Ubuntu 24.10 not recognizing RTX 4060 even tho drivers are installed
Hello everyone
I am having issues getting nvidia rtx 4060 to be seen by ubuntu 24.10
The laptop spec:
OS: Xubuntu 24.10 x86_64
Host: 82Y4 Legion Slim 7 16APH8
Kernel: 6.11.0-14-generic
Uptime: 4 mins
Packages: 3906 (dpkg), 22 (flatpak), 18 (snap)
Shell: zsh 5.9
Resolution: 3200x2000
DE: Xfce 4.18
WM: Xfwm4
WM Theme: Lavanda-Sea-Dark
Theme: Lavanda-Sea-Dark [GTK2/3]
Icons: Papirus-Dark [GTK2/3]
Terminal: tilda
CPU: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics (16) @ 1.500GHz
GPU: AMD ATI 65:00.0 Phoenix1
Memory: 3810MiB / 31272MiB
I tried to purge all drivers and install nvidia-driver-530, nvidia-driver-560 and nvidia-driver-570 but neither of them worked. I have windows installed and windows seems to work with nvida gpu, no issues whatsoever, so definitely not a hardware issue. When i swicth to discrete graphics in bios settings and boot linux i get black screen as if the gpu drivers are not being loaded. Secure boot is also disaled. Here are a few commands i ran:
$ grep nvidia /etc/modprobe.d/* /lib/modprobe.d/*
/etc/modprobe.d/blacklist-framebuffer.conf:#blacklist nvidiafb
/etc/modprobe.d/nvidia-graphics-drivers-kms.conf:# This file was generated by nvidia-driver-560
/etc/modprobe.d/nvidia-graphics-drivers-kms.conf:options nvidia-drm modeset=1
/lib/modprobe.d/nvidia-kms.conf:# This file was generated by nvidia-prime
/lib/modprobe.d/nvidia-kms.conf:options nvidia-drm modeset=1
$ sudo lshw -C display
*-display
     description: VGA compatible controller
     product: Phoenix1
     vendor: Advanced Micro Devices, Inc. [AMD/ATI]
     physical id: 0
     bus info: pci@0000:65:00.0
     logical name: /dev/fb0
     version: c2
     width: 64 bits
     clock: 33MHz
     capabilities: pm pciexpress msi msix vga_controller bus_master cap_list fb
     configuration: depth=32 driver=amdgpu latency=0 resolution=3200,2000
     resources: iomemory:7e0-7df irq:83 memory:7e10000000-7e1fffffff memory:79200000-793fffff ioport:1000(size=256) memory:79700000-7977ffff
$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
$ prime-select query
nvidia
$ sudo dmesg | grep -i nvidia
$ modinfo nvidia
filename:       /lib/modules/6.11.0-14-generic/updates/dkms/nvidia.ko.zst
alias:          char-major-195-*
version:        560.35.03
supported:      external
license:        NVIDIA
firmware:       nvidia/560.35.03/gsp_tu10x.bin
firmware:       nvidia/560.35.03/gsp_ga10x.bin
srcversion:     73D9C383254E4CB4BF2CDFA
alias:          pci:v000010DEd*sv*sd*bc06sc80i00*
alias:          pci:v000010DEd*sv*sd*bc03sc02i00*
alias:          pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
retpoline:      Y
vermagic:       6.11.0-14-generic SMP preempt mod_unload modversions
sig_id:         PKCS#7
signer:         username Secure Boot Module Signature key
sig_key:        75:B4:B4:D5:94:B9:3B:E8:FD:E9:12:93:3B:E0:21:92:57:F7:42:7B
sig_hashalgo:   sha512
signature:      11:30:6A:96:DC:2B:68:E2:1A:BE:66:C8:85:36:A7:A6:A3:62:63:42:
    01:2B:D6:3B:0D:29:F1:EB:83:70:CF:C1:1D:0C:8D:6C:43:DD:CC:DC:
    AD:84:2A:7E:49:68:D4:D8:A5:AC:C6:60:E5:BD:00:0A:7F:01:69:83:
    BF:BE:F9:15:77:27:02:68:16:E1:4B:C4:99:86:77:8C:0F:A0:A6:7B:
    8A:A8:C2:65:DD:C2:FF:D9:CB:36:75:CA:11:6B:97:7C:EC:01:3F:E2:
    45:E4:A3:2B:C1:2C:54:AC:CD:07:10:8D:D7:AB:C4:47:1A:82:0C:A6:
    7D:AF:54:4D:4B:6A:FF:90:51:4D:DE:F7:C8:10:11:D1:63:95:0F:49:
    F9:5B:D1:53:FC:0D:A0:8F:C5:92:66:2B:46:2A:CF:91:1C:4A:44:76:
    D5:7E:25:2B:AE:FA:EF:69:81:8C:76:AB:84:E6:6B:DD:2E:7B:1B:58:
    2C:B5:39:84:FA:AC:6A:31:31:DB:05:17:55:33:05:9A:FC:4B:8D:D3:
    A6:42:A7:F6:CF:FF:02:37:EF:AF:87:F9:C4:7A:8A:AF:86:26:59:DA:
    FC:F6:E1:7A:0B:A6:CE:E1:7B:EE:24:82:73:F3:40:BD:44:20:65:6E:
    6F:B9:9E:97:2E:90:76:DC:2D:6C:9C:42:02:37:E1:9E
parm:           NvSwitchRegDwords:NvSwitch regkey (charp)
parm:           NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm:           NVreg_ResmanDebugLevel:int
parm:           NVreg_RmLogonRC:int
parm:           NVreg_ModifyDeviceFiles:int
parm:           NVreg_DeviceFileUID:int
parm:           NVreg_DeviceFileGID:int
parm:           NVreg_DeviceFileMode:int
parm:           NVreg_InitializeSystemMemoryAllocations:int
parm:           NVreg_UsePageAttributeTable:int
parm:           NVreg_EnablePCIeGen3:int
parm:           NVreg_EnableMSI:int
parm:           NVreg_TCEBypassMode:int
parm:           NVreg_EnableStreamMemOPs:int
parm:           NVreg_RestrictProfilingToAdminUsers:int
parm:           NVreg_PreserveVideoMemoryAllocations:int
parm:           NVreg_EnableS0ixPowerManagement:int
parm:           NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm:           NVreg_DynamicPowerManagement:int
parm:           NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm:           NVreg_EnableGpuFirmware:int
parm:           NVreg_EnableGpuFirmwareLogs:int
parm:           NVreg_OpenRmEnableUnsupportedGpus:int
parm:           NVreg_EnableUserNUMAManagement:int
parm:           NVreg_MemoryPoolSize:int
parm:           NVreg_KMallocHeapMaxSize:int
parm:           NVreg_VMallocHeapMaxSize:int
parm:           NVreg_IgnoreMMIOCheck:int
parm:           NVreg_NvLinkDisable:int
parm:           NVreg_EnablePCIERelaxedOrderingMode:int
parm:           NVreg_RegisterPCIDriver:int
parm:           NVreg_EnableResizableBar:int
parm:           NVreg_EnableDbgBreakpoint:int
parm:           NVreg_EnableNonblockingOpen:int
parm:           NVreg_RegistryDwords:charp
parm:           NVreg_RegistryDwordsPerDevice:charp
parm:           NVreg_RmMsg:charp
parm:           NVreg_GpuBlacklist:charp
parm:           NVreg_TemporaryFilePath:charp
parm:           NVreg_ExcludedGpus:charp
parm:           NVreg_DmaRemapPeerMmio:int
parm:           NVreg_RmNvlinkBandwidth:charp
parm:           NVreg_ImexChannelCount:int
parm:           NVreg_CreateImexChannel0:int
parm:           rm_firmware_active:charp
$ sudo modprobe nvidia
modprobe: ERROR: could not insert 'nvidia': No such device
$ sudo apt-get install linux-headers-$(uname -r)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
linux-headers-6.11.0-14-generic is already the newest version (6.11.0-14.15).
The following packages were automatically installed and are no longer required:
  libprimus-vk1 primus-libs
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo dkms status
nvidia/560.35.03, 6.11.0-14-generic, x86_64: installed
virtualbox/7.0.20, 6.11.0-13-generic, x86_64: installed
virtualbox/7.0.20, 6.11.0-14-generic, x86_64: installed
$ cat /etc/default/grub
# If you change this file or any /etc/default/grub.d/*.cfg file,
# run 'update-grub' afterwards to update /boot/grub/grub.cfg.
# For full documentation of the options in these files, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2>/dev/null || echo Ubuntu`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash mem_sleep_default=s2idle acpi_osi=Linux acpi_sleep=nonvs acpi_sleep=s2idle"
GRUB_CMDLINE_LINUX=""
# If your computer has multiple operating systems installed, then you
# probably want to run os-prober. However, if your computer is a host
# for guest OSes installed via LVM or raw disk devices, running
# os-prober can cause damage to those guest OSes as it mounts
# filesystems to look for things.
#GRUB_DISABLE_OS_PROBER=false
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE/GOP/UGA
# you can see them in real GRUB with the command `videoinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
$ mokutil --sb-state
SecureBoot disabled
$ lspci -nn | grep -i nvidia
$ sudo lspci -vnn | grep -iE ‘vga|3d|nvidia’
pcilib: Error reading /sys/bus/pci/devices/0000:00:08.3/label: Operation not permitted
65:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Phoenix1 [1002:15bf] (rev c2) (prog-if 00 [VGA controller])
$ sudo dmesg | grep -i -E ‘acpi|pci|nvidia’
[    0.547988] ACPI: thermal: Thermal Zone [TZ01] (45 C)
[    0.561800] ACPI: bus type drm_connector registered
[    0.673021] ACPI: battery: Slot [BAT1] (battery present)
[    0.888899] rtsx_pci 0000:04:00.0: enabling device (0000 -> 0002)
[    0.903951] ACPI: bus type thunderbolt registered
[    0.971692] ACPI: video: Video Device [VGA] (multi-head: yes  rom: no  post: no)
[    0.976092] nvme nvme0: pci function 0000:05:00.0
[    0.976096] nvme nvme1: pci function 0000:02:00.0
[    2.574686] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-2/1-2.1/1-2.1:1.0/0003:25A7:FA61.0002/input/input10
[    2.634188] input: Compx 2.4G Receiver Mouse as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-2/1-2.1/1-2.1:1.1/0003:25A7:FA61.0003/input/input11
[    2.634549] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-2/1-2.1/1-2.1:1.1/0003:25A7:FA61.0003/input/input12
[    2.634710] input: Compx 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-2/1-2.1/1-2.1:1.1/0003:25A7:FA61.0003/input/input13
[    2.687318] input: Compx 2.4G Receiver System Control as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-2/1-2.1/1-2.1:1.1/0003:25A7:FA61.0003/input/input14
[    2.694402] input: ITE Tech. Inc. ITE Device(8258) Keyboard as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-5/1-5:1.0/0003:048D:C987.0004/input/input16
[    2.746384] input: ITE Tech. Inc. ITE Device(8258) as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-5/1-5:1.0/0003:048D:C987.0004/input/input17
[    2.746742] input: ITE Tech. Inc. ITE Device(8258) Wireless Radio Control as /devices/pci0000:00/0000:00:08.1/0000:65:00.3/usb1/1-5/1-5:1.0/0003:048D:C987.0004/input/input18
[    3.604659] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Using extra _DSD properties, bypassing _DSD in ACPI
[    3.610801] snd_pci_ps 0000:65:00.5: enabling device (0000 -> 0002)
[    3.616004] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:65:00.1/sound/card0/input19
[    3.616080] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:65:00.1/sound/card0/input20
[    3.616174] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:65:00.1/sound/card0/input21
[    3.616245] input: HD-Audio Generic HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:08.1/0000:65:00.1/sound/card0/input22
[    3.642183] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Using extra _DSD properties, bypassing _DSD in ACPI
[    3.670453] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:65:00.6/sound/card1/input23
[    3.671157] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:65:00.6/sound/card1/input24
[    5.390841] [drm] PCIE GART of 512M enabled (table at 0x0000008001900000).
[   12.361506] workqueue: acpi_ec_event_processor hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
[ 1909.264393] nvidia: module license 'NVIDIA' taints kernel.
[ 1909.264410] nvidia: module license taints kernel.
[ 1909.429718] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[ 1909.429734] NVRM: No NVIDIA GPU found.
[ 1909.448481] nvidia-nvlink: Unregistered Nvlink Core, major device number 509
[ 2536.844293] pci 0000:01:00.0: [10de:28e0] type 00 class 0x030000 PCIe Legacy Endpoint
[ 2536.844314] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00ffffff]
[ 2536.844326] pci 0000:01:00.0: BAR 1 [mem 0x00000000-0x1ffffffff 64bit pref]
[ 2536.844337] pci 0000:01:00.0: BAR 3 [mem 0x00000000-0x01ffffff 64bit pref]
[ 2536.844344] pci 0000:01:00.0: BAR 5 [io  0x0000-0x007f]
[ 2536.844352] pci 0000:01:00.0: ROM [mem 0x00000000-0x0007ffff pref]
[ 2536.844361] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
[ 2536.844446] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 2536.845263] pci 0000:01:00.0: Adding to iommu group 15
[ 2536.845447] pci 0000:01:00.0: vgaarb: bridge control possible
[ 2536.845451] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 2536.845508] pci 0000:01:00.1: [10de:22be] type 00 class 0x040300 PCIe Endpoint
[ 2536.845522] pci 0000:01:00.1: BAR 0 [mem 0x00000000-0x00003fff]
[ 2536.845553] pci 0000:01:00.1: Max Payload Size set to 256 (was 128, max 256)
[ 2536.845804] pci 0000:01:00.1: Adding to iommu group 15
[ 2536.846410] pci 0000:01:00.0: BAR 1 [mem 0x7c00000000-0x7dffffffff 64bit pref]: assigned
[ 2536.846424] pci 0000:01:00.0: BAR 3 [mem 0x7e00000000-0x7e01ffffff 64bit pref]: assigned
[ 2536.846436] pci 0000:01:00.0: BAR 0 [mem 0x78000000-0x78ffffff]: assigned
[ 2536.846443] pci 0000:01:00.0: ROM [mem 0x79000000-0x7907ffff pref]: assigned
[ 2536.846449] pci 0000:01:00.1: BAR 0 [mem 0x79080000-0x79083fff]: assigned
[ 2536.846456] pci 0000:01:00.0: BAR 5 [io  0x6000-0x607f]: assigned
[ 2536.846538] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[ 2536.846594] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 2536.860903] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card2/input25
[ 2536.861005] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card2/input26
[ 2536.861096] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card2/input27
[ 2536.861189] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card2/input28
[ 2537.463854] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[ 2537.463868] NVRM: No NVIDIA GPU found.
[ 2537.488860] nvidia-nvlink: Unregistered Nvlink Core, major device number 509
[ 2538.130393] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[ 2538.130418] NVRM: No NVIDIA GPU found.
[ 2538.156760] nvidia-nvlink: Unregistered Nvlink Core, major device number 509
$ journalctl -b -1 | grep -i “nvidia”
Feb 08 19:32:20 username systemd[1]: Starting systemd-backlight@backlight:nvidia_wmi_ec_backlight.service - Load/Save Screen Backlight Brightness of backlight:nvidia_wmi_ec_backlight...
Feb 08 19:32:20 username systemd[1]: Finished systemd-backlight@backlight:nvidia_wmi_ec_backlight.service - Load/Save Screen Backlight Brightness of backlight:nvidia_wmi_ec_backlight.
Feb 08 20:04:05 username sudo[8176]: username : TTY=pts/0 ; PWD=/home/username ; USER=root ; COMMAND=/usr/sbin/modprobe nvidia
Feb 08 20:04:05 username kernel: nvidia: module license 'NVIDIA' taints kernel.
Feb 08 20:04:05 username kernel: nvidia: module license taints kernel.
Feb 08 20:04:05 username kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Feb 08 20:04:05 username kernel: NVRM: No NVIDIA GPU found.
Feb 08 20:04:05 username kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 509
Feb 08 20:05:34 username sudo[8833]: username : TTY=pts/0 ; PWD=/home/username ; USER=root ; COMMAND=/usr/sbin/dkms install nvidia/560.35.03 -k 6.11.0-14-generic --force
Feb 08 20:06:50 username sudo[9784]: username : TTY=pts/0 ; PWD=/home/username ; USER=root ; COMMAND=/usr/sbin/dpkg-reconfigure nvidia-driver-560
Feb 08 20:11:14 username sudo[10356]: username : TTY=pts/0 ; PWD=/home/username ; USER=root ; COMMAND=/usr/bin/prime-select nvidia
Feb 08 20:14:33 username kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card2/input25
Feb 08 20:14:33 username kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card2/input26
Feb 08 20:14:33 username kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card2/input27
Feb 08 20:14:33 username kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card2/input28
Feb 08 20:14:33 username kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Feb 08 20:14:33 username kernel: NVRM: No NVIDIA GPU found.
Feb 08 20:14:33 username kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 509
Feb 08 20:14:34 username kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
Feb 08 20:14:34 username kernel: NVRM: No NVIDIA GPU found.
Feb 08 20:14:34 username kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 509
Feb 08 20:18:11 username sudo[15290]: username : TTY=pts/0 ; PWD=/home/username ; USER=root ; COMMAND=/usr/bin/apt-get install nvidia-driver-570
Feb 08 20:18:57 username userdel[15376]: delete user 'nvidia-persistenced'
Feb 08 20:18:57 username userdel[15376]: removed group 'nvidia-persistenced' owned by 'nvidia-persistenced'
Feb 08 20:18:57 username userdel[15376]: removed shadow group 'nvidia-persistenced' owned by 'nvidia-persistenced'
Feb 08 20:19:19 username adduser[16405]: Adding system user `nvidia-persistenced' (UID 117) ...
Feb 08 20:19:19 username adduser[16405]: Adding new group `nvidia-persistenced' (GID 123) ...
Feb 08 20:19:19 username groupadd[16411]: group added to /etc/group: name=nvidia-persistenced, GID=123
Feb 08 20:19:19 username groupadd[16411]: group added to /etc/gshadow: name=nvidia-persistenced
Feb 08 20:19:19 username groupadd[16411]: new group: name=nvidia-persistenced, GID=123
Feb 08 20:19:19 username adduser[16405]: Adding new user `nvidia-persistenced' (UID 117) with group `nvidia-persistenced' ...
Feb 08 20:19:19 username useradd[16416]: new user: name=nvidia-persistenced, UID=117, GID=123, home=/nonexistent, shell=/usr/sbin/nologin, from=/dev/pts/3
Feb 08 20:19:19 username chfn[16421]: changed user 'nvidia-persistenced' information
Feb 08 20:21:29 username systemd[1]: Stopping systemd-backlight@backlight:nvidia_wmi_ec_backlight.service - Load/Save Screen Backlight Brightness of backlight:nvidia_wmi_ec_backlight...
Feb 08 20:21:29 username systemd[1]: systemd-backlight@backlight:nvidia_wmi_ec_backlight.service: Deactivated successfully.
Feb 08 20:21:29 username systemd[1]: Stopped systemd-backlight@backlight:nvidia_wmi_ec_backlight.service - Load/Save Screen Backlight Brightness of backlight:nvidia_wmi_ec_backlight.
as stated in the pinned post “If you have a problem, PLEASE read this first”,
Please always include a copy of an nvidia-bug-report.log.gz file, which can be generated with the nvidia-bug-report.sh script
…otherwise it will be very difficult for anyone to help you. Also please try to format your post better, because even the sparse info you provided is currently unreadable…
Apologies for the bad formatting, forgot this can take markdown, and here is the bug report file as requested :)
nvidia-bug-report.log.gz (151.8 KB)
This is generated after i switch to driver 570 instead of 560 and the same issue persists
There’s a problem on PCIe level, so the Nvidia driver has nothing to work with even…
There were similar problems reported with Lenovo laptops with AMD iGPU + Nvidia dGPU in 2023: Problem with graphics drivers [Nvidia] [Amdgpu] / Newbie Corner / Arch Linux Forums
It was fixed by changing to different OS version, so maybe try 24.04 or some other distro.
Also make sure your BIOS/UEFI is up2date.
Finally, do you have Windows on this laptop also? If so, does it work there?
There is a BIOS update, so I will do that, the laptop does have windows and even though windows is crashing at the moment because of an update, the GPU works fine. Ubuntu 24.04 didnt even work, i just boot into a blank screen, I was not bothered to check the issue thus i installed ubuntu 24.10 and that one worked out of the box.
So I waited for ubuntu 25.04, I downloaded it yesterday, the issue persists even though the BIOS was updated as well. Any idea of how I can fix it as I thought 25.04 will fix it?
