After upgrading to the latest fedora 25 I am unable to compile the NVIDIA driver for my Quadro k2200.
I have also tried the beta x86_64-381.09 with no success
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Fri Apr 21 11:11:33 2017
installer version: 378.13
PATH: /usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses v6 user interface
→ Detected 16 CPUs online; setting concurrency level to 16.
→ Tagging shared libraries with chcon -t textrel_shlib_t.
→ License accepted.
→ Installing NVIDIA driver version 378.13.
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/4.10.10-200.fc25.x86_64/source’
→ Kernel output path: ‘/lib/modules/4.10.10-200.fc25.x86_64/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j16 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.10.10-200.fc25.x86_64/source” SYSOUT=“/lib/modules/4.10.10-200.fc25.x86_64/build”’…
rm -f -r conftest
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/4.10.10-200.fc25.x86_64/build KBUILD_VERBOSE= -C /lib/modules/4.10.10-200.fc25.x86_64/source M=/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.10.10-200.fc25.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/4.10.10-200.fc25.x86_64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory ‘/usr/src/kernels/4.10.10-200.fc25.x86_64’
make[2]: Entering directory ‘/usr/src/kernels/4.10.10-200.fc25.x86_64’
make[2]: Leaving directory ‘/usr/src/kernels/4.10.10-200.fc25.x86_64’
make[1]: Leaving directory ‘/usr/src/kernels/4.10.10-200.fc25.x86_64’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j16 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/4.10.10-200.fc25.x86_64/source” SYSOUT=“/lib/modules/4.10.10-200.fc25.x86_64/build”’…
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/4.10.10-200.fc25.x86_64/build KBUILD_VERBOSE= -C /lib/modules/4.10.10-200.fc25.x86_64/source M=/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/4.10.10-200.fc25.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/4.10.10-200.fc25.x86_64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
SYMLINK /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: INIT_WORK
CONFTEST: follow_pfn
CONFTEST: remap_pfn_range
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: acpi_device_id
CONFTEST: vm_insert_page
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: on_each_cpu
CONFTEST: kmem_cache_create
CONFTEST: smp_call_function
CONFTEST: ioremap_cache
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_wc
CONFTEST: pci_domain_nr
CONFTEST: acpi_walk_namespace
CONFTEST: sg_init_table
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: drm_driver_has_set_busid
CONFTEST: pm_vt_switch_required
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: of_parse_phandle
CONFTEST: write_cr4
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: request_threaded_irq
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_dev_unref
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: get_user_pages_remote
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_free
CONFTEST: i2c_adapter
CONFTEST: irq_handler_t
CONFTEST: pm_message_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: file_inode
CONFTEST: pci_save_state
CONFTEST: kuid_t
CONFTEST: task_struct
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_present
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: kernel_write
CONFTEST: strnstr
CONFTEST: iterate_dir
CONFTEST: kstrtoull
CONFTEST: vm_fault_has_address
CONFTEST: mm_context_t
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_init_functions_have_name_arg
CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_mode_config_funcs_has_atomic_state_alloc
CONFTEST: dom0_kernel_present
CONFTEST: drm_available
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: drm_atomic_available
CONFTEST: drm_atomic_modeset_nonblocking_commit_available
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-vm.o
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c: In function ‘nvidia_cpu_callback’:
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c:213:14: error: ‘CPU_DOWN_FAILED’ undeclared (first use in this function)
case CPU_DOWN_FAILED:
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c:213:14: note: each undeclared identifier is reported only once for each function it appears in
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c:220:14: error: ‘CPU_DOWN_PREPARE’ undeclared (first use in this function)
case CPU_DOWN_PREPARE:
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c:15:0:
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c: In function ‘nv_init_pat_support’:
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/common/inc/nv-linux.h:391:34: error: implicit declaration of function ‘register_cpu_notifier’ [-Werror=implicit-function-declaration]
#define register_hotcpu_notifier register_cpu_notifier
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c:258:17: note: in expansion of macro ‘register_hotcpu_notifier’
if (register_hotcpu_notifier(&nv_hotcpu_nfb) != 0)
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c: In function ‘nv_teardown_pat_support’:
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/common/inc/nv-linux.h:388:36: error: implicit declaration of function ‘unregister_cpu_notifier’ [-Werror=implicit-function-declaration]
#define unregister_hotcpu_notifier unregister_cpu_notifier
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.c:283:9: note: in expansion of macro ‘unregister_hotcpu_notifier’
unregister_hotcpu_notifier(&nv_hotcpu_nfb);
cc1: some warnings being treated as errors
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pat.o] Error 1
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/nvlink_pci.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/ebridge_linux.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia/ibmnpu_linux.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_page_migration.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_page_migration_stubs.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_page_migration_kepler.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_page_migration_maxwell.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_page_migration_pascal.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_mmu_mgmt.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_full_fault_buffer.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/mmu_fmt.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/gmmu_fmt.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_gpu_page_fault.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-connector.o
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm.c:27:0:
/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-priv.h:37:25: fatal error: linux/fence.h: No such file or directory
#include <linux/fence.h>
compilation terminated.
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm.o] Error 1
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-fb.o
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-drv.c:25:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-drv.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-drv.o] Error 1
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-modeset.o
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-utils.c:27:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-utils.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-utils.o] Error 1
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-fence.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nv-pci-table.o
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-crtc.c:27:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-crtc.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-crtc.o] Error 1
ld -r -o /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-modeset.o
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-connector.c:27:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-connector.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-connector.o] Error 1
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-encoder.c:27:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-encoder.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-encoder.o] Error 1
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-gem.c:27:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-gem.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-gem.o] Error 1
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-fb.c:27:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-fb.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-fb.o] Error 1
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-modeset.c:27:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-modeset.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-modeset.o] Error 1
In file included from /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-fence.c:27:0:
/usr/src/kernels/4.10.10-200.fc25.x86_64/scripts/Makefile.build:294: recipe for target ‘/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-fence.o’ failed
make[3]: *** [/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-drm/nvidia-drm-fence.o] Error 1
LD [M] /tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel/nvidia-uvm.o
make[3]: Target ‘__build’ not remade because of errors.
/usr/src/kernels/4.10.10-200.fc25.x86_64/Makefile:1494: recipe for target ‘module/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel’ failed
make[2]: *** [module/tmp/selfgz3031/NVIDIA-Linux-x86_64-378.13/kernel] Error 2
make[2]: Target ‘modules’ not remade because of errors.
Makefile:150: recipe for target ‘sub-make’ failed
make[1]: *** [sub-make] Error 2
make[1]: Target ‘modules’ not remade because of errors.
Makefile:81: recipe for target ‘modules’ failed
make: *** [modules] Error 2
→ Error.
ERROR: An error occurred while performing the step: “Building kernel modules”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j16 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.10.10-200.fc25.x86_64/source" SYSOUT="/lib/modules/4.10.10-200.fc25.x86_64/build" failed with the following output:
CONFTEST: INIT_WORK
CONFTEST: vmap
CONFTEST: pde_data
CONFTEST: write_cr4
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: sg_table
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: strnstr
CONFTEST: kstrtoull
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Thank you Jim
