Hello everyone.
I am facing trouble with my Ubuntu 22… sometimes its hang and it showed a black screen while the machine is working. I found out some suggestion that i need to update the driver in my laptop.
but i got this error, and installing not complete.:
Errors were encountered while processing:
nvidia-dkms-515
nvidia-driver-515
E: Sub-process /usr/bin/dpkg returned an error code (1)
once i check $sudo apt --fix-broken install
i got this output:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up nvidia-dkms-515 (515.86.01-0ubuntu0.22.10.1) ...
update-initramfs: deferring update (trigger activated)
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
Removing old nvidia-515.86.01 DKMS files...
Deleting module nvidia-515.86.01 completely from the DKMS tree.
Loading new nvidia-515.86.01 DKMS files...
Building for 5.19.0-26-generic
Building for architecture x86_64
Building initial module for 5.19.0-26-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-kernel-s
ource-515.0.crash'
Error! Bad return status for module build on kernel: 5.19.0-26-generic (x86_64)
Consult /var/lib/dkms/nvidia/515.86.01/build/make.log for more information.
dpkg: error processing package nvidia-dkms-515 (--configure):
installed nvidia-dkms-515 package post-installation script subprocess returned
error exit status 10
dpkg: dependency problems prevent configuration of nvidia-driver-515:
nvidia-driver-515 depends on nvidia-dkms-515 (= 515.86.01); however:
Package nvidia-dkms-515 is not configured yet.
dpkg: error processing package nvidia-driver-515 (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup erro
r from a previous failure.
Processing triggers for initramfs-tools (0.140ubuntu17
update-initramfs: Generating /boot/initrd.img-5.19.0-26-generic
nvidia-dkms-515
nvidia-driver-515
then i try to install DKMS $ sudo apt-get install dkms
dkms is already the newest version (3.0.6-2ubuntu2).
dkms set to manually installed.
Do you want to continue? [Y/n] y
INFO:Enable nvidia
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-kernel-source-515.0.crash'
installed nvidia-dkms-515 package post-installation script subprocess returned error exit status 10
No apport report written because the error message indicates its a followup error from a previous failure.
Processing triggers for initramfs-tools (0.140ubuntu17) ...
nvidia-dkms-515
nvidia-driver-515
for more information of my device:
dpkg -l |grep nvidia
ii libnvidia-cfg1-515:amd64 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-515 515.86.01-0ubuntu0.22.10.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-515:amd64 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-515:i386 515.86.01-0ubuntu0.22.10.1 i386 NVIDIA libcompute package
rc libnvidia-compute-520:amd64 520.61.05-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-decode-515:amd64 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-515:i386 515.86.01-0ubuntu0.22.10.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.10-1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-515:amd64 515.86.01-0ubuntu0.22.10.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-515:i386 515.86.01-0ubuntu0.22.10.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-515:amd64 515.86.01-0ubuntu0.22.10.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-515:amd64 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-515:i386 515.86.01-0ubuntu0.22.10.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-515:amd64 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-515:i386 515.86.01-0ubuntu0.22.10.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc linux-objects-nvidia-515-5.19.0-21-generic 5.19.0-21.21+1 amd64 Linux kernel nvidia modules for version 5.19.0-21 (objects)
ii linux-objects-nvidia-515-5.19.0-23-generic 5.19.0-23.24+1 amd64 Linux kernel nvidia modules for version 5.19.0-23 (objects)
ii linux-signatures-nvidia-5.19.0-23-generic 5.19.0-23.24+1 amd64 Linux kernel signatures for nvidia modules for version 5.19.0-23-generic
ii nvidia-compute-utils-515 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA compute utilities
iF nvidia-dkms-515 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA DKMS package
iU nvidia-driver-515 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-515 515.86.01-0ubuntu0.22.10.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-515 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 520.61.05-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-515 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-515 515.86.01-0ubuntu0.22.10.1 amd64 NVIDIA binary Xorg driver
$ dpkg-divert --list
diversion of /usr/share/dict/words to /usr/share/dict/words.pre-dictionaries-common by dictionaries-common
diversion of /usr/share/man/man1/sh.1.gz to /usr/share/man/man1/sh.distrib.1.gz by dash
diversion of /usr/share/vim/vim90/doc/help.txt to /usr/share/vim/vim90/doc/help.txt.vim-tiny by vim-runtime
diversion of /usr/share/vim/vim90/doc/tags to /usr/share/vim/vim90/doc/tags.vim-tiny by vim-runtime
diversion of /usr/share/aisleriot/cards/bonded.svg to /usr/share/aisleriot/cards/bonded.svg.unbranded by branding-ubuntu
diversion of /usr/share/gnome-mahjongg/themes/postmodern.svg to /usr/share/gnome-mahjongg/themes/postmodern.svg.unbranded by branding-ubuntu
diversion of /bin/sh to /bin/sh.distrib by dash
diversion of /usr/share/aisleriot/pixmaps/baize.png to /usr/share/aisleriot/pixmaps/baize.png.unbranded by branding-ubuntu
diversion of /usr/share/aisleriot/pixmaps/slot.svg to /usr/share/aisleriot/pixmaps/slot.svg.unbranded by branding-ubuntu
$sudo lshw -C display
*-display UNCLAIMED
description: VGA compatible controller
product: GA107M [GeForce RTX 3050 Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: iomemory:600-5ff iomemory:610-60f memory:5f000000-5fffffff memory:6000000000-60ffffffff memory:6100000000-6101ffffff ioport:4000(size=128) memory:60080000-600fffff
*-display UNCLAIMED
product: TigerLake-H GT1 [UHD Graphics]
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list
resources: iomemory:610-60f iomemory:400-3ff memory:6104000000-6104ffffff memory:4000000000-400fffffff ioport:5000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
*-graphics
product: EFI VGA
physical id: 2
logical name: /dev/fb0
capabilities: fb
configuration: depth=32 resolution=1920,1080
can you help me to fix this issue please
