Posting output of the commands before reboot:
cc -v
Using built-in specs.
COLLECT_GCC=cc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/11/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: …/src/configure -v --with-pkgversion=‘Ubuntu 11.2.0-7ubuntu2’ --with-bugurl=file:///usr/share/doc/gcc-11/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-11 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --enable-cet --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-11-ZPT0kp/gcc-11-11.2.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-11-ZPT0kp/gcc-11-11.2.0/debian/tmp-gcn/usr --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-serialization=2
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.2.0 (Ubuntu 11.2.0-7ubuntu2)
apt install --reinstall linux-headers-generic
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 2 316 B of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 Index of /ubuntu impish-updates/main amd64 linux-headers-generic amd64 5.13.0.30.40 [2 316 B]
Fetched 2 316 B in 0s (26,8 kB/s)
(Reading database … 259321 files and directories currently installed.)
Preparing to unpack …/linux-headers-generic_5.13.0.30.40_amd64.deb …
Unpacking linux-headers-generic (5.13.0.30.40) over (5.13.0.30.40) …
Setting up linux-headers-generic (5.13.0.30.40) …
dkms remove nvidia/510.54
-------- Uninstall Beginning --------
Module: nvidia
Version: 510.54
Kernel: 5.13.0-30-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
nvidia.ko:
- Uninstallation
- Deleting from: /lib/modules/5.13.0-30-generic/updates/dkms/
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous module version.
nvidia-modeset.ko:
- Uninstallation
- Original module
nvidia-drm.ko:
- Uninstallation
- Original module
nvidia-uvm.ko:
- Uninstallation
- Original module
nvidia-peermem.ko:
- Uninstallation
- Original module
depmod…
DKMS: uninstall completed.
dkms install nvidia/510.54
Kernel preparation unnecessary for this kernel. Skipping…
applying patch disable_fstack-clash-protection_fcf-protection.patch…patching file Kbuild
Hunk #1 succeeded at 82 (offset 11 lines).
Building module:
cleaning build area…
unset ARCH; [ ! -h /usr/bin/cc ] && export CC=/usr/bin/gcc; env NV_VERBOSE=1 ‘make’ -j16 NV_EXCLUDE_BUILD_MODULES=’’ KERNEL_UNAME=5.13.0-30-generic IGNORE_XEN_PRESENCE=1 IGNORE_CC_MISMATCH=1 SYSSRC=/lib/modules/5.13.0-30-generic/build LD=/usr/bin/ld.bfd modules…
Signing module:
- /var/lib/dkms/nvidia/510.54/5.13.0-30-generic/x86_64/module/nvidia-peermem.ko
- /var/lib/dkms/nvidia/510.54/5.13.0-30-generic/x86_64/module/nvidia.ko
- /var/lib/dkms/nvidia/510.54/5.13.0-30-generic/x86_64/module/nvidia-drm.ko
- /var/lib/dkms/nvidia/510.54/5.13.0-30-generic/x86_64/module/nvidia-modeset.ko
- /var/lib/dkms/nvidia/510.54/5.13.0-30-generic/x86_64/module/nvidia-uvm.ko
Secure Boot not enabled on this system.
DKMS: build completed.
nvidia.ko:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/5.13.0-30-generic/updates/dkms/
nvidia-modeset.ko:
- Original module
- Installation
nvidia-drm.ko:
- Original module
- Installation
nvidia-uvm.ko:
- Original module
- Installation
nvidia-peermem.ko:
- Original module
- Installation
depmod…
DKMS: install completed.
update-initramfs -u
update-initramfs: Generating /boot/initrd.img-5.13.0-30-generic
I: The initramfs will attempt to resume from /dev/nvme0n1p7
I: (UUID=3d8639ea-77b8-4ce8-8b8d-feebfaccfb2e)
I: Set the RESUME variable to override this
Will get back to you after reboot
