Hi, I’m running on Kali Linux (2016.2 version) trying to install Nvidia driver and cuda toolkit via .Run package from terminal…So after issued the .Run command, the installation starts but it stops giving me the error:
“the driver installation is unable to locate the kernel source. Please make sure that the kernel source packages are installed and set up correctly. If you that the kernel source packages are installed and set up correctly, you may pass the location of the kernel source with the ‘–kernel-source-path’ flag.”
Some info
I’ve installed Linux headers first:
apt-get install linux-headers-$(uname -r)
The toolkit is the 6.5 version, drivers are 340.xx, and my GPU is a 330m
Any ideas on how to solve this problem?
i have problem too same to you biulding kernel modules
here in my var/log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Jan 2 11:59:31 2019
installer version: 367.44
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
→ Detected 4 CPUs online; setting concurrency level to 4.
→ License accepted.
→ Installing NVIDIA driver version 367.44.
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.18.0-kali3-amd64/source’
→ Kernel output path: ‘/lib/modules/4.18.0-kali3-amd64/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j4 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.18.0-kali3-amd64/source” SYSOUT=“/lib/modules/4.18.0-kali3-amd64/build”’…
rm -f -r conftest
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/4.18.0-kali3-amd64/build KBUILD_VERBOSE= -C /lib/modules/4.18.0-kali3-amd64/source M=/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.18.0-kali3-amd64/source NV_KERNEL_OUTPUT=/lib/modules/4.18.0-kali3-amd64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory ‘/usr/src/linux-headers-4.18.0-kali3-common’
make[2]: Entering directory ‘/usr/src/linux-headers-4.18.0-kali3-amd64’
make[2]: Leaving directory ‘/usr/src/linux-headers-4.18.0-kali3-amd64’
make[1]: Leaving directory ‘/usr/src/linux-headers-4.18.0-kali3-common’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.18.0-kali3-amd64/source” SYSOUT=“/lib/modules/4.18.0-kali3-amd64/build”’…
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/4.18.0-kali3-amd64/build KBUILD_VERBOSE= -C /lib/modules/4.18.0-kali3-amd64/source M=/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.18.0-kali3-amd64/source NV_KERNEL_OUTPUT=/lib/modules/4.18.0-kali3-amd64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
SYMLINK /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: acquire_console_sem
CONFTEST: kmem_cache_create
CONFTEST: console_lock
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: drm_driver_has_set_busid
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_parse_phandle
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: request_threaded_irq
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: kernel_write
CONFTEST: strnstr
CONFTEST: iterate_dir
CONFTEST: kstrtoull
CONFTEST: mm_context_t
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_functions_have_name_arg
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg
CONFTEST: dom0_kernel_present
CONFTEST: drm_available
CONFTEST: nvidia_grid_build
CONFTEST: drm_atomic_available
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-acpi.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-acpi.c:15:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/common/inc/nv-linux.h:225:2: error: #error “This driver requires the ability to change memory types!”
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-instance.c:13:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-frontend.c:13:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.c:13:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-instance.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-chrdev.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-frontend.o] Error 1
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-acpi.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-cray.o
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.c: In function ‘nv_start_rc_timer’:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.c:2746:5: error: implicit declaration of function ‘init_timer’; did you mean ‘init_timers’? [-Werror=implicit-function-declaration]
init_timer(&nvl->rc_timer);
init_timers
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.c:2747:28: error: assignment to ‘void (*)(struct timer_list )’ from incompatible pointer type ‘void ()(long unsigned int)’ [-Werror=incompatible-pointer-types]
nvl->rc_timer.function = nvidia_rc_timer;
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.c:2748:18: error: ‘struct timer_list’ has no member named ‘data’
nvl->rc_timer.data = (unsigned long) nvl;
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-dma.o
cc1: some warnings being treated as errors
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-gvi.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-chrdev.c:15:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-cray.c:15:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-dma.c:15:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-chrdev.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-i2c.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-cray.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mempool.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-gvi.c:15:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-dma.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mmap.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-gvi.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-p2p.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-i2c.c:15:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mempool.c:15:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-i2c.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mempool.o] Error 1
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-p2p.c:15:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mmap.c:15:
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-procfs.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mmap.o] Error 1
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-p2p.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vm.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c:15:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-procfs.c:15:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c: In function ‘nvidia_cpu_callback’:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c:213:14: error: ‘CPU_DOWN_FAILED’ undeclared (first use in this function); did you mean ‘ACPI_RASF_FAILED’?
case CPU_DOWN_FAILED:
ACPI_RASF_FAILED
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c:213:14: note: each undeclared identifier is reported only once for each function it appears in
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-procfs.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vtophys.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-usermap.c:15:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c:220:14: error: ‘CPU_DOWN_PREPARE’ undeclared (first use in this function); did you mean ‘CPU_UP_PREPARE’?
case CPU_DOWN_PREPARE:
CPU_UP_PREPARE
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vm.c:14:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c: In function ‘nv_init_pat_support’:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/common/inc/nv-linux.h:389:34: error: implicit declaration of function ‘register_cpu_notifier’; did you mean ‘register_acpi_notifier’? [-Werror=implicit-function-declaration]
#define register_hotcpu_notifier register_cpu_notifier
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c:258:17: note: in expansion of macro ‘register_hotcpu_notifier’
if (register_hotcpu_notifier(&nv_hotcpu_nfb) != 0)
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c: In function ‘nv_teardown_pat_support’:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/common/inc/nv-linux.h:386:36: error: implicit declaration of function ‘unregister_cpu_notifier’; did you mean ‘unregister_acpi_notifier’? [-Werror=implicit-function-declaration]
#define unregister_hotcpu_notifier unregister_cpu_notifier
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.c:283:9: note: in expansion of macro ‘unregister_hotcpu_notifier’
unregister_hotcpu_notifier(&nv_hotcpu_nfb);
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.o] Error 1
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-usermap.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vm.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-pci.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vtophys.c:15:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vtophys.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-registry.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-interface.c:15:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.c:15:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-pci.c:15:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.c: In function ‘os_lock_user_pages’:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.c:120:48: warning: passing argument 4 of ‘get_user_pages’ makes pointer from integer without a cast [-Wint-conversion]
page_count, write, force, user_pages, NULL);
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/common/inc/nv-pgprot.h:17,
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/common/inc/nv-linux.h:17,
/usr/src/linux-headers-4.18.0-kali3-common/include/linux/mm.h:1490:46: note: expected ‘struct page **’ but argument is of type ‘NvBool’ {aka ‘unsigned char’}
unsigned int gup_flags, struct page **pages,
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.c:120:55: error: passing argument 5 of ‘get_user_pages’ from incompatible pointer type [-Werror=incompatible-pointer-types]
/usr/src/linux-headers-4.18.0-kali3-common/include/linux/mm.h:1491:32: note: expected ‘struct vm_area_struct **’ but argument is of type ‘struct page **’
struct vm_area_struct **vmas);
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/common/inc/nv-linux.h:18,
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/common/inc/nv-mm.h:45:41: error: too many arguments to function ‘get_user_pages’
#define NV_GET_USER_PAGES get_user_pages
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.c:119:11: note: in expansion of macro ‘NV_GET_USER_PAGES’
ret = NV_GET_USER_PAGES((unsigned long)address,
/usr/src/linux-headers-4.18.0-kali3-common/include/linux/mm.h:1489:6: note: declared here
long get_user_pages(unsigned long start, unsigned long nr_pages,
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-interface.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-usermap.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-modeset-interface.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-pci.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pci-table.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-registry.c:15:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-registry.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv_uvm_interface.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-usermap.c:15:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-modeset-interface.c:15:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-usermap.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_linux.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-modeset-interface.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_pci.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv_uvm_interface.c:21:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv_uvm_interface.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ebridge_linux.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ibmnpu_linux.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.h:39,
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_utils.c:25:
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common.h:62,
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common.c:37:
In file included from /usr/src/linux-headers-4.18.0-kali3-common/include/asm-generic/bug.h:5,
from /usr/src/linux-headers-4.18.0-kali3-common/arch/x86/include/asm/bug.h:83,
from /usr/src/linux-headers-4.18.0-kali3-common/include/linux/bug.h:5,
from /usr/src/linux-headers-4.18.0-kali3-common/include/linux/mmdebug.h:5,
from /usr/src/linux-headers-4.18.0-kali3-common/include/linux/mm.h:9,
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.h: In function ‘__fatal_signal_pending’:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.h:212:25: error: implicit declaration of function ‘sigismember’ [-Werror=implicit-function-declaration]
return unlikely(sigismember(&p->pending.signal, SIGKILL));
/usr/src/linux-headers-4.18.0-kali3-common/include/linux/compiler.h:77:42: note: in definition of macro ‘unlikely’
# define unlikely(x) __builtin_expect(!!(x), 0)
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_utils.c:25:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.h: In function ‘fatal_signal_pending’:
/tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.h:217:16: error: implicit declaration of function ‘signal_pending’; did you mean ‘timer_pending’? [-Werror=implicit-function-declaration]
return signal_pending(p) && __fatal_signal_pending(p);
timer_pending
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common.h:62,
timer_pending
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_utils.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_stubs.o
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_kepler.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_maxwell.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_pascal.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_mgmt.o
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.c:24:
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nvstatus.o
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration.c:31:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.c:24:
timer_pending
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nv-kthread-q-selftest.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration.c:31:
timer_pending
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common_test.o
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_mgmt.c:23:
timer_pending
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_mgmt.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_directed_tests.o
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common_test.h:27,
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common_test.c:24:
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_basic_sanity_tests.o
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_events.o
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common_test.h:27,
timer_pending
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common_test.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_counters.o
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_mgmt.h:26,
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_gpu_ops_tests.h:32,
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_directed_tests.c:24:
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_basic_sanity_tests.c:23:
In file included from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_mgmt.h:26,
timer_pending
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_events.c:24:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:322: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_directed_tests.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_debug_session.o
timer_pending
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_counters.c:29:
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_basic_sanity_tests.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_gpu_ops_tests.o
timer_pending
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_events.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite.o
timer_pending
make[3]: *** [/usr/src/linux-headers-4.18.0-kali3-common/scripts/Makefile.build:323: /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_counters.o] Error 1
CC [M] /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_cache.o
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_debug_session.c:24:
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/common/inc/nv_uvm_interface.h:30,
from /tmp/selfgz1556/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_gpu_ops_tests.c:23:
timer_pending
