I recently upgraded my ubuntu OS from 18 to 20. This messed up my nvidia driver installation. My monitors are connected to the onboard intel graphics, and this is working fine after the upgrade. I re-installed nvidia drivers after the upgrade (“sudo apt install nvidia-driver-495”). But nvidia-smi gives the following error message “NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.”
I want to use the integrated intel graphics for the monitors, and the NVIDIA GPU just for my deep learning experiments.
I followed the instructions and deleted the “blacklist nvidia” line from the file.
The grep nvidia /etc/modprobe.d/* /lib/modprobe.d/* commands output looks like this:
/etc/modprobe.d/blacklist-framebuffer.conf:blacklist nvidiafb
/etc/modprobe.d/nvidia-installer-disable-nouveau.conf:# generated by nvidia-installer
/lib/modprobe.d/blacklist-nvidia.conf:# This file was generated by nvidia-prime
/lib/modprobe.d/blacklist-nvidia.conf:blacklist nvidia-drm
/lib/modprobe.d/blacklist-nvidia.conf:blacklist nvidia-modeset
/lib/modprobe.d/blacklist-nvidia.conf:alias nvidia off
/lib/modprobe.d/blacklist-nvidia.conf:alias nvidia-drm off
/lib/modprobe.d/blacklist-nvidia.conf:alias nvidia-modeset off
/lib/modprobe.d/nvidia-kms.conf:# This file was generated by nvidia-prime
/lib/modprobe.d/nvidia-kms.conf:options nvidia-drm modeset=1
The output of nvidia-smi is still the same
Deleted the whole file, ran the update-initramfs and rebooted.
Now the kernel module went missing. Please reinstall the kernel headers
sudo apt install linux-headers-$(uname -r)
and afterwards post the output of
dkms status
$ sudo apt install linux-headers-$(uname -r)
Reading package lists... Done
Building dependency tree
Reading state information... Done
linux-headers-5.4.0-94-generic is already the newest version (5.4.0-94.106).
linux-headers-5.4.0-94-generic set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ dkms status
rtl88x2bu, 5.8.7.1, 5.4.0-94-generic, x86_64: installed
I installed it using sudo apt install nvidia-driver-495.
The output of dpkg -l | grep nvidia is
ii libnvidia-cfg1-495:amd64 495.46-0ubuntu0.20.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-495 495.46-0ubuntu0.20.04.1 all Shared files used by the NVIDIA libraries
rc libnvidia-compute-450:amd64 450.102.04-0ubuntu1 amd64 NVIDIA libcompute package
rc libnvidia-compute-460:amd64 460.106.00-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-compute-495:amd64 495.46-0ubuntu0.20.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-495:i386 495.46-0ubuntu0.20.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-495:amd64 495.46-0ubuntu0.20.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-495:i386 495.46-0ubuntu0.20.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-495:amd64 495.46-0ubuntu0.20.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-495:i386 495.46-0ubuntu0.20.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-495:amd64 495.46-0ubuntu0.20.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-495:amd64 495.46-0ubuntu0.20.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-495:i386 495.46-0ubuntu0.20.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-495:amd64 495.46-0ubuntu0.20.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-495:i386 495.46-0ubuntu0.20.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
rc nvidia-compute-utils-450 450.102.04-0ubuntu1 amd64 NVIDIA compute utilities
rc nvidia-compute-utils-460 460.106.00-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-compute-utils-495 495.46-0ubuntu0.20.04.1 amd64 NVIDIA compute utilities
rc nvidia-dkms-450 450.102.04-0ubuntu1 amd64 NVIDIA DKMS package
rc nvidia-dkms-460 460.106.00-0ubuntu1 amd64 NVIDIA DKMS package
ii nvidia-dkms-495 495.46-0ubuntu0.20.04.1 amd64 NVIDIA DKMS package
ii nvidia-driver-495 495.46-0ubuntu0.20.04.1 amd64 NVIDIA driver metapackage
rc nvidia-kernel-common-450 450.102.04-0ubuntu1 amd64 Shared files used with the kernel module
rc nvidia-kernel-common-460 460.106.00-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-common-495 495.46-0ubuntu0.20.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-495 495.46-0ubuntu0.20.04.1 amd64 NVIDIA kernel source package
ii nvidia-machine-learning-repo-ubuntu1804 1.0.0-1 amd64 nvidia-machine-learning repository configuration files
ii nvidia-prime 0.8.16~0.20.04.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 470.57.01-0ubuntu0.20.04.2 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-495 495.46-0ubuntu0.20.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18build1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-495 495.46-0ubuntu0.20.04.1 amd64 NVIDIA binary Xorg driver
I re-ran all the steps that you mentioned above. When i rebooted, the X GUI stopped working and I had to run “prime-select intel” to get the GUI back.
You have a config file somewhere that uses the modesetting driver for the nvidia gpu.
Please post the output of
ls -l /etc/X11 /etc/X11/xorg.conf.d /usr/share/X11/xorg.conf.d
On another note, what would be the best way to install CUDA 11? Looks like my current sources are setup for CUDA 10.
$ sudo apt update
Hit:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:4 http://packages.ros.org/ros2/ubuntu focal InRelease
Hit:5 http://packages.osrfoundation.org/gazebo/ubuntu-stable focal InRelease
Hit:6 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:7 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:8 http://archive.canonical.com/ubuntu focal InRelease
Hit:9 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu focal InRelease
All packages are up to date.
$ apt search nvidia-cuda-toolkit
Sorting... Done
Full Text Search... Done
nvidia-cuda-toolkit/focal 10.1.243-3 amd64
NVIDIA CUDA development toolkit
nvidia-cuda-toolkit-gcc/focal 10.1.243-3 amd64
NVIDIA CUDA development toolkit (GCC compatibility)
Just add the repo from the nvidia downloads page and install cuda-toolkit (not cuda), e.g.
sudo apt install cuda-toolkit
or for a specific version
sudo apt install cuda-toolkit-11-4
