GeForce RTX 4060 not working with Ubuntu 20.04
I have a new Gigabyte G5 laptop with GeForce RTX 4060.
I installed Ubuntu 20.04 and tried to install the NVIDIA driver using “Software & Updates” and “Additional Drivers” (I selected the recommended one, which is “NVIDIA driver metapackage from nvidia-driver-525 (proprietary)”.
After the installation, I ran nvidia-smi and got an error
“NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure the latest NVIDIA driver is installed and running”.
I rebooted the system, but now either a minimal BASH-like GRUB or a black screen is showing up.
I rebooted from the bootable USK key and reinstalled completely Ubuntu 20.04 and the driver and got the same issue.
What can I do for this?
Thanks in advance for your help
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
nvidia-bug-report.log.gz (142.5 KB)
Hello, I had the same problem with my laptop and this driver so i return with the X.Org X server driver.
I have a RTX 4060 and a AMD Ryzen 9 7845HX. I have a dual Windows 11 and Ubuntu 20.04.6LTS.
I think my graphic card isn’t use by Ubunu. When I look at Graphics in settings I have llvmpipe(LLVM 12.0.0,256bits).
I have run
sudo ubuntu-drivers autoinstall
Now my driver is NVIDIA driver (open kernel) metapackage from nvidia-driver-525-open(propretary, tested).
But my second screen (plugged in HDMI) don’t work. My Graphics is always llvmpipe(LLVM 12.0.0,256bits).
And when i lauch NVIDIA X Server settings the page is empty.
Also when i launch Ubuntu form my dual boot menu i got this :
[0.265724] ACPI BIDS Error (bug): Failure creating named object [_SB.PCIO.G
PPO._PRW], AE_ALREADY_EXISTS (20210730/dswload2-326)
[0.265732] ACPI Errors AE_ALREADY _EXISTS, During name Lookup/catalog (202107
30/psobject-220)
[0.265735] ACPI BIOS Errar (bug): Could not resolve symbol [_SB.PCIOGPP2],
AE_NOT_FOUND (20210730/dsminad2-162)
[0.265738] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/ps
object-220)
[0.266817] ACPI Error: AE_NOT_FOUND, While resolving a named reference packa
ge element - _SB_PCI0_GPP7_UPOD.DPOO_U4UP.U4P3.UHIO (20210730]/dspkginit-438)
[0.2668331] ACPI Error: AE_NOT_FOUND, While resolving a named reference packa
[ 0.26684B]ACPI Error: AE_NOT_FOUND, While resolving a named reference packa
[0.266862]ACPI Error: AE_NOT_FOUND, While resolving a named reference packa
[0.266866] ACPI Error: AE_NOT_FOUND, While resolving a named reference packa
[0.834719] hub 8-0:1.0: config failed,hub doesn’t have any ports!(err -19)
/dev/nvmeonip7: clean, 551405/9601024 files, 10133028/38400000 blocks
[ 4.810798) NVRM cpuidInfoAMD: Unrecognized AMD processor in cpuidInfoAMD
[ 6.014457] mt7921e 0000:04:00.0: driver own failed
[ 6.224224] [drmw:nv_drm_load [nvidia_drm]] ERROR [nvidia-drm] [GPU ID OX00000100] Failed to allocate NvKmsKapiDevice
[ 6.334330] [drmw:nv_drm_probe_devices [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to register device
Maybe the info below can help :
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ inxi -F
System:
Host: eliott-ROG-Strix-G713PV-GL713PV Kernel: 5.15.0-69-generic x86_64 bits: 64 Desktop: Gnome 3.36.9
Distro: Ubuntu 20.04.6 LTS (Focal Fossa)
Machine: Type: Laptop System: ASUSTeK product: ROG Strix G713PV_GL713PV v: 1.0 serial: <superuser/root required>
Mobo: ASUSTeK model: G713PV v: 1.0 serial: <superuser/root required> UEFI: American Megatrends LLC. v: G713PV.311
date: 03/03/2023
Battery: ID-1: BAT0 charge: 92.8 Wh condition: 92.8/90.0 Wh (103%)
CPU: Topology: 12-Core model: AMD Ryzen 9 7845HX with Radeon Graphics bits: 64 type: MT MCP L2 cache: 12.0 MiB
Speed: 1495 MHz min/max: 1500/3000 MHz Core speeds (MHz): 1: 1464 2: 1449 3: 2088 4: 1746 5: 1496 6: 1523 7: 1496
8: 1497 9: 1497 10: 1494 11: 3571 12: 3588 13: 1495 14: 1435 15: 1435 16: 3585 17: 1436 18: 1874 19: 1496 20: 1495
21: 3595 22: 3593 23: 1937 24: 4489
Graphics: Device-1: NVIDIA driver: nvidia v: 525.105.17
Device-2: Advanced Micro Devices [AMD/ATI] driver: N/A
Display: x11 server: X.Org 1.20.13 driver: ati,fbdev unloaded: modesetting,radeon,vesa resolution: 2560x1440~93Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.2.6
Audio: Device-1: NVIDIA driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Device-4: DisplayLink USB3.0 Hub type: USB driver: snd-usb-audio
Device-5: DisplayLink type: USB driver: cdc_ncm,snd-usb-audio
Sound Server: ALSA v: k5.15.0-69-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp3s0 state: down mac: c8:7f:54:cb:8c:05
Device-2: MEDIATEK driver: N/A
IF-ID-1: enx9cebe8653b10 state: down mac: 9c:eb:e8:65:3b:10
IF-ID-2: usb0 state: unknown speed: -1 duplex: half mac: 1a:8e:e5:15:f1:14
Drives: Local Storage: total: 953.87 GiB used: 35.33 GiB (3.7%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2400 MTFDKBA1T0QFM size: 953.87 GiB
Partition: ID-1: / size: 143.13 GiB used: 35.30 GiB (24.7%) fs: ext4 dev: /dev/nvme0n1p7
Sensors: System Temperatures: cpu: 61.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1900
Info: Processes: 445 Uptime: 19m Memory: 14.84 GiB used: 2.03 GiB (13.7%) Shell: bash inxi: 3.0.38
When i run
nvidia-smi
i got :
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ nvidia-smi
No devices were found
Wrong driver. Please use Software & Updates to switch to the non “-open” driver version.
nvidia-bug-report.log.gz (135.4 KB)
I switched to the NVIDIA driver metapackage from nvidia-driver-525 (prorietary) but my Ubuntu don’t work anymore. I got some errors when i launch it :
So i try to reboot and i got the same thing.
Next i reboot again and I used the advance parameter at launch to use the Ubuntu, with Linux 5.15.0-46-généric ( recovery mode). After that the PC reboot with some error and now Ubuntu work. But my second screen don’t work and my graphic is still `llvmpipe (LLVM 12.0.0, 256bits)'.
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
The primary gpu which is driving the internal display is the amd. The kernel is too old to drive it so when the nvidia driver was functional, it took over and displayed on some external connector.
Please upgrade your kernel by using the liquorix ppa and possibly also install needed firmware upgrade manually.
nvidia-bug-report.sh.gz (123.5 KB)
Hi, thank for your answer. I had follow this tutorial : Install or Upgrade To Latest Linux Kernel on Ubuntu 20.04 & Linux Mint 20 to update my Kernel. Now I have this version : 6.2.11-060211-generic. But I can’t launch my Ubuntu without using the recovery mode. If I don’t I have this error and the computer stay stuck.
I’m still on the NVIDIA driver metapackage from nvidia-driver-525 (prorietary). I still have the other problems. I don’t know which firmware I need so I’m a little bit lost on how found and install them.
Recently I also tried the driver-530 non open and nothing change.
You can’t use the kernel from mainline, the headers package is incompatible. Please use the liquorix ppa.
nvidia-bug-report.log.gz (149.1 KB)
Hi, sorry I misunderstood. So I went on this website : Liquorix Kernel : Steven Barrett and add the two lines below in my Software & Updates menu in the Other Software section.
Screenshot from 2023-04-21 08-29-20
So now I have this :
I had reboot, on the restart I got this error and the laptop get stuck :
So I 'm still using the emergency mode to launch it. I still have the other problems.
Please check if you can switch vt (ctrl+alt+f4) and log in there to create a log.
I can log in the Virtual Terminal but I don’t found the command to create a log. Do you know it ? Once the log is created where can I find it ?
nvidia-bug-report.log.gz (154.5 KB)
That was created in recovery mode, not usable.
I still don’t understand why you’re trying to install a three-years old OS on a brand new hardware.
I use this OS because I use a ROS noetic who don’t work on the other Ubuntu version. And the hardware its because I do some simulation with 3D rendering so i need a powerful laptop.
I can’t launch Ubuntu without the recovery mode if i use the 525 non open driver. If i switch and give you the log will it help ?
Please boot normally once, then reboot to recovery and immediately run
sudo journalctl -b-1 |grep kernel >boot.txt
and attach boot.txt.
boot.txt (142.9 KB)
That log was from a boot to recovery
ro recovery nomodeset dis_ucode_ldr
Please decrease -1 to -2 or lower to find a normal boot
sudo journalctl -b-2 |grep kernel |head -n1
I think i didn’t understood everything. After a reboot (still in recovery mode, because i can’t boot without it ) I had run sudo journalctl -b-2 |grep kernel |head -n1 and i decrease but how find a normal boot ?
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-2 |grep kernel |head -n1
avril 25 10:10:52 eliott-ROG-Strix-G713PV-GL713PV kernel: Linux version 6.2.12-1-liquorix-amd64 (steven@liquorix.net) (gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1 ZEN SMP PREEMPT_DYNAMIC liquorix 6.2-17ubuntu1~focal (2023-04
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-3 |grep kernel |head -n1
avril 25 10:07:21 eliott-ROG-Strix-G713PV-GL713PV kernel: Linux version 6.2.11-3-liquorix-amd64 (steven@liquorix.net) (gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1 ZEN SMP PREEMPT_DYNAMIC liquorix 6.2-16ubuntu1~focal (2023-04
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-4 |grep kernel |head -n1
avril 25 12:03:43 eliott-ROG-Strix-G713PV-GL713PV kernel: Linux version 6.2.12-1-liquorix-amd64 (steven@liquorix.net) (gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1 ZEN SMP PREEMPT_DYNAMIC liquorix 6.2-17ubuntu1~focal (2023-04
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-5 |grep kernel |head -n1
avril 25 10:12:53 eliott-ROG-Strix-G713PV-GL713PV kernel: Linux version 6.2.11-060211-generic (kernel@sita) (x86_64-linux-gnu-gcc-12 (Ubuntu 12.2.0-9ubuntu1) 12.2.0, GNU ld (GNU Binutils for Ubuntu) 2.39) #202304131639 SMP PREEMPT_DYNAMIC Thu Apr 13 16:45:29 UTC 2023
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-6 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-7 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-8 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-9 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-10 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-11 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-12 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-13 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-14 |grep kernel |head -n1
eliott@eliott-ROG-Strix-G713PV-GL713PV:~$ sudo journalctl -b-15 |grep kernel |head -n1
