Problem:
After attempting to update my nvidia driver, I got stuck in a black screen on reboot. I was able to get back to my desktop but now my display port connections / dual monitors do not work. Only HDMI on single monitor is working.
Background:
This has happened within the span of a day. I was trying to get the latest Tekken to work and I figured I would update my nvidia driver from 525. I initially chose 550 but I missed that this was the beta version. Initially trying to install 550, I was having problems so I ran the below commands:
sudo apt install nvidia-driver-550 --fix-missing
and then
sudo apt install nvidia-driver-550 --fix-broken install
I don’t recall what fully happened from this output and then I ran this command:
apt --fix-broken install
From those 3 commands, I removed some Nvidia dependencies that I needed (I think) and I was living in the terminal for a while where I couldn’t even return to my desktop. Going through my logs I did see this error but I don’t know if it was the main error or not.
RmInitAdapter
rm_init_adapter failed
nvidia-drm Failed to allocate NvKMsKapiDevice
From other posts on here, eventually I purged all Nvidia driver, disconnected my gpu, and was able to get to my desktop from my mobo via HDMI. Using Software & Updates > Additional Drivers, I reinstalled multiple versions, because I have been trying to fix my issue and running out of ideas. I have these 3 versions installed: nvidia driver metapackage from nvidia-525,535, and now I am currently on 545.
Logs / Config Info:
OS: Ubuntu 22.04 with GNOME
Kernel: 6.5.0-15-generic (and tried on 6.5.0-14-generic)
Nvidia-smi
| NVIDIA-SMI 545.29.06 Driver Version: 545.29.06 CUDA Version: 12.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 2070 Off | 00000000:01:00.0 On | N/A |
| 0% 38C P8 3W / 175W | 496MiB / 8192MiB | 3% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1490 G /usr/lib/xorg/Xorg 143MiB |
| 0 N/A N/A 1755 G /usr/bin/gnome-shell 70MiB |
| 0 N/A N/A 3049 G …irefox/3728/usr/lib/firefox/firefox 187MiB |
| 0 N/A N/A 4054 G …39692028,3432445436170888676,131072 52MiB |
| 0 N/A N/A 5373 G …,WinRetrieveSuggestionsOnlyOnDemand 36MiB |
dpkg -l | grep nvidia
rc glx-alternative-nvidia 1.2.1~deb11u1 amd64 allows the selection of NVIDIA as GLX provider
ii libnvidia-cfg1-545:amd64 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-545 545.29.06-0ubuntu0.22.04.2 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-450-server:amd64 450.248.02-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-470-server:amd64 470.223.02-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-510:amd64 510.73.05-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
rc libnvidia-compute-535:amd64 535.154.05-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-545:amd64 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA libcompute package
ii libnvidia-compute-545:i386 545.29.06-0ubuntu0.22.04.2 i386 NVIDIA libcompute package
ii libnvidia-decode-545:amd64 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-545:i386 545.29.06-0ubuntu0.22.04.2 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.9-1.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-eglcore:i386 515.48.07-1 i386 NVIDIA binary EGL core libraries
ii libnvidia-encode-545:amd64 545.29.06-0ubuntu0.22.04.2 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-545:i386 545.29.06-0ubuntu0.22.04.2 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-545:amd64 545.29.06-0ubuntu0.22.04.2 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-545:amd64 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-545:i386 545.29.06-0ubuntu0.22.04.2 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-545:amd64 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-545:i386 545.29.06-0ubuntu0.22.04.2 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii linux-objects-nvidia-525-open-6.5.0-15-generic 6.5.0-15.15~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-15 (objects)
ii linux-objects-nvidia-525-open-6.5.0-15-lowlatency 6.5.0-15.15.1.1~22.04.1+1 amd64 Linux kernel nvidia modules for version 6.5.0-15 (objects)
rc nvidia-compute-utils-450-server 450.248.02-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-470-server 470.223.02-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-525 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-535 535.154.05-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-545 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA compute utilities
rc nvidia-dkms-450-server 450.248.02-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
rc nvidia-dkms-470-server 470.223.02-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
rc nvidia-dkms-525 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
rc nvidia-dkms-525-open 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package (open kernel module)
rc nvidia-dkms-535 535.154.05-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
rc nvidia-dkms-535-open 535.154.05-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package (open kernel module)
ii nvidia-dkms-545 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA DKMS package
ii nvidia-driver-545 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA driver metapackage
ii nvidia-firmware-545-545.29.06 545.29.06-0ubuntu0.22.04.2 amd64 Firmware files used by the kernel module
rc nvidia-kernel-common-450-server 450.248.02-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-470-server 470.223.02-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-525 525.147.05-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-535 535.154.05-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-545 545.29.06-0ubuntu0.22.04.2 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-545 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-545 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-545 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA binary Xorg driver
Nvidia settings does show my one monitor via HDMI but not my others via display port. I have no idea what to do at this point so that my display ports work and I to get dual monitor working again.
Thanks for any assistance.
Edit 1
I changed to kernel 5.15 since I didn’t realize 6.5 needed gcc-12. Then I repurged my nvidia drivers again, and reinstalled nvidia-driver-525 with gcc-11 and no luck still. I tried to go back to 6.5 with gcc-12 and attempted to go with 545 as well with no luck. I made things worse though because nvidia-smi no longer works with this error when running on 5.15 and I can no longer get to my desktop in 6.5. I have no idea what I should do at this point to either get 6.5 or 5.15 working.
Failed to initialize NVML: Driver/library version mismatch
Here is the updated grep search
ii libnvidia-cfg1-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-525 525.147.05-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-525:i386 525.147.05-0ubuntu0.22.04.1 i386 NVIDIA libcompute package
rc libnvidia-compute-545:amd64 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA libcompute package
ii libnvidia-decode-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-525:i386 525.147.05-0ubuntu0.22.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-525:i386 525.147.05-0ubuntu0.22.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-525:i386 525.147.05-0ubuntu0.22.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-525:i386 525.147.05-0ubuntu0.22.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-525 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-545 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA compute utilities
ii nvidia-dkms-525 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA DKMS package
rc nvidia-dkms-545 545.29.06-0ubuntu0.22.04.2 amd64 NVIDIA DKMS package
ii nvidia-driver-525 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA driver metapackage
rc nvidia-fabricmanager-535 535.154.05-0ubuntu0.22.04.1 amd64 Fabric Manager for NVSwitch based systems.
ii nvidia-kernel-common-525 525.147.05-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-545 545.29.06-0ubuntu0.22.04.2 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-525 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-utils-525 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA driver support binaries
ii xserver-xorg-video-nvidia-525 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
And I am having some issues uploading the nvidia-bug-report, I’ll try again later this afternoon.
