Hi
Installing the new driver on Debian kernel image 5.19-trunk-amd64 works flawlessly.
I used the DKMS option to build the modules automatically.
but …
On self-cooked kernels it sometimes installs , sometimes fails.
Working on 5.18 , failing on 5.19.
Log :CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-pci.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-dmabuf.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-acpi.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-cray.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-dma.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-i2c.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-mmap.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-p2p.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-pat.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-procfs.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-procfs-utils.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-usermap.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-vm.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-vtophys.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-interface.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-mlock.o
/var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-dma.c: In function ‘nv_dma_use_map_resource’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-dma.c:783:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
783 | const struct dma_map_ops *ops = get_dma_ops(dma_dev->dev);
/var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-mmap.c: In function ‘nv_encode_caching’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-mmap.c:343:16: warning: this statement may fall through [-Wimplicit-fallthrough=]
343 | if (NV_ALLOW_CACHING(memory_type))
/var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-mmap.c:346:9: note: here
346 | default:
In file included from ./include/linux/kernel.h:26,
from ./arch/x86/include/asm/percpu.h:27,
from ./arch/x86/include/asm/preempt.h:6,
from ./include/linux/preempt.h:78,
from ./include/linux/spinlock.h:55,
from /var/lib/dkms/nvidia/515.65.01/build/common/inc/nv-lock.h:29,
from /var/lib/dkms/nvidia/515.65.01/build/common/inc/nv-linux.h:32,
from /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-vm.c:26:
/var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-vm.c: In function ‘nv_get_max_sysmem_address’:
./include/linux/minmax.h:20:35: warning: comparison of distinct pointer types lacks a cast
20 | (!!(sizeof((typeof(x) *)1 == (typeof(y) *)1)))
./include/linux/minmax.h:26:18: note: in expansion of macro ‘__typecheck’
26 | (__typecheck(x, y) && __no_side_effects(x, y))
./include/linux/minmax.h:36:31: note: in expansion of macro ‘__safe_cmp’
36 | __builtin_choose_expr(__safe_cmp(x, y),
./include/linux/minmax.h:52:25: note: in expansion of macro ‘__careful_cmp’
52 | #define max(x, y) __careful_cmp(x, y, >)
/var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-vm.c:225:26: note: in expansion of macro ‘max’
225 | global_max_pfn = max(global_max_pfn, node_end_pfn(node_id));
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-pci.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-registry.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-usermap.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-modeset-interface.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-pci-table.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-kthread-q.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-ibmnpu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-memdbg.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-report-err.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-rsync.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-msi.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-caps.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-frontend.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv_uvm_interface.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nvlink_linux.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/nvlink_caps.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/linux_nvswitch.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/procfs_nvswitch.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia/i2c_nvswitch.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_common.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_linux.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/nvstatus.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/nvCpuUuid.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/nv-kthread-q.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_tools.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_global.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_gpu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_gpu_isr.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_procfs.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_va_space.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_va_space_mm.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_gpu_semaphore.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_mem.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_rm_mem.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_channel.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_lock.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_hal.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_range_tree.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_rb_tree.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_range_allocator.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_va_range.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_va_policy.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_va_block.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_range_group.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_gpu_replayable_faults.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_gpu_non_replayable_faults.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_gpu_access_counters.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_events.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_module.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_mmu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pte_batch.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_tlb_batch.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_push.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pushbuffer.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_thread_context.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_tracker.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_maxwell.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_maxwell_host.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_maxwell_ce.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_maxwell_mmu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_maxwell_fault_buffer.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_maxwell_access_counter_buffer.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pascal.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pascal_ce.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pascal_host.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pascal_mmu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_volta_host.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_volta_mmu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_volta.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_turing.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_turing_access_counter_buffer.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_turing_fault_buffer.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_turing_mmu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_turing_host.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_ampere.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_ampere_ce.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_ampere_host.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_ampere_mmu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_policy.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_utils.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_kvmalloc.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pmm_sysmem.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pmm_gpu.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_migrate.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_populate_pageable.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_migrate_pageable.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_map_external.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_user_channel.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_hmm.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_heuristics.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_thrashing.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_prefetch.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_ats.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_ats_ibm.o
/var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pmm_gpu.c: In function ‘uvm_pmm_gpu_alloc_kernel’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pmm_gpu.c:645:16: warning: unused variable ‘gpu’ [-Wunused-variable]
645 | uvm_gpu_t *gpu = uvm_pmm_to_gpu(pmm);
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_ats_faults.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_test_rng.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_range_tree_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_range_allocator_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_hmm_sanity_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_mem_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_rm_mem_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_page_tree_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_tracker_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_push_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_channel_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_ce_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_host_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_lock_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_utils_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_kvmalloc_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pmm_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_events_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_perf_module_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_va_block_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_range_group_tree_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_thread_context_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm/uvm_rb_tree_test.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-modeset/nv-kthread-q.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-drv.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-utils.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-encoder.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-connector.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-gem.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-fb.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-modeset.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-linux.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-helper.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nv-pci-table.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-gem-dma-buf.o
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-format.o
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c: In function ‘cursor_plane_req_config_update’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c:88:32: warning: unused variable ‘nv_drm_plane_state’ [-Wunused-variable]
88 | struct nv_drm_plane_state *nv_drm_plane_state =
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c:87:27: warning: unused variable ‘nv_dev’ [-Wunused-variable]
87 | struct nv_drm_device *nv_dev = to_nv_device(plane->dev);
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c: In function ‘plane_req_config_update’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c:189:9: warning: unused variable ‘ret’ [-Wunused-variable]
189 | int ret = 0;
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c: In function ‘nv_drm_plane_atomic_set_property’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c:504:32: warning: unused variable ‘nv_drm_plane_state’ [-Wunused-variable]
504 | struct nv_drm_plane_state *nv_drm_plane_state =
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c: In function ‘nv_drm_enumerate_crtcs_and_planes’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-crtc.c:1148:13: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
1148 | struct drm_plane *overlay_plane =
CC [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-peermem/nvidia-peermem.o
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-modeset.c: In function ‘__will_generate_flip_event’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-modeset.c:98:10: warning: unused variable ‘overlay_event’ [-Wunused-variable]
98 | bool overlay_event = false;
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-modeset.c:97:10: warning: unused variable ‘primary_event’ [-Wunused-variable]
97 | bool primary_event = false;
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-modeset.c:96:23: warning: unused variable ‘primary_plane’ [-Wunused-variable]
96 | struct drm_plane *primary_plane = crtc->primary;
LD [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia.o
ld: warning: /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-kernel.o: missing .note.GNU-stack section implies executable stack
ld: NOTE: This behaviour is deprecated and will be removed in a future version of the linker
ld -r -o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-interface.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-pci.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-dmabuf.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-acpi.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-cray.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-dma.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-i2c.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-mmap.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-p2p.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-pat.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-procfs.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-procfs-utils.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-usermap.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-vm.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-vtophys.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-interface.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-mlock.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-pci.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-registry.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/os-usermap.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-modeset-interface.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-pci-table.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-kthread-q.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-memdbg.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-ibmnpu.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-report-err.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-rsync.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-msi.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-caps.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv-frontend.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nv_uvm_interface.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nvlink_linux.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/nvlink_caps.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/linux_nvswitch.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/procfs_nvswitch.o /var/lib/dkms/nvidia/515.65.01/build/nvidia/i2c_nvswitch.o
LD [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-uvm.o
LD [M] /var/lib/dkms/nvidia/515.65.01/build/nvidia-modeset.o
ld -r -o /var/lib/dkms/nvidia/515.65.01/build/nvidia-modeset/nv-modeset-interface.o /var/lib/dkms/nvidia/515.65.01/build/nvidia-modeset/nvidia-modeset-linux.o /var/lib/dkms/nvidia/515.65.01/build/nvidia-modeset/nv-kthread-q.o
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-helper.c: In function ‘__nv_drm_framebuffer_put’:
/var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-helper.c:47:5: error: implicit declaration of function ‘drm_framebuffer_put’ [-Werror=implicit-function-declaration]
47 | drm_framebuffer_put(fb);
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:249 : /var/lib/dkms/nvidia/515.65.01/build/nvidia-drm/nvidia-drm-helper.o] Erreur 1
make[2]: *** Attente des tâches non terminées…
make[1]: *** [Makefile:1844 : /var/lib/dkms/nvidia/515.65.01/build] Erreur 2
make[1] : on quitte le répertoire « /usr/src/linux-headers-5.19.0-amd64 »
make: *** [Makefile:82 : modules] Erreur 2
Any help would be appreciated
