGL libraries? (Answer: Yes)
-> Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
-> Searching for conflicting X files:
ERROR: Unable to open '/usr/lib64/xorg/modules/nvidia-396.37/libglx.so' for reading (No such file or directory)
ERROR: Unable to open '/usr/lib64/nvidia/xorg/libglx.so' for reading (No such file or directory)
-> done.
-> Searching for conflicting OpenGL files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (304.137):
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-glcore.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libGL.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/extensions/libglx.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-tls.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/tls/libnvidia-tls.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/drivers/nvidia_drv.so'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/xorg/modules/libnvidia-wfb.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libXvMCNVIDIA.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-ml.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-cfg.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libcuda.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-opencl.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libOpenCL.so.1.0.0'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvidia-compiler.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/vdpau/libvdpau_nvidia.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib64/libnvcuvid.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/libcuda.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-ml.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/libOpenCL.so.1.0.0'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-compiler.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-opencl.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/libGL.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-glcore.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/libnvidia-tls.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/tls/libnvidia-tls.so.304.137'...
   executing: '/usr/bin/chcon -t textrel_shlib_t /usr/lib/vdpau/libvdpau_nvidia.so.304.137'...
   executing: '/usr/sbin/ldconfig'...
   /usr/sbin/ldconfig: /lib/libaperi_min.so is for unknown machine 40.
   /usr/sbin/ldconfig: /lib/liblowLevelApi.so.0 is not a symbolic link
   /usr/sbin/ldconfig: /lib/libuv.so.1 is not a symbolic link
   /usr/sbin/ldconfig: /lib/libtv.so.0 is not a symbolic link
   /usr/sbin/ldconfig: /lib/libtestHwRpcApi.so.0 is not a symbolic link
   /usr/sbin/ldconfig: /lib/libtestHwApi.so.0 is not a symbolic link
   /usr/sbin/ldconfig: /lib/liblinear.so.0 is not a symbolic link
   /usr/sbin/ldconfig: /lib/libhwRpcApi.so.0 is not a symbolic link
   /usr/sbin/ldconfig: /lib/libhwApi.so.0 is not a symbolic link
   executing: '/usr/sbin/depmod -aq'...
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
ERROR: Failed to run `/usr/sbin/dkms build -m nvidia -v 304.137 -k 3.10.0-862.9.1.el7.x86_64`:
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
-> error.
ERROR: Failed to install the kernel module through DKMS. No kernel module was installed; please try installing again without DKMS, or check the DKMS logs for more information.
ERROR: Installation has failed.  Please see the file '/var/log/nvidia-installer.log' for details.  You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
And the contents of “/var/lib/dkms/nvidia/304.137/build/make.log” are (cropped, it’s too much to copy and paste here):
In file included from /var/lib/dkms/nvidia/304.137/build/nv-linux.h:82:0,
                 from /var/lib/dkms/nvidia/304.137/build/nv-chrdev.c:15:
include/linux/mm.h:1377:6: note: expected ‘struct page **’ but argument is of type ‘struct vm_area_struct **’
 long get_user_pages_remote(struct task_struct *tsk, struct mm_struct *mm,
In file included from /var/lib/dkms/nvidia/304.137/build/nv-chrdev.c:15:0:
/var/lib/dkms/nvidia/304.137/build/nv-linux.h:1919:45: error: too few arguments to function ‘get_user_pages_remote’
                                             pages, vmas);
include/linux/mm.h:1377:6: note: declared here
make[3]: *** [/var/lib/dkms/nvidia/304.137/build/nv-procfs.o] Error 1
make[3]: *** [/var/lib/dkms/nvidia/304.137/build/nv-chrdev.o] Error 1
make[3]: *** [/var/lib/dkms/nvidia/304.137/build/os-registry.o] Error 1
make[2]: *** [_module_/var/lib/dkms/nvidia/304.137/build] Error 2
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make[1]: *** [module] Error 1
make: *** [module] Error 2
I understand, that the nvidia.ko module could not be built. What can be done to get the drivers working on Linux CentOS 7?
