535 driver issue on GeForce RTX 3060 Mobile
I installed the latest Nvidia Driver 535, but when I boot, the computer doesn’t detect the graphics card and there is a dpkg error like this:
Setting up nvidia-dkms-535 (535.43.02-0ubuntu0~gpu22.04.2) ...
update-initramfs: deferring update (trigger activated)
update-initramfs: Generating /boot/initrd.img-6.3.5-2-liquorix-amd64
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
Removing old nvidia-535.43.02 DKMS files...
Loading new nvidia-535.43.02 DKMS files...
Error! DKMS tree already contains: nvidia-535.43.02
You cannot add the same module/version combo more than once.
dpkg: error processing package nvidia-dkms-535 (--configure):
 installed nvidia-dkms-535 package post-installation script subprocess returned error exit status 3
dpkg: dependency problems prevent configuration of nvidia-driver-535:
 nvidia-driver-535 depends on nvidia-dkms-535 (<= 535.43.02-1); however:
  Package nvidia-dkms-535 is not configured yet.
 nvidia-driver-535 depends on nvidia-dkms-535 (>= 535.43.02); however:
dpkg: error processing package nvidia-driver-535 (--configure):
 dependency problems - leaving unconfigured
Processing triggers for initramfs-tools (0.140ubuntu13) ...
update-initramfs: Generating /boot/initrd.img-6.3.5-060305-generic
Errors were encountered while processing:
 nvidia-dkms-535
 nvidia-driver-535
I am on Lenovo Legion 5 Pro with a GeForce RTX 3060 Mobile.
Kernel: 6.3.5-2-liquorix-amd64
nvidia-bug-report.log.gz (160.6 KB)
I don’t think you can build that dkms module for kernel 6.3 yet. You need to revert to 6.2 or stock ubuntu kernel.
That’s not true.
Removing old nvidia-535.43.02 DKMS files…
Loading new nvidia-535.43.02 DKMS files…
Technically that’s not a dpkg error, but a dkms one.
From the look of it, you already had the same driver version installed.
Did you try to install it from a different source? Or the -open version over the proprietary one - or vice versa?
What does dkms status show?
I reverted to kernel 6.2.16 without liquorix, and now the PC detects my graphics card. However, the dkms error still persists.
I installed the nvidia driver by running:
sudo aptitude install nvidia-driver-535
Here’s what dkms status shows:
nvidia/535.43.02: added
I use the proprietary version, and not the open one.
Are the kernel headers installed?
sudo apt install linux-headers-$(uname -r)
I checked and they are.
Then we need the output of:
dkms install nvidia/535.43.02
and maybe the corresponding make.log. Most likely to be found at:
/var/lib/dkms/nvidia/<DRIVER_VERSION>/<KERNEL_VERSION>/x86_64/log/
Here’s what i got:
$ sudo dkms install nvidia/535.43.02
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
unset ARCH; [ ! -h /usr/bin/cc ] && export CC=/usr/bin/gcc; env NV_VERBOSE=1 'make' -j16 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=6.2.16-060216-generic IGNORE_XEN_PRESENCE=1 IGNORE_CC_MISMATCH=1 SYSSRC=/lib/modules/6.2.16-060216-generic/build LD=/usr/bin/ld.bfd CONFIG_X86_KERNEL_IBT= modules...........
Signing module:
 - /var/lib/dkms/nvidia/535.43.02/6.2.16-060216-generic/x86_64/module/nvidia-peermem.ko
 - /var/lib/dkms/nvidia/535.43.02/6.2.16-060216-generic/x86_64/module/nvidia-uvm.ko
 - /var/lib/dkms/nvidia/535.43.02/6.2.16-060216-generic/x86_64/module/nvidia-drm.ko
 - /var/lib/dkms/nvidia/535.43.02/6.2.16-060216-generic/x86_64/module/nvidia.ko
 - /var/lib/dkms/nvidia/535.43.02/6.2.16-060216-generic/x86_64/module/nvidia-modeset.ko
Secure Boot not enabled on this system.
nvidia.ko:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/6.2.16-060216-generic/updates/dkms/
nvidia-modeset.ko:
 - Original module
 - Installation
nvidia-drm.ko:
 - Original module
 - Installation
nvidia-uvm.ko:
 - Original module
 - Installation
nvidia-peermem.ko:
 - Original module
 - Installation
depmod...
make.log (1.1 MB)
Looks like a successful install.
Well, the graphics card at least is detected by Ubuntu now, and if the installation seems successful, I guess I have no other choice than to ignore the dkms error messages.
From the last dkms output you showed me, there is no error message.
So how should I know, that somewhere there is an error.
If the card is detected and working, at least the most important issue is resolved right?
Yeah, it works, so I don’t really have any big problem. I was just curious as to why dkms would give me an error each time if the install is successful. Anyway, thank you for the support.
I am occurring the same issue, and for me, this command fails:
sudo dkms install nvidia/535.43.02 1 err
Kernel preparation unnecessary for this kernel. Skipping…
Building module:
cleaning build area…
unset ARCH; [ ! -h /usr/bin/cc ] && export CC=/usr/bin/gcc; env NV_VERBOSE=1 ‘make’ -j8 NV_EXCLUDE_BUILD_MODULES=‘’ KERNEL_UNAME=5.15.0-52-generic IGNORE_XEN_PRESENCE=1 IGNORE_CC_MISMATCH=1 SYSSRC=/lib/modules/5.15.0-52-generic/build LD=/usr/bin/ld.bfd CONFIG_X86_KERNEL_IBT= modules…(bad exit status: 2)
ERROR (dkms apport): kernel package linux-headers-5.15.0-52-generic is not supported
Error! Bad return status for module build on kernel: 5.15.0-52-generic (x86_64)
Consult /var/lib/dkms/nvidia/535.43.02/build/make.log for more information.
sudo apt install nvidia-driver-535 1 err
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
The following additional packages will be installed:
nvidia-dkms-535 nvidia-kernel-source-535
Recommended packages:
libnvidia-compute-535:i386 libnvidia-decode-535:i386
libnvidia-encode-535:i386 libnvidia-fbc1-535:i386 libnvidia-gl-535:i386
The following packages will be REMOVED:
nvidia-dkms-535-open nvidia-driver-535-open nvidia-kernel-source-535-open
The following NEW packages will be installed:
nvidia-dkms-535 nvidia-driver-535 nvidia-kernel-source-535
0 upgraded, 3 newly installed, 3 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/45.4 MB of archives.
After this operation, 54.4 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database … 231851 files and directories currently installed.)
Removing nvidia-driver-535-open (535.43.02-0ubuntu0~gpu22.04.2) …
Removing nvidia-dkms-535-open (535.43.02-0ubuntu0~gpu22.04.2) …
Removing all DKMS Modules
Done.
INFO:Disable nvidia
Removing nvidia-kernel-source-535-open (535.43.02-0ubuntu0~gpu22.04.2) …
Selecting previously unselected package nvidia-kernel-source-535.
(Reading database … 231419 files and directories currently installed.)
Preparing to unpack …/nvidia-kernel-source-535_535.43.02-0ubuntu0~gpu22.04.2_a
md64.deb …
Unpacking nvidia-kernel-source-535 (535.43.02-0ubuntu0~gpu22.04.2) …
Selecting previously unselected package nvidia-dkms-535.
Preparing to unpack …/nvidia-dkms-535_535.43.02-0ubuntu0~gpu22.04.2_amd64.deb
Unpacking nvidia-dkms-535 (535.43.02-0ubuntu0~gpu22.04.2) …
Selecting previously unselected package nvidia-driver-535.
Preparing to unpack …/nvidia-driver-535_535.43.02-0ubuntu0~gpu22.04.2_amd64.de
b …
Unpacking nvidia-driver-535 (535.43.02-0ubuntu0~gpu22.04.2) …
Setting up nvidia-kernel-source-535 (535.43.02-0ubuntu0~gpu22.04.2) …
Setting up nvidia-dkms-535 (535.43.02-0ubuntu0~gpu22.04.2) …
update-initramfs: Generating /boot/initrd.img-5.13.0-52-generic
I: The initramfs will attempt to resume from /dev/dm-2
I: (/dev/mapper/vgubuntu-swap_1)
I: Set the RESUME variable to override this.
INFO:Enable nvidia
Building for 5.13.0-52-generic 5.15.0-52-generic
Building for architecture x86_64
Building initial module for 5.13.0-52-generic
ERROR (dkms apport): kernel package linux-headers-5.13.0-52-generic is not supported
Error! Bad return status for module build on kernel: 5.13.0-52-generic (x86_64)
dpkg: error processing package nvidia-dkms-535 (–configure):
installed nvidia-dkms-535 package post-installation script subprocess returned error exit status 10
dpkg: error processing package nvidia-driver-535 (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
Processing triggers for initramfs-tools (0.140ubuntu13) …
update-initramfs: Generating /boot/initrd.img-5.15.0-52-generic
nvidia-dkms-535
nvidia-driver-535
E: Sub-process /usr/bin/dpkg returned an error code (1)
make.log (1.6 KB)
