Dear vatbier
I am using SuSe TW Linux 5.2.11-1-default #1 SMP Thu Aug 29 06:41:19 UTC 2019 (6385110) i686 i686 i386 GNU/Linux means 32 bit and tried above mentioned patches.
Nouveau is blacklisted and not loaded during install.
The 340.107 Driver then compiled w/ --no-unified-memory and did not include DKMS in menu-install.
The machine starts in 5.2 but screen stays black, Xorg.0.log stating “no screen found”.
Am I missing any configuration ?
Same patched driver runs w/ 4.20.6-1-default #1 SMP Thu Jan 31 07:37:50 UTC 2019 (463cfd2) i686 i686 i386 GNU/Linux w/o problem.
See below the Xorg.0.log
Thanks, Freddy
PS 340.107 patch for linux kernel 5.2 - Linux - NVIDIA Developer Forums maybe same question
[ 13.597] (–) Log file renamed from “/var/log/Xorg.pid-1830.log” to “/var/log/Xorg.0.log”
[ 13.598]
X.Org X Server 1.20.5
X Protocol Version 11, Revision 0
[ 13.598] Build Operating System: openSUSE SUSE LINUX
[ 13.598] Current Operating System: Linux chimera3.homesite 5.2.11-1-default #1 SMP Thu Aug 29 06:41:19 UTC 2019 (6385110) i686
[ 13.598] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.2.11-1-default root=UUID=3a2095f0-d479-4bcd-933e-899906ff64f6 resume=/dev/sda1 splash=silent quiet nomodeset showopts
[ 13.598] Build Date: 30 August 2019 12:00:00PM
[ 13.598]
[ 13.598] Current version of pixman: 0.36.0
[ 13.598] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 13.598] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 13.598] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Oct 4 12:49:00 2019
[ 13.611] (==) Using config file: “/etc/X11/xorg.conf”
[ 13.611] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 13.611] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 13.617] (==) ServerLayout “Layout0”
[ 13.617] () |–>Screen “Screen0” (0)
[ 13.617] () | |–>Monitor “Monitor0”
[ 13.618] () | |–>Device “Device0”
[ 13.618] () |–>Input Device “Keyboard0”
[ 13.618] () |–>Input Device “Mouse0”
[ 13.618] (==) Automatically adding devices
[ 13.618] (==) Automatically enabling devices
[ 13.618] (==) Automatically adding GPU devices
[ 13.618] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 13.628] (WW) The directory “/usr/share/fonts/misc/sgi” does not exist.
[ 13.628] Entry deleted from font path.
[ 13.629] (==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/ghostscript/,
/usr/share/fonts/cyrillic:unscaled,
/usr/share/fonts/truetype/,
built-ins
[ 13.629] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 13.629] (WW) Ignoring unrecognized extension “XFree86-DGA”
[ 13.629] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 13.629] (WW) Disabling Keyboard0
[ 13.629] (WW) Disabling Mouse0
[ 13.629] (II) Loader magic: 0x6966a0
[ 13.629] (II) Module ABI versions:
[ 13.629] X.Org ANSI C Emulation: 0.4
[ 13.629] X.Org Video Driver: 24.0
[ 13.629] X.Org XInput driver : 24.1
[ 13.629] X.Org Server Extension : 10.0
[ 13.630] (++) using VT number 7
[ 13.630] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 13.634] (–) PCI:*(1@0:0:0) 10de:06e1:1acc:853d rev 161, Mem @ 0xfd000000/16777216, 0xd0000000/268435456, 0xfa000000/33554432, I/O @ 0x0000cc00/128, BIOS @ 0x???/131072
[ 13.634] (–) PCI: (2@0:0:0) 14f1:8880:0070:f038 rev 4, Mem @ 0xfe800000/2097152
[ 13.634] (II) LoadModule: “glx”
[ 13.642] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 13.731] (II) Module glx: vendor=“NVIDIA Corporation”
[ 13.731] compiled for 4.0.2, module version = 1.0.0
[ 13.731] Module class: X.Org Server Extension
[ 13.731] (II) NVIDIA GLX Module 340.107 Thu May 24 21:47:46 PDT 2018
[ 13.731] (II) LoadModule: “nvidia”
[ 13.735] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 13.750] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 13.750] compiled for 4.0.2, module version = 1.0.0
[ 13.750] Module class: X.Org Video Driver
[ 13.753] (II) NVIDIA dlloader X Driver 340.107 Thu May 24 21:24:47 PDT 2018
[ 13.753] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 13.801] (II) Loading sub module “fb”
[ 13.801] (II) LoadModule: “fb”
[ 13.801] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 13.803] (II) Module fb: vendor=“X.Org Foundation”
[ 13.803] compiled for 1.20.5, module version = 1.0.0
[ 13.803] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.803] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 13.803] (II) Loading sub module “wfb”
[ 13.803] (II) LoadModule: “wfb”
[ 13.803] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 13.804] (II) Module wfb: vendor=“X.Org Foundation”
[ 13.804] compiled for 1.20.5, module version = 1.0.0
[ 13.804] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.804] (II) Loading sub module “ramdac”
[ 13.805] (II) LoadModule: “ramdac”
[ 13.805] (II) Module “ramdac” already built-in
[ 13.811] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 13.811] (EE) NVIDIA: system’s kernel log for additional error messages and
[ 13.811] (EE) NVIDIA: consult the NVIDIA README for details.
[ 13.811] (EE) No devices detected.
[ 13.811] (EE)
Fatal server error:
[ 13.811] (EE) no screens found(EE)
[ 13.811] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 13.811] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 13.811] (EE)
[ 13.911] (EE) Server terminated with error (1). Closing log file.
