NVIDIA-SMI driver problem on Ubuntu 18.04
Hello, I have nvidia driver 430.26 on ubuntu 18.04.
I had no problem with that version. Ubuntu updayed automatically the driver to 435.50. I have below problem. I removed nvidia and tried to go back 430. No chance.
nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I have Windows and Ubuntu on my computer. Secure boot is disabled. Legacy/UEFI mode is used on my MSI Z390 Tomahawk motherboard.
nvidia-bug-report.log.gz (1.08 MB)
There doesn’t seem to be any nvidia driver installed and nouveau is used. Please reinstall the driver the driver using
sudo apt install --reinstall nvidia-driver-430
and create a new nvidia-bug-report.log.
Please also post the output of
dkms status
Reading package lists… Done
Building dependency tree
Reading state information… Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 4 not upgraded.
Need to get 0 B/403 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database … 261825 files and directories currently installed.)
Preparing to unpack …/nvidia-driver-430_430.26-0ubuntu0.18.04.2_amd64.deb …
Unpacking nvidia-driver-430 (430.26-0ubuntu0.18.04.2) over (430.26-0ubuntu0.18.04.2) …
Setting up nvidia-driver-430 (430.26-0ubuntu0.18.04.2) …
dkms status
nvidia, 430.26: added
Please run
sudo dkms install nvidia/430.26 --all
and reboot. Afterwards, create a new nvidia-bug-report.log.
hi, run and rebooted. log is attached
nvidia-bug-report.log.gz (1.07 MB)
Still no driver been built by dkms. I suspect the problem is not with the driver but the kernel did not properly register with dkms on update.
Please reinstall the kernel headers
sudo apt install --reinstall linux-headers-5.0.0-31-generic
and post the output of
dkms status
afterwards.
Hello again. thanks for your support. It is working now.
root@predictor:/home/root# dkms status
nvidia, 430.26, 5.0.0-31-generic, x86_64: installed
root@predictor:/home/root# nvidia-smi
Sat Oct 19 19:31:57 2019
| NVIDIA-SMI 430.26 Driver Version: 430.26 CUDA Version: 10.2 |
| 0 GeForce RTX 2070 Off | 00000000:01:00.0 Off | N/A |
| 19% 61C P0 56W / 175W | 1MiB / 7981MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
Im facing a similar problem with nvidia driver 440 , dual boot, disabled secure boot , mine is a msi gf 630 laptopnvidia-bug-report.log (1.1 MB)
I’m also having similar issues in an Optimus setup. RTX2070 on an MSI GS65 running Ubuntu 18.04.
Legacy boot (no UEFI)
nvidia-bug-report.log (1.2 MB)
/# dkms status
nvidia, 435.21, 5.3.0-45-generic, x86_64: installed
nvidia, 435.21, 5.3.0-46-generic, x86_64: installed
/# nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
/# prime-select query
nvidia
/# lshw -C display
  *-display UNCLAIMED
       description: VGA compatible controller
       product: TU106M [GeForce RTX 2070 Mobile]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller cap_list
       configuration: latency=0
       resources: memory:ac000000-acffffff memory:80000000-8fffffff memory:90000000-91ffffff ioport:4000(size=128) memory:ad000000-ad07ffff
  *-display
       product: UHD Graphics 630 (Mobile)
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 02
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:158 memory:ab000000-abffffff memory:40000000-4fffffff ioport:5000(size=64) memory:c0000-dffff
You’re running ab old kernel from 19.04 compiled with gcc 8.3.0 but the 19.10 system compiler is gcc 9.2.1 so the kernel module doesn’t compile. Please switch to the correct kernel version in the grub menu.
Also, please delete /etc/X11/xorg.conf as this is breaking PRIME setup.
Fantastic, generix! Thank you for your help.
grub was booting symbolic links that pointed to ancient kernel files. Fixed the links, reinstalled the driver and prime.
Everything works as intended now!
Thanks again.
Hi, generix, encountering similar issue here, could you be more concrete on how to “…switch to the correct kernel version in the grub menu”. I’m kind of a newbie using Ubuntu, many thanks!!!
What I have:
root@NUS:~# nvidia-smi
root@NUS:~# nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
root@NUS:~# dkms status
nvidia, 435.21: added
root@NUS:~# lspci -v | grep 3D
root@NUS:~# uname -r
5.4.0-42-generic
root@NUS:~# sudo lshw -C display
  *-display UNCLAIMED
       product: GM204GL [Quadro M4000]
       physical id: 0
       bus info: pci@0000:03:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list
       resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
What have done to install the driver:
root@NUS:~# ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:02.0/0000:03:00.0 ==
modalias : pci:v000010DEd000013F1sv000010DEsd00001153bc03sc00i00
vendor   : NVIDIA Corporation
model    : GM204GL [Quadro M4000]
driver   : nvidia-driver-390 - distro non-free
driver   : nvidia-driver-415 - third-party free
driver   : nvidia-driver-435 - distro non-free recommended
driver   : xserver-xorg-video-nouveau - distro free builtin
root@NUS:~# sudo apt-get autoremove
Reading package lists... Done
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@NUS:~# sudo apt-get remove nvidia*
Note, selecting 'nvidia-kernel-common-418-server' for glob 'nvidia*'
Note, selecting 'nvidia-325-updates' for glob 'nvidia*'
Note, selecting 'nvidia-346-updates' for glob 'nvidia*'
Note, selecting 'nvidia-driver-binary' for glob 'nvidia*'
Note, selecting 'nvidia-331-dev' for glob 'nvidia*'
Note, selecting 'nvidia-304-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-384-dev' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-346-updates' for glob 'nvidia*'
Note, selecting 'nvidia-340-updates-uvm' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common' for glob 'nvidia*'
Note, selecting 'nvidia-331-updates-uvm' for glob 'nvidia*'
Note, selecting 'nvidia-cg-toolkit' for glob 'nvidia*'
Note, selecting 'nvidia-driver-libs-i386:i386' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-440-server' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-390' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-410' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-415' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-418' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-430' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-435' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-440' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-450' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-340-updates' for glob 'nvidia*'
Note, selecting 'nvidia-384-updates' for glob 'nvidia*'
Note, selecting 'nvidia' for glob 'nvidia*'
Note, selecting 'nvidia-driver' for glob 'nvidia*'
Note, selecting 'nvidia-367-updates' for glob 'nvidia*'
Note, selecting 'nvidia-modprobe' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-common-440-server' for glob 'nvidia*'
Note, selecting 'nvidia-texture-tools' for glob 'nvidia*'
Note, selecting 'nvidia-utils' for glob 'nvidia*'
Note, selecting 'nvidia-387-updates' for glob 'nvidia*'
Note, selecting 'nvidia-current-diagnostic' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-340xx-vdpau-driver' for glob 'nvidia*'
Note, selecting 'nvidia-349-updates' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-304-updates' for glob 'nvidia*'
Note, selecting 'nvidia-310-updates' for glob 'nvidia*'
Note, selecting 'nvidia-331-updates' for glob 'nvidia*'
Note, selecting 'nvidia-352-dev' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-304xx-vdpau-driver' for glob 'nvidia*'
Note, selecting 'nvidia-vdpau-driver' for glob 'nvidia*'
Note, selecting 'nvidia-346-dev' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-331-updates' for glob 'nvidia*'
Note, selecting 'nvidia-utils-390' for glob 'nvidia*'
Note, selecting 'nvidia-smi' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-361-updates' for glob 'nvidia*'
Note, selecting 'nvidia-313-updates' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-340xx-kernel-dkms' for glob 'nvidia*'
Note, selecting 'nvidia-334-updates' for glob 'nvidia*'
Note, selecting 'nvidia-utils-410' for glob 'nvidia*'
Note, selecting 'nvidia-utils-415' for glob 'nvidia*'
Note, selecting 'nvidia-utils-418' for glob 'nvidia*'
Note, selecting 'nvidia-utils-430' for glob 'nvidia*'
Note, selecting 'nvidia-utils-435' for glob 'nvidia*'
Note, selecting 'nvidia-utils-440' for glob 'nvidia*'
Note, selecting 'nvidia-utils-450' for glob 'nvidia*'
Note, selecting 'nvidia-331-uvm' for glob 'nvidia*'
Note, selecting 'nvidia-prime' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-390' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-dkms' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-410' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-415' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-418' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-430' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-435' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-440' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-450' for glob 'nvidia*'
Note, selecting 'nvidia-current-updates' for glob 'nvidia*'
Note, selecting 'nvidia-340-dev' for glob 'nvidia*'
Note, selecting 'nvidia-nsight' for glob 'nvidia*'
Note, selecting 'nvidia-common' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-346-updates' for glob 'nvidia*'
Note, selecting 'nvidia-352-updates' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-390' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-410' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-415' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-418' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-430' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-435' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-440' for glob 'nvidia*'
Note, selecting 'nvidia-headless-no-dkms-450' for glob 'nvidia*'
Note, selecting 'nvidia-current-dev' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-352-updates' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-390' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-410' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-415' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-418' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-430' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-435' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-440' for glob 'nvidia*'
Note, selecting 'nvidia-compute-utils-450' for glob 'nvidia*'
Note, selecting 'nvidia-355-updates' for glob 'nvidia*'
Note, selecting 'nvidia-driver-libs-nonglvnd' for glob 'nvidia*'
Note, selecting 'nvidia-375-dev' for glob 'nvidia*'
Note, selecting 'nvidia-current' for glob 'nvidia*'
Note, selecting 'nvidia-profiler' for glob 'nvidia*'
Note, selecting 'nvidia-375-updates' for glob 'nvidia*'
Note, selecting 'nvidia-driver-390' for glob 'nvidia*'
Note, selecting 'nvidia-337-updates' for glob 'nvidia*'
Note, selecting 'nvidia-358-updates' for glob 'nvidia*'
Note, selecting 'nvidia-367-dev' for glob 'nvidia*'
Note, selecting 'nvidia-driver-410' for glob 'nvidia*'
Note, selecting 'nvidia-driver-415' for glob 'nvidia*'
Note, selecting 'nvidia-driver-418' for glob 'nvidia*'
Note, selecting 'nvidia-driver-430' for glob 'nvidia*'
Note, selecting 'nvidia-driver-435' for glob 'nvidia*'
Note, selecting 'nvidia-driver-440' for glob 'nvidia*'
Note, selecting 'nvidia-driver-450' for glob 'nvidia*'
Note, selecting 'nvidia-cuda-toolkit' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-304xx-driver' for glob 'nvidia*'
Note, selecting 'nvidia-driver-libs' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source' for glob 'nvidia*'
Note, selecting 'nvidia-378-updates' for glob 'nvidia*'
Note, selecting 'nvidia-340-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-319-updates' for glob 'nvidia*'
Note, selecting 'nvidia-304-dev' for glob 'nvidia*'
Note, selecting 'nvidia-331-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-visual-profiler' for glob 'nvidia*'
Note, selecting 'nvidia-persistenced' for glob 'nvidia*'
Note, selecting 'nvidia-361-dev' for glob 'nvidia*'
Note, selecting 'nvidia-settings-binary' for glob 'nvidia*'
Note, selecting 'nvidia-361-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-304' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-331' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-340' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-346' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-352' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-361' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-367' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-375' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-384' for glob 'nvidia*'
Note, selecting 'nvidia-352-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-331-updates' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-352-updates' for glob 'nvidia*'
Note, selecting 'nvidia-304-updates' for glob 'nvidia*'
Note, selecting 'nvidia-340-uvm' for glob 'nvidia*'
Note, selecting 'nvidia-headless-390' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-340xx-driver' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-304-updates' for glob 'nvidia*'
Note, selecting 'nvidia-headless-410' for glob 'nvidia*'
Note, selecting 'nvidia-headless-415' for glob 'nvidia*'
Note, selecting 'nvidia-headless-418' for glob 'nvidia*'
Note, selecting 'nvidia-headless-430' for glob 'nvidia*'
Note, selecting 'nvidia-headless-435' for glob 'nvidia*'
Note, selecting 'nvidia-headless-440' for glob 'nvidia*'
Note, selecting 'nvidia-headless-450' for glob 'nvidia*'
Note, selecting 'nvidia-cuda-dev' for glob 'nvidia*'
Note, selecting 'nvidia-cuda-doc' for glob 'nvidia*'
Note, selecting 'nvidia-340-updates' for glob 'nvidia*'
Note, selecting 'nvidia-361-updates' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-dev' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-dev' for glob 'nvidia*'
Note, selecting 'nvidia-legacy-304xx-kernel-dkms' for glob 'nvidia*'
Note, selecting 'nvidia-cg-dev' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-418-server' for glob 'nvidia*'
Note, selecting 'nvidia-cg-doc' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-340-updates' for glob 'nvidia*'
Note, selecting 'nvidia-libopencl1-361-updates' for glob 'nvidia*'
Note, selecting 'nvidia-381-updates' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-304' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-331' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-340' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-346' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-352' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-361' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-367' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-375' for glob 'nvidia*'
Note, selecting 'nvidia-cuda-gdb' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-304' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd-384' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-310' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-313' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-319' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-325' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-331' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-334' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-337' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-340' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-343' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-346' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-349' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-352' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-355' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-358' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-361' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-364' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-367' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-375' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-378' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-381' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-384' for glob 'nvidia*'
Note, selecting 'nvidia-experimental-387' for glob 'nvidia*'
Note, selecting 'nvidia-343-updates' for glob 'nvidia*'
Note, selecting 'nvidia-364-updates' for glob 'nvidia*'
Note, selecting 'nvidia-304' for glob 'nvidia*'
Note, selecting 'nvidia-310' for glob 'nvidia*'
Note, selecting 'nvidia-313' for glob 'nvidia*'
Note, selecting 'nvidia-319' for glob 'nvidia*'
Note, selecting 'nvidia-325' for glob 'nvidia*'
Note, selecting 'nvidia-331' for glob 'nvidia*'
Note, selecting 'nvidia-334' for glob 'nvidia*'
Note, selecting 'nvidia-337' for glob 'nvidia*'
Note, selecting 'nvidia-340' for glob 'nvidia*'
Note, selecting 'nvidia-343' for glob 'nvidia*'
Note, selecting 'nvidia-346' for glob 'nvidia*'
Note, selecting 'nvidia-349' for glob 'nvidia*'
Note, selecting 'nvidia-352' for glob 'nvidia*'
Note, selecting 'nvidia-355' for glob 'nvidia*'
Note, selecting 'nvidia-358' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-390' for glob 'nvidia*'
Note, selecting 'nvidia-361' for glob 'nvidia*'
Note, selecting 'nvidia-364' for glob 'nvidia*'
Note, selecting 'nvidia-367' for glob 'nvidia*'
Note, selecting 'nvidia-375' for glob 'nvidia*'
Note, selecting 'nvidia-378' for glob 'nvidia*'
Note, selecting 'nvidia-381' for glob 'nvidia*'
Note, selecting 'nvidia-384' for glob 'nvidia*'
Note, selecting 'nvidia-387' for glob 'nvidia*'
Note, selecting 'nvidia-dkms-kernel' for glob 'nvidia*'
Note, selecting 'nvidia-390' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-410' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-415' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-418' for glob 'nvidia*'
Note, selecting 'nvidia-346-updates-dev' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-430' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-435' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-440' for glob 'nvidia*'
Note, selecting 'nvidia-kernel-source-450' for glob 'nvidia*'
Note, selecting 'nvidia-settings' for glob 'nvidia*'
Note, selecting 'nvidia-opencl-icd' for glob 'nvidia*'
Note, selecting 'nvidia-settings' instead of 'nvidia-settings-binary'
Package 'nvidia-libopencl1-dev' is not installed, so not removed
Package 'nvidia-libopencl1' is not installed, so not removed
Package 'nvidia-vdpau-driver' is not installed, so not removed
Package 'nvidia-legacy-340xx-vdpau-driver' is not installed, so not removed
Package 'nvidia-390' is not installed, so not removed
Package 'nvidia-driver' is not installed, so not removed
Package 'nvidia-legacy-340xx-driver' is not installed, so not removed
Package 'nvidia-legacy-304xx-driver' is not installed, so not removed
Package 'nvidia-kernel-dkms' is not installed, so not removed
Package 'nvidia-legacy-340xx-kernel-dkms' is not installed, so not removed
Package 'nvidia-legacy-304xx-kernel-dkms' is not installed, so not removed
Package 'nvidia' is not installed, so not removed
Package 'nvidia-current-updates' is not installed, so not removed
Package 'nvidia-experimental-304' is not installed, so not removed
Package 'nvidia-310' is not installed, so not removed
Package 'nvidia-310-updates' is not installed, so not removed
Package 'nvidia-experimental-310' is not installed, so not removed
Package 'nvidia-313' is not installed, so not removed
Package 'nvidia-313-updates' is not installed, so not removed
Package 'nvidia-experimental-313' is not installed, so not removed
Package 'nvidia-319' is not installed, so not removed
Package 'nvidia-319-updates' is not installed, so not removed
Package 'nvidia-experimental-319' is not installed, so not removed
Package 'nvidia-325' is not installed, so not removed
Package 'nvidia-325-updates' is not installed, so not removed
Package 'nvidia-experimental-325' is not installed, so not removed
Package 'nvidia-experimental-331' is not installed, so not removed
Package 'nvidia-334' is not installed, so not removed
Package 'nvidia-334-updates' is not installed, so not removed
Package 'nvidia-experimental-334' is not installed, so not removed
Package 'nvidia-337' is not installed, so not removed
Package 'nvidia-337-updates' is not installed, so not removed
Package 'nvidia-experimental-337' is not installed, so not removed
Package 'nvidia-experimental-340' is not installed, so not removed
Package 'nvidia-343' is not installed, so not removed
Package 'nvidia-343-updates' is not installed, so not removed
Package 'nvidia-experimental-343' is not installed, so not removed
Package 'nvidia-experimental-346' is not installed, so not removed
Package 'nvidia-349' is not installed, so not removed
Package 'nvidia-349-updates' is not installed, so not removed
Package 'nvidia-experimental-349' is not installed, so not removed
Package 'nvidia-experimental-352' is not installed, so not removed
Package 'nvidia-355' is not installed, so not removed
Package 'nvidia-355-updates' is not installed, so not removed
Package 'nvidia-experimental-355' is not installed, so not removed
Package 'nvidia-358' is not installed, so not removed
Package 'nvidia-358-updates' is not installed, so not removed
Package 'nvidia-experimental-358' is not installed, so not removed
Package 'nvidia-experimental-361' is not installed, so not removed
Package 'nvidia-364' is not installed, so not removed
Package 'nvidia-364-updates' is not installed, so not removed
Package 'nvidia-experimental-364' is not installed, so not removed
Package 'nvidia-367-updates' is not installed, so not removed
Package 'nvidia-experimental-367' is not installed, so not removed
Package 'nvidia-375-updates' is not installed, so not removed
Package 'nvidia-experimental-375' is not installed, so not removed
Package 'nvidia-378' is not installed, so not removed
Package 'nvidia-378-updates' is not installed, so not removed
Package 'nvidia-experimental-378' is not installed, so not removed
Package 'nvidia-381' is not installed, so not removed
Package 'nvidia-381-updates' is not installed, so not removed
Package 'nvidia-experimental-381' is not installed, so not removed
Package 'nvidia-384-updates' is not installed, so not removed
Package 'nvidia-experimental-384' is not installed, so not removed
Package 'nvidia-387' is not installed, so not removed
Package 'nvidia-387-updates' is not installed, so not removed
Package 'nvidia-experimental-387' is not installed, so not removed
Note, selecting 'libnvtt-bin' instead of 'nvidia-texture-tools'
Package 'nvidia-driver-libs' is not installed, so not removed
Package 'nvidia-driver-libs-nonglvnd' is not installed, so not removed
Package 'nvidia-driver-libs-i386:i386' is not installed, so not removed
Package 'nvidia-kernel-common-418-server' is not installed, so not removed
Package 'nvidia-kernel-common-440-server' is not installed, so not removed
Package 'nvidia-legacy-304xx-vdpau-driver' is not installed, so not removed
Package 'nvidia-340-updates-uvm' is not installed, so not removed
Package 'nvidia-346' is not installed, so not removed
Package 'nvidia-346-dev' is not installed, so not removed
Package 'nvidia-346-updates' is not installed, so not removed
Package 'nvidia-346-updates-dev' is not installed, so not removed
Package 'nvidia-352' is not installed, so not removed
Package 'nvidia-352-dev' is not installed, so not removed
Package 'nvidia-352-updates' is not installed, so not removed
Package 'nvidia-352-updates-dev' is not installed, so not removed
Package 'nvidia-361' is not installed, so not removed
Package 'nvidia-361-dev' is not installed, so not removed
Package 'nvidia-361-updates' is not installed, so not removed
Package 'nvidia-361-updates-dev' is not installed, so not removed
Package 'nvidia-367' is not installed, so not removed
Package 'nvidia-367-dev' is not installed, so not removed
Package 'nvidia-375' is not installed, so not removed
Package 'nvidia-375-dev' is not installed, so not removed
Package 'nvidia-cg-dev' is not installed, so not removed
Package 'nvidia-cg-doc' is not installed, so not removed
Package 'nvidia-cg-toolkit' is not installed, so not removed
Package 'nvidia-cuda-dev' is not installed, so not removed
Package 'nvidia-cuda-doc' is not installed, so not removed
Package 'nvidia-cuda-gdb' is not installed, so not removed
Package 'nvidia-cuda-toolkit' is not installed, so not removed
Package 'nvidia-libopencl1-346' is not installed, so not removed
Package 'nvidia-libopencl1-346-updates' is not installed, so not removed
Package 'nvidia-libopencl1-352' is not installed, so not removed
Package 'nvidia-libopencl1-352-updates' is not installed, so not removed
Package 'nvidia-libopencl1-361' is not installed, so not removed
Package 'nvidia-libopencl1-361-updates' is not installed, so not removed
Package 'nvidia-libopencl1-367' is not installed, so not removed
Package 'nvidia-libopencl1-375' is not installed, so not removed
Package 'nvidia-nsight' is not installed, so not removed
Package 'nvidia-opencl-dev' is not installed, so not removed
Package 'nvidia-opencl-icd-346' is not installed, so not removed
Package 'nvidia-opencl-icd-346-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-352' is not installed, so not removed
Package 'nvidia-opencl-icd-352-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-361' is not installed, so not removed
Package 'nvidia-opencl-icd-361-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-367' is not installed, so not removed
Package 'nvidia-opencl-icd-375' is not installed, so not removed
Package 'nvidia-profiler' is not installed, so not removed
Package 'nvidia-visual-profiler' is not installed, so not removed
Package 'nvidia-331' is not installed, so not removed
Package 'nvidia-331-dev' is not installed, so not removed
Package 'nvidia-331-updates' is not installed, so not removed
Package 'nvidia-331-updates-dev' is not installed, so not removed
Package 'nvidia-331-updates-uvm' is not installed, so not removed
Package 'nvidia-331-uvm' is not installed, so not removed
Package 'nvidia-340' is not installed, so not removed
Package 'nvidia-340-dev' is not installed, so not removed
Package 'nvidia-340-updates' is not installed, so not removed
Package 'nvidia-340-updates-dev' is not installed, so not removed
Package 'nvidia-340-uvm' is not installed, so not removed
Package 'nvidia-compute-utils-390' is not installed, so not removed
Package 'nvidia-compute-utils-430' is not installed, so not removed
Package 'nvidia-compute-utils-440' is not installed, so not removed
Package 'nvidia-dkms-390' is not installed, so not removed
Package 'nvidia-dkms-430' is not installed, so not removed
Package 'nvidia-dkms-440' is not installed, so not removed
Package 'nvidia-driver-390' is not installed, so not removed
Package 'nvidia-driver-430' is not installed, so not removed
Package 'nvidia-driver-440' is not installed, so not removed
Package 'nvidia-headless-390' is not installed, so not removed
Package 'nvidia-headless-430' is not installed, so not removed
Package 'nvidia-headless-435' is not installed, so not removed
Package 'nvidia-headless-440' is not installed, so not removed
Package 'nvidia-headless-no-dkms-390' is not installed, so not removed
Package 'nvidia-headless-no-dkms-430' is not installed, so not removed
Package 'nvidia-headless-no-dkms-435' is not installed, so not removed
Package 'nvidia-headless-no-dkms-440' is not installed, so not removed
Package 'nvidia-kernel-common-390' is not installed, so not removed
Package 'nvidia-kernel-common-430' is not installed, so not removed
Package 'nvidia-kernel-common-440' is not installed, so not removed
Package 'nvidia-kernel-source-390' is not installed, so not removed
Package 'nvidia-kernel-source-430' is not installed, so not removed
Package 'nvidia-kernel-source-440' is not installed, so not removed
Package 'nvidia-opencl-icd-340' is not installed, so not removed
Package 'nvidia-utils-390' is not installed, so not removed
Package 'nvidia-utils-430' is not installed, so not removed
Package 'nvidia-utils-440' is not installed, so not removed
Package 'nvidia-common' is not installed, so not removed
Package 'nvidia-libopencl1-331' is not installed, so not removed
Package 'nvidia-libopencl1-331-updates' is not installed, so not removed
Package 'nvidia-libopencl1-340' is not installed, so not removed
Package 'nvidia-libopencl1-340-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-331' is not installed, so not removed
Package 'nvidia-opencl-icd-331-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-340-updates' is not installed, so not removed
Package 'nvidia-compute-utils-410' is not installed, so not removed
Package 'nvidia-dkms-410' is not installed, so not removed
Package 'nvidia-driver-410' is not installed, so not removed
Package 'nvidia-headless-410' is not installed, so not removed
Package 'nvidia-headless-no-dkms-410' is not installed, so not removed
Package 'nvidia-kernel-common-410' is not installed, so not removed
Package 'nvidia-kernel-source-410' is not installed, so not removed
Package 'nvidia-utils-410' is not installed, so not removed
Package 'nvidia-384' is not installed, so not removed
Package 'nvidia-384-dev' is not installed, so not removed
Package 'nvidia-libopencl1-384' is not installed, so not removed
Package 'nvidia-opencl-icd-384' is not installed, so not removed
Package 'nvidia-modprobe' is not installed, so not removed
Package 'nvidia-304' is not installed, so not removed
Package 'nvidia-304-dev' is not installed, so not removed
Package 'nvidia-304-updates' is not installed, so not removed
Package 'nvidia-304-updates-dev' is not installed, so not removed
Package 'nvidia-compute-utils-415' is not installed, so not removed
Package 'nvidia-compute-utils-418' is not installed, so not removed
Package 'nvidia-compute-utils-450' is not installed, so not removed
Package 'nvidia-current' is not installed, so not removed
Package 'nvidia-current-dev' is not installed, so not removed
Package 'nvidia-dkms-415' is not installed, so not removed
Package 'nvidia-dkms-418' is not installed, so not removed
Package 'nvidia-dkms-450' is not installed, so not removed
Package 'nvidia-driver-415' is not installed, so not removed
Package 'nvidia-driver-418' is not installed, so not removed
Package 'nvidia-driver-450' is not installed, so not removed
Package 'nvidia-headless-415' is not installed, so not removed
Package 'nvidia-headless-418' is not installed, so not removed
Package 'nvidia-headless-450' is not installed, so not removed
Package 'nvidia-headless-no-dkms-415' is not installed, so not removed
Package 'nvidia-headless-no-dkms-418' is not installed, so not removed
Package 'nvidia-headless-no-dkms-450' is not installed, so not removed
Package 'nvidia-kernel-common-415' is not installed, so not removed
Package 'nvidia-kernel-common-418' is not installed, so not removed
Package 'nvidia-kernel-common-450' is not installed, so not removed
Package 'nvidia-kernel-source-415' is not installed, so not removed
Package 'nvidia-kernel-source-418' is not installed, so not removed
Package 'nvidia-kernel-source-450' is not installed, so not removed
Package 'nvidia-libopencl1-304' is not installed, so not removed
Package 'nvidia-libopencl1-304-updates' is not installed, so not removed
Package 'nvidia-opencl-icd-304' is not installed, so not removed
Package 'nvidia-opencl-icd-304-updates' is not installed, so not removed
Package 'nvidia-utils-415' is not installed, so not removed
Package 'nvidia-utils-418' is not installed, so not removed
Package 'nvidia-utils-450' is not installed, so not removed
The following packages were automatically installed and are no longer required:
  dkms libatomic1:i386 libbsd0:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386
  libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386
  libelf1:i386 libexpat1:i386 libffi6:i386 libgl1:i386 libgl1-mesa-dri:i386
  libglapi-mesa:i386 libglvnd0:i386 libglx-mesa0:i386 libglx0:i386
  libllvm10:i386 libnvidia-cfg1-435 libnvidia-common-435
  libnvidia-compute-435:i386 libnvidia-decode-435 libnvidia-decode-435:i386
  libnvidia-encode-435 libnvidia-encode-435:i386 libnvidia-fbc1-435
  libnvidia-fbc1-435:i386 libnvidia-gl-435 libnvidia-gl-435:i386
  libnvidia-ifr1-435 libnvidia-ifr1-435:i386 libpciaccess0:i386
  libsensors4:i386 libstdc++6:i386 libx11-6:i386 libx11-xcb1:i386 libxau6:i386
  libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386
  libxcb-sync1:i386 libxcb1:i386 libxdamage1:i386 libxdmcp6:i386 libxext6:i386
  libxfixes3:i386 libxnvctrl0 libxshmfence1:i386 libxxf86vm1:i386
  screen-resolution-extra xserver-xorg-video-nvidia-435
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
  nvidia-compute-utils-435 nvidia-dkms-435 nvidia-driver-435
  nvidia-kernel-common-435 nvidia-kernel-source-435 nvidia-prime
  nvidia-settings nvidia-utils-435
0 upgraded, 0 newly installed, 8 to remove and 0 not upgraded.
After this operation, 39.5 MB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 338229 files and directories currently installed.)
Removing nvidia-driver-435 (435.21-0ubuntu0.18.04.2) ...
Removing nvidia-compute-utils-435 (435.21-0ubuntu0.18.04.2) ...
Removing nvidia-dkms-435 (435.21-0ubuntu0.18.04.2) ...
Removing all DKMS Modules
Done.
INFO:Disable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
update-initramfs: deferring update (trigger activated)
Removing nvidia-kernel-common-435 (435.21-0ubuntu0.18.04.2) ...
Removing nvidia-kernel-source-435 (435.21-0ubuntu0.18.04.2) ...
Removing nvidia-prime (0.8.8.2) ...
Removing nvidia-settings (450.51.05-0ubuntu1) ...
Removing nvidia-utils-435 (435.21-0ubuntu0.18.04.2) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for initramfs-tools (0.130ubuntu3.9) ...
update-initramfs: Generating /boot/initrd.img-5.4.0-42-generic
I: The initramfs will attempt to resume from /dev/sda6
I: (UUID=ac47a98c-8560-4626-8c8e-ebae77b4278d)
I: Set the RESUME variable to override this.
Processing triggers for libc-bin (2.27-3ubuntu1.2) ...
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn.so.7 is not a symbolic link
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
root@NUS:~# sudo apt-get purge cuda*
Note, selecting 'cuda-cusparse-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvprof-11-0' for glob 'cuda*'
Note, selecting 'cuda-npp-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvprune-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvprune-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvprune-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvprune-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-10-2' for glob 'cuda*'
Note, selecting 'cuda-cublas-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-drivers-418' for glob 'cuda*'
Note, selecting 'cuda-drivers-440' for glob 'cuda*'
Note, selecting 'cuda-drivers-450' for glob 'cuda*'
Note, selecting 'cuda-gdb-10-0' for glob 'cuda*'
Note, selecting 'cuda-gdb-10-1' for glob 'cuda*'
Note, selecting 'cuda-gdb-10-2' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute--10-0' for glob 'cuda*'
Note, selecting 'cuda-gdb-11-0' for glob 'cuda*'
Note, selecting 'cuda-visual-tools-10-0' for glob 'cuda*'
Note, selecting 'cuda-visual-tools-10-1' for glob 'cuda*'
Note, selecting 'cuda-visual-tools-10-2' for glob 'cuda*'
Note, selecting 'cuda-curand-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-curand-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-curand-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-cupti-10-0' for glob 'cuda*'
Note, selecting 'cuda-cupti-10-1' for glob 'cuda*'
Note, selecting 'cuda-cupti-10-2' for glob 'cuda*'
Note, selecting 'cuda-curand-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-visual-tools-11-0' for glob 'cuda*'
Note, selecting 'cuda-libraries-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-libraries-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-libraries-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-cublas-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-cupti-11-0' for glob 'cuda*'
Note, selecting 'cuda-drivers-branch' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1204' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-libraries-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-minimal-build-10-0' for glob 'cuda*'
Note, selecting 'cuda-minimal-build-10-1' for glob 'cuda*'
Note, selecting 'cuda-minimal-build-10-2' for glob 'cuda*'
Note, selecting 'cuda-drivers' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1404' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1410' for glob 'cuda*'
Note, selecting 'cuda-minimal-build-11-0' for glob 'cuda*'
Note, selecting 'cuda-cufft-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1504' for glob 'cuda*'
Note, selecting 'cuda-license-7-5' for glob 'cuda*'
Note, selecting 'cuda-cupti-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-libraries-10-0' for glob 'cuda*'
Note, selecting 'cuda-libraries-10-1' for glob 'cuda*'
Note, selecting 'cuda-libraries-10-2' for glob 'cuda*'
Note, selecting 'cuda-runtime-10-0' for glob 'cuda*'
Note, selecting 'cuda-runtime-10-1' for glob 'cuda*'
Note, selecting 'cuda-runtime-10-2' for glob 'cuda*'
Note, selecting 'cuda-cusolver-10-0' for glob 'cuda*'
Note, selecting 'cuda-cusolver-10-1' for glob 'cuda*'
Note, selecting 'cuda-cusolver-10-2' for glob 'cuda*'
Note, selecting 'cuda-cupti-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-libraries-11-0' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1804' for glob 'cuda*'
Note, selecting 'cuda-runtime-11-0' for glob 'cuda*'
Note, selecting 'cuda-drivers-diagnostic' for glob 'cuda*'
Note, selecting 'cuda-cusparse-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-cusparse-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-cusparse-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-sanitizer-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvjpeg-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-cufft-10-0' for glob 'cuda*'
Note, selecting 'cuda-cufft-10-1' for glob 'cuda*'
Note, selecting 'cuda-cufft-10-2' for glob 'cuda*'
Note, selecting 'cuda-nsight-systems-10-1' for glob 'cuda*'
Note, selecting 'cuda-nsight-systems-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvrtc-11-0' for glob 'cuda*'
Note, selecting 'cuda-cusparse-10-0' for glob 'cuda*'
Note, selecting 'cuda-cusparse-10-1' for glob 'cuda*'
Note, selecting 'cuda-cusparse-10-2' for glob 'cuda*'
Note, selecting 'cuda-nsight-systems-11-0' for glob 'cuda*'
Note, selecting 'cuda-npp-10-0' for glob 'cuda*'
Note, selecting 'cuda-npp-10-1' for glob 'cuda*'
Note, selecting 'cuda-npp-10-2' for glob 'cuda*'
Note, selecting 'cuda-tools-10-0' for glob 'cuda*'
Note, selecting 'cuda-tools-10-1' for glob 'cuda*'
Note, selecting 'cuda-tools-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvtx-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvtx-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvtx-10-2' for glob 'cuda*'
Note, selecting 'cuda-tools-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvtx-11-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-10-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-10-1' for glob 'cuda*'
Note, selecting 'cuda-cudart-10-2' for glob 'cuda*'
Note, selecting 'cuda-license-10-0' for glob 'cuda*'
Note, selecting 'cuda-license-10-1' for glob 'cuda*'
Note, selecting 'cuda-license-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvdisasm-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvdisasm-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvdisasm-10-2' for glob 'cuda*'
Note, selecting 'cuda-samples-10-0' for glob 'cuda*'
Note, selecting 'cuda-samples-10-1' for glob 'cuda*'
Note, selecting 'cuda-samples-10-2' for glob 'cuda*'
Note, selecting 'cuda-documentation-10-0' for glob 'cuda*'
Note, selecting 'cuda-documentation-10-1' for glob 'cuda*'
Note, selecting 'cuda-documentation-10-2' for glob 'cuda*'
Note, selecting 'cuda-cusolver-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvdisasm-11-0' for glob 'cuda*'
Note, selecting 'cuda-samples-11-0' for glob 'cuda*'
Note, selecting 'cuda-cross-qnx' for glob 'cuda*'
Note, selecting 'cuda-documentation-11-0' for glob 'cuda*'
Note, selecting 'cuda-compat-10-0' for glob 'cuda*'
Note, selecting 'cuda-compat-10-1' for glob 'cuda*'
Note, selecting 'cuda-compat-10-2' for glob 'cuda*'
Note, selecting 'cuda-compat-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvcc-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvcc-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvcc-10-2' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1404-7-5-local' for glob 'cuda*'
Note, selecting 'cuda-nvvp-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvvp-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvvp-10-2' for glob 'cuda*'
Note, selecting 'cuda-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00' for glob 'cuda*'
Note, selecting 'cuda-nvcc-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvvp-11-0' for glob 'cuda*'
Note, selecting 'cuda-toolkit-10-0' for glob 'cuda*'
Note, selecting 'cuda-toolkit-10-1' for glob 'cuda*'
Note, selecting 'cuda-toolkit-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvgraph-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-toolkit-11-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-cudart-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvml-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvml-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvml-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-cudart-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-nvml-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-gpu-library-advisor-10-0' for glob 'cuda*'
Note, selecting 'cuda-gpu-library-advisor-10-1' for glob 'cuda*'
Note, selecting 'cuda-cublas-10-0' for glob 'cuda*'
Note, selecting 'cuda-core-10-0' for glob 'cuda*'
Note, selecting 'cuda-core-10-1' for glob 'cuda*'
Note, selecting 'cuda-core-10-2' for glob 'cuda*'
Note, selecting 'cuda-cusolver-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-cusolver-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-cusolver-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-driver-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-sanitizer-api-10-1' for glob 'cuda*'
Note, selecting 'cuda-sanitizer-api-10-2' for glob 'cuda*'
Note, selecting 'cuda-compiler-10-0' for glob 'cuda*'
Note, selecting 'cuda-compiler-10-1' for glob 'cuda*'
Note, selecting 'cuda-compiler-10-2' for glob 'cuda*'
Note, selecting 'cuda-demo-suite-10-0' for glob 'cuda*'
Note, selecting 'cuda-demo-suite-10-1' for glob 'cuda*'
Note, selecting 'cuda-demo-suite-10-2' for glob 'cuda*'
Note, selecting 'cuda-npp-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-npp-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-npp-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-compiler-11-0' for glob 'cuda*'
Note, selecting 'cuda-demo-suite-11-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-10-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-10-1' for glob 'cuda*'
Note, selecting 'cuda-nsight-10-2' for glob 'cuda*'
Note, selecting 'cuda-curand-10-0' for glob 'cuda*'
Note, selecting 'cuda-curand-10-1' for glob 'cuda*'
Note, selecting 'cuda-curand-10-2' for glob 'cuda*'
Note, selecting 'cuda-command-line-tools-10-0' for glob 'cuda*'
Note, selecting 'cuda-command-line-tools-10-1' for glob 'cuda*'
Note, selecting 'cuda-command-line-tools-10-2' for glob 'cuda*'
Note, selecting 'cuda-cufft-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-cufft-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-cufft-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-nsight-11-0' for glob 'cuda*'
Note, selecting 'cuda-driver-dev-10-0' for glob 'cuda*'
Note, selecting 'cuda-driver-dev-10-1' for glob 'cuda*'
Note, selecting 'cuda-driver-dev-10-2' for glob 'cuda*'
Note, selecting 'cuda-repo-ubuntu1504-7-5-local' for glob 'cuda*'
Note, selecting 'cuda-10-0' for glob 'cuda*'
Note, selecting 'cuda-10-1' for glob 'cuda*'
Note, selecting 'cuda-10-2' for glob 'cuda*'
Note, selecting 'cuda-command-line-tools-11-0' for glob 'cuda*'
Note, selecting 'cuda-driver-dev-11-0' for glob 'cuda*'
Note, selecting 'cuda-misc-headers-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-11-0' for glob 'cuda*'
Note, selecting 'cuda-memcheck-10-0' for glob 'cuda*'
Note, selecting 'cuda-memcheck-10-1' for glob 'cuda*'
Note, selecting 'cuda-memcheck-10-2' for glob 'cuda*'
Note, selecting 'cuda' for glob 'cuda*'
Note, selecting 'cuda-memcheck-11-0' for glob 'cuda*'
Note, selecting 'cuda-cudart-cross-qnx-10-0' for glob 'cuda*'
Note, selecting 'cuda-gdb-src-10-0' for glob 'cuda*'
Note, selecting 'cuda-gdb-src-10-1' for glob 'cuda*'
Note, selecting 'cuda-gdb-src-10-2' for glob 'cuda*'
Note, selecting 'cuda-misc-headers-10-0' for glob 'cuda*'
Note, selecting 'cuda-misc-headers-10-1' for glob 'cuda*'
Note, selecting 'cuda-misc-headers-10-2' for glob 'cuda*'
Note, selecting 'cuda-gdb-src-11-0' for glob 'cuda*'
Note, selecting 'cuda-cuobjdump-10-0' for glob 'cuda*'
Note, selecting 'cuda-cuobjdump-10-1' for glob 'cuda*'
Note, selecting 'cuda-cuobjdump-10-2' for glob 'cuda*'
Note, selecting 'cuda-cuobjdump-11-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute-10-0' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute-10-1' for glob 'cuda*'
Note, selecting 'cuda-nsight-compute-10-2' for glob 'cuda*'
Note, selecting 'cuda-nvprof-10-0' for glob 'cuda*'
Note, selecting 'cuda-nvprof-10-1' for glob 'cuda*'
Note, selecting 'cuda-nvprof-10-2' for glob 'cuda*'
Package 'cuda-license-7-5' is not installed, so not removed
Package 'cuda-repo-ubuntu1204' is not installed, so not removed
Package 'cuda-repo-ubuntu1404' is not installed, so not removed
Package 'cuda-repo-ubuntu1404-7-5-local' is not installed, so not removed
Package 'cuda-repo-ubuntu1410' is not installed, so not removed
Package 'cuda-repo-ubuntu1504' is not installed, so not removed
Package 'cuda-repo-ubuntu1504-7-5-local' is not installed, so not removed
Package 'cuda-cudart-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-driver-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-misc-headers-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cusolver-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cublas-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cufft-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-curand-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cusparse-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-npp-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-10-0' is not installed, so not removed
Package 'cuda-10-1' is not installed, so not removed
Package 'cuda-10-2' is not installed, so not removed
Package 'cuda-command-line-tools-10-0' is not installed, so not removed
Package 'cuda-command-line-tools-10-2' is not installed, so not removed
Package 'cuda-compat-10-0' is not installed, so not removed
Package 'cuda-compiler-10-0' is not installed, so not removed
Package 'cuda-compiler-10-2' is not installed, so not removed
Package 'cuda-core-10-0' is not installed, so not removed
Package 'cuda-core-10-1' is not installed, so not removed
Package 'cuda-core-10-2' is not installed, so not removed
Package 'cuda-cross-qnx-10-0' is not installed, so not removed
Package 'cuda-cross-qnx' is not installed, so not removed
Package 'cuda-cublas-10-0' is not installed, so not removed
Package 'cuda-cublas-dev-10-0' is not installed, so not removed
Package 'cuda-cudart-10-0' is not installed, so not removed
Package 'cuda-cudart-10-2' is not installed, so not removed
Package 'cuda-cudart-dev-10-0' is not installed, so not removed
Package 'cuda-cudart-dev-10-2' is not installed, so not removed
Package 'cuda-cufft-10-0' is not installed, so not removed
Package 'cuda-cufft-10-2' is not installed, so not removed
Package 'cuda-cufft-dev-10-0' is not installed, so not removed
Package 'cuda-cufft-dev-10-2' is not installed, so not removed
Package 'cuda-cuobjdump-10-0' is not installed, so not removed
Package 'cuda-cuobjdump-10-2' is not installed, so not removed
Package 'cuda-cupti-10-0' is not installed, so not removed
Package 'cuda-cupti-10-2' is not installed, so not removed
Package 'cuda-cupti-dev-10-2' is not installed, so not removed
Package 'cuda-curand-10-0' is not installed, so not removed
Package 'cuda-curand-10-2' is not installed, so not removed
Package 'cuda-curand-dev-10-0' is not installed, so not removed
Package 'cuda-curand-dev-10-2' is not installed, so not removed
Package 'cuda-cusolver-10-0' is not installed, so not removed
Package 'cuda-cusolver-10-2' is not installed, so not removed
Package 'cuda-cusolver-dev-10-0' is not installed, so not removed
Package 'cuda-cusolver-dev-10-2' is not installed, so not removed
Package 'cuda-cusparse-10-0' is not installed, so not removed
Package 'cuda-cusparse-10-2' is not installed, so not removed
Package 'cuda-cusparse-dev-10-0' is not installed, so not removed
Package 'cuda-cusparse-dev-10-2' is not installed, so not removed
Package 'cuda-demo-suite-10-0' is not installed, so not removed
Package 'cuda-demo-suite-10-1' is not installed, so not removed
Package 'cuda-demo-suite-10-2' is not installed, so not removed
Package 'cuda-demo-suite-11-0' is not installed, so not removed
Package 'cuda-documentation-10-0' is not installed, so not removed
Package 'cuda-documentation-10-2' is not installed, so not removed
Package 'cuda-driver-dev-10-0' is not installed, so not removed
Package 'cuda-driver-dev-10-2' is not installed, so not removed
Package 'cuda-drivers-diagnostic' is not installed, so not removed
Package 'cuda-gdb-10-0' is not installed, so not removed
Package 'cuda-gdb-10-2' is not installed, so not removed
Package 'cuda-gdb-src-10-0' is not installed, so not removed
Package 'cuda-gdb-src-10-1' is not installed, so not removed
Package 'cuda-gdb-src-10-2' is not installed, so not removed
Package 'cuda-gpu-library-advisor-10-0' is not installed, so not removed
Package 'cuda-libraries-10-0' is not installed, so not removed
Package 'cuda-libraries-10-1' is not installed, so not removed
Package 'cuda-libraries-10-2' is not installed, so not removed
Package 'cuda-libraries-dev-10-0' is not installed, so not removed
Package 'cuda-libraries-dev-10-2' is not installed, so not removed
Package 'cuda-license-10-0' is not installed, so not removed
Package 'cuda-memcheck-10-0' is not installed, so not removed
Package 'cuda-memcheck-10-2' is not installed, so not removed
Package 'cuda-minimal-build-10-0' is not installed, so not removed
Package 'cuda-minimal-build-10-1' is not installed, so not removed
Package 'cuda-minimal-build-10-2' is not installed, so not removed
Package 'cuda-misc-headers-10-0' is not installed, so not removed
Package 'cuda-misc-headers-10-2' is not installed, so not removed
Package 'cuda-npp-10-0' is not installed, so not removed
Package 'cuda-npp-10-2' is not installed, so not removed
Package 'cuda-npp-dev-10-0' is not installed, so not removed
Package 'cuda-npp-dev-10-2' is not installed, so not removed
Package 'cuda-nsight-10-0' is not installed, so not removed
Package 'cuda-nsight-10-2' is not installed, so not removed
Package 'cuda-nsight-compute--10-0' is not installed, so not removed
Package 'cuda-nsight-compute-10-0' is not installed, so not removed
Package 'cuda-nsight-compute-10-2' is not installed, so not removed
Package 'cuda-nsight-systems-10-2' is not installed, so not removed
Package 'cuda-nvcc-10-0' is not installed, so not removed
Package 'cuda-nvcc-10-2' is not installed, so not removed
Package 'cuda-nvdisasm-10-0' is not installed, so not removed
Package 'cuda-nvdisasm-10-2' is not installed, so not removed
Package 'cuda-nvgraph-10-0' is not installed, so not removed
Package 'cuda-nvgraph-10-2' is not installed, so not removed
Package 'cuda-nvgraph-dev-10-0' is not installed, so not removed
Package 'cuda-nvgraph-dev-10-2' is not installed, so not removed
Package 'cuda-nvjpeg-10-0' is not installed, so not removed
Package 'cuda-nvjpeg-10-2' is not installed, so not removed
Package 'cuda-nvjpeg-dev-10-0' is not installed, so not removed
Package 'cuda-nvjpeg-dev-10-2' is not installed, so not removed
Package 'cuda-nvml-dev-10-0' is not installed, so not removed
Package 'cuda-nvml-dev-10-2' is not installed, so not removed
Package 'cuda-nvml-dev-11-0' is not installed, so not removed
Package 'cuda-nvprof-10-0' is not installed, so not removed
Package 'cuda-nvprof-10-2' is not installed, so not removed
Package 'cuda-nvprune-10-0' is not installed, so not removed
Package 'cuda-nvprune-10-2' is not installed, so not removed
Package 'cuda-nvprune-11-0' is not installed, so not removed
Package 'cuda-nvrtc-10-0' is not installed, so not removed
Package 'cuda-nvrtc-10-2' is not installed, so not removed
Package 'cuda-nvrtc-dev-10-0' is not installed, so not removed
Package 'cuda-nvrtc-dev-10-2' is not installed, so not removed
Package 'cuda-nvtx-10-0' is not installed, so not removed
Package 'cuda-nvtx-10-2' is not installed, so not removed
Package 'cuda-nvtx-11-0' is not installed, so not removed
Package 'cuda-nvvp-10-0' is not installed, so not removed
Package 'cuda-nvvp-10-2' is not installed, so not removed
Package 'cuda-repo-ubuntu1804' is not installed, so not removed
Package 'cuda-runtime-10-0' is not installed, so not removed
Package 'cuda-runtime-10-1' is not installed, so not removed
Package 'cuda-runtime-10-2' is not installed, so not removed
Package 'cuda-samples-10-0' is not installed, so not removed
Package 'cuda-samples-10-2' is not installed, so not removed
Package 'cuda-sanitizer-api-10-2' is not installed, so not removed
Package 'cuda-toolkit-10-0' is not installed, so not removed
Package 'cuda-toolkit-10-2' is not installed, so not removed
Package 'cuda-tools-10-0' is not installed, so not removed
Package 'cuda-tools-10-2' is not installed, so not removed
Package 'cuda-visual-tools-10-0' is not installed, so not removed
Package 'cuda-visual-tools-10-2' is not installed, so not removed
Package 'cuda-compat-10-1' is not installed, so not removed
Package 'cuda-drivers-418' is not installed, so not removed
Package 'cuda-compat-10-2' is not installed, so not removed
Package 'cuda-drivers-440' is not installed, so not removed
Package 'cuda-compat-11-0' is not installed, so not removed
Package 'cuda-drivers-450' is not installed, so not removed
Package 'cuda-drivers' is not installed, so not removed
Package 'cuda-11-0' is not installed, so not removed
Package 'cuda' is not installed, so not removed
Package 'cuda-command-line-tools-11-0' is not installed, so not removed
Package 'cuda-compiler-11-0' is not installed, so not removed
Package 'cuda-cudart-11-0' is not installed, so not removed
Package 'cuda-cudart-dev-11-0' is not installed, so not removed
Package 'cuda-cuobjdump-11-0' is not installed, so not removed
Package 'cuda-cupti-11-0' is not installed, so not removed
Package 'cuda-cupti-dev-11-0' is not installed, so not removed
Package 'cuda-documentation-11-0' is not installed, so not removed
Package 'cuda-driver-dev-11-0' is not installed, so not removed
Package 'cuda-gdb-11-0' is not installed, so not removed
Package 'cuda-gdb-src-11-0' is not installed, so not removed
Package 'cuda-libraries-11-0' is not installed, so not removed
Package 'cuda-libraries-dev-11-0' is not installed, so not removed
Package 'cuda-memcheck-11-0' is not installed, so not removed
Package 'cuda-minimal-build-11-0' is not installed, so not removed
Package 'cuda-nsight-11-0' is not installed, so not removed
Package 'cuda-nsight-compute-11-0' is not installed, so not removed
Package 'cuda-nsight-systems-11-0' is not installed, so not removed
Package 'cuda-nvcc-11-0' is not installed, so not removed
Package 'cuda-nvdisasm-11-0' is not installed, so not removed
Package 'cuda-nvprof-11-0' is not installed, so not removed
Package 'cuda-nvrtc-11-0' is not installed, so not removed
Package 'cuda-nvrtc-dev-11-0' is not installed, so not removed
Package 'cuda-nvvp-11-0' is not installed, so not removed
Package 'cuda-runtime-11-0' is not installed, so not removed
Package 'cuda-samples-11-0' is not installed, so not removed
Package 'cuda-sanitizer-11-0' is not installed, so not removed
Package 'cuda-toolkit-11-0' is not installed, so not removed
Package 'cuda-tools-11-0' is not installed, so not removed
Package 'cuda-visual-tools-11-0' is not installed, so not removed
  nsight-compute-2019.5.0 nsight-systems-2019.5.2 screen-resolution-extra
  cuda-command-line-tools-10-1* cuda-compiler-10-1* cuda-cudart-10-1*
  cuda-cudart-dev-10-1* cuda-cufft-10-1* cuda-cufft-dev-10-1*
  cuda-cuobjdump-10-1* cuda-cupti-10-1* cuda-curand-10-1*
  cuda-curand-dev-10-1* cuda-cusolver-10-1* cuda-cusolver-dev-10-1*
  cuda-cusparse-10-1* cuda-cusparse-dev-10-1* cuda-documentation-10-1*
  cuda-driver-dev-10-1* cuda-gdb-10-1* cuda-gpu-library-advisor-10-1*
  cuda-libraries-dev-10-1* cuda-license-10-1* cuda-license-10-2*
  cuda-memcheck-10-1* cuda-misc-headers-10-1* cuda-npp-10-1*
  cuda-npp-dev-10-1* cuda-nsight-10-1* cuda-nsight-compute-10-1*
  cuda-nsight-systems-10-1* cuda-nvcc-10-1* cuda-nvdisasm-10-1*
  cuda-nvgraph-10-1* cuda-nvgraph-dev-10-1* cuda-nvjpeg-10-1*
  cuda-nvjpeg-dev-10-1* cuda-nvml-dev-10-1* cuda-nvprof-10-1*
  cuda-nvprune-10-1* cuda-nvrtc-10-1* cuda-nvrtc-dev-10-1* cuda-nvtx-10-1*
  cuda-nvvp-10-1* cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00*
  cuda-samples-10-1* cuda-sanitizer-api-10-1* cuda-toolkit-10-1*
  cuda-tools-10-1* cuda-visual-tools-10-1* libcublas-dev* libcublas10*
0 upgraded, 0 newly installed, 49 to remove and 0 not upgraded.
After this operation, 5,191 MB disk space will be freed.
(Reading database ... 337730 files and directories currently installed.)
Removing cuda-toolkit-10-1 (10.1.243-1) ...
Removing cuda-tools-10-1 (10.1.243-1) ...
Removing cuda-command-line-tools-10-1 (10.1.243-1) ...
Removing cuda-compiler-10-1 (10.1.243-1) ...
Removing cuda-cupti-10-1 (10.1.243-1) ...
Removing cuda-visual-tools-10-1 (10.1.243-1) ...
Removing cuda-libraries-dev-10-1 (10.1.243-1) ...
Removing cuda-documentation-10-1 (10.1.243-1) ...
Removing cuda-samples-10-1 (10.1.243-1) ...
Removing cuda-cufft-dev-10-1 (10.1.243-1) ...
Removing cuda-cufft-10-1 (10.1.243-1) ...
Removing cuda-gdb-10-1 (10.1.243-1) ...
Removing cuda-cuobjdump-10-1 (10.1.243-1) ...
Removing cuda-curand-dev-10-1 (10.1.243-1) ...
Removing cuda-curand-10-1 (10.1.243-1) ...
Removing cuda-cusolver-dev-10-1 (10.1.243-1) ...
Removing cuda-cusolver-10-1 (10.1.243-1) ...
Removing cuda-cusparse-dev-10-1 (10.1.243-1) ...
Removing cuda-cusparse-10-1 (10.1.243-1) ...
Removing cuda-gpu-library-advisor-10-1 (10.1.243-1) ...
Removing libcublas-dev (10.2.2.89-1) ...
Removing libcublas10 (10.2.2.89-1) ...
Removing cuda-license-10-2 (10.2.89-1) ...
Removing cuda-memcheck-10-1 (10.1.243-1) ...
Removing cuda-nvcc-10-1 (10.1.243-1) ...
Removing cuda-misc-headers-10-1 (10.1.243-1) ...
Removing cuda-npp-dev-10-1 (10.1.243-1) ...
Removing cuda-npp-10-1 (10.1.243-1) ...
Removing cuda-nsight-10-1 (10.1.243-1) ...
Removing cuda-nsight-compute-10-1 (10.1.243-1) ...
Removing cuda-nsight-systems-10-1 (10.1.243-1) ...
Removing cuda-nvdisasm-10-1 (10.1.243-1) ...
Removing cuda-nvgraph-dev-10-1 (10.1.243-1) ...
Removing cuda-nvgraph-10-1 (10.1.243-1) ...
Removing cuda-nvjpeg-dev-10-1 (10.1.243-1) ...
Removing cuda-nvjpeg-10-1 (10.1.243-1) ...
Removing cuda-nvml-dev-10-1 (10.1.243-1) ...
Removing cuda-nvprof-10-1 (10.1.243-1) ...
Removing cuda-nvprune-10-1 (10.1.243-1) ...
dpkg: warning: while removing cuda-nvprune-10-1, directory '/usr/local/cuda-10.1/bin' not empty so not removed
Removing cuda-nvrtc-dev-10-1 (10.1.243-1) ...
Removing cuda-nvrtc-10-1 (10.1.243-1) ...
Removing cuda-nvtx-10-1 (10.1.243-1) ...
Removing cuda-nvvp-10-1 (10.1.243-1) ...
Removing cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00 (1.0-1) ...
Removing cuda-sanitizer-api-10-1 (10.1.243-1) ...
Removing cuda-cudart-dev-10-1 (10.1.243-1) ...
Removing cuda-cudart-10-1 (10.1.243-1) ...
Removing cuda-driver-dev-10-1 (10.1.243-1) ...
dpkg: warning: while removing cuda-driver-dev-10-1, directory '/usr/local/cuda-10.1/targets/x86_64-linux/lib' not empty so not removed
Removing cuda-license-10-1 (10.1.243-1) ...
(Reading database ... 325627 files and directories currently installed.)
Purging configuration files for cuda-cupti-10-1 (10.1.243-1) ...
Purging configuration files for cuda-cudart-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvcc-10-1 (10.1.243-1) ...
Purging configuration files for cuda-cusolver-10-1 (10.1.243-1) ...
Purging configuration files for cuda-repo-ubuntu1804-10-1-local-10.1.243-418.87.00 (1.0-1) ...
Purging configuration files for cuda-nvtx-10-1 (10.1.243-1) ...
Purging configuration files for cuda-curand-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvgraph-10-1 (10.1.243-1) ...
Purging configuration files for cuda-cudart-dev-10-1 (10.1.243-1) ...
dpkg: warning: while removing cuda-cudart-dev-10-1, directory '/usr/local/cuda-10.1/targets/x86_64-linux/include' not empty so not removed
Purging configuration files for cuda-cusparse-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvjpeg-10-1 (10.1.243-1) ...
Purging configuration files for cuda-sanitizer-api-10-1 (10.1.243-1) ...
dpkg: warning: while removing cuda-sanitizer-api-10-1, directory '/usr/local/cuda-10.1/extras' not empty so not removed
Purging configuration files for cuda-cufft-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvprof-10-1 (10.1.243-1) ...
Purging configuration files for cuda-nvrtc-10-1 (10.1.243-1) ...
Purging configuration files for libcublas10 (10.2.2.89-1) ...
Purging configuration files for cuda-npp-10-1 (10.1.243-1) ...
Purging configuration files for cuda-visual-tools-10-1 (10.1.243-1) ...
Purging configuration files for cuda-toolkit-10-1 (10.1.243-1) ...
root@NUS:~# sudo add-apt-repository ppa:graphics-drivers/ppa
 Fresh drivers from upstream, currently shipping Nvidia.
## Current Status
Current long-lived branch release: `nvidia-430` (430.40)
Dropped support for Fermi series (https://nvidia.custhelp.com/app/answers/detail/a_id/4656)
Old long-lived branch release: `nvidia-390` (390.129)
For GF1xx GPUs use `nvidia-390` (390.129)
For G8x, G9x and GT2xx GPUs use `nvidia-340` (340.107)
For NV4x and G7x GPUs use `nvidia-304` (304.137) End-Of-Life!
Support timeframes for Unix legacy GPU releases:
https://nvidia.custhelp.com/app/answers/detail/a_id/3142
## What we're working on right now:
- Normal driver updates
- Help Wanted: Mesa Updates for Intel/AMD users, ping us if you want to help do this work, we're shorthanded.
## WARNINGS:
This PPA is currently in testing, you should be experienced with packaging before you dive in here:
Volunteers welcome!
### How you can help:
## Install PTS and benchmark your gear:
    sudo apt-get install phoronix-test-suite
Run the benchmark:
    phoronix-test-suite default-benchmark openarena xonotic tesseract gputest unigine-valley
and then say yes when it asks you to submit your results to openbechmarking.org. Then grab a cup of coffee, it takes a bit for the benchmarks to run. Depending on the version of Ubuntu you're using it might preferable for you to grabs PTS from upstream directly: http://www.phoronix-test-suite.com/?k=downloads
## Share your results with the community:
Post a link to your results (or any other feedback to): https://launchpad.net/~graphics-drivers-testers
Remember to rerun and resubmit the benchmarks after driver upgrades, this will allow us to gather a bunch of data on performance that we can share with everybody.
If you run into old documentation referring to other PPAs, you can help us by consolidating references to this PPA.
If someone wants to go ahead and start prototyping on `software-properties-gtk` on what the GUI should look like, please start hacking!
## Help us Help You!
We use the donation funds to get the developers hardware to test and upload these drivers, please consider donating to the "community" slider on the donation page if you're loving this PPA:
http://www.ubuntu.com/download/desktop/contribute
 More info: https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa
Press [ENTER] to continue or Ctrl-c to cancel adding it.
Hit:1 https://cloud.r-project.org/bin/linux/ubuntu bionic-cran35/ InRelease
Hit:2 http://sg.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:4 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  InRelease
Hit:5 http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64  Release
Hit:6 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
Hit:7 http://sg.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:8 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:9 http://sg.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:11 https://packagecloud.io/github/git-lfs/ubuntu bionic InRelease
Reading package lists... Done
root@NUS:~# sudo apt install nvidia-driver-435
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
  nvidia-compute-utils-435 nvidia-dkms-435 nvidia-kernel-common-435
  nvidia-kernel-source-435 nvidia-prime nvidia-settings nvidia-utils-435
The following NEW packages will be installed:
0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/14.2 MB of archives.
After this operation, 39.5 MB of additional disk space will be used.
Selecting previously unselected package nvidia-compute-utils-435.
(Reading database ... 325621 files and directories currently installed.)
Preparing to unpack .../0-nvidia-compute-utils-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-compute-utils-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-kernel-source-435.
Preparing to unpack .../1-nvidia-kernel-source-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-kernel-source-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-kernel-common-435.
Preparing to unpack .../2-nvidia-kernel-common-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-kernel-common-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-dkms-435.
Preparing to unpack .../3-nvidia-dkms-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-dkms-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-utils-435.
Preparing to unpack .../4-nvidia-utils-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-utils-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-driver-435.
Preparing to unpack .../5-nvidia-driver-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-driver-435 (435.21-0ubuntu0.18.04.2) ...
Selecting previously unselected package nvidia-prime.
Preparing to unpack .../6-nvidia-prime_0.8.8.2_all.deb ...
Unpacking nvidia-prime (0.8.8.2) ...
Selecting previously unselected package nvidia-settings.
Preparing to unpack .../7-nvidia-settings_450.51.05-0ubuntu1_amd64.deb ...
Unpacking nvidia-settings (450.51.05-0ubuntu1) ...
Setting up nvidia-compute-utils-435 (435.21-0ubuntu0.18.04.2) ...
Warning: The home dir /nonexistent you specified can't be accessed: No such file or directory
Adding system user `nvidia-persistenced' (UID 122) ...
Adding new group `nvidia-persistenced' (GID 127) ...
Adding new user `nvidia-persistenced' (UID 122) with group `nvidia-persistenced' ...
Not creating home directory `/nonexistent'.
Setting up nvidia-prime (0.8.8.2) ...
Setting up nvidia-settings (450.51.05-0ubuntu1) ...
Setting up nvidia-utils-435 (435.21-0ubuntu0.18.04.2) ...
Setting up nvidia-kernel-common-435 (435.21-0ubuntu0.18.04.2) ...
Setting up nvidia-kernel-source-435 (435.21-0ubuntu0.18.04.2) ...
Setting up nvidia-dkms-435 (435.21-0ubuntu0.18.04.2) ...
INFO:Enable nvidia
Loading new nvidia-435.21 DKMS files...
Building for 5.4.0-42-generic
Building for architecture x86_64
Building initial module for 5.4.0-42-generic
ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-dkms-435.0.crash'
Error! Bad return status for module build on kernel: 5.4.0-42-generic (x86_64)
Consult /var/lib/dkms/nvidia/435.21/build/make.log for more information.
Setting up nvidia-driver-435 (435.21-0ubuntu0.18.04.2) ...
root@NUS:~# sudo apt install --reinstall nvidia-driver-435
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/413 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 326120 files and directories currently installed.)
Preparing to unpack .../nvidia-driver-435_435.21-0ubuntu0.18.04.2_amd64.deb ...
Unpacking nvidia-driver-435 (435.21-0ubuntu0.18.04.2) over (435.21-0ubuntu0.18.04.2) ...
root@NUS:~# sudo dkms install nvidia/435.21 --all
root@NUS:~# dkms status
nvidia, 435.21: added
And attached my nvidia-bug-report.log
nvidia-bug-report.log.gz (103.3 KB)
BTW, I have also checked my grub file in /etc/default, these are what I have in my grub file:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
And I do not have a /etc/X11/xorg.conf and /etc/modprobe.d/blacklist-nvidia.conf file on my computer.
I have rebooted my computer after the reinstallation for several times already. Makes no difference.
Any help would be highly appreciated!
Also have the similar issue.
dkms status shows:
nvidia, 440.95.01, 5.0.0-31-generic, x86_64: installed
and nvidia-smi shows:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
lshw -C display shows:
*-display UNCLAIMED
description: VGA compatible controller
product: GM204M [GeForce GTX 970M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:08:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
nvidia-bug-report.log.gz (80.7 KB)
dear generix!
thanks a lot! with you messages here I’ve done everything right. firstly there was “NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.” error then after setting the right kernel version( not yours, I have obviosly another xD) I’ve got another error where I should put nouveau in blacklist( 16.04 - How to disable Nouveau kernel driver - Ask Ubuntu ) and afterwords everything works! thank you you’ve made my whole day!
best regards,
Alex
