nvidia-linux-grid-510-510.73.08-1.x86_64.rpm works on CentOS 7
nvidia-linux-grid-510_510.73.08_amd64.deb works on Ubuntu 22 LTS
nvidia-linux-grid-510-510.108.03-1.x86_64.rpm works on Rocky Linux 8.8
Is there a simple way to get 510.73.08 installed on Rocky Linux 8.8, or should we upgrade our GRID Virtual GPU Manager and Guest VM drivers to 510.108.03?
Output of rpm -iv ./nvidia-linux-grid-510-510.73.08-1.x86_64.rpm on Rocky Linux 8.8:
DKMS make.log for nvidia-510.73.08 for kernel 4.18.0-477.27.1.el8_8.x86_64 (x86_64)
Mon Oct 16 00:50:08 EDT 2023
make[1]: Entering directory '/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64'
make[2]: Entering directory '/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64'
SYMLINK /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-kernel.o
SYMLINK /var/lib/dkms/nvidia/510.73.08/build/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: PDE_DATA
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: get_backlight_device_by_name
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: hlist_for_each_entry
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: vga_tryget
CONFTEST: pgprot_decrypted
CONFTEST: cc_mkdec
CONFTEST: iterate_fd
CONFTEST: seq_read_iter
CONFTEST: sg_page_iter_page
CONFTEST: unsafe_follow_pfn
CONFTEST: drm_gem_object_get
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: set_close_on_exec
CONFTEST: add_memory_driver_managed
CONFTEST: device_property_read_u64
CONFTEST: devm_of_platform_populate
CONFTEST: of_dma_configure
CONFTEST: of_property_count_elems_of_size
CONFTEST: of_property_read_variable_u8_array
CONFTEST: i2c_new_client_device
CONFTEST: i2c_unregister_device
CONFTEST: of_get_named_gpio
CONFTEST: devm_gpio_request_one
CONFTEST: gpio_direction_input
CONFTEST: gpio_direction_output
CONFTEST: gpio_get_value
CONFTEST: gpio_set_value
CONFTEST: gpio_to_irq
CONFTEST: icc_get
CONFTEST: icc_put
CONFTEST: icc_set_bw
CONFTEST: dma_set_coherent_mask
CONFTEST: acpi_bus_get_device
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: ioasid_get
CONFTEST: migrate_vma_setup
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: nvhost_dma_fence_unpack
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: acpi_fadt_low_power_s0
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: pci_dev_has_ats_enabled
CONFTEST: mt_device_gre
CONFTEST: remove_memory_has_nid_arg
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: migrate_vma_added_flags
CONFTEST: make_device_exclusive_range
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_device_list
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: drm_device_has_pdev
CONFTEST: drm_crtc_state_has_no_vblank
CONFTEST: drm_mode_config_has_allow_fb_modifiers
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: ib_peer_memory_symbols
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-pci.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-acpi.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-cray.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-dma.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-i2c.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-mmap.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-p2p.o
/var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-dma.c: In function ‘nv_dma_use_map_resource’:
/var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-dma.c:783:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
const struct dma_map_ops *ops = get_dma_ops(dma_dev->dev);
/var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-dma.c: At top level:
/var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-dma.c:991: warning: "IMPORT_SGT_STUBS_NEEDED" redefined
#define IMPORT_SGT_STUBS_NEEDED 0
/var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-dma.c:985: note: this is the location of the previous definition
#define IMPORT_SGT_STUBS_NEEDED 1
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-pat.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-procfs.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-procfs-utils.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-usermap.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-vm.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-vtophys.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/os-interface.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/os-mlock.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/os-pci.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/os-registry.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/os-usermap.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-modeset-interface.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-pci-table.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-kthread-q.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-memdbg.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-ibmnpu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-report-err.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-rsync.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-msi.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-caps.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv-frontend.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nv_uvm_interface.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nvlink_linux.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/nvlink_caps.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/linux_nvswitch.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/procfs_nvswitch.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia/i2c_nvswitch.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_common.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_linux.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/nvstatus.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/nvCpuUuid.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/nv-kthread-q.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_tools.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_global.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_gpu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_gpu_isr.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_procfs.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_va_space.o
/var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm.c: In function ‘uvm_mmap’:
/var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm.c:887:1: warning: label ‘out_va_space_unlock’ defined but not used [-Wunused-label]
out_va_space_unlock:
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_va_space_mm.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_gpu_semaphore.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_mem.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_rm_mem.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_channel.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_lock.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_hal.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_range_tree.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_rb_tree.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_range_allocator.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_va_range.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_va_block.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_range_group.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_gpu_replayable_faults.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_gpu_non_replayable_faults.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_gpu_access_counters.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_events.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_module.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_mmu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pte_batch.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_tlb_batch.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_push.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pushbuffer.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_thread_context.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_tracker.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_maxwell.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_maxwell_host.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_maxwell_ce.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_maxwell_mmu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_maxwell_fault_buffer.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_maxwell_access_counter_buffer.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pascal.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pascal_ce.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pascal_host.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pascal_mmu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_volta_host.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_volta_mmu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_volta.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_turing.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_turing_access_counter_buffer.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_turing_fault_buffer.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_turing_mmu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_turing_host.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_ampere.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_ampere_ce.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_ampere_host.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_ampere_mmu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_policy.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_utils.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_kvmalloc.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pmm_sysmem.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pmm_gpu.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_migrate.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_populate_pageable.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_migrate_pageable.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_map_external.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_user_channel.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_hmm.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_heuristics.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_thrashing.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_prefetch.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_ats_ibm.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_ats_faults.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_test_rng.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_range_tree_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_range_allocator_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_hmm_sanity_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_mem_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_rm_mem_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_page_tree_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_tracker_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_push_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_channel_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_ce_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_host_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_lock_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_utils_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_kvmalloc_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pmm_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_events_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_perf_module_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_va_block_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_range_group_tree_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_thread_context_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-uvm/uvm_rb_tree_test.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-modeset/nv-kthread-q.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-drv.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-utils.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-encoder.o
In file included from /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-gem.h:45,
from /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-gem-nvkms-memory.h:30,
from /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-fb.h:38,
from /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-drv.c:27:
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-dma-resv-helper.h: In function ‘nv_dma_resv_add_excl_fence’:
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-dma-resv-helper.h:72:5: error: implicit declaration of function ‘dma_resv_add_excl_fence’; did you mean ‘nv_dma_resv_add_excl_fence’? [-Werror=implicit-function-declaration]
dma_resv_add_excl_fence(obj, fence);
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-connector.o
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-gem.o
from /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c:33:
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-fb.o
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c: In function ‘cursor_plane_req_config_update’:
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c:81:32: warning: unused variable ‘nv_drm_plane_state’ [-Wunused-variable]
struct nv_drm_plane_state *nv_drm_plane_state =
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c:80:27: warning: unused variable ‘nv_dev’ [-Wunused-variable]
struct nv_drm_device *nv_dev = to_nv_device(plane->dev);
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c: In function ‘plane_req_config_update’:
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c:182:9: warning: unused variable ‘ret’ [-Wunused-variable]
int ret = 0;
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c: In function ‘nv_drm_plane_atomic_set_property’:
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c:497:32: warning: unused variable ‘nv_drm_plane_state’ [-Wunused-variable]
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c: In function ‘nv_drm_enumerate_crtcs_and_planes’:
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.c:1141:13: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
struct drm_plane *overlay_plane =
cc1: some warnings being treated as errors
CC [M] /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-modeset.o
make[3]: *** [/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64/scripts/Makefile.build:318: /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-drv.o] Error 1
make[3]: *** Waiting for unfinished jobs....
from /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-gem.c:30:
make[3]: *** [/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64/scripts/Makefile.build:317: /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-crtc.o] Error 1
from /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-fb.c:29:
make[3]: *** [/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64/scripts/Makefile.build:317: /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-gem.o] Error 1
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-modeset.c: In function ‘__will_generate_flip_event’:
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-modeset.c:98:10: warning: unused variable ‘overlay_event’ [-Wunused-variable]
bool overlay_event = false;
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-modeset.c:97:10: warning: unused variable ‘primary_event’ [-Wunused-variable]
bool primary_event = false;
/var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-modeset.c:96:23: warning: unused variable ‘primary_plane’ [-Wunused-variable]
struct drm_plane *primary_plane = crtc->primary;
make[3]: *** [/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64/scripts/Makefile.build:317: /var/lib/dkms/nvidia/510.73.08/build/nvidia-drm/nvidia-drm-fb.o] Error 1
make[2]: *** [/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64/Makefile:1616: _module_/var/lib/dkms/nvidia/510.73.08/build] Error 2
make[2]: Leaving directory '/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64'
make[1]: *** [Makefile:158: sub-make] Error 2
make[1]: Leaving directory '/usr/src/kernels/4.18.0-477.27.1.el8_8.x86_64'
make: *** [Makefile:82: modules] Error 2
