Nvidia-smi gives "No devies were found" - incorrect gcc version
I’m on Ubuntu 22.04, kernel: 6.5.0-25-generic
Anytime I attempt to use sudo apt upgrade I get the dpkg error below:
dpkg: error processing package nvidia-driver-535 (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
        Processing triggers for initramfs-tools (0.140ubuntu13) ...
update-initramfs: Generating /boot/initrd.img-6.5.0-25-generic
Errors were encountered while processing:
 nvidia-dkms-535
 nvidia-driver-535
E: Sub-process /usr/bin/dpkg returned an error code (1)
Unfortunately, running
sudo apt-get remove --purge nvidia-* -y
sudo apt autoremove
sudo apt install nvidia-utils-535
sudo apt install nvidia-utils-535-server
sudo reboot
and checking nvidia-smi the output is:
penguins@penguins-XPS-15-9520:~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Output from lspci | grep 3D:
01:00.0 3D controller: NVIDIA Corporation GA107M [GeForce RTX 3050 Ti Mobile] (rev a1)
Output from lspci | grep vga:
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-P Integrated Graphics Controller (rev 0c)
Output from cat /proc/driver/nvidia/version:
cat: /proc/driver/nvidia/version: No such file or directory
If anyone can provide any sort of direction for where to go from here I’d really appreciate it, would love to be able to update/upgrade packages :D
Please try reinstalling the kernel headers
sudo apt install --reinstall linux-headers-$(uname -r)
This should trigger a driver compile. In case it still fails, this should reference a make.log you can attach.
Thanks for the help! I’ve attached the file, and the output from sudo apt install --reinstall linux-headers-$(uname -r) is below
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 5 not upgraded.
Need to get 3,449 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://security.ubuntu.com/ubuntu jammy-security/main amd64 linux-headers-6.5.0-25-generic amd64 6.5.0-25.25~22.04.1 [3,449 kB]
Fetched 3,449 kB in 0s (7,135 kB/s)
(Reading database ... 214835 files and directories currently installed.)
Preparing to unpack .../linux-headers-6.5.0-25-generic_6.5.0-25.25~22.04.1_amd64.deb ...
Unpacking linux-headers-6.5.0-25-generic (6.5.0-25.25~22.04.1) over (6.5.0-25.25~22.04.1) ...
Setting up linux-headers-6.5.0-25-generic (6.5.0-25.25~22.04.1) ...
nvidia-installer.log (567 Bytes)
Did you uninstall the packaged driver meanwhile? Where does the installer log come from? It contains nearly nothing.
Not that I’m aware of, I just reran the following and checked the .log file again but I don’t think it even got updated.
penguins@penguins-XPS-15-9520:~$ sudo apt install nvidia-utils-535-server
nvidia-utils-535-server is already the newest version (535.161.07-0ubuntu0.22.04.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
penguins@penguins-XPS-15-9520:~$ sudo apt install --reinstall linux-headers-$(uname -r)
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Fetched 3,449 kB in 1s (3,143 kB/s)
Also, should probably note that I had to get the log file from /vars/log/ as /var/lib/dkms/ doesn’t exist for some reason.
Odd. Please post the output of
dkms status
It wasn’t installed (odd indeed) so just ran the install and tried the same commands above, log file didn’t update and the /var/log/dkms/ path still doesn’t exist.
dkms:
Command 'dkms' not found, but can be installed with:
sudo apt install dkms
Retry:
Fetched 3,449 kB in 2s (2,200 kB/s)
(Reading database ... 214886 files and directories currently installed.)
/etc/kernel/header_postinst.d/dkms:
 * dkms: running auto installation service for kernel 6.5.0-25-generic
   ...done.
dpkg -l |grep nvidia
and
dkms status
penguins@penguins-XPS-15-9520:~$ dpkg -l |grep nvidia
rc  libnvidia-compute-535:amd64                535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA libcompute package
ii  libnvidia-compute-535-server:amd64         535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA libcompute package
ii  nvidia-utils-535-server                    535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA Server Driver support binaries
penguins@penguins-XPS-15-9520:~$ dkms status
The driver isn’t installed at all. Backtracking your posts shows you uninstalled the driver and then just installed the utils. Please install the driver
sudo apt install nvidia-driver-535
Oh whoops lmao, my bad. Unfortunatelt that still gives an error, the end of the output and the .log file is below:
Consult /var/lib/dkms/nvidia/535.161.07/build/make.log for more information.
dpkg: error processing package nvidia-dkms-535 (--configure):
 installed nvidia-dkms-535 package post-installation script subprocess returned error exit status 10
Setting up libnvidia-encode-535:amd64 (535.161.07-0ubuntu0.22.04.1) ...
Setting up libnvidia-encode-535:i386 (535.161.07-0ubuntu0.22.04.1) ...
dpkg: dependency problems prevent configuration of nvidia-driver-535:
 nvidia-driver-535 depends on nvidia-dkms-535 (<= 535.161.07-1); however:
  Package nvidia-dkms-535 is not configured yet.
 nvidia-driver-535 depends on nvidia-dkms-535 (>= 535.161.07); however:
        Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu3) ...
Processing triggers for libc-bin (2.35-0ubuntu3.6) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
 nvidia-dkms-535
 nvidia-driver-535
make.log (37.1 KB)
Also, the output of the commands you gav eme before I ran the install one (not sure ifthey’re necessary but):
ii  libnvidia-cfg1-535:amd64                   535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-535                       535.161.07-0ubuntu0.22.04.1             all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-535:amd64                535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA libcompute package
ii  libnvidia-compute-535:i386                 535.161.07-0ubuntu0.22.04.1             i386         NVIDIA libcompute package
rc  libnvidia-compute-535-server:amd64         535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA libcompute package
ii  libnvidia-decode-535:amd64                 535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-535:i386                  535.161.07-0ubuntu0.22.04.1             i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-535:amd64                 535.161.07-0ubuntu0.22.04.1             amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-535:i386                  535.161.07-0ubuntu0.22.04.1             i386         NVENC Video Encoding runtime library
ii  libnvidia-extra-535:amd64                  535.161.07-0ubuntu0.22.04.1             amd64        Extra libraries for the NVIDIA driver
ii  libnvidia-fbc1-535:amd64                   535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-535:i386                    535.161.07-0ubuntu0.22.04.1             i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-535:amd64                     535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-535:i386                      535.161.07-0ubuntu0.22.04.1             i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  nvidia-compute-utils-535                   535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA compute utilities
iF  nvidia-dkms-535                            535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA DKMS package
iU  nvidia-driver-535                          535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA driver metapackage
ii  nvidia-firmware-535-535.161.07             535.161.07-0ubuntu0.22.04.1             amd64        Firmware files used by the kernel module
ii  nvidia-kernel-common-535                   535.161.07-0ubuntu0.22.04.1             amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-535                   535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.17.1                                all          Tools to enable NVIDIA's Prime
ii  nvidia-settings                            510.47.03-0ubuntu1                      amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-535                           535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA driver support binaries
ii  screen-resolution-extra                    0.18.2                                  all          Extension for the nvidia-settings control panel
ii  xserver-xorg-video-nvidia-535              535.161.07-0ubuntu0.22.04.1             amd64        NVIDIA binary Xorg driver
nvidia/535.161.07: added
Ok, known issue, the ubuntu kernel team changed the gcc version used. Please install the package gcc-12, then reinstall the headers again to trigger the driver compile.
No dice unfortunately, can’t even install gcc-12.
penguins@penguins-XPS-15-9520:~$ sudo apt install gcc-12
gcc-12 is already the newest version (12.3.0-1ubuntu1~22.04).
2 not fully installed or removed.
Do you want to continue? [Y/n] y
Setting up nvidia-dkms-535 (535.161.07-0ubuntu0.22.04.1) ...
update-initramfs: deferring update (trigger activated)
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
Removing old nvidia-535.161.07 DKMS files...
Deleting module nvidia-535.161.07 completely from the DKMS tree.
Loading new nvidia-535.161.07 DKMS files...
Building for 6.5.0-25-generic
Building for architecture x86_64
Building initial module for 6.5.0-25-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-dkms-535.0.crash'
Error! Bad return status for module build on kernel: 6.5.0-25-generic (x86_64)
 nvidia-dkms-535
 nvidia-driver-535
Log: make.log (37.1 KB)
Crash file )saved as log so i could upload): nvidia-dkms-535.0-crash.log (37.8 KB)
gcc -v
and
cc -v
penguins@penguins-XPS-15-9520:~$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/11/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 11.4.0-1ubuntu1~22.04' --with-bugurl=file:///usr/share/doc/gcc-11/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-11 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --enable-cet --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-11-XeT9lY/gcc-11-11.4.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-11-XeT9lY/gcc-11-11.4.0/debian/tmp-gcn/usr --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-serialization=2
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04)
penguins@penguins-XPS-15-9520:~$ cc -v
COLLECT_GCC=cc
Thread model: posix
Doesn’t gcc need to be version 12 or something to be compatible with the nvidia driver?
gcc 12 is installed but wasn’t switched to as it seems so the incompatible gcc-11 is still used. Please check if update alternatives are installed:
update-alternatives --query gcc
update-alternatives --query cc
Doesn’t look like it unfortunately. Also, thank you so much for your time <3 much appreciate
penguins@penguins-XPS-15-9520:~$ update-alternatives --query gcc
update-alternatives: error: no alternatives for gcc
penguins@penguins-XPS-15-9520:~$ update-alternatives --query cc
Link: /usr/bin/cc
Slaves:
 cc.1.gz /usr/share/man/man1/cc.1.gz
Status: auto
Best: /usr/bin/gcc
Value: /usr/bin/gcc
Alternative: /usr/bin/gcc
Priority: 20
Slaves:
 cc.1.gz /usr/share/man/man1/gcc.1.gz
Maybe just uninstall gcc-11 and then reinstall gcc 12.
Okay I think I did that properly
penguins@penguins-XPS-15-9520:~$ sudo apt remove gcc-11
Package 'gcc-11' is not installed, so not removed
The following packages were automatically installed and are no longer required:
  libasan6 libgcc-11-dev libstdc++-11-dev libtsan0
Use 'sudo apt autoremove' to remove them.
INFO:Enable nvidia
Secure Boot not enabled on this system.
Done.
nvidia.ko:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/6.5.0-25-generic/updates/dkms/
nvidia-modeset.ko:
 - Original module
 - Installation
nvidia-drm.ko:
 - Original module
 - Installation
nvidia-uvm.ko:
 - Original module
 - Installation
nvidia-peermem.ko:
 - Original module
 - Installation
depmod...
Setting up nvidia-driver-535 (535.161.07-0ubuntu0.22.04.1) ...
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/12/lto-wrapper
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 12.3.0-1ubuntu1~22.04' --with-bugurl=file:///usr/share/doc/gcc-12/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-12 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --enable-cet --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-12-ALHxjy/gcc-12-12.3.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-12-ALHxjy/gcc-12-12.3.0/debian/tmp-gcn/usr --enable-offload-defaulted --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 12.3.0 (Ubuntu 12.3.0-1ubuntu1~22.04)
Should I try sudo apt install nvidia-driver-535 again?
The driver should already be compiled and ready to go according to the output you provided.
dkms status
should show ‘installed’
