I am trying to install NVIDIA-Linux-x86_64-410.57.run
Complete log is here.
Please guide me on how to install driver.
[code]
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Mon Nov 18 12:40:44 2019
installer version: 410.57
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
–no-x-check
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 36 CPUs online; setting concurrency level to 32.
→ Installing NVIDIA driver version 410.57.
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/5.0.0-32-generic/build’
→ Kernel output path: ‘/lib/modules/5.0.0-32-generic/build’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j32 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.0.0-32-generic/build” SYSOUT=“/lib/modules/5.0.0-32-generic/build”’…
rm -f -r conftest
make[1]: Entering directory ‘/usr/src/linux-headers-5.0.0-32-generic’
make[1]: Leaving directory ‘/usr/src/linux-headers-5.0.0-32-generic’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j32 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/5.0.0-32-generic/build” SYSOUT=“/lib/modules/5.0.0-32-generic/build”’…
SYMLINK /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: hash__remap_4k_pfn
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: acquire_console_sem
CONFTEST: kmem_cache_create
CONFTEST: console_lock
CONFTEST: on_each_cpu
CONFTEST: acpi_evaluate_integer
CONFTEST: smp_call_function
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_dma_mapping_error
CONFTEST: pci_domain_nr
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: get_num_physpages
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: proc_create_data
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: pm_vt_switch_required
CONFTEST: proc_remove
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: of_get_ibm_chip_id
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: register_cpu_notifier
CONFTEST: backlight_device_register
CONFTEST: register_acpi_notifier
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: get_user_pages_remote
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_free
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_disable_all
CONFTEST: drm_atomic_helper_set_config
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: acpi_op_remove
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: task_struct
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_init_function_args
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: kref_has_refcount_of_type_refcount_t
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_old_atomic_state_iterators_present
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv.o
cc1plus: warning: command line option ‘-Wdeclaration-after-statement’ is valid for C/ObjC but not for C++
cc1plus: warning: command line option ‘-Wno-pointer-sign’ is valid for C/ObjC but not for C++
cc1plus: warning: command line option ‘-std=gnu90’ is valid for C/ObjC but not for C++
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-procfs.o
In file included from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/common/inc/conftest.h:5:0,
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/common/inc/nv-linux.h:17,
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-frontend.c:13:
/tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/conftest/functions.h:14:2: error: #error kmem_cache_create() conftest failed!
/tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/conftest/functions.h:15:2: error: #error on_each_cpu() conftest failed!
/tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/conftest/functions.h:16:2: error: #error smp_call_function() conftest failed!
/tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/conftest/functions.h:21:2: error: #error acpi_walk_namespace() conftest failed!
/tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/conftest/functions.h:23:2: error: #error pci_dma_mapping_error() conftest failed!
/tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/conftest/functions.h:60:2: error: #error wait_on_bit_lock() conftest failed!
/tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/conftest/functions.h:65:2: error: #error radix_tree_replace_slot() conftest failed!
In file included from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/common/inc/conftest.h:7:0,
/tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/conftest/macros.h:1:2: error: #error INIT_WORK() conftest failed!
In file included from ./arch/x86/include/asm/barrier.h:5:0,
from ./include/linux/compiler.h:250,
from ./include/linux/export.h:45,
from ./include/linux/linkage.h:7,
from ./include/linux/preempt.h:10,
from ./include/linux/spinlock.h:51,
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/common/inc/nv-lock.h:16,
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/common/inc/nv-linux.h:19,
./arch/x86/include/asm/alternative.h:95:42: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
#define alt_rlen(num) e_replacement(num)"f-"b_replacement(num)“f”
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-usermap.o
In file included from ./arch/x86/include/asm/bitops.h:503:0,
from ./include/linux/bitops.h:19,
from ./include/linux/kernel.h:11,
from ./include/linux/list.h:9,
from ./include/linux/preempt.h:11,
./arch/x86/include/asm/arch_hweight.h:22:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
: "="REG_OUT (res)
./arch/x86/include/asm/arch_hweight.h:50:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
: "="REG_OUT (res)
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-instance.c:13:
#define alt_rlen(num) e_replacement(num)“f-“b_replacement(num)“f”
In file included from ./arch/x86/include/asm/preempt.h:6:0,
from ./include/linux/preempt.h:78,
./arch/x86/include/asm/percpu.h:49:26: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
#define __percpu_prefix “%%”__stringify(__percpu_seg)”:”
./arch/x86/include/asm/percpu.h:100:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op “b %1,”__percpu_arg(0)
./arch/x86/include/asm/percpu.h:105:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op “w %1,”__percpu_arg(0)
./arch/x86/include/asm/percpu.h:110:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op “l %1,”__percpu_arg(0)
./arch/x86/include/asm/percpu.h:115:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op “q %1,”__percpu_arg(0)
./arch/x86/include/asm/percpu.h:141:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("incb "__percpu_arg(0) : “+m” (var));
./arch/x86/include/asm/percpu.h:143:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("decb "__percpu_arg(0) : “+m” (var));
./arch/x86/include/asm/percpu.h:145:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("addb %1, "__percpu_arg(0)
./arch/x86/include/asm/percpu.h:151:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("incw "__percpu_arg(0) : “+m” (var));
./arch/x86/include/asm/percpu.h:153:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("decw "__percpu_arg(0) : “+m” (var));
./arch/x86/include/asm/percpu.h:155:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("addw %1, "__percpu_arg(0)
./arch/x86/include/asm/percpu.h:161:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("incl "__percpu_arg(0) : “+m” (var));
./arch/x86/include/asm/percpu.h:163:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("decl "__percpu_arg(0) : “+m” (var));
./arch/x86/include/asm/percpu.h:165:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("addl %1, "__percpu_arg(0)
./arch/x86/include/asm/percpu.h:171:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("incq "__percpu_arg(0) : “+m” (var));
./arch/x86/include/asm/percpu.h:173:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("decq "__percpu_arg(0) : “+m” (var));
./arch/x86/include/asm/percpu.h:175:8: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("addq %1, "__percpu_arg(0)
./arch/x86/include/asm/percpu.h:188:19: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm volatile(op “b “__percpu_arg(1)”,%0”
./arch/x86/include/asm/percpu.h:193:19: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm volatile(op “w “__percpu_arg(1)”,%0”
./arch/x86/include/asm/percpu.h:198:19: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm volatile(op “l “__percpu_arg(1)”,%0”
./arch/x86/include/asm/percpu.h:203:19: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm volatile(op “q “__percpu_arg(1)”,%0”
./arch/x86/include/asm/percpu.h:217:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op “b “__percpu_arg(P1)”,%0”
./arch/x86/include/asm/percpu.h:222:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op “w “__percpu_arg(P1)”,%0”
./arch/x86/include/asm/percpu.h:227:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op “l “__percpu_arg(P1)”,%0”
./arch/x86/include/asm/percpu.h:232:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op “q “__percpu_arg(P1)”,%0”
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/os-pci.o
./arch/x86/include/asm/percpu.h:245:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op "b "__percpu_arg(0)
./arch/x86/include/asm/percpu.h:249:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op "w "__percpu_arg(0)
./arch/x86/include/asm/percpu.h:253:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op "l "__percpu_arg(0)
./arch/x86/include/asm/percpu.h:257:10: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(op "q "__percpu_arg(0)
./arch/x86/include/asm/percpu.h:272:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("xaddb %0, "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:277:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("xaddw %0, "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:282:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("xaddl %0, "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:287:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(“xaddq %0, “__percpu_arg(1)
./arch/x86/include/asm/percpu.h:308:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(”\n\tmov “__percpu_arg(1)”,%%al”
./arch/x86/include/asm/percpu.h:309:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
“\n1:\tcmpxchgb %2, “__percpu_arg(1)
./arch/x86/include/asm/percpu.h:316:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(”\n\tmov “__percpu_arg(1)”,%%ax”
./arch/x86/include/asm/percpu.h:317:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
“\n1:\tcmpxchgw %2, “__percpu_arg(1)
./arch/x86/include/asm/percpu.h:324:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(”\n\tmov “__percpu_arg(1)”,%%eax”
./arch/x86/include/asm/percpu.h:325:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
“\n1:\tcmpxchgl %2, “__percpu_arg(1)
./arch/x86/include/asm/percpu.h:332:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm(”\n\tmov “__percpu_arg(1)”,%%rax”
./arch/x86/include/asm/percpu.h:333:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
"\n1:\tcmpxchgq %2, "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:355:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("cmpxchgb %2, "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:361:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("cmpxchgw %2, "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:367:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("cmpxchgl %2, "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:373:7: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm("cmpxchgq %2, "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:453:15: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm volatile("cmpxchg8b "__percpu_arg(1)
./arch/x86/include/asm/percpu.h:530:15: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
asm volatile(“btl “__percpu_arg(2)”,%1”
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-vm.o
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv.c:14:
: "="REG_OUT (res)
: "="REG_OUT (res)
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-chrdev.c:15:
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/os-mlock.o
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-acpi.c:15:
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-modeset-interface.o
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-p2p.c:15:
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-gvi.c:15:
: "="REG_OUT (res)
"\n1:\tcmpxchgw %2, "__percpu_arg(1)
: “=“REG_OUT (res)
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-pci-table.o
from /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-cray.c:15:
: "="REG_OUT (res)
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz17289/NVIDIA-Linux-x86_64-410.57/kernel/nvidia/nv-vtophys.o
: "="REG_OUT (res)
